Author: wmb Date: 2009-05-13 00:48:24 +0200 (Wed, 13 May 2009) New Revision: 1178
Modified: cpu/x86/apic.fth Log: apic.fth - Nuked carriage returns in the file.
Modified: cpu/x86/apic.fth =================================================================== --- cpu/x86/apic.fth 2009-05-12 22:47:27 UTC (rev 1177) +++ cpu/x86/apic.fth 2009-05-12 22:48:24 UTC (rev 1178) @@ -1,310 +1,310 @@ -purpose: Advanced Programmable Interrupt Controller driver -\ See license at end of file - -0 0 " fee00000" " /" begin-package - -" apic" name - -\ Docs: -\ "Intel Architecture Software Developer's Manual", Volume 3, chapter 7.5: -\ "Advanced Programmable Interrupt Controller (APIC)" -\ See linux/include/asm-i386/i82489.h for further details. - -: apic-base-msr! ( l -- ) 0 h# 1b msr! ; \ High 32 bits are unused -: apic-base-msr@ ( -- l ) h# 1b msr@ drop ; - -: apic-on ( -- ) apic-base-msr@ h# fff and h# 800 or apic-mmio-base or apic-base-msr! ; -: apic-off ( -- ) apic-base-msr@ h# 800 invert and apic-base-msr! ; - -0 value apic-base \ Needs to be mapped and set - -: apic! ( l reg -- ) apic-base + l! ; -: apic@ ( reg -- l ) apic-base + l@ ; -: apic-set ( mask reg -- ) dup apic@ rot or swap apic! ; -: apic-clr ( mask reg -- ) dup apic@ rot invert and swap apic! ; - -\ Support - -code cpu-capabilities ( -- n ) - 1 # ax mov - cpuid - dx push -c; -: apic-present? ( -- flag ) cpu-capabilities h# 200 and 0<> ; - -\ Methods - -: taskpri@ ( -- n ) h# 80 apic@ ; -: taskpri! ( n -- ) h# 80 apic! ; -: arbpri@ ( -- n ) h# 90 apic@ ; -: arbpri! ( n -- ) h# 90 apic! ; -: spiv@ ( -- n ) h# f0 apic@ ; -: spiv! ( n -- ) h# f0 apic! ; - -: id! ( id -- ) d# 24 lshift d# 20 apic! ; -: id@ ( -- id ) d# 20 apic@ d# 24 rshift ; -: lvt0@ ( -- n ) h# 350 apic@ ; -: lvt0! ( n -- ) h# 350 apic@ ; -: lvt1@ ( -- n ) h# 360 apic@ ; -: lvt1! ( n -- ) h# 360 apic@ ; - -: lvt0-disable-irq ( -- ) h# 10000 h# 350 apic-set ; \ Disable LINT0 -: lvt0-enable-irq ( -- ) h# 10000 h# 350 apic-clr ; \ Enable LINT0 -: lvt1-disable-irq ( -- ) h# 10000 h# 360 apic-set ; \ Disable LINT1 -: lvt1-enable-irq ( -- ) h# 10000 h# 360 apic-clr ; \ Enable LINT1 -: timer! ( l -- ) h# 380 apic@ drop h# 380 apic! ; -: timer@ ( -- l ) h# 390 apic@ ; -: timer-disable-irq ( -- ) h# 10000 h# 320 apic-set ; \ Dis IRQ when timer passes 0 -: timer-enable-irq ( -- ) h# 10000 h# 320 apic-clr ; \ Dis IRQ when timer passes 0 -: timer-periodic ( -- ) h# 30000 h# 320 apic-set ; -: timer-one-shot ( -- ) h# 320 apic@ h# 20000 invert and h# 10000 or h# 320 apic! ; -: timer-irq! ( vector -- ) h# 320 apic@ h# ff invert and or h# 10000 or h# 320 apic! ; -: perf-disable-irq ( -- ) h# 10000 h# 340 apic-set ; \ Dis IRQ when perf timer passes 0 -: perf-enable-irq ( -- ) h# 10000 h# 340 apic-clr ; \ Dis IRQ when perf timer passes 0 -: perf-irq! ( vector -- ) h# 340 apic@ h# ff invert and or h# 10000 or h# 340 apic! ; - -: ack-irq ( -- ) h# f0 apic@ drop 0 h# b0 apic! ; \ b0 is eoi - -: soft-on ( -- ) - spiv@ - h# 100 or \ APIC on - h# 200 invert and \ Focus processor checking - h# ff or \ Spurious IRQ vector ff - spiv! -; - - -: open ( -- okay? ) - apic-base 0= if - apic-mmio-base h# 400 " map-in" $call-parent to apic-base - apic-on - taskpri@ h# ff invert and taskpri! \ "Accept All" - soft-on - \ Virtual wire mode - \ REMOTE_IRR (4000), SEND_PENDING (1000), DELIVERY_MODE_EXTINT (700) - lvt0@ h# 1ff00 invert and h# 5700 or lvt0! - \ REMOTE_IRR (4000), SEND_PENDING (1000), DELIVERY_MODE_NMI (400) - lvt1@ h# 1ff00 invert and h# 5400 or lvt1! - then - - true -; -: close ( -- ) ; - -end-package - -0 0 " fec00000" " /" begin-package - -" io-apic" name - -0 value io-apic-base -: io-apic@ ( index -- l ) io-apic-base c! io-apic-base h# 10 + l@ ; -: io-apic! ( l index -- ) io-apic-base c! io-apic-base h# 10 + l! ; - -\ Debugging - -: .apic-mode ( low -- ) - 8 rshift 7 and case - 0 of ." Fixed " endof - 1 of ." LowPri " endof - 2 of ." SMI " endof - 3 of ." Res3 " endof - 4 of ." NMI " endof - 5 of ." Init " endof - 6 of ." Res6 " endof - 7 of ." Ext " endof - endcase -; - -: .apic-irq ( int# -- ) - 2* h# 10 + dup io-apic@ - ." Vec: " dup h# ff and 2 u.r space - dup .apic-mode - dup h# 800 and if ." Logical " else ." Physical " then - dup h# 1000 and if ." Pending " else ." Idle " then - dup h# 2000 and if ." Low " else ." High " then - dup h# 8000 and if - ." Level " dup h# 4000 and if ." IRR " else ." EOI " then - else ." Edge " then - h# 10000 and if ." Masked " else ." Open " then - 1+ io-apic@ - ." EDID: " dup d# 16 rshift h# ff and 2 u.r - ." Dest: " d# 24 rshift h# ff and 2 u.r - cr -; -: .apic-irqs ( -- ) - push-hex - 1 io-apic@ d# 16 rshift h# ff and 1+ 0 do - i 2 u.r space i .apic-irq - loop - pop-base -; - -\ Methods - -: trigger-irq ( irq# -- ) io-apic-base h# 20 + c! ; -: eoi ( vector -- ) io-apic-base h# 40 + c! ; - -: open ( -- okay? ) - io-apic-base 0= if - io-apic-mmio-base h# 80 " map-in" $call-parent to io-apic-base - then - true -; -: close ( -- ) ; - -end-package - -0 value apic-ih -0 value io-apic-ih -stand-init: APIC - " /apic" open-dev to apic-ih - " /io-apic" open-dev to io-apic-ih -; - -0 [if] -\ For tdcr (3e0): -\ Divisor: 1 2 4 8 16 32 64 128 -\ Value : b 0 1 2 3 8 9 a - -\ Timer base low bit at bit 18 -\ Timer base div is mask 2 - -\ Other regs: -\ LVR 0x30 -\ GET_APIC_VERSION(x) ((x)&0xFF) - -\ TPR 80 Task Priority, 000000xx only service interrupts higher than this value -\ APR 90 Arbitration Priority, used during bus arbitration -\ PPR a0 Processor Priority, depends complexly on TPR and incoming interrupt - -\ LDR 0xD0 Logical Destination Register II000000 II is logical APIC ID -\ DFR 0xE0 Destination Format Register M0000000 M is the model (F:flat or 0:cluster) -\ LVTERR 0x370 -\ TDCR 0x3E0 -\ ICR 0x310 Generate local interrupt by writing - -\ IRR 200 - 270 (8 registers - 256 bits) Request - bit is set if interrupt pending -\ ISR 100 - 170 (8 