[commit] r3261 - cpu/arm/olpc
Author: wmb Date: Fri Aug 31 02:22:54 2012 New Revision: 3261 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3261 Log: Fixed a commentary typo in the previous checkin. Modified: cpu/arm/olpc/gpio-i2c.fth Modified: cpu/arm/olpc/gpio-i2c.fth ============================================================================== --- cpu/arm/olpc/gpio-i2c.fth Fri Aug 31 02:22:06 2012 (r3260) +++ cpu/arm/olpc/gpio-i2c.fth Fri Aug 31 02:22:54 2012 (r3261) @@ -49,8 +49,8 @@ cam-sda-gpio# to smb-data-gpio# slave-address to smb-slave ; - \ Since this I2C bus is dedicated to the DCON, we save space by - \ implementing only the methods that the DCON uses + \ Since this I2C bus is dedicated to the camera sensor, we save space by + \ implementing only the methods that the sensor uses : reg-b@ ( reg# -- b ) smb-setup smb-byte@ ; : reg-b! ( b reg# -- ) smb-setup smb-byte! ; : open ( -- flag ) true ;
participants (1)
repository service
