HAOUAS Elyes (ehaouas@noos.fr) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9971
commit d2b3ea9b9abd5146f882856d5ab7206c92e07015 Author: Elyes HAOUAS ehaouas@noos.fr Date: Thu Apr 23 12:10:17 2015 +0200
[Do not Merge] try to add 945G based board
Change-Id: I97401a39a958a17f2f9120539362e3fa7819a742 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- src/mainboard/nec/945g-m4/Kconfig | 42 +++++ src/mainboard/nec/945g-m4/Kconfig.name | 2 + src/mainboard/nec/945g-m4/acpi/ec.asl | 49 +++++ src/mainboard/nec/945g-m4/acpi/i945_pci_irqs.asl | 83 ++++++++ src/mainboard/nec/945g-m4/acpi/ich7_pci_irqs.asl | 103 ++++++++++ src/mainboard/nec/945g-m4/acpi/platform.asl | 90 +++++++++ src/mainboard/nec/945g-m4/acpi/superio.asl | 92 +++++++++ src/mainboard/nec/945g-m4/acpi/thermal.asl | 94 +++++++++ src/mainboard/nec/945g-m4/acpi/video.asl | 43 +++++ src/mainboard/nec/945g-m4/acpi_tables.c | 230 +++++++++++++++++++++++ src/mainboard/nec/945g-m4/board_info.txt | 7 + src/mainboard/nec/945g-m4/cmos.layout | 194 +++++++++++++++++++ src/mainboard/nec/945g-m4/devicetree.cb | 116 ++++++++++++ src/mainboard/nec/945g-m4/dsdt.asl | 43 +++++ src/mainboard/nec/945g-m4/fadt.c | 155 +++++++++++++++ src/mainboard/nec/945g-m4/irq_tables.c | 61 ++++++ src/mainboard/nec/945g-m4/mainboard.c | 94 +++++++++ src/mainboard/nec/945g-m4/mptable.c | 106 +++++++++++ src/mainboard/nec/945g-m4/romstage.c | 224 ++++++++++++++++++++++ src/mainboard/nec/945g-m4/smihandler.c | 49 +++++ src/mainboard/nec/945g-m4/superio_hwm.c | 161 ++++++++++++++++ src/mainboard/nec/945g-m4/superio_hwm.h | 25 +++ src/mainboard/nec/Kconfig | 9 +- src/northbridge/intel/i945/raminit.c | 37 +++- 24 files changed, 2098 insertions(+), 11 deletions(-)
diff --git a/src/mainboard/nec/945g-m4/Kconfig b/src/mainboard/nec/945g-m4/Kconfig new file mode 100644 index 0000000..791a8f9 --- /dev/null +++ b/src/mainboard/nec/945g-m4/Kconfig @@ -0,0 +1,42 @@ +if BOARD_NEC_945G_M4 +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select ARCH_X86 + select CPU_INTEL_SOCKET_LGA775 + select NORTHBRIDGE_INTEL_I945 + select NORTHBRIDGE_INTEL_SUBTYPE_I945GC + select CHECK_SLFRCS_ON_RESUME + select SOUTHBRIDGE_INTEL_I82801GX + select SUPERIO_WINBOND_W83627EHG + select HAVE_ACPI_TABLES + select HAVE_PIRQ_TABLE + select HAVE_MP_TABLE + select HAVE_OPTION_TABLE + select HAVE_ACPI_RESUME + select BOARD_ROMSIZE_KB_512 + select CHANNEL_XOR_RANDOMIZATION + +config MAINBOARD_DIR + string + default nec/945g-m4 + +config MAINBOARD_PART_NUMBER + string + default "945G-M4" + +config MMCONF_BASE_ADDRESS + hex + default 0xf0000000 + +config IRQ_SLOT_COUNT + int + default 18 + +config MAX_CPUS + int + default 4 + +#config VGA_BIOS_FILE +# string +# default "amipci_01.20" +endif # BOARD_NEC_945G_M4 diff --git a/src/mainboard/nec/945g-m4/Kconfig.name b/src/mainboard/nec/945g-m4/Kconfig.name new file mode 100644 index 0000000..46571f0 --- /dev/null +++ b/src/mainboard/nec/945g-m4/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_NEC_945G_M4 + bool "945G-M" diff --git a/src/mainboard/nec/945g-m4/acpi/ec.asl b/src/mainboard/nec/945g-m4/acpi/ec.asl new file mode 100644 index 0000000..e6c30a0 --- /dev/null +++ b/src/mainboard/nec/945g-m4/acpi/ec.asl @@ -0,0 +1,49 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +Device(EC0) +{ + Name (_HID, EISAID("PNP0C09")) + Name (_UID, 1) + + Method (_CRS, 0) + { + Name (ECMD, ResourceTemplate() + { + IO (Decode16, 0x62, 0x62, 0, 1) + IO (Decode16, 0x66, 0x66, 0, 1) + }) + + Return (ECMD) + } + + Method (_REG, 2) + { + // This method is needed by Windows XP/2000 + // for EC initialization before a driver + // is loaded + } + + Name (_GPE, 23) // GPI07 / GPE23 -> Runtime SCI + + // TODO EC Query methods + + // TODO Scope _SB devices for AC power, LID, Power button + +} diff --git a/src/mainboard/nec/945g-m4/acpi/i945_pci_irqs.asl b/src/mainboard/nec/945g-m4/acpi/i945_pci_irqs.asl new file mode 100644 index 0000000..fb57b5e --- /dev/null +++ b/src/mainboard/nec/945g-m4/acpi/i945_pci_irqs.asl @@ -0,0 +1,83 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 coreboot + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* This is board specific information: IRQ routing for i945G */ + + +// PCI Interrupt Routing +Method(_PRT) +{ + If (PICM) { + Return (Package() { + // PCIe Graphics 0:1.0 + Package() { 0x0001ffff, 0, 0, 10 }, + Package() { 0x0001ffff, 1, 0, 11 }, + Package() { 0x0001ffff, 2, 0, 12 }, + Package() { 0x0001ffff, 3, 0, 13 }, + // Onboard graphics (IGD) 0:2.0 + Package() { 0x0002ffff, 0, 0, 10 }, + // High Definition Audio 0:1b.0 + Package() { 0x001bffff, 0, 0, 10 }, + // PCIe Root Ports 0:1c.x + Package() { 0x001cffff, 0, 0, 10 }, + Package() { 0x001cffff, 1, 0, 11 }, + Package() { 0x001cffff, 2, 0, 12 }, + Package() { 0x001cffff, 3, 0, 13 }, + // USB and EHCI 0:1d.x + Package() { 0x001dffff, 0, 0, 17 }, + Package() { 0x001dffff, 1, 0, 19 }, + Package() { 0x001dffff, 2, 0, 13 }, + Package() { 0x001dffff, 3, 0, 12 }, + // AC97/IDE 0:1e.2, 0:1e.3 + Package() { 0x001effff, 0, 0, 11 }, + Package() { 0x001effff, 1, 0, 24 }, + // LPC device 0:1f.0 + Package() { 0x001fffff, 0, 0, 12 }, + Package() { 0x001fffff, 1, 0, 13 }, + }) + } Else { + Return (Package() { + // PCIe Graphics 0:1.0 + Package() { 0x0001ffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + Package() { 0x0001ffff, 1, _SB.PCI0.LPCB.LNKB, 0 }, + Package() { 0x0001ffff, 2, _SB.PCI0.LPCB.LNKC, 0 }, + Package() { 0x0001ffff, 3, _SB.PCI0.LPCB.LNKD, 0 }, + // Onboard graphics (IGD) 0:2.0 + Package() { 0x0002ffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + // High Definition Audio 0:1b.0 + //Package() { 0x001bffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + // PCIe Root Ports 0:1c.x + Package() { 0x001cffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + Package() { 0x001cffff, 1, _SB.PCI0.LPCB.LNKB, 0 }, + Package() { 0x001cffff, 2, _SB.PCI0.LPCB.LNKC, 0 }, + Package() { 0x001cffff, 3, _SB.PCI0.LPCB.LNKD, 0 }, + // USB and EHCI 0:1d.x + Package() { 0x001dffff, 0, _SB.PCI0.LPCB.LNKH, 0 }, + Package() { 0x001dffff, 1, _SB.PCI0.LPCB.LNKD, 0 }, + Package() { 0x001dffff, 2, _SB.PCI0.LPCB.LNKC, 0 }, + Package() { 0x001dffff, 3, _SB.PCI0.LPCB.LNKA, 0 }, + // AC97/IDE 0:1e.2, 0:1e.3 + Package() { 0x001effff, 0, _SB.PCI0.LPCB.LNKB, 0 }, + Package() { 0x001effff, 1, _SB.PCI0.LPCB.LNKE, 0 }, + // LPC device 0:1f.0 + Package() { 0x001fffff, 0, _SB.PCI0.LPCB.LNKC, 0 }, + Package() { 0x001fffff, 1, _SB.PCI0.LPCB.LNKD, 0 }, + }) + } +} diff --git a/src/mainboard/nec/945g-m4/acpi/ich7_pci_irqs.asl b/src/mainboard/nec/945g-m4/acpi/ich7_pci_irqs.asl new file mode 100644 index 0000000..c108d3f --- /dev/null +++ b/src/mainboard/nec/945g-m4/acpi/ich7_pci_irqs.asl @@ -0,0 +1,103 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* This is board specific information: IRQ routing for the + * 0:1e.0 PCI bridge of the ICH7 + */ + +If (PICM) { + Return (Package() { + Package() { 0x0000ffff, 0, 0, 16}, + + Package() { 0x0001ffff, 0, 0, 20}, + Package() { 0x0001ffff, 1, 0, 21}, + Package() { 0x0001ffff, 2, 0, 22}, + Package() { 0x0001ffff, 3, 0, 23}, + + Package() { 0x0002ffff, 0, 0, 21}, + Package() { 0x0002ffff, 1, 0, 22}, + Package() { 0x0002ffff, 2, 0, 23}, + Package() { 0x0002ffff, 3, 0, 20}, + + Package() { 0x0003ffff, 0, 0, 22}, + Package() { 0x0003ffff, 1, 0, 23}, + Package() { 0x0003ffff, 2, 0, 20}, + Package() { 0x0003ffff, 3, 0, 21}, + + Package() { 0x0004ffff, 0, 0, 23}, + Package() { 0x0004ffff, 1, 0, 20}, + Package() { 0x0004ffff, 2, 0, 21}, + Package() { 0x0004ffff, 3, 0, 22}, + + Package() { 0x0005ffff, 0, 0, 19}, + Package() { 0x0005ffff, 1, 0, 18}, + Package() { 0x0005ffff, 2, 0, 17}, + Package() { 0x0005ffff, 3, 0, 16}, + + Package() { 0x0006ffff, 0, 0, 18}, + Package() { 0x0006ffff, 1, 0, 17}, + Package() { 0x0006ffff, 2, 0, 16}, + Package() { 0x0006ffff, 3, 0, 19}, + + Package() { 0x0009ffff, 0, 0, 21}, + Package() { 0x0009ffff, 1, 0, 22}, + Package() { 0x0009ffff, 2, 0, 23}, + Package() { 0x0009ffff, 3, 0, 20}, + }) +} Else { + Return (Package() { + Package() { 0x0000ffff, 0, _SB.PCI0.LPCB.LNKA, 0}, + + Package() { 0x0001ffff, 0, _SB.PCI0.LPCB.LNKE, 