registers - 256 bits) Service - INTA latches highest priority bit -\ TMR 180 - 1F0 (8 registers - 256 bits) Bit is set for level, clear for edge. EOI commands sends EOI msg to all IOAPIC - -20 0 -30 50014 -80 f0 -d0 0 -e0 ffffffff -f0 10f -320 10000 Timer Masked off -340 10000 PCINT Masked off -350 700 LINT0 vector 0 mode ExtINT (111) Edge Trigger Active High -360 400 LINT1 vector 0 mode NMI (100) Edge Trigger Active High -370 10000 ERROR Masked off -380 0 -390 0 - -Io apic -259 9 (def 08) bit 0=1 enabe MSI Flat Mode Support - -25c 10 APIC D11 is masked to 1, cluster mode disabled -268-26f 0 .. 0 Priority of all CPUs = 0 -296 a - bit 0 = 0 Assert HDPWR# for both read / write cycles (other bits are enable V4 fast TRDY, dynamic HDPWR#) -297 1 - bit 1 = 0 Don't pipeline APIC requests, bit 0 = 1 enable redirect low priority apic reqs to CPU 0 -386 3f - bit 5 ena apic low interrupt arb, bit 4 io apic fec80000 - fecf.ffff to PCI2, bit 3 host snoop, 2 enable top sm mem, 1 enable sdio support for using system memory 4kbytes, 1 enable compatible smm -485 5 - bit 1 = 0 free-running apic clock (not dynamic) [Reserved in 855] -488 0 - bits 1 and 0 free running apic clocks [Reserved in 855] -4a2 d6 - bit 3 = 0 disable apic interface power management [Reserved in 855] - --- Following registers in D0F5 are [Reserved in 855] -540 4c (default) - bit 7 disable legacy apic, c is irrelevant if disabled -541 0 (def) - irrelevant if 540 disabled -542 3 (def) - bit 3 disable intx transparent mode, bit 2 dis apic nonshare mode, bit 1 ena APIC interrupt disable, bit 0 enabe boot interrupt function -544 0 (def) - bit 7 boring, bit 1 dis pcie dev uses msi cycle wake up system from c3, bit 0 apic data voltage 2.5v --- End reserved - - -io apic regs: fec0.0000 -00 index register for indirect regs -10 data register for indirect regs -20 write the IRQ # -40 EOI WO - -indirect io apic regs -00 1000000 IOAPIC ID is 1 -01 178003 (RO) version -02 1000000 Arb ID is 1 -03 1 Front side bus message delivery -10,11 0100.0000 . 0001.0000 DD00 . 0000 . 000 ooom . tips MVV -.. -3e,3f 0100.0000 . 0001.0000 - DD is destination APIC ID in physical mode (since bit 11 = 0) - m = 1 means masked - - -8848 0 bit 7 = 0 address bit 2 of FSBis not force low (default) -884d 1 bit 3=0 disable some funny thing about APCI Ch0 ext interrupt delivery (def), bit 2=0 dis ser irq always shared in APIC mode (def) - -PnP routing -8854 00 non-inverted PCI INT# -8855 a0 INTA IRQ10 -8856 b9 INTC IRQ11, INTB IRQ9 -8857 a0 INTD IRQ10 - -APIC Mode INTA-H -PIRQ16 A -PIRQ17 B -PIRQ18 C -PIRQ19 D -PIRQ20 E -PIRQ21 F -PIRQ22 G -PIRQ23 H - -8858 60 (def 40) bit 6 ena Internal APIC -885b 53 (def 01) bit 6 port 80 to LPC, bit 4 ena APIC clock gating, bit 3=0 dis bypass apic de-assert Msg, bit 1 res, bit 0 ena dynamic clock stop -886c 00 (def) bit 3 dis apic positive decode -88b0 30 (def 08) bits 5,4 ena uart 2,1, bit 3=0 disable apic C4P State Mode Control -88e7 80 (def 