Author: wmb Date: Sat Oct 1 19:45:39 2011 New Revision: 2558 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2558
Log: OLPC XO-1 - Changed camera driver to use the shared common code for the Omnivision sensor and the selftest infrastructure.
Added: dev/olpc/cafecamera/platform.fth Modified: dev/olpc/cafecamera/cafecamera.bth dev/olpc/cafecamera/cafecamera.fth
Modified: dev/olpc/cafecamera/cafecamera.bth ============================================================================== --- dev/olpc/cafecamera/cafecamera.bth Sat Oct 1 19:44:26 2011 (r2557) +++ dev/olpc/cafecamera/cafecamera.bth Sat Oct 1 19:45:39 2011 (r2558) @@ -9,7 +9,10 @@
FCode-version2
+fload ${BP}/dev/olpc/cafecamera/platform.fth +fload ${BP}/dev/olpc/ov7670.fth fload ${BP}/dev/olpc/cafecamera/cafecamera.fth +fload ${BP}/dev/olpc/cameratest.fth
end0
Modified: dev/olpc/cafecamera/cafecamera.fth ============================================================================== --- dev/olpc/cafecamera/cafecamera.fth Sat Oct 1 19:44:26 2011 (r2557) +++ dev/olpc/cafecamera/cafecamera.fth Sat Oct 1 19:45:39 2011 (r2558) @@ -1,331 +1,6 @@ \ See license at end of file purpose: Driver for the CMOS camera
-headers -hex - -" camera" device-name -" olpc,camera" model -" camera" device-type -" olpc,camera" " compatible" string-property -" OV7670" " sensor" string-property - -h# 4000 constant /regs - -my-address my-space encode-phys - 0 encode-int encode+ h# 0 encode-int encode+ - -my-address my-space h# 200.0010 + encode-phys encode+ - 0 encode-int encode+ /regs encode-int encode+ - -" reg" property - - -: my-w@ ( offset -- w ) my-space + " config-w@" $call-parent ; -: my-w! ( w offset -- ) my-space + " config-w!" $call-parent ; - -0 instance value chip - -: cl! ( l adr -- ) chip + rl! ; -: cl@ ( adr -- l ) chip + rl@ ; - -: map-regs ( -- ) - 0 0 h# 0200.0010 my-space + /regs " map-in" $call-parent to chip - 4 my-w@ 6 or 4 my-w! -; - -: unmap-regs ( -- ) - chip /regs " map-out" $call-parent -\ 4 my-w@ 6 invert and 4 my-w! \ No need to turn it off -; - -\ ======================= OV7670 SMBUS operations ========================== - -\ cafe_smbus_xfer - -h# 42 2 << constant ov-sid - -: clr-smb-intr ( -- ) 7.0000 30 cl! ; -: smbus-wait ( -- ) - begin 28 cl@ 7.0000 and until - 1 ms \ 20 usec delay -; - -: ov@ ( reg -- data ) - clr-smb-intr - ov-sid 87.fc01 or b8 cl! \ TWSI control 0: id, 8-bit, clk - bc cl@ drop \ Force write - d# 16 << 100.0000 or bc cl! \ TWSI control 1: read, reg - smbus-wait - bc cl@ ff and -; - -: ov! ( data reg -- ) - clr-smb-intr - ov-sid 8.7fc01 or b8 cl! \ TWSI control 0: id, 8-bit, clk - bc cl@ drop \ Force write - d# 16 << or bc cl! \ TWSI control 1: read, reg - 2 ms - smbus-wait - bc cl@ drop -; - -: ovc ( val adr -- ) - 