Author: wmb Date: Mon Feb 25 09:35:53 2013 New Revision: 3570 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3570
Log: Added Bluetooth diagnostic driver.
Added: dev/bluetooth/marvell-hci.fth
Added: dev/bluetooth/marvell-hci.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ dev/bluetooth/marvell-hci.fth Mon Feb 25 09:35:53 2013 (r3570) @@ -0,0 +1,980 @@ + +\ h# 00 constant config-reg \ 03 for 8688 +\ h# 02 constant host-int-mask-reg \ 04 for 8688 +\ h# 03 constant host-intstatus-reg \ 05 for 8688 +\ h# 30 constant card-status-reg \ 20 for 8688 +\ h# 40 constant sq-read-base-addr-a0-reg \ 10 for 8688 +\ h# 41 constant sq-read-base-addr-a1-reg \ 11 for 8688 +\ h# 5c constant card-revision-reg \ ?? for 8688 +\ h# 60 constant card-fw-status0-reg \ 40 for 8688 +\ h# 61 constant card-fw-status1-reg \ 41 for 8688 +\ h# 62 constant card-rx-len-reg \ 42 for 8688 +\ h# 63 constant card-rx-unit-reg \ 43 for 8688 +\ h# 78 constant ioport0-reg \ 00 for 8688 +\ h# 79 constant ioport1-reg \ 01 for 8688 +\ h# 7a constant ioport2-reg \ 02 for 8688 + +h# 200 value SDIO_BLOCK_SIZE + +\ The data in the result buffer does not include the event code +\ the command code, or the error status byte. +\ /result does not count those either, but only the excess result +\ bytes following the error status byte. + +h# 80 buffer: result-buf +0 value /result + +: copy-result ( adr -- ) + \ "4 -" omits the event count, the ocf_ogf field, and the error status byte + dup 1+ c@ 4 - to /result ( adr ) + \ "6 +" skips the event code, the length byte, and the 4 bytes cited above. + 6 + result-buf /result move ( ) +; + +: .vendor-cmd ( adr ocf process? -- adr ocf process? ) + ." Vendor command " over .x ( adr ocf process? ) + 2 pick 5 + c@ ?dup if ( adr ocf process? error ) + ." failed with error " .x cr ( adr ocf process? ) + else ( adr ocf process? ) + ." succeeded" cr ( adr ocf process? ) + then ( adr ocf process? ) +; + +h# 4e constant #events +create events h# 4e /token * allot + +: check-event# ( event# -- ) #events >= abort" Too many events" ; +: xt-set-event ( event# xt -- ) over check-event# events rot ta+ token! ; +: set-event ( event# -- ) lastacf xt-set-event ; +: UNKNOWN ( -- ) ; +: UNUSED ( n -- ) ['] UNKNOWN xt-set-event ; + +h# 00 UNUSED + +: inquiry-complete \ b.status + cdump cr +; h# 01 set-event + +: inquiry-result \ b.nresp { bdaddr b.pscan-rep-mode b.pscan-period-mode b.pscan-mode b.dev-class[3] w.clock-offset } + cdump cr +; h# 02 set-event + +: conn-complete \ b.status w.handle bdaddr b.link-type b.encr-mode + cdump cr +; h# 03 set-event + +: conn-request \ bdaddr b.dev-class[3] b.link-type + cdump cr +; h# 04 set-event + +: disconn-complete \ b.status w.handle b.reason + cdump cr +; h# 05 set-event + +: auth-complete \ b.status w.handle + cdump cr +; h# 06 set-event + +: remote-name \ b.status bdaddr b.name[248] + cdump cr +; h# 07 set-event + +: encrypt-change \ b.status w.handle b.encrypt + cdump cr +; h# 08 set-event + +: change-link-key-complete \ b.status w.handle + cdump cr +; h# 09 set-event + +: master-link-key-complete \ b.status w.handle b.flag + cdump cr +; h# 0a set-event + +: remote-features \ b.status w.handle b.features[8] + cdump cr +; h# 0b set-event + +: remote-version \ b.status w.handle b.lmp-ver w.manufacturer w.lmp-subver + cdump cr +; h# 0c set-event + +: qos-setup-complete \ b.status w.handle { b.service-type L.token-rate L.peak-bandwidth L.latency L.delay-variation} + cdump cr +; h# 0d set-event + +: cmd-complete \ b.ncmd w.opcode + ." Cmd " over 1+ le-w@ .x space + 3 /string cdump cr +; h# 0e set-event + +: cmd-status \ b.status b.ncmd w.opcode + cdump cr +; h# 0f set-event + +: hardware-error \ b.errorcode + cdump cr +; h# 10 set-event + +: flush-occurred \ w.handle + cdump cr +; h# 11 set-event + +: role-change \ b.status bdaddr b.role + cdump cr +; h# 12 set-event + +: num-comp-pkts \ b.num-hndl { w.handle w.count } + cdump cr +; h# 13 set-event + +: mode-change \ b.status w.handle b.mode w.interval + cdump cr +; h# 14 set-event + +: return-link-keys \ b.num { bdaddr, b.key[16] } + cdump cr +; h# 15 set-event + +: pin-code-req \ bdaddr + cdump cr +; h# 16 set-event + +: link-key-req \ bdaddr + cdump cr +; h# 17 set-event + +: link-key-notify \ bdaddr b.link-key[16] b.key-type + cdump cr +; h# 18 set-event + +: loopback-command \ [variable] + cdump cr +; h# 19 set-event + +: data-buffer-overflow \ b.link-type + cdump cr +; h# 1a set-event + +: max-slots-change \ w.handle b.lmp-max-slots + cdump cr +; h# 1b set-event + +: clock-offset \ b.status w.handle w.clock-offset + cdump cr +; h# 1c set-event + +: pkt-type-change \ b.status w.handle w.pkt-type + cdump cr +; h# 1d set-event + +: qos-violation \ w.handle + cdump cr +; h# 1e set-event + +h# 1f UNUSED + +: pscan-rep-mode \ bdaddr b.pscan-rep-mode + cdump cr +; h# 20 set-event + +: flow-specification-complete \ b.status w.handle b.flags b.direction b.service-type b.token-rate l.token-bucket-size l.bandwidth l.latency + cdump cr +; h# 21 set-event + +: inquiry-result-with-rssi \ b.nresp {bdaddr b.pscan-rep-mode b.pscan-period-mode b.dev-class[3] w.clock-offset S.rssi} + cdump cr +; h# 22 set-event + \ inquiry-info-with-rssi-and-pscan-mode \ b.nresp { bdaddr b.pscan-rep-mode b.pscan-period-mode b.pscan-mode b.dev-class[3] w.clock-offset S.rssi } + +: remote-ext-features \ b.status w.handle b.page b.max-page b.features[8] + cdump cr +; h# 23 set-event + +h# 2c h# 24 do i UNUSED loop + +: sync-conn-complete \ b.status w.handle bdaddr b.link-type b.tx-interval b.retrans-w.ndow. w.rx-pkt-len w.tx-pkt-len b.air-mode + cdump cr +; h# 2c set-event + +: sync-conn-changed \ b.status w.handle b.tx-interval b.retrans-w.ndow. w.rx-pkt-len w.tx-pkt-len + cdump cr +; h# 2d set-event + +: sniff-subrate \ b.status w.handle w.max-tx-latency w.max-rx-latency w.max-remote-timeout w.max-local-timeout + cdump cr +; h# 2e set-event + +: extended-inquiry-info \ b.nresp { bdaddr b.pscan-rep-mode b.pscan-period-mode b.dev-class[3] w.clock-offset S.rssi b.data[240] } + cdump cr +; h# 2f set-event + +: key-refresh-complete \ b.status w.handle + cdump cr +; h# 30 set-event + +: io-capa-request \ bdaddr + cdump cr +; h# 31 set-event + +: io-capa-reply \ bdaddr b.capability b.oob-data b.authentication + cdump cr +; h# 32 set-event + +: user-confirm-req \ bdaddr l.passkey + cdump cr +; h# 33 set-event + +: user-passkey-req \ bdaddr + cdump cr +; h# 34 set-event + +: remote-oob-data-request \ bdaddr + cdump cr +; h# 35 set-event + +: simple-pair-complete \ b.status bdaddr + cdump cr +; h# 36 set-event + +h# 37 UNUSED + +: link-supervision-timeout-changed \ w.handle w.timeout + cdump cr +; h# 38 set-event + +: enhanced-flush-complete \ w.handle + cdump cr +; h# 39 set-event + +h# 3a UNUSED + +: user-passkey-notification \ bdaddr l.passkey + cdump cr +; h# 3b set-event + +: keypress-notification \ bdaddr b.type + cdump cr +; h# 3c set-event + +: remote-host-features \ bdaddr b.features[8] + cdump cr +; h# 3d set-event + +: le-meta \ b.subevent + cdump cr +; h# 3e set-event + +\ 1 le-connection-complete \ b.status w.handle b.role b.peer-type 6.peer-addr w.interval w.latency w.timeout b.accuracy +\ 2 le-advertising-report \ b.num { b.event-type b.addr-type 6.address b.datalen { b.data } S.rssi } +\ 3 le-connection-update-complete \ b.status w.handle w.interval w.latency w.timeout +\ 4 le-read-remote-used-features-complete \ b.status w.handle 8.features +\ 5 le-long-term-key-request \ w.handle 8.random w.diversifier + +h# 3f UNUSED + +: physical-link-complete \ b.status b.plink + cdump cr +; h# 40 set-event + +: channel-selected \ b.plink + cdump cr +; h# 41 set-event + +: disconnection-phys-link-complete \ b.status b.plink b.reason + cdump cr +; h# 42 set-event + +: physical-link-loss-early-warning \ b.plink b.reason + cdump cr +; h# 43 set-event + +: physical-link-recovery \ b.plink + cdump cr +; h# 44 set-event + +: logical-link-complete \ b.status w.llink b.plink b.flow-spec-id + cdump cr +; h# 45 set-event + +: disconnection-log-link-complete \ b.status w.llink b.reason + cdump cr +; h# 46 set-event + +: flow-spec-modify-complete \ b.status w.handle + cdump cr +; h# 47 set-event + +: num-comp-blocks \ w.num-blocks b.num-hndl { w.handle w.pkts w.blocks } + cdump cr +; h# 48 set-event + +: amp-start-test \ b.status b.scenario + cdump cr +; h# 49 set-event + +: amp-test-end \ b.status b.scenario + cdump cr +; h# 4a set-event + +: amp-receiver-report \ b.ctlr-type b.reason l.event-type w.numfr + cdump cr +; h# 4b set-event + +: short-range-mode-change-complete \ b.status b.plink b.state + cdump cr +; h# 4c set-event + +: amp-status-change \ b.status b.amp-status + cdump cr +; h# 4d set-event + +: unwrap-event ( adr len -- adr' len' event# ) + drop >r ( r: adr ) + r@ 2 + r@ 1+ c@ r> c@ ( eadr elen event# ) +; +: .event ( adr len -- ) + ." Event: " ( adr len ) + unwrap-event ( adr' len' event# ) + dup #events >= if ( adr len event# ) + drop ." UNKNOWN " ( adr len ) + cdump cr ( ) + else ( adr len event# ) + events swap ta+ token@ ( adr len xt ) + dup .name ( adr len xt ) + execute ( ) + then ( ) +; + +\ If it is a vendor event, copy the result into a dedicated buffer +\ instead of returning the data to the caller +: x-check-evtpkt ( adr len -- process? ) + over c@ >r 2 /string r> ( adr' len' type ) + h# e = if \ EV_CMD_COMPLETE ( adr len ) + drop dup 1 + le-w@ d# 1024 /mod ( adr ocf ogf ) + \ For now we ignore ocf, but we could check if its value is h# 5b - + \ BT_CMD_MODULE_CFG_REQ - and do something to indicate completion + h# 3f <> ( adr ocf process? ) + dup 0= if ( adr ocf process? ) + 