Author: wmb Date: Thu Nov 15 23:22:25 2012 New Revision: 3434 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3434
Log: OLPC XO-4 - added support for new SD_PWROFF and SD_1.8VSEL GPIOs
Modified: cpu/arm/olpc/cl4/gpiopins.fth cpu/arm/olpc/cl4/sdhci.fth cpu/arm/olpc/sdhci.fth
Modified: cpu/arm/olpc/cl4/gpiopins.fth ============================================================================== --- cpu/arm/olpc/cl4/gpiopins.fth Thu Nov 15 22:40:18 2012 (r3433) +++ cpu/arm/olpc/cl4/gpiopins.fth Thu Nov 15 23:22:25 2012 (r3434) @@ -72,3 +72,6 @@
d# 15 constant rotate-gpio# d# 17 constant check-gpio# + +d# 115 constant sd-pwroff-gpio# +d# 116 constant sd-1.8vsel-gpio#
Modified: cpu/arm/olpc/cl4/sdhci.fth ============================================================================== --- cpu/arm/olpc/cl4/sdhci.fth Thu Nov 15 22:40:18 2012 (r3433) +++ cpu/arm/olpc/cl4/sdhci.fth Thu Nov 15 23:22:25 2012 (r3434) @@ -13,6 +13,8 @@ d# 40 encode-int 1 encode-int encode+ " power-delay-ms" property \ Active low " /gpio" encode-phandle d# 31 encode-int encode+ 1 encode-int encode+ " cd-gpios" property + \ Active low + " /gpio" encode-phandle sd-pwroff-gpio# encode-int encode+ 1 encode-int encode+ " power-gpios" property
\ MMP3 0 0 " wp-inverted" property
Modified: cpu/arm/olpc/sdhci.fth ============================================================================== --- cpu/arm/olpc/sdhci.fth Thu Nov 15 22:40:18 2012 (r3433) +++ cpu/arm/olpc/sdhci.fth Thu Nov 15 23:22:25 2012 (r3434) @@ -59,6 +59,8 @@ [ifdef] en-wlan-pwr-gpio# base-addr h# d428.0800 = if en-wlan-pwr-gpio# gpio-set then [then] +[ifdef] sd-pwroff-gpio# + base-addr h# d428.0000 = if sd-pwroff-gpio# gpio-clr then [then] ; ' gpio-power-on to card-power-on @@ -73,6 +75,9 @@ [ifdef] en-wlan-pwr-gpio# base-addr h# d428.0800 = if en-wlan-pwr-gpio# gpio-clr then [then] +[ifdef] sd-pwroff-gpio# + base-addr h# d428.0000 = if sd-pwroff-gpio# gpio-set then +[then] sdhci-card-power-off ; ' gpio-power-off to card-power-off