2dup ov@ ( val reg# val actual ) - tuck <> if ( val reg# actual ) - ." Bad camera I2C value at " swap 2 u.r ( val actual ) - ." expected " swap 2 u.r ." got " 2 u.r cr ( ) - else ( val reg# actual ) - 3drop ( ) - then ( ) -; - -\ ============================= camera operations ============================= - -false value ov7670-detected? - -: ((camera-init) ( -- ) - 80 12 ov! \ reset (reads back different) - 01 11 ov! \ 30 fps - 04 3a ov! \ UYVY or VYUY - 00 12 ov! \ VGA - - \ Hardware window - 13 17 ov! \ Horiz start high bits - 01 18 ov! \ Horiz stop high bits - b6 32 ov! \ HREF pieces - 0a 19 ov! \ Vert start high bits - 7a 1a ov! \ Vert stop high bits - 0a 03 ov! \ GAIN, VSTART, VSTOP pieces - - \ Mystery scaling numbers - 00 0c ov! \ Control 3 - 00 3e ov! \ Control 14 - 3a 70 ov! 35 71 ov! 11 72 ov! f0 73 ov! - 02 a2 ov! - 00 15 ov! \ Control 10 - - \ Gamma curve values - 20 7a ov! 10 7b ov! 1e 7c ov! 35 7d ov! - 5a 7e ov! 69 7f ov! 76 80 ov! 80 81 ov! - 88 82 ov! 8f 83 ov! 96 84 ov! a3 85 ov! - af 86 ov! c4 87 ov! d7 88 ov! e8 89 ov! - - \ AGC and AEC parameters - e0 13 ov! \ Control 8 - 00 00 ov! \ Gain lower 8 bits - 40 0d ov! \ Control 4 magic reserved bit - 18 14 ov! \ Control 9: 4x gain + magic reserved bit - 05 a5 ov! \ 50hz banding step limit - 07 ab ov! \ 60hz banding step limit - 95 24 ov! \ AGC upper limit - 33 25 ov! \ AGC lower limit - e3 24 ov! \ AGC/AEC fast mode op region - 78 9f ov! \ Hist AEC/AGC control 1 - 68 a0 ov! \ Hist AEC/AGC control 2 - 03 a1 ov! \ Magic - d8 a6 ov! \ Hist AEC/AGC control 3 - d8 a7 ov! \ Hist AEC/AGC control 4 - f0 a8 ov! \ Hist AEC/AGC control 5 - 90 a9 ov! \ Hist AEC/AGC control 6 - 94 aa ov! \ Hist AEC/AGC control 7 - e5 13 ov! \ Control 8 - - \ Mostly magic - 61 0e ov! 4b 0f ov! 02 16 ov! 07 1e ov! - 02 21 ov! 91 22 ov! 07 29 ov! 0b 33 ov! - 0b 35 ov! 1d 37 ov! 71 38 ov! 2a 39 ov! - 78 3c ov! 40 4d ov! 20 4e ov! 00 69 ov! - 4a 6b ov! 10 74 ov! 4f 8d ov! 00 8e ov! - 00 8f ov! 00 90 ov! 00 91 ov! 00 96 ov! - 00 9a ov! 84 b0 ov! 0c b1 ov! 0e b2 ov! - 82 b3 ov! 0a b8 ov! - - \ More magic, some of which tweaks white balance - 0a 43 ov! f0 44 ov! 34 45 ov! 58 46 ov! - 28 47 ov! 3a 48 ov! 88 59 ov! 88 5a ov! - 44 5b ov! 67 5c ov! 49 5d ov! 0e 5e ov! - 0a 6c ov! 55 6d ov! 11 6e ov! - 9f 6f ov! \ 9e for advance AWB - 40 6a ov! - 40 01 ov! \ Blue gain - 60 02 ov! \ Red gain - e7 13 ov! \ Control 8 - - \ Matrix coefficients - 80 4f ov! 80 50 ov! 00 51 ov! 22 52 ov! - 5e 53 ov! 80 54 ov! 9e 58 ov! - - 08 41 ov! \ AWB gain enable - 00 3f ov! \ Edge enhancement factor - 05 75 ov! e1 76 ov! 00 4c ov! 01 77 ov! - c3 3d ov! \ Control 13 - 09 4b ov! 60 c9 ov! \ Reads back differently - 38 41 ov! \ Control 16 - 40 56 ov! - - 11 34 ov! - 12 3b ov! \ Control 11 - 