Author: wmb Date: Tue Jul 3 07:26:24 2012 New Revision: 3030 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3030
Log: OLPC BSL download code - completed code with "test-msp430" word for testing the initial hardware build.
Modified: cpu/arm/olpc/bsl.fth
Modified: cpu/arm/olpc/bsl.fth ============================================================================== --- cpu/arm/olpc/bsl.fth Tue Jul 3 07:24:13 2012 (r3029) +++ cpu/arm/olpc/bsl.fth Tue Jul 3 07:26:24 2012 (r3030) @@ -3,7 +3,42 @@
\ devalias bsl /uart@NNNN:9600,8,e,1//bsl-protocol
-h# fe016000 value bsl-uart-base \ Virtual address of UART; set later + +\ These constants are correct for XO-1.75 and XO-CL4; they might +\ need to be changed for different hardware. See setup-gpios-hack + +h# 17000 +io constant bsl-uart-base \ UART2 + +d# 98 constant bsl-test-gpio# \ GPIO98 is alternate function 0 (the default) +d# 152 constant bsl-rst-gpio# \ SM_BELn, with GPIO152 as alternate function 1 + +\ This is platform-dependent + +: setup-gpios ( -- ) + 3 d# 55 af! 3 d# 56 af! \ Setup pins for UART2 + 0 bsl-test-gpio# af! \ Set to GPIO function + 1 bsl-rst-gpio# af! \ Set to GPIO function (AF0 is SM_BELn for this pin) +; + +0 [if] +\ This is for the test system on which this code was originally developed +: setup-gpios-hack ( -- ) + \ On the test system, the BSL device is driven from the console UART, + \ not a dedicated UART, so we must disconnect that UART from the console mux + fallback-in-ih ?dup if dup remove-input close-dev 0 to fallback-in-ih then + fallback-out-ih ?dup if dup remove-output close-dev 0 to fallback-out-ih then + + h# 16000 +io to bsl-uart-base \ UART4 + + d# 115 to test-gpio# \ Normally UART3 TXD, but repurposed as a GPIO + d# 116 to rst-gpio# \ Normally UART3 RXD, but repurposed as a GPIO + + 0 bsl-test-gpio# af! \ Set to GPIO function instead of UART3 + 0 bsl-rst-gpio# af! \ Set to GPIO function instead of UART3 +; +[then] + +\ These are MMP2/3 dependent
: bsl-baud ( baud-rate -- ) \ 9600,8,e,1 uart-base >r bsl-uart-base to uart-base baud h# 1b 3 uart! r> to uart-base @@ -17,53 +52,41 @@ r> to uart-base ;
-0 value rst-gpio# -0 value test-gpio# -\ : bsl-config-test ( -- ) -: init-gpios - fallback-in-ih ?dup if dup remove-input close-dev 0 to fallback-in-ih then - fallback-out-ih ?dup if dup remove-output close-dev 0 to fallback-out-ih then
- d# 115 to test-gpio# - d# 116 to rst-gpio# - - test-gpio# 0 swap af! - rst-gpio# 0 swap af! -; +\ After this point the code is largely generic
: bsl-open ( -- ) - init-gpios + setup-gpios
- rst-gpio# gpio-clr - test-gpio# gpio-clr - rst-gpio# gpio-dir-out - test-gpio# gpio-dir-out - h# 16000 +io to bsl-uart-base + bsl-rst-gpio# gpio-clr + bsl-test-gpio# gpio-clr + bsl-rst-gpio# gpio-dir-out + bsl-test-gpio# gpio-dir-out
d# 9600 bsl-baud ; : bsl-close ( -- ) - rst-gpio# gpio-dir-in - test-gpio# gpio-dir-in + bsl-rst-gpio# gpio-dir-in + bsl-test-gpio# gpio-dir-in ; : msp430-off ( -- ) - rst-gpio# gpio-clr - test-gpio# gpio-clr + bsl-rst-gpio# gpio-clr + bsl-test-gpio# gpio-clr ;
: dly ( -- ) d# 10 ms ; : start-bsl ( -- ) bsl-open d# 250 ms - test-gpio# gpio-set + bsl-test-gpio# gpio-set dly - test-gpio# gpio-clr + bsl-test-gpio# gpio-clr dly - test-gpio# gpio-set + bsl-test-gpio# gpio-set dly - rst-gpio# gpio-set + bsl-rst-gpio# gpio-set dly - test-gpio# gpio-clr + bsl-test-gpio# gpio-clr ; : flush-bsl ( -- ) begin receive? while drop repeat ; : rst-bsl ( -- ) msp430-off start-bsl flush-bsl ; @@ -238,6 +261,16 @@ r> 3drop ;