2 pick copy-result ( adr ocf process? ) + .vendor-cmd ( adr ocf process? ) + then ( ocf process? ) + nip nip ( process? ) + else ( adr len ) + 2drop true ( process? ) + then +; +: check-evtpkt ( adr len -- process? ) + .event false +; + +0 value psmode +: handle-marvell-event ( adr len -- process? ) + over c@ h# ff <> if 2drop true exit then \ Check for Marvell event + drop 2 + ( data-adr ) + dup c@ case ( data-adr type ) + + h# 23 of \ AUTO_SLEEP_MODE ( data-adr ) + dup 2+ c@ if ( data-adr ) + ." PS Mode command failed" cr ( data-adr ) + else ( data-adr ) + dup 1+ c@ 2 = to psmode ( data-adr ) + then ( data-adr ) + false ( data-adr process? ) + endof ( data-adr ) + + h# 59 of \ SLEEP_CONFIG ( data-adr ) + dup 3 + c@ if ( data-adr ) + ." HSCFG command failed" cr ( data-adr ) + then ( data-adr ) + false ( data-adr process? ) + endof ( data-adr type ) + + h# 5a of \ SLEEP_ENABLE ( data-adr ) + dup 1+ c@ if ( data-adr ) + ." HS Enable command failed" cr ( data-adr ) + else + \ true to sleep-activated? + then ( data-adr ) + false ( data-adr process? ) + endof ( data-adr type ) + + h# 5b of \ MODULE_CFG_REQ ( data-adr ) + \ Pass on everything except MODULE_BRINGUP_REQ and MODULE_SHUTDOWN_REQ + dup 1+ c@ h# f1 h# f2 between 0= ( data-adr process? ) + endof ( data-adr type ) + + ( default ) ( data-adr type ) + true swap ( data-adr process? type ) + endcase ( data-adr process? ) + + nip ( process? ) +; + +true instance value got-data? +0 instance value /data +0 instance value data + +: copy-data ( adr len buf+ actual -- actual ) + rot min ( adr buf+ actual' ) + -rot swap ( actual buf+ adr ) + 2 pick move ( actual ) +; + +h# 200 buffer: event-buf + +d# 1000 instance value bt-timeout +: normal-timeout ( -- ) d# 1000 to bt-timeout ; + +: timed-wait ( -- adr len type ) + get-msecs bt-timeout + ( time-limit ) + begin ( time-limit ) + dup get-msecs - 0< abort" Bluetooth timeout" ( time-limit ) + " got-bt-packet?" $call-parent ( time-limit [ dadr dlen type ] flag ) + until ( time-limit dadr dlen type ) + 3 roll drop ( dadr dlen type ) + rot event-buf ( dlen type dadr buf ) + 3 pick move ( dlen type ) + event-buf -rot ( adr len type ) + " recycle-packet" $call-parent ( adr len type ) +; + +0 instance value #cmds-allowed +: unwrap-cmd-complete ( eadr elen -- adr len cmd# ) + over c@ to #cmds-allowed ( eadr elen ) + 3 /string ( adr len ) + over 2- le-w@ ( eadr elen cmd# ) +; +: ?cmd-error ( adr -- ) + c@ ?dup if ( error# ) + ." Command failed with error 0x" .x cr + then +; + +: unwrap-cmd-status ( eadr elen -- adr len cmd# ) + over 1+ c@ to #cmds-allowed ( eadr elen ) + over ?cmd-error ( eadr elen ) + 4 /string ( adr len ) + over 2- le-w@ ( eadr elen cmd# ) +; + +: wait-event ( -- eadr elen event# ) + begin timed-wait 4 <> while ( dadr dlen ) + 2drop ( ) + repeat ( dadr dlen ) + unwrap-event ( eadr elen event# ) +; + +\ adr,len is the unwrapped command response data +: wait-cmd-complete ( cmd# -- adr len ) + >r ( r: cmd# ) + begin ( r: cmd# ) + wait-event h# e = if ( eadr elen r: cmd# ) + unwrap-cmd-complete ( cadr clen this-cmd# r: cmd# ) + r@ = if ( cadr clen r: cmd# ) + r> drop exit ( -- adr len ) + then ( cadr clen r: cmd# ) + then ( adr len r: cmd# ) + 