88 a4 ov! 00 96 ov! 30 97 ov! 20 98 ov! - 30 99 ov! 84 9a ov! 29 9b ov! 03 9c ov! - 5c 9d ov! 3f 9e ov! 04 78 ov! - - \ Extra-weird stuff. Some sort of multiplexor register - 01 79 ov! f0 c8 ov! - 0f 79 ov! 00 c8 ov! - 10 79 ov! 7e c8 ov! - 0a 79 ov! 80 c8 ov! - 0b 79 ov! 01 c8 ov! - 0c 79 ov! 0f c8 ov! - 0d 79 ov! 20 c8 ov! - 09 79 ov! 80 c8 ov! - 02 79 ov! c0 c8 ov! - 03 79 ov! 40 c8 ov! - 05 79 ov! 30 c8 ov! - 26 79 ov! - - \ OVT says that rewrite this works around a bug in 565 mode. - \ The symptom of the bug is red and green speckles in the image. - 01 11 ov! \ 30 fps def 80 -; - -: config-check ( -- ) - 01 11 ovc \ 30 fps - 04 3a ovc \ UYVY or VYUY - ( 00 12 ovc ) \ VGA - - \ Hardware window - 13 17 ovc \ Horiz start high bits - 01 18 ovc \ Horiz stop high bits - b6 32 ovc \ HREF pieces - ( 0a 19 ovc ) \ Vert start high bits - 7a 1a ovc \ Vert stop high bits - 0a 03 ovc \ GAIN, VSTART, VSTOP pieces - - \ Mystery scaling numbers - 00 0c ovc \ Control 3 - 00 3e ovc \ Control 14 - 3a 70 ovc 35 71 ovc 11 72 ovc f0 73 ovc - 02 a2 ovc - 00 15 ovc \ Control 10 - - \ Gamma curve values - 20 7a ovc 10 7b ovc 1e 7c ovc 35 7d ovc - 5a 7e ovc 69 7f ovc 76 80 ovc 80 81 ovc - 88 82 ovc 8f 83 ovc 96 84 ovc a3 85 ovc - af 86 ovc c4 87 ovc d7 88 ovc e8 89 ovc - - \ AGC and AEC parameters - ( e0 13 ovc ) \ Control 8 - ( 00 00 ovc ) \ Gain lower 8 bits - 40 0d ovc \ Control 4 magic reserved bit - ( 18 14 ovc ) \ Control 9: 4x gain + magic reserved bit - 05 a5 ovc \ 50hz banding step limit - 07 ab ovc \ 60hz banding step limit - ( 95 24 ovc ) \ AGC upper limit - 33 25 ovc \ AGC lower limit - e3 24 ovc \ AGC/AEC fast mode op region - 78 9f ovc \ Hist AEC/AGC control 1 - 68 a0 ovc \ Hist AEC/AGC control 2 - 03 a1 ovc \ Magic - d8 a6 ovc \ Hist AEC/AGC control 3 - d8 a7 ovc \ Hist AEC/AGC control 4 - f0 a8 ovc \ Hist AEC/AGC control 5 - 90 a9 ovc \ Hist AEC/AGC control 6 - 94 aa ovc \ Hist AEC/AGC control 7 - ( e5 13 ovc ) \ Control 8 - - \ Mostly magic - 61 0e ovc 4b 0f ovc 02 16 ovc 07 1e ovc - 02 21 ovc 91 22 ovc 07 29 ovc 0b 33 ovc - 0b 35 ovc 1d 37 ovc 71 38 ovc 2a 39 ovc - 78 3c ovc 40 4d ovc 20 4e ovc 00 69 ovc - 4a 6b ovc 10 74 ovc 4f 8d ovc 00 8e ovc - 00 8f ovc 00 90 ovc 00 91 ovc 00 96 ovc - ( 00 9a ovc ) 84 b0 ovc 0c b1 ovc 0e b2 ovc - 82 b3 ovc 0a b8 ovc - - \ More magic, some of which tweaks white balance - 0a 43 ovc f0 44 ovc 34 45 ovc 58 46 ovc - 28 47 ovc 3a 48 ovc 88 59 ovc 88 5a ovc - 44 5b ovc 67 5c ovc 49 5d ovc 0e 5e ovc - 0a 6c ovc 55 6d ovc 11 6e ovc - 9f 6f ovc \ 9e for advance AWB - ( 40 6a ovc ) - ( 40 01 ovc ) \ Blue gain - ( 60 02 ovc ) \ Red gain - e7 13 ovc \ Control 8 - - \ Matrix coefficients - b3 4f ovc b3 50 ovc 00 51 ovc 3d 52 ovc - a7 53 ovc e4 54 ovc 9e 58 ovc - - \ 08 41 ovc \ AWB gain enable - ( 00 3f ovc ) \ Edge enhancement factor - 05 75 ovc e1 76 ovc ( 00 4c ovc ) 01 77 ovc - c0 3d ovc \ Control 13 - 09 4b ovc ( 60 c9 ovc ) - 38 41 ovc \ Control 16 - 40 56 ovc - - 11 34 ovc - 12 3b ovc \ Control 11 - 88 a4 ovc 00 96 ovc 30 97 ovc 20 98 ovc - 30 99 ovc 84 9a ovc 29 9b ovc 03 9c ovc - 5c 9d ovc 3f 9e ovc 04 78 ovc - -; - -: camera-init ( -- ) - false to ov7670-detected? - ((camera-init) - 1d ov@ 1c ov@ bwjoin 7fa2 <> if exit then \ Manufacturing ID - b ov@ a ov@ bwjoin 7673 <> if exit then \ Product ID - true to ov7670-detected? -; - -\ VGA RGB565 -: init-rgb565 ( -- ) - 04 12 ov! \ VGA, RGB565 - 00 8c ov! \ No RGB444 - 00 04 ov! \ Control 1 - 10 40 ov! \ RGB565 output - 38 14 ov! \ 16x gain ceiling - b3 4f ov! \ v-red - b3 50 ov! \ v-green - 00 51 ov! \ v-blue - 3d 52 ov! \ u-red - a7 53 ov! \ u-green - e4 54 ov! \ u-blue - c0 3d ov! \ Gamma enable, UV saturation auto adjust -; - -: read-agc ( -- n ) - 3 ov@ h# c0 and 2 lshift 0 ov@ or -; - -: read-aec ( -- n ) - 7 ov@ h# 3f and d# 10 lshift - h# 10 ov@ 2 lshift or - 4 ov@ 3 and or -; - -: set-hw ( vstop vstart hstop hstart -- ) - dup 3 >> 17 ov! \ Horiz start high bits - over 3 >> 18 ov! \ Horiz stop high bits - 32 ov@ swap 7 and or swap 7 and 3 << or 10 ms 32 ov! \ Horiz bottom bits - - dup 2 >> 19 ov! \ Vert start high bits - over 2 >> 1a ov! \ Vert start high bits - 03 ov@ swap 3 and or swap 3 and 2 << or 10 ms 03 ov! \ Vert bottom bits -; - -: camera-config ( -- ) - ((camera-init) - init-rgb565 - d# 490 d# 10 d# 14 d# 158 set-hw \ VGA window info -; - \ ============================= cafe operations ==============================
d# 640 constant VGA_WIDTH @@ -444,15 +119,21 @@ 0 value buf-mask 0 value buf-act : /string ( adr len n -- adr' len' ) tuck - -rot + swap ; + +\ Advance next-buf - modulo #dma-bufs - by the number of bits set in buf-mask : +next-buf ( buf-mask -- ) 0 swap ( cnt buf-mask ) - 3 0 do dup 1 and rot + swap 1 >> loop drop - next-buf + #dma-bufs mod to next-buf + #dma-bufs 0 do ( cnt buf-mask ) + dup 1 and ( cnt buf-mask bit ) + rot + ( buf-mask cnt' ) + swap 1 >> ( cnt buf-mask' ) + loop drop ( cnt ) + next-buf + #dma-bufs mod to next-buf ( ) ; : buf-done? ( -- buf-mask ) 28 cl@ 2f 30 cl! 7 and ; -: read-buf ( adr len i -- adr' len' ) +: read-buf ( adr len buf# -- adr' len' ) 1 over << buf-mask and 0= if drop exit then - ( adr len i ) + ( adr len buf# ) 'dma-buf 2 pick 2 pick ( adr len dma-buf adr len ) /dma-buf min dup >r move r> ( adr len len' ) buf-act over + to buf-act ( adr len len' ) @@ -469,12 +150,60 @@ buf-mask +next-buf ;