00) bit 7 enable apic cycle reflect to all bus master activity effective signal -88ec 00 (def 00) bits 7:4=0 disable V1 interrupt routing - -PMIO+65 bit 7 set to 1 to enable APIC interrupt wake up system from C4P state - -8f73 01 (def 00) bit4=0 enable APIC cycle block p2c write cycle (def), bit 0=1 enable pci broken master timer -8f74 0c (def 00) bit3=1 lock cycle issued by cpu block p2c cycles, bit2=1 APIC FSB directly up through CCA (not PCI) and 7c[1] must also be set [Bit 2 is reserved in 855] -8f7c 02 (def 02) bit2=1 APIC FSB directly up through CCA (not PCI) and 74[2] must also be set - -8f80 07 (def 00) bit0=1 APIC cycle blocks HDAC upstream write - -8fe0 93 (def 40) various. bit 3=0 dis APIC cycle flush HDAC Upstream Write Cycle [Reserved in 855] -8fe6 3f (def 01) bit5 supposedly reserved, bit4=1 split fecxx.xxxx range btw PCI1 and PCI2, bit3=1 processor MSI support enable, bit2=1 Top SMM enable, bit1=1 High SMM enable, bit0=1 Compatible SMM enable - - - -When enable internal APIC, PCI devices and internal function IRQ routing are: - -IRQ16 HPET IRQ -IRQ17 HPET IRQ -IRQ18 HPET IRQ -IRQ19 HPET IRQ -IRQ20 UHCI Port 0-1 IRQ and Card Boot IRQ -IRQ21 EIDE IRQ and UHCI Port 4-5 IRQ -IRQ22 UHCI Port 2-3 and SDIO -IRQ23 Card Reader, EHCI Port 0-5 - -HPET IRQs - -Mode Timer0 Timer1 Timer2 --------------------------------------------- -Legacy 0(PIC)/2(APIC) 8(PIC)/8(APIC) - -NonLeg 16-19 APIC 16-19 APIC 11,16-19 APIC - - - 83c 0a display IRQ 10 -603c 0a SDIO IRQ 10 -683c 09 card controller IRQ 9 -803c 0a UHCI 01 IRQ 10 INTA -813c 09 UHCI 23 IRQ 9 INTB -823c 0b UHCI 45 IRQ 11 INTC -843c 0a EHCI IRQ 10 INTD -a03c 09 HDAC IRQ 9 - -[then] +purpose: Advanced Programmable Interrupt Controller driver +\ See license at end of file + +0 0 " fee00000" " /" begin-package + +" apic" name + +\ Docs: +\ "Intel Architecture Software Developer's Manual", Volume 3, chapter 7.5: +\ "Advanced Programmable Interrupt Controller (APIC)" +\ See linux/include/asm-i386/i82489.h for further details. + +: apic-base-msr! ( l -- ) 0 h# 1b msr! ; \ High 32 bits are unused +: apic-base-msr@ ( -- l ) h# 1b msr@ drop ; + +: apic-on ( -- ) apic-base-msr@ h# fff and h# 800 or apic-mmio-base or apic-base-msr! ; +: apic-off ( -- ) apic-base-msr@ h# 800 invert and apic-base-msr! ; + +0 value apic-base \ Needs to be mapped and set + +: apic! ( l reg -- ) apic-base + l! ; +: apic@ ( reg -- l ) apic-base + l@ ; +: apic-set ( mask reg -- ) dup apic@ rot or swap apic! ; +: apic-clr ( mask reg -- ) dup apic@ rot invert and swap apic! ; + +\ Support + +code cpu-capabilities ( -- n ) + 1 # ax mov + cpuid + dx push +c; +: apic-present? ( -- flag ) cpu-capabilities h# 200 and 0<> ; + +\ Methods + +: taskpri@ ( -- n ) h# 80 apic@ ; +: taskpri! ( n -- ) h# 80 apic! ; +: arbpri@ ( -- n ) h# 90 apic@ ; +: arbpri! ( n -- ) h# 90 apic! ; +: spiv@ ( -- n ) h# f0 apic@ ; +: spiv! ( n -- ) h# f0 apic! ; + +: id! ( id -- ) d# 24 lshift d# 20 