Author: wmb Date: Sat Dec 31 23:25:58 2011 New Revision: 2795 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2795
Log: OLPC trac #11349 - The generic "$delete1" file command was leaving a directory ihandle open in the case where the file could not be deleted, leading to a delayed action bug that could cause write data not to be flushed from the disk buffer.
Modified: ofw/core/filecmds.fth
Modified: ofw/core/filecmds.fth ============================================================================== --- ofw/core/filecmds.fth Sat Dec 31 21:53:45 2011 (r2794) +++ ofw/core/filecmds.fth Sat Dec 31 23:25:58 2011 (r2795) @@ -295,8 +295,9 @@
: $delete1 ( path$ -- ) open-directory ?dup 0= abort" Can't open directory" ( name$ dir-ih ) - >r " $delete!" r@ $call-method abort" Can't delete file" ( r: dir-ih ) - r> close-dev + >r " $delete!" r@ $call-method ( error? r: dir-ih ) + r> close-dev ( error? ) + abort" Can't delete file" ; ' $delete1 to _ofdelete