+0 value snap-next-buf +: snap-buf-done? ( -- false | buf true ) + 1 snap-next-buf lshift ( bitmask ) + dup h# 28 cl@ and if ( bitmask ) + h# 38 or h# 30 cl! ( ) \ Clear interrupts + snap-next-buf dup 1+ #dma-bufs mod to snap-next-buf ( buf# ) + 'dma-buf true ( buf true ) + else ( bitmask ) + drop false ( flag ) + then +; + +: resync ( -- ) + \ Wait for the current frame to be ready + begin snap-buf-done? until drop + + \ Ack any buffers that are already ready + begin snap-buf-done? while drop repeat + + \ Now when the next buffer is ready, it will be fresh +; + +\ Clear out any stale buffers +: xresync ( -- ) + \ Ack pending end-of-frames until there are none + begin h# 28 cl@ 7 and dup while h# 30 cl! repeat drop + + \ Now wait for a frame to become ready and set snap-next-buf to point to it + begin h# 28 cl@ 7 and dup 0= while drop repeat ( mask ) + 3 0 do + dup 1 and if + i to snap-next-buf + unloop exit + then + 2/ + loop + 0 to snap-next-buf +; + external : write ( adr len -- actual ) 2drop 0 ;
: read ( adr len -- actual ) buf-done? ?dup if (read) else 2drop 0 then ; +: snap ( timeout -- true | buf false ) + 0 do + snap-buf-done? if ( buf ) + false unloop exit ( -- buf false ) + then + 1 ms + loop + true +;
: open ( -- flag ) map-regs @@ -492,93 +221,13 @@ unmap-regs ;
-\ ============================= selftest operation =========================== - -d# 10,000 constant movie-time -0 constant test-x -0 constant test-y - -\ Thanks to Cortland Setlow (AKA Blaketh) for the autobrightness code -\ and the full-screen + mirrored display. - -: autobright ( -- ) - read-agc 3 + 3 rshift h# f min " bright!" " $call-screen" evaluate -; -: full-brightness ( -- ) h# f " bright!" " $call-screen" evaluate ; - -: display-frame ( adr -- ) -\ test-x test-y VGA_WIDTH VGA_HEIGHT " draw-rectangle" " $call-screen" evaluate +: display-frame ( buf -- ) " expand-to-screen" " $call-screen" evaluate -\ autobright -; - -: timeout-read ( adr len timeout -- actual ) - >r 0 -rot r> 0 ?do ( actual adr len ) - 2dup read ?dup if 3 roll drop -rot leave then - 1 ms - loop 2drop -; - -: shoot-movie ( -- error? ) - /dma-buf #dma-bufs * dup dma-alloc swap ( adr len ) - get-msecs movie-time + -rot ( timeout adr len ) - begin - 2dup read ?dup 0> if ( timeout adr len actual ) - VGA_WIDTH VGA_HEIGHT * 2* / 0 ?do over display-frame loop - else - 1 ms - then ( timeout adr len ) - get-msecs 3 pick u> - until ( timeout adr len ) - dma-free drop false ( error? ) -; - -: shoot-still ( -- error? ) - /dma-buf dup dma-alloc tuck ( adr len adr ) - /dma-buf d# 1,000 timeout-read 0> if ( adr len ) - over display-frame - false - else - true - then ( adr len error? ) - -rot dma-free ( error? ) -; - -: mirrored ( -- ) h# 1e ov@ h# 20 or h# 1e ov! ; -: unmirrored ( -- ) h# 1e ov@ h# 20 invert and h# 1e ov! ; - -: selftest ( -- error? ) - open 0= if true exit then - unmirrored shoot-still ?dup if close exit then ( error? ) - d# 1,000 ms - mirrored shoot-movie full-brightness ( error? ) - close ( error? ) -; - -: dump-regs ( run# -- ) - 0 d# 16 " at-xy" eval - ." Pass " .d - key upc h# 47 = if ." Good" else ." Bad" then cr \ 47 is G - - ." 