apic! ; +: id@ ( -- id ) d# 20 apic@ d# 24 rshift ; +: lvt0@ ( -- n ) h# 350 apic@ ; +: lvt0! ( n -- ) h# 350 apic@ ; +: lvt1@ ( -- n ) h# 360 apic@ ; +: lvt1! ( n -- ) h# 360 apic@ ; + +: lvt0-disable-irq ( -- ) h# 10000 h# 350 apic-set ; \ Disable LINT0 +: lvt0-enable-irq ( -- ) h# 10000 h# 350 apic-clr ; \ Enable LINT0 +: lvt1-disable-irq ( -- ) h# 10000 h# 360 apic-set ; \ Disable LINT1 +: lvt1-enable-irq ( -- ) h# 10000 h# 360 apic-clr ; \ Enable LINT1 +: timer! ( l -- ) h# 380 apic@ drop h# 380 apic! ; +: timer@ ( -- l ) h# 390 apic@ ; +: timer-disable-irq ( -- ) h# 10000 h# 320 apic-set ; \ Dis IRQ when timer passes 0 +: timer-enable-irq ( -- ) h# 10000 h# 320 apic-clr ; \ Dis IRQ when timer passes 0 +: timer-periodic ( -- ) h# 30000 h# 320 apic-set ; +: timer-one-shot ( -- ) h# 320 apic@ h# 20000 invert and h# 10000 or h# 320 apic! ; +: timer-irq! ( vector -- ) h# 320 apic@ h# ff invert and or h# 10000 or h# 320 apic! ; +: perf-disable-irq ( -- ) h# 10000 h# 340 apic-set ; \ Dis IRQ when perf timer passes 0 +: perf-enable-irq ( -- ) h# 10000 h# 340 apic-clr ; \ Dis IRQ when perf timer passes 0 +: perf-irq! ( vector -- ) h# 340 apic@ h# ff invert and or h# 10000 or h# 340 apic! ; + +: ack-irq ( -- ) h# f0 apic@ drop 0 h# b0 apic! ; \ b0 is eoi + +: soft-on ( -- ) + spiv@ + h# 100 or \ APIC on + h# 200 invert and \ Focus processor checking + h# ff or \ Spurious IRQ vector ff + spiv! +; + + +: open ( -- okay? ) + apic-base 0= if + apic-mmio-base h# 400 " map-in" $call-parent to apic-base + apic-on + taskpri@ h# ff invert and taskpri! \ "Accept All" + soft-on + \ Virtual wire mode + \ REMOTE_IRR (4000), SEND_PENDING (1000), DELIVERY_MODE_EXTINT (700) + lvt0@ h# 1ff00 invert and h# 5700 or lvt0! + \ REMOTE_IRR (4000), SEND_PENDING (1000), DELIVERY_MODE_NMI (400) + lvt1@ h# 1ff00 invert and h# 5400 or lvt1! + then + + true +; +: close ( -- ) ; + +end-package + +0 0 " fec00000" " /" begin-package + +" io-apic" name + +0 value io-apic-base +: io-apic@ ( index -- l ) io-apic-base c! io-apic-base h# 10 + l@ ; +: io-apic! ( l index -- ) io-apic-base c! io-apic-base h# 10 + l! ; + +\ Debugging + +: .apic-mode ( low -- ) + 8 rshift 7 and case + 0 of ." Fixed " endof + 1 of ." LowPri " endof + 2 of ." SMI " endof + 3 of ." Res3 " endof + 4 of ." NMI " endof + 5 of ." Init " endof + 6 of ." Res6 " endof + 7 of ." Ext " endof + endcase +; + +: .apic-irq ( int# -- ) + 2* h# 10 + dup io-apic@ + ." Vec: " dup h# ff and 2 u.r space + dup .apic-mode + dup h# 800 and if ." Logical " else ." Physical " then + dup h# 1000 and if ." Pending " else ." Idle " then + dup h# 2000 and if ." Low " else ." High " then + dup h# 8000 and if + ." Level " dup h# 4000 and if ." IRR " else ." EOI " then + else ." Edge " then + h# 10000 and if ." Masked " else ." Open " then + 1+ io-apic@ + ." EDID: " dup d# 16 rshift h# ff and 2 u.r + ." Dest: " d# 24 rshift h# ff and 2 u.r + cr +; +: .apic-irqs ( -- ) + push-hex + 1 