[commit] r2504 - cpu/arm/olpc/1.75
Author: wmb Date: Fri Sep 9 03:48:38 2011 New Revision: 2504 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2504 Log: OLPC XO-1.75 - automatically pull and build cforth in a subdirectory of the OFW build directory. Added: cpu/arm/olpc/1.75/cforth-version.fth cpu/arm/olpc/1.75/cforth.bth Modified: cpu/arm/olpc/1.75/olpc.bth Added: cpu/arm/olpc/1.75/cforth-version.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/1.75/cforth-version.fth Fri Sep 9 03:48:38 2011 (r2504) @@ -0,0 +1,15 @@ +\ This file controls which CForth source version to include in the OFW build +\ and the method for fetching it + +\ If CFORTH_VERSION is "modify", the repository will be cloned with git+ssh: so can push changes. +\ You need ssh access to the server. +\ macro: CFORTH_VERSION modify + +\ If CFORTH_VERSION is "clone", the repository will be cloned with git:. You won't be able to +\ push changes, but you will get the full metadata so you can use commands like git grep. +\ You don't need ssh access to the server. +\ macro: CFORTH_VERSION clone + +\ Otherwise, the source code will be will be downloaded as a tarball via gitweb. +\ macro: CFORTH_VERSION 59859f04454bc2574ab68cf0fd76ebdbc5f26fb6 +macro: CFORTH_VERSION HEAD Added: cpu/arm/olpc/1.75/cforth.bth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/1.75/cforth.bth Fri Sep 9 03:48:38 2011 (r2504) @@ -0,0 +1,42 @@ +purpose: Fetch and compile CForth for the Security Processor + +command: &builder &this +build-now + +fload ${BP}/cpu/arm/olpc/1.75/cforth-version.fth + +macro: CFORTH_BUILD_DIR cforth/build/arm-xo-1.75 + +\ Don't re-fetch the cforth source, thus preventing overwrites of development modifications. +\ If you change cforth-version.fth to specify a different cforth source version, you must +\ manually delete the old cforth subtree. + +" ${CFORTH_BUILD_DIR}/Makefile" expand$ $file-exists? 0= [if] + " ${CFORTH_VERSION}" expand$ " modify" $= [if] + " git clone -q git+ssh://dev.laptop.org/git/users/wmb/cforth" expand$ $sh + [else] + " ${CFORTH_VERSION}" expand$ " clone" $= [if] + " git clone -q git://dev.laptop.org/users/wmb/cforth" expand$ $sh + [else] + " wget -q -O - http://dev.laptop.org/git/users/wmb/cforth/snapshot/cforth-${CFORTH_VERSION}.tar.gz | tar xfz -" expand$ $sh + " mv cforth-${CFORTH_VERSION} cforth" expand$ $sh + " wget -q -O - http://dev.laptop.org/git/users/wmb/cforth/patch | head -1 | cut -f 2 -d ' ' >>${CFORTH_BUILD_DIR}/version" expand$ $sh + \ " echo -n const char cforth_version[] = '""' >${CFORTH_BUILD_DIR}/cforth_version.c" expand$ $sh + \ " wget -q -O - http://dev.laptop.org/git/users/wmb/cforth/patch | head -1 | cut -f 2 -d ' ' >>${CFORTH_BUILD_DIR}/cforth_version.c" expand$ $sh + \ " echo '"";' >>${CFORTH_BUILD_DIR}/cforth_version.c" expand$ $sh + [then] + [then] +[then] + +" (cd ${CFORTH_BUILD_DIR}; make --no-print-directory)" expand$ $sh + +\ If the above make changed either cforth.img or shim.img, copy the new one into this directory, +\ thus triggering a rebuild of the OFW .rom file + +" cforth.img" modtime " ${CFORTH_BUILD_DIR}/cforth.img" expand$ modtime < [if] + " (cp ${CFORTH_BUILD_DIR}/cforth.img .)" expand$ $sh +[then] + +" shim.img" modtime " ${CFORTH_BUILD_DIR}/shim.img" expand$ modtime < [if] + " (cp ${CFORTH_BUILD_DIR}/shim.img .)" expand$ $sh +[then] Modified: cpu/arm/olpc/1.75/olpc.bth ============================================================================== --- cpu/arm/olpc/1.75/olpc.bth Sat Sep 3 17:55:57 2011 (r2503) +++ cpu/arm/olpc/1.75/olpc.bth Fri Sep 9 03:48:38 2011 (r2504) @@ -15,6 +15,7 @@ in: ${BP}/dev/usb2/device/storage/build/usbstorage.fc in: testicons.bin in: ${BP}/clients/emacs/arm/emacs +in: cforth.img build-now fload ${BP}/cpu/arm/olpc/1.75/fw-version.fth @@ -48,8 +49,8 @@ \ Main Processor code loaded into DRAM image: OBMI 800 d101c000 ${BP}/cpu/arm/olpc/1.75/dummy.img \ Secure Processor code loaded into SRAM -image: WTMI 1000 d1018000 ${BP}/../cforth/build/arm-xo-1.75/shim.img -image: CFTH 2000 d1000000 ${BP}/../cforth/build/arm-xo-1.75/app.img +image: WTMI 1000 d1018000 shim.img +image: CFTH 2000 d1000000 cforth.img \ anonymous: 20000 ${BP}/cpu/arm/olpc/1.75/build/fw.img reserved: \ fload ${BP}/cpu/arm/olpc/1.75/ddr_samsung_1g.fth
participants (1)
repository service