0 1 2 3 4 5 6 7 8 9 a b c d e f" cr - ." -----------------------------------------------" cr - h# ca 0 do - i 2 u.r ." : " - i h# 10 bounds do - i h# ca < if i ov@ 3 u.r then - loop - cr - h# 10 +loop -; - -: xselftest ( -- error? ) - open 0= if true exit then - h# 10 0 do - shoot-still drop d# 500 ms camera-config config-check - i dump-regs - loop - 0 close ( error? ) +\ test-x test-y VGA_WIDTH VGA_HEIGHT " draw-rectangle" " $call-screen" evaluate ; +: start-display ( -- ) ; +: stop-display ( -- ) ; +false constant camera-blocked?
\ Do this at probe time to make sure the camera power is off map-regs
Added: dev/olpc/cafecamera/platform.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ dev/olpc/cafecamera/platform.fth Sat Oct 1 19:45:39 2011 (r2558) @@ -0,0 +1,94 @@ +\ See license at end of file +purpose: Platform specifics for OLPC Camera on XO-1 + +headers +hex + +" camera" device-name +" olpc,camera" model +" camera" device-type +" olpc,camera" " compatible" string-property + +h# 4000 constant /regs + +my-address my-space encode-phys + 0 encode-int encode+ h# 0 encode-int encode+ + +my-address my-space h# 200.0010 + encode-phys encode+ + 0 encode-int encode+ /regs encode-int encode+ + +" reg" property + +: my-w@ ( offset -- w ) my-space + " config-w@" $call-parent ; +: my-w! ( w offset -- ) my-space + " config-w!" $call-parent ; + +0 instance value chip + +: cl! ( l adr -- ) chip + rl! ; +: cl@ ( adr -- l ) chip + rl@ ; + +: map-regs ( -- ) + 0 0 h# 0200.0010 my-space + /regs " map-in" $call-parent to chip + 4 my-w@ 6 or 4 my-w! +; + +: unmap-regs ( -- ) + chip /regs " map-out" $call-parent +\ 4 my-w@ 6 invert and 4 my-w! \ No need to turn it off +; + +h# 42 2 << constant ov-sid + +: clr-smb-intr ( -- ) 7.0000 30 cl! ; +: smbus-wait ( -- ) + begin 28 cl@ 7.0000 and until + 1 ms \ 20 usec delay +; + +: ov@ ( reg -- data ) + clr-smb-intr + ov-sid 87.fc01 or b8 cl! \ TWSI control 0: id, 8-bit, clk + bc cl@ drop \ Force write + d# 16 << 100.0000 or bc cl! \ TWSI control 1: read, reg + smbus-wait + bc cl@ ff and +; + +: ov! ( data reg -- ) + clr-smb-intr + ov-sid 8.7fc01 or b8 cl! \ TWSI control 0: id, 8-bit, clk + bc cl@ drop \ Force write + d# 16 << or bc cl! \ TWSI control 1: read, reg + 2 ms + smbus-wait + bc cl@ drop +; + +\ This must be headerless so evaluate won't find this version +headerless +: confirm-selftest? ( -- flag ) " confirm-selftest?" evaluate ; +headers + +\ LICENSE_BEGIN +\ Copyright (c) 2011 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