io-apic@ d# 16 rshift h# ff and 1+ 0 do + i 2 u.r space i .apic-irq + loop + pop-base +; + +\ Methods + +: trigger-irq ( irq# -- ) io-apic-base h# 20 + c! ; +: eoi ( vector -- ) io-apic-base h# 40 + c! ; + +: open ( -- okay? ) + io-apic-base 0= if + io-apic-mmio-base h# 80 " map-in" $call-parent to io-apic-base + then + true +; +: close ( -- ) ; + +end-package + +0 value apic-ih +0 value io-apic-ih +stand-init: APIC + " /apic" open-dev to apic-ih + " /io-apic" open-dev to io-apic-ih +; + +0 [if] +\ For tdcr (3e0): +\ Divisor: 1 2 4 8 16 32 64 128 +\ Value : b 0 1 2 3 8 9 a + +\ Timer base low bit at bit 18 +\ Timer base div is mask 2 + +\ Other regs: +\ LVR 0x30 +\ GET_APIC_VERSION(x) ((x)&0xFF) + +\ TPR 80 Task Priority, 000000xx only service interrupts higher than this value +\ APR 90 Arbitration Priority, used during bus arbitration +\ PPR a0 Processor Priority, depends complexly on TPR and incoming interrupt + +\ LDR 0xD0 Logical Destination Register II000000 II is logical APIC ID +\ DFR 0xE0 Destination Format Register M0000000 M is the model (F:flat or 0:cluster) +\ LVTERR 0x370 +\ TDCR 0x3E0 +\ ICR 0x310 Generate local interrupt by writing + +\ IRR 200 - 270 (8 registers - 256 bits) Request - bit is set if interrupt pending +\ ISR 100 - 170 (8 registers - 256 bits) Service - INTA latches highest priority bit +\ TMR 180 - 1F0 (8 registers - 256 bits) Bit is set for level, clear for edge. EOI commands sends EOI msg to all IOAPIC + +20 0 +30 50014 +80 f0 +d0 0 +e0 ffffffff +f0 10f +320 10000 Timer Masked off +340 10000 PCINT Masked off +350 700 LINT0 vector 0 mode ExtINT (111) Edge Trigger Active High +360 400 LINT1 vector 0 mode NMI (100) Edge Trigger Active High +370 10000 ERROR Masked off +380 0 +390 0 + +Io apic +259 9 (def 08) bit 0=1 enabe MSI Flat Mode Support + +25c 10 APIC D11 is masked to 1, cluster mode disabled +268-26f 0 .. 0 Priority of all CPUs = 0 +296 a - bit 0 = 0 Assert HDPWR# for both read / write cycles (other bits are enable V4 fast TRDY, dynamic HDPWR#) +297 1 - bit 1 = 0 Don't pipeline APIC requests, bit 0 = 1 enable redirect low priority apic reqs to CPU 0 +386 3f - bit 5 ena apic low interrupt arb, bit 4 io apic fec80000 - fecf.ffff to PCI2, bit 3 host snoop, 2 enable top sm mem, 1 enable sdio support for using system memory 4kbytes, 1 enable compatible smm +485 5 - bit 1 = 0 free-running apic clock (not dynamic) [Reserved in 855] +488 0 - bits 1 and 0 free running apic clocks [Reserved in 855] +4a2 d6 - bit 3 = 0 disable apic interface power management [Reserved in 855] + +-- Following registers in D0F5 are [Reserved in 855] +540 4c (default) - bit 7 disable legacy apic, c is irrelevant if disabled +541 0 (def) - irrelevant if 540 disabled +542 3 (def) - bit 3 disable intx transparent mode, bit 2 dis apic nonshare mode, bit 1 ena APIC interrupt disable, bit 0 enabe boot interrupt function +544 0 (def) - bit 7 boring, bit 1 dis pcie dev uses msi cycle wake up system from c3, bit 0 apic data voltage 2.5v +-- End reserved + + +io apic regs: fec0.0000 +00 index register for indirect regs +10 data register for indirect regs +20 write the IRQ # +40 EOI WO + +indirect io apic regs +00 1000000 IOAPIC ID is 1 +01 178003 (RO) version +02 1000000 Arb ID is 1 +03 1 Front side bus message delivery +10,11 0100.0000 . 