Author: wmb Date: Fri Jan 21 01:12:35 2011 New Revision: 2135 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2135
Log: ARM - support movw in assembler, disassembler and simulator, support msr in simulator.
Modified: cpu/arm/armsim.c cpu/arm/assem.fth cpu/arm/disassem.fth
Modified: cpu/arm/armsim.c ============================================================================== --- cpu/arm/armsim.c Fri Jan 21 01:10:53 2011 (r2134) +++ cpu/arm/armsim.c Fri Jan 21 01:12:35 2011 (r2135) @@ -496,7 +496,7 @@ default: UNIMP("BXTYPE"); break; } break; case 0x09: switch (BXTYPE) { - case 0x0: UNIMP("msr"); break; + case 0x0: INSTR("msr"); APSR.all = RM; break; case 0x1: INSTR("bx"); PC = RM; break; case 0x2: INSTR("bxj"); PC = RM; break; case 0x3: INSTR("blx"); if (LINK) LR = PC - 4; PC = RM; break; @@ -805,7 +805,7 @@ case 0x15: INSTR("adc"); ADC(RD, RN, IMM32, C); break; case 0x16: INSTR("sbc"); SBB(RD, IMM32, RN, C); break; case 0x17: INSTR("rsc"); SBB(RD, IMM32, RN, C); break; -case 0x18: INSTR("mov"); RD = IMM16; break; +case 0x18: INSTR("movw"); RD = IMM16; break; case 0x19: switch (BXTYPE) { case 0x0: INSTR("nop"); break; case 0x1:
Modified: cpu/arm/assem.fth ============================================================================== --- cpu/arm/assem.fth Fri Jan 21 01:10:53 2011 (r2134) +++ cpu/arm/assem.fth Fri Jan 21 01:12:35 2011 (r2135) @@ -548,6 +548,18 @@ : amode-rdop2 ( -- ) init-operands get-r12 get-opr2 !op ; : amode-rev ( -- ) init-operands get-r12 get-r00 !op ;
+: set-imm16 ( n -- ) + dup fff and 0 set-field + d# 12 >> d# 16 set-field +; +: amode-movw ( -- ) + init-operands get-r12 get-immediate ( imm ) + dup 0 10000 within 0= if + " Immediate value won't fit in 16 bits" ad-error + then + set-imm16 !op +; + : amode-lsm ( need-r16? -- ) init-operands if @@ -923,6 +935,7 @@ : clz 016f.0f10 {cond/s} amode-rdop2 ; : mov 01a0.0000 {cond/s} amode-rdop2 ; : mvn 01e0.0000 {cond/s} amode-rdop2 ; +: movw 0300.0000 {cond} amode-movw ;
: mul 0000.0090 {cond/s} amode-mul ; : mla 0020.0090 {cond/s} amode-mla ; @@ -988,7 +1001,7 @@ get-register >r ( r: adr? reg# ) get-immediate r> r> rot ( reg# adr? addr|imm ) 2dup swap if ( reg# adr? addr|imm addr|imm ) - here >offset ( reg# adr? addr|imm offset|imm ) + here >offset ( reg# adr? addr|imm offset ) then dup fits? if ( reg# adr? addr|imm offset|imm ) 2drop if @@ -1004,7 +1017,11 @@ true asm-const ( reg# op ) then else ( reg# imm imm ) - drop false asm-const ( reg# op ) + 0 1.0000 within if ( reg# imm ) + set-imm16 0300.0000 ( reg# op ) \ movw rN,#<imm16> + else ( reg# imm ) + false asm-const ( reg# op ) + then then ( reg# op ) then ( reg# op ) iop rd-field !op
Modified: cpu/arm/disassem.fth ============================================================================== --- cpu/arm/disassem.fth Fri Jan 21 01:10:53 2011 (r2134) +++ cpu/arm/disassem.fth Fri Jan 21 01:12:35 2011 (r2135) @@ -245,10 +245,16 @@ d#24 bit? 0= 5 2 bits 0= and if .alu-ext else .ld/st-ext then ;
+: .movw ( -- ) \ movw rN,#imm + ." movw" {<cond>} op.rd, ." #" + d# 16 4bits d# 12 << 0 d# 12 bits or u.h +; + \ Stop after changing PC : ?pc-change ( -- ) d# 12 4bits d# 15 = end-found ! ;
: .alu-op ( -- ) \ d# 25 3 bits 0|1 = + d#20 8bits h# 30 = if .movw exit then d#25 bit? 0= d# 4 bit? and d# 7 bit? and if .ext exit then alu# h# d and h# d = if \ Moves .alu {s} op.rd, .r/imm
