Author: quozl Date: Tue Jun 14 07:30:53 2011 New Revision: 2275 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2275
Log: OLPC XO-1.75 trac #10989 - fix for RTC year increment on reboot, by remapping CMOS to RTC RAM addresses.
Modified: cpu/arm/olpc/1.75/fw.bth
Modified: cpu/arm/olpc/1.75/fw.bth ============================================================================== --- cpu/arm/olpc/1.75/fw.bth Tue Jun 14 04:42:19 2011 (r2274) +++ cpu/arm/olpc/1.75/fw.bth Tue Jun 14 07:30:53 2011 (r2275) @@ -230,15 +230,28 @@ : ec-indexed-io-off ( -- ) ; \ !!! : ec-ixio-reboot ( -- ) ; \ !!! : flash-base ( -- ) true abort" The stuff that relies on flash-base in security.fth needs to be reworked!" ; + +\ idt1338 rtc and ram address map +\ 00 -> 0f rtc +\ 10 -> 3f cmos + +: >rtc ( index -- rtc-address ) h# 3f and h# 10 + ; + : cmos@ ( index -- data ) - h# 38 mod 8 + " rtc@" clock-node @ ( index adr len ih ) + >rtc " rtc@" clock-node @ ( index adr len ih ) ['] $call-method catch if 4drop 0 then ; : cmos! ( data index -- ) - h# 38 mod 8 + " rtc!" clock-node @ ( data index adr len ih ) - ['] $call-method catch if 2drop 3drop then + >rtc " rtc!" clock-node @ ( data index adr len ih ) + ['] $call-method catch if 2drop 3drop then ;
+\ cmos address map +\ 80 audio volume +\ 81 audio volume +\ 82 alternate boot +\ 83 xid + : dimmer ( -- ) screen-ih if " dimmer" screen-ih $call-method then ; : brighter ( -- ) screen-ih if " brighter" screen-ih $call-method then ;
@@ -248,7 +261,7 @@ 2 to bundle-suffix
stand-init: xid - 0 cmos@ dup 1+ 0 cmos! ( n ) + h# 83 cmos@ dup 1+ h# 83 cmos! ( n ) d# 24 lshift ( new-xid ) " dev /obp-tftp to rpc-xid dend" evaluate ;