0001.0000 DD00 . 0000 . 000 ooom . tips MVV +.. +3e,3f 0100.0000 . 0001.0000 + DD is destination APIC ID in physical mode (since bit 11 = 0) + m = 1 means masked + + +8848 0 bit 7 = 0 address bit 2 of FSBis not force low (default) +884d 1 bit 3=0 disable some funny thing about APCI Ch0 ext interrupt delivery (def), bit 2=0 dis ser irq always shared in APIC mode (def) + +PnP routing +8854 00 non-inverted PCI INT# +8855 a0 INTA IRQ10 +8856 b9 INTC IRQ11, INTB IRQ9 +8857 a0 INTD IRQ10 + +APIC Mode INTA-H +PIRQ16 A +PIRQ17 B +PIRQ18 C +PIRQ19 D +PIRQ20 E +PIRQ21 F +PIRQ22 G +PIRQ23 H + +8858 60 (def 40) bit 6 ena Internal APIC +885b 53 (def 01) bit 6 port 80 to LPC, bit 4 ena APIC clock gating, bit 3=0 dis bypass apic de-assert Msg, bit 1 res, bit 0 ena dynamic clock stop +886c 00 (def) bit 3 dis apic positive decode +88b0 30 (def 08) bits 5,4 ena uart 2,1, bit 3=0 disable apic C4P State Mode Control +88e7 80 (def 00) bit 7 enable apic cycle reflect to all bus master activity effective signal +88ec 00 (def 00) bits 7:4=0 disable V1 interrupt routing + +PMIO+65 bit 7 set to 1 to enable APIC interrupt wake up system from C4P state + +8f73 01 (def 00) bit4=0 enable APIC cycle block p2c write cycle (def), bit 0=1 enable pci broken master timer +8f74 0c (def 00) bit3=1 lock cycle issued by cpu block p2c cycles, bit2=1 APIC FSB directly up through CCA (not PCI) and 7c[1] must also be set [Bit 2 is reserved in 855] +8f7c 02 (def 02) bit2=1 APIC FSB directly up through CCA (not PCI) and 74[2] must also be set + +8f80 07 (def 00) bit0=1 APIC cycle blocks HDAC upstream write + +8fe0 93 (def 40) various. bit 3=0 dis APIC cycle flush HDAC Upstream Write Cycle [Reserved in 855] +8fe6 3f (def 01) bit5 supposedly reserved, bit4=1 split fecxx.xxxx range btw PCI1 and PCI2, bit3=1 processor MSI support enable, bit2=1 Top SMM enable, bit1=1 High SMM enable, bit0=1 Compatible SMM enable + + + +When enable internal APIC, PCI devices and internal function IRQ routing are: + +IRQ16 HPET IRQ +IRQ17 HPET IRQ +IRQ18 HPET IRQ +IRQ19 HPET IRQ +IRQ20 UHCI Port 0-1 IRQ and Card Boot IRQ +IRQ21 EIDE IRQ and UHCI Port 4-5 IRQ +IRQ22 UHCI Port 2-3 and SDIO +IRQ23 Card Reader, EHCI Port 0-5 + +HPET IRQs + +Mode Timer0 Timer1 Timer2 +-------------------------------------------- +Legacy 0(PIC)/2(APIC) 8(PIC)/8(APIC) - +NonLeg 16-19 APIC 16-19 APIC 11,16-19 APIC + + + 83c 0a display IRQ 10 +603c 0a SDIO IRQ 10 +683c 09 card controller IRQ 9 +803c 0a UHCI 01 IRQ 10 INTA +813c 09 UHCI 23 IRQ 9 INTB +823c 0b UHCI 45 IRQ 11 INTC +843c 0a EHCI IRQ 10 INTD +a03c 09 HDAC IRQ 9 + +[then]