+: force-erase ( -- ) + ." Resetting/erasing" cr + rst-bsl + ['] 00-password catch drop + rst-bsl + ff-password +; + +\ Decoder for TI TXT file format + 0 value next-address 0 value line-#bytes d# 50 buffer: binary-buf @@ -269,7 +302,7 @@ loop ( adr len ) true abort" TI TXT Line too long!" ; -: handle-line ( adr len -- ) +: ti-txt-handle-line ( adr len -- ) dup 0= if 2drop exit then ( adr len ) over c@ case [char] @ of ( adr len ) @@ -282,25 +315,121 @@ -rot program-bytes ( char ) endcase ( ) ; -: force-erase ( -- ) - ." Resetting/erasing" cr - rst-bsl - ['] 00-password catch drop - rst-bsl - ff-password + +\ Decoder for Intel HEX format file +\needs parse-ihex-record fload ${BP}/forth/lib/intelhex.fth + +0 value ihex-hi-adr +: ihex-handle-line ( adr len -- ) + dup 0= if 2drop exit then ( adr len ) + parse-ihex-record ( data-adr data-len offset type ) + case + 0 of \ Data ( data-adr data-len offset ) + ihex-hi-adr + rx-data-block ( ) + endof + 1 of \ End of file ( data-adr data-len offset ) + 3drop ( ) + endof + 2 of \ Segment address ( data-adr data-len offset ) + 2drop le-w@ 4 lshift to ihex-hi-adr ( ) + endof + 3 of \ Start segment address ( data-adr data-len offset ) + 3drop + endof + 4 of \ Extended linear address ( data-adr data-len offset ) + 2drop le-w@ d# 16 lshift to ihex-hi-adr ( ) + endof + 5 of \ Start address ( data-adr data-len offset ) + 3drop + endof + ( default ) true abort" Bogus ihex record type" + endcase ; + d# 100 buffer: line-buf -: $bsl-ti-text-file ( filename$ -- ) - $read-open ( ) - force-erase ( ) +defer bsl-handle-line + +: set-bsl-file-format ( -- ) + ifd @ fgetc case + [char] : of + ['] ihex-handle-line to bsl-handle-line + endof + [char] @ of + ['] ti-txt-handle-line to bsl-handle-line + endof + ( default ) + ifd @ fclose + true abort" Unsupported file format for BSL programming" + endcase + + 0 ifd @ fseek +; + +d# 100 buffer: line-buf +: $flash-bsl ( filename$ -- ) + $read-open ( ) + set-bsl-file-format ( ) + force-erase ( ) ." Programming" cr - begin ( ) + begin ( ) line-buf d# 100 ifd @ read-line abort" Read line failed" - while ( len ) - line-buf swap handle-line ( ) - repeat ( len ) - drop - ifd @ fclose + while ( len ) + line-buf swap ( adr len ) + ['] bsl-handle-line catch ?dup if ( x x throw-code ) + ifd @ fclose throw ( ?? -- ) + then ( ) + repeat ( len ) + drop ( ) + ifd @ fclose ( ) +; + +\ This is a destructive test in that it erases whatever firmware happens +\ to already be in the device. + + +h# 70 value /bsl-chunk +/bsl-chunk buffer: bsl-buf +: bsl-write ( adr len device-adr -- ) + to next-address ( adr len ) + begin dup while ( adr len ) + dup /bsl-chunk min ( adr len thislen ) + third over next-address rx-data-block ( adr len thislen ) + dup next-address + to next-address ( adr len thislen ) + /string ( adr' len' ) + repeat ( adr 0 ) + 2drop ( ) +; +: bsl-verify ( adr len device-adr -- okay? ) + to next-address ( adr len ) + begin dup while ( adr len ) + dup /bsl-chunk min ( adr len thislen ) + bsl-buf over next-address tx-data-block ( adr len thislen ) + third bsl-buf third comp if ( adr len thislen ) + 3drop false exit ( -- false ) + then ( adr len thislen ) + dup next-address + to next-address ( adr len thislen ) + /string ( adr' len' ) + repeat ( adr 0 ) + 2drop ( ) + true ( true ) +; +h# 3000 constant /bsl-test-buf +/bsl-test-buf buffer: bsl-test-buf +0 value bsl-test-init? +: bsl-test-data ( -- adr len ) + bsl-test-init? 0= if + bsl-test-buf /bsl-test-buf bounds ?do + random-long i l! + /l +loop + true to bsl-test-init? + then + bsl-test-buf /bsl-test-buf +; +: test-msp430 ( -- ) + ." Erasing ..." force-erase cr + ." Writing ..." bsl-test-data h# 8000 bsl-write cr ( ) + ." Verifying ..." bsl-test-data h# 8000 bsl-verify cr ( okay? ) + if ." FAILED!" else ." Good" then cr ;
\ LICENSE_BEGIN
