Author: wmb Date: 2009-08-05 05:25:58 +0200 (Wed, 05 Aug 2009) New Revision: 1274
Added: cpu/x86/firfilter.fth Log: Added firfilter.fth, an FIR upsampling filter.
Added: cpu/x86/firfilter.fth =================================================================== --- cpu/x86/firfilter.fth (rev 0) +++ cpu/x86/firfilter.fth 2009-08-05 03:25:58 UTC (rev 1274) @@ -0,0 +1,156 @@ +purpose: FIR polyphase digital 6x upsampling filter + +d# 15 constant mulscale \ Bits for fractional multipliers + +\ Upsample, expanding one input sample to #phases output samples +\ outptr - where to put the output samples; updated to the next location +\ stride - the distance between successive input samples - 2 for mono, 4 for stereo +\ inptr - pointer into array of input samples +\ weights - pointer to filter weights, sorted by phase +\ taps/phase - the number of filter taps per phase +\ #phases - the number of filter phases, equal to the upsampling ratio + +code fir-upsample ( outptr stride inptr weights taps/phase #phases -- outptr' stride ) + \ 20 16 12 08 04 00 + \ 24 20 16 12 08 04 00:DI + + d# 08 [sp] si xchg \ SI: weights (old value stored on stack) + di push \ Save DI + + begin + d# 16 [sp] bx mov \ BX: inptr + di di xor \ Accumulator + + d# 08 [sp] cx mov \ taps/phase + begin + op: 0 [bx] ax mov + cwde + 0 [si] imul + 4 [si] si lea \ Update weight pointer + mulscale # dx ax shrd \ Scale down by multiplier scale factor + ax di add \ Accumulate + + d# 20 [sp] bx sub \ Update inbuf ptr + loopa + + di ax mov + + \ Saturate + d# 32767 # ax cmp > if + d# 32767 # ax mov + else + d# -32767 # ax cmp < if + d# -32767 # ax mov + then + then + + d# 24 [sp] di mov \ Output pointer + op: ax stos \ Store output value + di d# 24 [sp] mov \ Update output pointer + + d# 04 [sp] dec \ Phase counter + 0= until + + di pop \ Restore DI + d# 08 [sp] si mov \ Restore SI + d# 16 [sp] sp lea \ Remove stuff from stack +c; + +\ Convert a decimal fraction to a scaled integer multiplier +: mul: ( "coef" -- ) + safe-parse-word push-decimal $number drop pop-base ( n ) + 1 mulscale lshift d# 1,000,000,000 */ ( n' ) + , +; + +\ Filter coefficients for 6x upsampling. The following filter was +\ computed with GNU Octave, using the program shown at the end of this file. +\ The coeeficients are ordered by phase for easy addressing in the inner loop. +\ The transition band is centered on Fs/6. The stopband attenuation is 78dB. +\ The -3dB point is about 95% of Fs/6. + +d# 6 constant #phases +d# 16 constant taps/phase + +create weights +\ Phase 0 +mul: 0.000190788 mul: 0.000375061 mul: -0.001237886 mul: 0.003214694 +mul: -0.007235622 mul: 0.015062052 mul: -0.031397096 mul: 0.080446668 +mul: 0.976279469 mul: -0.074732552 mul: 0.034801841 mul: -0.018817755 +mul: 0.010022601 mul: -0.004881022 mul: 0.002025107 mul: -0.000631880 + +\ Phase 1 +mul: -0.000511063 mul: 0.001786043 mul: -0.005327045 mul: 0.012716422 +mul: -0.026661852 mul: 0.052425455 mul: -0.105580171 mul: 0.283737941 +mul: 0.885823376 mul: -0.166749609 mul: 0.078608864 mul: -0.041296857 +mul: 0.021106533 mul: -0.009784496 mul: 0.003821226 mul: -0.001092645 + +\ Phase 2 +mul: -0.000795594 mul: 0.003214599 mul: -0.009060710 mul: 0.020831489 +mul: -0.042537000 mul: 0.082398233 mul: -0.167272365 mul: 0.508384704 +mul: 0.720544802 mul: -0.194040773 mul: 0.093827768 mul: -0.048873931 +mul: 0.024446032 mul: -0.010977550 mul: 0.004090325 mul: -0.001079175 + +\ Phase 3 +mul: -0.001079175 mul: 0.004090325 mul: -0.010977550 mul: 0.024446032 +mul: -0.048873931 mul: 0.093827768 mul: -0.194040773 mul: 0.720544802 +mul: 0.508384704 mul: -0.167272365 mul: 0.082398233 mul: -0.042537000 +mul: 0.020831489 mul: -0.009060710 mul: 0.003214599 mul: -0.000795594 + +\ Phase 4 +mul: -0.001092645 mul: 0.003821226 mul: -0.009784496 mul: 0.021106533 +mul: -0.041296857 mul: 0.078608864 mul: -0.166749609 mul: 0.885823376 +mul: 0.283737941 mul: -0.105580171 mul: 0.052425455 mul: -0.026661852 +mul: 0.012716422 mul: -0.005327045 mul: 0.001786043 mul: -0.000511063 + +\ Phase 5 +mul: -0.000631880 mul: 0.002025107 mul: -0.004881022 mul: 0.010022601 +mul: -0.018817755 mul: 0.034801841 mul: -0.074732552 mul: 0.976279469 +mul: 0.080446668 mul: -0.031397096 mul: 0.015062052 mul: -0.007235622 +mul: 0.003214694 mul: -0.001237886 mul: 0.000375061 mul: 0.000190788 + +taps/phase 2* /n* buffer: zbuf + +\ Stride is 2 for mono, 4 for stereo +\ For stereo you must call it twice with an offset of 2 for +\ inbuf and outbuf on the second call +: 8khz>48khz ( inbuf /inbuf outbuf stride -- ) + 2swap ( outbuf stride inbuf /inbuf ) + + \ First compute half a phase worth of samples with leading zeros + 2 pick taps/phase * >r ( outbuf stride inbuf /inbuf r: span ) + zbuf r@ 2/ erase ( outbuf stride inbuf /inbuf ) + + over zbuf r@ 2/ + r@ move ( outbuf stride inbuf /inbuf ) + r@ /string ( outbuf stride inbuf' /inbuf' ) + + 2swap zbuf r@ + r@ 2/ bounds ?do ( inbuf /inbuf outbuf stride ) + i weights taps/phase #phases fir-upsample ( inbuf /inbuf outbuf' strid ) + dup +loop ( inbuf /inbuf outbuf stride ) + + \ Compute the bulk of the samples where the filter taps fit entirely + \ within the input buffer + 2over bounds ?do ( inbuf /inbuf outbuf stride ) + i weights taps/phase #phases fir-upsample ( inbuf /inbuf outbuf' stride ) + dup +loop ( inbuf /inbuf outbuf stride ) + + \ Finally compute half a phase worth of samples with trailing zeros + 2swap ( outbuf stride inbuf /inbuf ) + + r@ - zbuf r@ move ( outbuf stride ) + zbuf r@ + r@ 2/ erase ( outbuf stride ) + zbuf r@ + r@ 2/ bounds ?do ( outbuf stride ) + i weights taps/phase #phases fir-upsample ( outbuf' stride ) + dup +loop ( outbuf stride ) + + r> 3drop ( ) +; + +0 [if] +\ Here is some Matlab/Octave code to compute the weights +weights = remez(95, [0 .12 .215 1], [1 1 0 0]); +for phase=1:6 + for tap=1:16 + printf("mul: %.9f ", 5.9 * weights((tap-1)*6+phase)); + end +end +[then]
