Author: wmb Date: 2009-04-29 10:15:13 +0200 (Wed, 29 Apr 2009) New Revision: 1161
Modified: cpu/x86/pc/olpc/via/demodram.fth Log: Via demo version - oops in previous checkin.
Modified: cpu/x86/pc/olpc/via/demodram.fth =================================================================== --- cpu/x86/pc/olpc/via/demodram.fth 2009-04-29 08:13:15 UTC (rev 1160) +++ cpu/x86/pc/olpc/via/demodram.fth 2009-04-29 08:15:13 UTC (rev 1161) @@ -294,38 +294,3 @@ [then]
\ fload ${BP}/cpu/x86/pc/ramtest.fth - -\ UMARamSetting.c -\ SetUMARam - 0 3 devfunc - a1 00 80 mreg \ Enable internal GFX - a2 ff ee mreg \ Set GFX timers - a4 ff 01 mreg \ GFX Data Delay to Sync with Clock - a6 ff 76 mreg \ Page register life timer - a7 ff 8c mreg \ Internal GFX allocation - b3 ff 9a mreg \ Disable read past write - de ff 06 mreg \ Enable CHA and CHB merge mode (but description says this value disable merging!) - end-table - - 0 3 devfunc - a1 70 40 mreg \ Set frame buffer size to 64M (8M:10, 16M:20, 32M:30, etc) - fbsize - end-table - - 1 0 devfunc - \ Reg 1b2 controls the number of writable bits in the BAR at 810 - b2 ff 70 mreg \ Offset of frame buffer, depends on size - fbsize - 04 ff 07 mreg \ Enable IO and memory access to display - end-table - - d000.0000 810 config-wl \ S.L. Base address - f000.0000 814 config-wl \ MMIO Base address - cd01 3a0 config-ww \ Set frame buffer size and CPU-relative address and enable - - 0 0 devfunc - d4 00 03 mreg \ Enable MMIO and S.L. access in Host Control device - fe 00 10 mreg \ 16-bit I/O port decoding for VGA (no aliases) - end-table - - 1 0 devfunc - b0 07 03 mreg \ VGA memory selection (coreboot uses 03, Phoenix 01. I think 03 is correct) - end-table
