Author: wmb Date: 2009-05-14 09:44:05 +0200 (Thu, 14 May 2009) New Revision: 1189
Modified: clients/memtest86/init.c Log: memtest - added type detection for some more Via CPU types.
Modified: clients/memtest86/init.c =================================================================== --- clients/memtest86/init.c 2009-05-14 06:22:53 UTC (rev 1188) +++ clients/memtest86/init.c 2009-05-14 07:44:05 UTC (rev 1189) @@ -15,6 +15,7 @@ #include "pci.h" #include "io.h" #include "ega.h" +#include "msr.h"
extern short memsz_mode; extern short firmware; @@ -107,7 +108,7 @@ cprint(LINE_CPU+2, 0, "L2 Cache: Unknown "); cprint(LINE_CPU+3, 0, "Memory : "); aprint(LINE_CPU+3, 10, v->test_pages); - cprint(LINE_CPU+4, 0, "Chipset : "); +// cprint(LINE_CPU+4, 0, "Chipset : ");
/* * Need to find out CPU type before seting up pci. This is @@ -788,12 +789,34 @@ off = 12; break; case 6: // VIA C3 - if (cpu_id.step < 8) { - cprint(LINE_CPU, 0, "VIA C3 Samuel2"); - off = 14; - } else { - cprint(LINE_CPU, 0, "Via C3 Eden"); - off = 11; + { + unsigned long vall, valh, code; + rdmsr(0x1153, vall, valh); + code = ((vall >> 20) & 3) ^ ((vall >> 18) & 3); + switch (code) { + case 0: + cprint(LINE_CPU, 0, "VIA C7-M"); + off = 8; + break; + case 1: + cprint(LINE_CPU, 0, "VIA C7"); + off = 6; + break; + case 2: + if (cpu_id.step < 8) { + cprint(LINE_CPU, 0, "VIA C3 Samuel2"); + off = 14; + } else { + cprint(LINE_CPU, 0, "Via C3 Eden"); + off = 11; + } + break; + case 3: + cprint(LINE_CPU, 0, "VIA C7-D"); + off = 8; + break; + + } } break; }