2drop ( r: cmd# ) + again +; + +: wait-cmd-status ( -- ) + begin ( ) + wait-event h# f = if ( eadr elen ) + unwrap-cmd-status ( cadr clen this-cmd# ) + 3drop exit ( -- ) + then ( adr len ) + 2drop ( ) + again +; + +: le-3@ ( adr -- n ) le-l@ h# ffffff and ; +: <c@ ( adr -- ) c@ dup h# 80 and if d# 256 - then ; +: .dbm ( adr -- ) <c@ .d ." dBm " ; +: show-pscan ( adr -- ) ." Rep: " c@ . ; +: show-class ( adr -- ) ." Class: 0x" le-3@ .x ; +: show-bdaddr ( adr -- ) ." BDADDR: " 6 cdump ; +: show-offset ( adr -- ) ." Offset: 0x" le-w@ .x ; +: show-rssi ( adr -- ) ." RSSI: " .dbm ; + +: parse-inquiry ( eadr elen -- ) + over c@ >r 1 /string r> ( adr' len' #responses ) + 0 ?do ( adr len ) + over show-bdaddr ( adr len ) + over 7 + show-pscan ( adr len ) + over 9 + show-class ( adr len ) + over d# 12 + show-offset ( adr len ) + cr ( adr len ) + d# 14 /string ( adr' len' ) + loop ( adr len ) + 2drop +; + +: show-inquiry-rssi ( adr -- ) + dup show-bdaddr ( adr ) + dup 7 + show-pscan ( adr len ) + dup 8 + show-class ( adr ) + dup d# 11 + show-offset ( adr ) + d# 13 + show-rssi ( ) +; +: parse-inquiry-rssi ( eadr elen -- ) + over c@ >r 1 /string r> ( adr' len' #responses ) + 0 ?do ( adr len ) + over show-inquiry-rssi cr ( adr len ) + d# 14 /string ( adr' len' ) + loop ( adr len ) + 2drop +; + +: .tx-power ( adr len -- adr len ) ." TX_Power: " over 1+ .dbm ; +: .short-name ( adr len -- adr len ) ." Short_Name: " 2dup 1 /string type space ; +: .long-name ( adr len -- adr len ) ." Name: " 2dup 1 /string type space ; +: show-extended-inquiry ( adr -- ) + begin dup c@ dup while ( adr len ) + swap 1+ tuck c@ ( adr' len type ) + case ( adr len type ) + \ 1 is flags + \ 2-7 are service UUIDs + 8 of .short-name endof ( adr len type ) + 9 of .long-name endof ( adr len type ) + h# a of .tx-power endof ( adr len type ) + \ h# d-f are simple pairing OOB tags + \ h# 10 is security manager TK value + \ h# 11 is security manager OOB flags + \ h# 12 is slave connection interval range + \ h# 14-15 are service solicitation UUIDS + \ h# 16 is service data + \ h# ff is manufacturer-specific data + endcase ( adr len ) + + ( adr' ) + repeat ( adr len ) + 2drop +; + +: parse-extended-inquiry ( eadr elen -- ) + over c@ >r 1 /string r> ( adr' len' #responses ) + 0 ?do ( adr len ) + over show-inquiry-rssi cr ( adr len ) + d# 14 /string ( adr' len' ) + over show-extended-inquiry ( adr len ) + cr cr ( adr len ) + h# f0 /string ( adr len ) + loop ( adr len ) + 2drop +; + +\ adr,len is the unwrapped command response data +: process-inquiry ( -- ) + begin ( ) + wait-event case ( eadr elen event# ) + 1 of \ Inquiry Complete ( eadr elen ) + drop ?cmd-error ( ) + exit + endof + + 2 of \ Inquiry Result ( eadr elen ) + parse-inquiry ( ) + endof ( eadr elen event# ) + + h# f of \ Command Status ( eadr elen ) + unwrap-cmd-status ( eadr elen cmd# ) + drop ." Inquiry results:" cr + endof ( eadr elen event# ) + + h# 22 of \ Inquiry Info w/RSSI ( eadr elen ) + parse-inquiry-rssi ( ) + endof ( eadr elen event# ) + + h# 2f of \ Extended Inquiry Info ( eadr elen ) + parse-extended-inquiry ( ) + endof ( eadr elen event# ) + + \ default ( eadr elen event# ) + \ nip nip ( event# ) + ." Skipping event# " dup . ( eadr elen event# ) + 2 spaces -rot cdump cr ( event# ) + endcase ( ) + again +; + +: read ( adr len -- actual ) + " got-bt-packet?" $call-parent 0= if ( adr len ) + 2drop -2 exit + then ( adr len dadr dlen type ) + + case ( adr len dadr dlen type ) + + h# fe of \ VENDOR ( adr len dadr dlen ) + 2dup handle-marvell-event if ( adr len dadr dlen ) + copy-data ( actual ) + else ( adr len dadr dlen ) + 4drop -1 ( -1 ) + then ( actual ) + endof ( adr len dadr dlen type ) + + 4 of \ EVENT ( adr len dadr dlen ) + 2dup check-evtpkt if ( adr len dadr dlen ) + copy-data ( actual ) + else ( adr len dadr dlen ) + 4drop -1 ( actual ) + then ( ) + endof ( adr len dadr dlen type ) + + 2 of \ ACLDATA ( adr len dadr dlen ) + copy-data ( actual ) + endof ( adr len dadr dlen type ) + + 3 of \ SCODATA ( adr len ) + copy-data ( actual ) + endof ( adr len dadr dlen type ) + + ( default ) ( adr len dadr len type ) + dup ." Invalid BT SDIO packet type " .d cr + nip nip nip nip -1 swap ( actual type ) + endcase ( actual ) + + " recycle-packet" $call-parent ( actual ) +; +0 instance value outbuf +: host-to-card ( adr len -- ) + SDIO_BLOCK_SIZE round-up ( adr len' ) + 2 0 do ( adr len ) + 2dup " sdio-blocks!" $call-parent ( adr len actual ) + over = if 2drop unloop exit then ( adr len ) + loop ( adr len ) + 2drop ( ) + true abort" BT SDIO write failed" ( ) +; + +\ Command packet: +\ SDIO Type-A Transport header +\ 0..2 Length of interface data (after byte 3) +\ 3 Service ID: 1=HCI 2=ACL 3=SCO 4=Event FE=Vendor +\ Command header +\ 4..5 Command code - OGF<<10 | OCF +\ 6 Length of command data (after byte 6) +\ Command data +\ 7.. Varies according to command + +: 'cmd-data ( -- adr ) outbuf 7 + ; + +: send-cmd ( data-len ogf+ocf service-id -- ) + outbuf 3 + c! ( ogf+ocf ) + outbuf 4 + le-w! ( data-len ) + dup outbuf 6 + c! ( data-len ) + 3 + dup outbuf le-w! ( len-wo-transport-hdr ) + outbuf swap 4 + host-to-card ( ) +; + +0 value x \ Temporary variables to assist command creation +0 value /x + +: 'x ( -- adr ) x /x + ; +: +x ( n -- ) /x + to /x ; +: +x$ ( $ -- ) 'x swap dup +x move ; +: +x3 ( n -- ) 'x le-l! 3 +x ; +: +xl ( n -- ) 'x le-l! /l +x ; +: +xw ( n -- ) 'x le-w! /w +x ; +: +xb ( n -- ) 'x c! /c +x ; +: +xerase ( n -- ) 'x over erase +x ; +: +xbdaddr ( 'bdaddr -- ) 6 +x$ ; + +: cmd( ( -- ) 'cmd-data to x 0 to /x ; +: )cmd ( cmd# -- ) /x swap 1 send-cmd ; +: )cmd-wait ( cmd# -- ) dup )cmd wait-cmd-complete ; +: )vendor-cmd ( cmd# -- ) /x swap h# fe send-cmd ; +: )vendor-cmd-wait ( cmd# -- adr len ) /x swap h# fe send-cmd wait-cmd-complete ; + +: send-vendor-cmd ( data-len cmd-code -- ) + h# fc00 or h# fe send-cmd ( ) \ fe is Vendor command service ID +; +: send-hci-cmd ( data-len cmd# -- ) + 1 send-cmd ( ) \ 1 is HCI command service ID +; +: do-hci-cmd ( data-len cmd# -- adr len ) + tuck 1 send-cmd ( cmd# ) + wait-cmd-complete ( adr len ) +; + +: send-rev-cmd ( -- ) 0 h# f send-vendor-cmd ; +: send-read-mem-cmd ( reg# len -- ) + 'cmd-data 4 + c! ( reg# ) + 'cmd-data le-l! ( ) + 5 h# 1 send-vendor-cmd +; + +: +cmd ( offset -- adr ) 'cmd-data + ; +: cmd! ( n offset -- ) +cmd c! ; + +: send-rx-test ( #reports 'bdaddr tx-am len #packets type rxfreq txfreq