Author: wmb Date: 2008-09-30 23:28:10 +0200 (Tue, 30 Sep 2008) New Revision: 957
Modified: cpu/x86/pc/biosload/config.fth Log: Biosload build - configure for VirtualBox.
Modified: cpu/x86/pc/biosload/config.fth =================================================================== --- cpu/x86/pc/biosload/config.fth 2008-09-30 21:27:00 UTC (rev 956) +++ cpu/x86/pc/biosload/config.fth 2008-09-30 21:28:10 UTC (rev 957) @@ -3,13 +3,13 @@
\ create pc \ Demo version for generic PC \ create pc-linux \ Demo version for generic PC and Linux -create pc-serial \ Demo version for generic PC +\ create pc-serial \ Demo version for generic PC
\ --- The environment that "boots" OFW --- \ - Image Format - Example Media - previous stage bootloader
\ - (Syslinux) COM32 format - USB Key w/ FAT FS - Syslinux -create syslinux-loaded +\ create syslinux-loaded
\ - Linux kernel format - USB Key w/ FAT FS - LinuxBIOS w/ stripped Linux payload \ create bzimage-loaded @@ -24,6 +24,9 @@ \ Load and run in qemu \ create qemu-loaded
+\ Load and run in VirtualBox +create virtualbox-loaded + \ Load from ROM by preOF code from Intel \ create preof-loaded
@@ -32,10 +35,28 @@ create pc [then]
-[ifdef] qemu-loaded \ LinuxBIOS+OFW under QEMU currently doesn't do VGA right +[ifdef] qemu-loaded \ LinuxBIOS+OFW under QEMU currently does not do VGA right create serial-console [then]
+[ifdef] virtualbox-loaded +\ create debug-startup +\ create serial-console +create resident-packages +create addresses-assigned \ Don't reassign PCI addresses +\ create virtual-mode +\ create use-root-isa +create use-timestamp-counter +create use-pci-isa +create use-isa-ide +create use-ega +create use-elf +\ create use-ne2000 +create use-watch-all +create use-null-nvram +\ create no-floppy-node +[then] + [ifdef] etherboot-variant create debug-startup create serial-console @@ -51,7 +72,7 @@ \ and physical addresses.
\ Here we use virtual mode for Linux, so that we can debug past -\ the point where Linux starts using the MMU. It isn't strictly +\ the point where Linux starts using the MMU. It is not strictly \ necessary to use virtual mode if you just want to boot Linux \ and then have OFW disappear. create virtual-mode @@ -89,6 +110,7 @@ [then]
fload ${BP}/cpu/x86/pc/biosload/addrs.fth + \ LICENSE_BEGIN \ Copyright (c) 2006 FirmWorks \