scenario -- ) + cmd( + +xb \ scenario + +xb \ txfreq + +xb \ rxfreq + +xb \ type + +xl \ #packets + +xw \ len + +xb \ tx-am + +xbdaddr \ bdaddr + +xb \ #reports + + h# fc05 )vendor-cmd-wait 2drop +; +: rx-test ( -- ) +\ #r bdaddr am len #p DM1 rxf txf 0pat + 0 " abcdef" drop 1 d# 10 1 3 0 1 1 send-rx-test +; +: giac ( -- adr len ) " "(33 8b 9e)" ; + +: set-scan ( mask -- ) cmd( +xb h# c1a )cmd-wait 2drop ; +: enable-scanning ( -- ) 3 set-scan ; +: disable-scanning ( -- ) 0 set-scan ; + +: set-inquiry-mode ( 0|1|2-- ) + cmd( +xb h# c45 )cmd-wait drop ?cmd-error +; +: cancel-inquiry ( -- ) cmd( h# 402 )cmd-wait drop ?cmd-error ; + +: x-send-inquiry ( -- ) + h# 33 0 cmd! h# 8b 1 cmd! h# 9e 2 cmd! \ General Inquiry LAC + 4 3 cmd! \ 4 * 1.28 seconds + 1 4 cmd! \ Return after first response + 5 h# 401 send-hci-cmd +; +: olpc-in-extended-inquiry? ( adr -- flag ) + begin dup c@ dup while ( adr len ) + swap 1+ tuck c@ ( adr' len type ) + 8 9 between if ( adr len ) + 2dup 1 /string ( adr len remote-name$ ) + " OLPC-XO" $= if ( adr len ) + 2drop true exit ( -- true ) + then + then ( adr len ) + + ( adr' ) + repeat ( adr len ) + 2drop false ( false ) +; +: olpc-xo-found? ( eadr elen -- seen? ) + over c@ >r 1 /string r> ( adr' len' #responses ) + 0 ?do ( adr len ) + d# 14 /string ( adr' len' ) + over olpc-in-extended-inquiry? if ( adr len ) + 2drop true unloop exit ( -- true ) + then ( adr len ) + h# f0 /string ( adr len ) + loop ( adr len ) + 2drop false ( false ) +; + +: wait-olpc-response ( -- seen? ) + begin ( ) + wait-event case ( eadr elen event# ) + 1 of \ Inquiry Complete ( eadr elen ) + drop ?cmd-error ( ) + false exit ( -- false ) + endof + + h# 2f of \ Extended Inquiry Info ( eadr elen ) + olpc-xo-found? if ( ) + cancel-inquiry ( ) + true exit ( -- true ) + then + endof ( eadr elen event# ) + + \ default ( eadr elen event# ) + nip nip ( event# ) + endcase ( ) + again +; +: send-inquiry ( -- ) + cmd( + giac +x$ \ General Inquiry LAC + d# 4 +xb \ 4 * 1.28 seconds + d# 16 +xb \ #responses + h# 401 )cmd + wait-cmd-status +; +: inquire ( -- ) + d# 10000 to bt-timeout + send-inquiry + process-inquiry + normal-timeout +; +: inquire-olpc? ( -- seen? ) + 2 set-inquiry-mode + d# 7000 to bt-timeout + send-inquiry + wait-olpc-response ( seen? ) + normal-timeout +; + +6 instance buffer: his-bdaddr +6 instance buffer: my-bdaddr +: read-bdaddr ( -- ) + cmd( h# 1009 )cmd-wait ( adr len ) + over c@ if ( adr len ) + ." Bluetooth read-bdaddr command failed!" cr + 2drop exit + then + drop 1+ my-bdaddr 6 move +; + +: .bdaddr ( 'bdaddr -- ) 6 cdump space ; + +0 instance value the-connection +: parse-connection ( adr -- ) + dup c@ if drop exit then ( adr ) + dup 1+ le-w@ to the-connection + ." Connected to " dup 3 + .bdaddr ( adr ) + dup 9 + c@ case + 0 of ." SOC" endof + 1 of ." ACL" endof + endcase + dup d# 10 + c@ if ." Encrypted" then + cr + drop +; +: wait-connected ( -- ) + begin ( ) + wait-event case ( eadr elen event# ) + 3 of \ Connection Complete ( eadr elen ) + drop dup ?cmd-error ( eadr ) + parse-connection + exit + endof + + \ default ( eadr elen event# ) + \ nip nip ( event# ) + ." Skipping event# " dup . ( eadr elen event# ) + 2 spaces -rot cdump cr ( event# ) + endcase ( ) + again +; + +h# cc18 value packet-types +0 value his-clock-offset +: connect ( 'bdaddr -- ) + cmd( ( 'bdaddr ) + +xbdaddr ( ) + packet-types +xw + 0 +xb \ Page Scan Mode R0 + 0 +xb \ Reserved, must be 0 + his-clock-offset +xw + 0 +xb \ Disallow Role Switch + h# 405 )cmd wait-cmd-status +; +: wait-disconnected ( -- ) + begin ( ) + wait-event case ( eadr elen event# ) + 5 of \ Disconnection Complete ( eadr elen ) + drop ?cmd-error ( eadr ) + exit + endof + + \ default ( eadr elen event# ) + \ nip nip ( event# ) + ." Skipping event# " dup . ( eadr elen event# ) + 2 spaces -rot cdump cr ( event# ) + endcase ( ) + again +; + +: disconnect ( -- ) + cmd( the-connection +xw h# 13 +xb h# 406 )cmd + wait-cmd-status wait-disconnected +; + +: set-name ( name$ -- ) + cmd( d# 248 over - -rot +x$ +xerase h# c13 )cmd-wait + drop ?cmd-error +; +: get-name ( -- name$ ) + cmd( h# c14 )cmd-wait + over ?cmd-error ( adr len ) + over c@ if 2drop " " else ( adr len ) + drop 1+ cscount ( name$ ) + then ( name$ ) +; +: wait-remote-name ( -- name$ ) + begin ( ) + wait-event case ( eadr elen event# ) + 7 of \ Remote Name Request Complete ( eadr elen ) + drop dup ?cmd-error ( eadr ) + 7 + cscount exit ( -- adr len ) + endof + + \ default ( eadr elen event# ) + \ nip nip ( event# ) + ." Skipping event# " dup . ( eadr elen event# ) + 2 spaces -rot cdump cr ( event# ) + endcase ( ) + again +; + +: get-remote-name ( offset rep bdaddr -- name$ ) + cmd( +xbdaddr +xb 0 +xb +xw h# 419 )cmd wait-cmd-status + wait-remote-name ( name$ ) +; + +: set-class ( class# -- ) + cmd( +x3 h# c24 )cmd-wait drop ?cmd-error +; +: set-my-class ( -- ) h# 10010c set-class ; \ Laptop computer, transfer + +: set-extended-response ( adr len fec? -- ) + cmd( +xb +x$ h# f0 /x 1- - +xerase h# c52 )cmd-wait drop ?cmd-error +; +: set-olpc-xo-response ( -- ) + " "(08 09)OLPC-XO" false set-extended-response +; +: start-server ( -- ) + " OLPC-XO" set-name \ Not strictly necessary + enable-scanning + set-olpc-xo-response +; + +: open ( -- flag ) + my-space " set-address" $call-parent + h# 200 " set-block-size" $call-parent + h# 200 " alloc-buffer" $call-parent to outbuf + my-args " scan" $= if start-server then + true +; +: close ( -- ) + outbuf h# 200 " free-buffer" $call-parent +; +: selftest ( -- error? ) + open 0= if + ." Can't open Bluetooth device" cr + true exit + then + inquire-olpc? 0= + dup if ." No response from Bluetooth scan server" cr then +; +also forth definitions +: scan-bt ( -- ) + " /bluetooth:scan" open-dev ( ihandle ) + ?dup if ( ihandle ) + ." Bluetooth scan server started. Type a key to exit" cr + begin key? until key drop ( ihandle ) + close-dev ( ) + else + ." Can't start Bluetooth scan server." cr + then +; +previous definitions + +\ Classes: +\ Information: 800000 +\ Telephony: 400000 +\ Audio 200000 +\ Object xfer 100000 +\ Capturing 80000 +\ Rendering 40000 +\ Networking 20000 +\ Positioning 10000 +\ Limited discoverable mode 2000 +\ Major: Computer 100, Phone 200, LAN AP 300, AV 400, Peripheral 500, Imaging 600, Wearable 700, Toy 800, Misc 000, Uncategorized 1f00 +\ Minor: major-dependent, e.g. 204 is cell phone +\ P2030 phone: 51 04 8c 68 30 2c Class: 5a0204