0}, + Package() { 0x0001ffff, 1, _SB.PCI0.LPCB.LNKF, 0}, + Package() { 0x0001ffff, 2, _SB.PCI0.LPCB.LNKG, 0}, + Package() { 0x0001ffff, 3, _SB.PCI0.LPCB.LNKH, 0}, + + Package() { 0x0002ffff, 0, _SB.PCI0.LPCB.LNKF, 0}, + Package() { 0x0002ffff, 1, _SB.PCI0.LPCB.LNKG, 0}, + Package() { 0x0002ffff, 2, _SB.PCI0.LPCB.LNKH, 0}, + Package() { 0x0002ffff, 3, _SB.PCI0.LPCB.LNKE, 0}, + + Package() { 0x0003ffff, 0, _SB.PCI0.LPCB.LNKG, 0}, + Package() { 0x0003ffff, 1, _SB.PCI0.LPCB.LNKH, 0}, + Package() { 0x0003ffff, 2, _SB.PCI0.LPCB.LNKE, 0}, + Package() { 0x0003ffff, 3, _SB.PCI0.LPCB.LNKF, 0}, + + Package() { 0x0004ffff, 0, _SB.PCI0.LPCB.LNKH, 0}, + Package() { 0x0004ffff, 1, _SB.PCI0.LPCB.LNKE, 0}, + Package() { 0x0004ffff, 2, _SB.PCI0.LPCB.LNKF, 0}, + Package() { 0x0004ffff, 3, _SB.PCI0.LPCB.LNKG, 0}, + + Package() { 0x0005ffff, 0, _SB.PCI0.LPCB.LNKD, 0}, + Package() { 0x0005ffff, 1, _SB.PCI0.LPCB.LNKC, 0}, + Package() { 0x0005ffff, 2, _SB.PCI0.LPCB.LNKB, 0}, + Package() { 0x0005ffff, 3, _SB.PCI0.LPCB.LNKA, 0}, + + Package() { 0x0006ffff, 0, _SB.PCI0.LPCB.LNKC, 0}, + Package() { 0x0006ffff, 1, _SB.PCI0.LPCB.LNKB, 0}, + Package() { 0x0006ffff, 2, _SB.PCI0.LPCB.LNKA, 0}, + Package() { 0x0006ffff, 3, _SB.PCI0.LPCB.LNKD, 0}, + + Package() { 0x0009ffff, 0, _SB.PCI0.LPCB.LNKF, 0}, + Package() { 0x0009ffff, 1, _SB.PCI0.LPCB.LNKG, 0}, + Package() { 0x0009ffff, 2, _SB.PCI0.LPCB.LNKH, 0}, + Package() { 0x0009ffff, 3, _SB.PCI0.LPCB.LNKE, 0}, + }) +} + diff --git a/src/mainboard/nec/945g-m4/acpi/platform.asl b/src/mainboard/nec/945g-m4/acpi/platform.asl new file mode 100644 index 0000000..6770348 --- /dev/null +++ b/src/mainboard/nec/945g-m4/acpi/platform.asl @@ -0,0 +1,90 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* The APM port can be used for generating software SMIs */ + +OperationRegion (APMP, SystemIO, 0xb2, 2) +Field (APMP, ByteAcc, NoLock, Preserve) +{ + APMC, 8, // APM command + APMS, 8 // APM status +} + +/* Port 80 POST */ + +OperationRegion (POST, SystemIO, 0x80, 1) +Field (POST, ByteAcc, Lock, Preserve) +{ + DBG0, 8 +} + +/* SMI I/O Trap */ +Method(TRAP, 1, Serialized) +{ + Store (Arg0, SMIF) // SMI Function + Store (0, TRP0) // Generate trap + Return (SMIF) // Return value of SMI handler +} + +/* The _PIC method is called by the OS to choose between interrupt + * routing via the i8259 interrupt controller or the APIC. + * + * _PIC is called with a parameter of 0 for i8259 configuration and + * with a parameter of 1 for Local Apic/IOAPIC configuration. + */ + +Method(_PIC, 1) +{ + // Remember the OS' IRQ routing choice. + Store(Arg0, PICM) +} + +/* The _PTS method (Prepare To Sleep) is called before the OS is + * entering a sleep state. The sleep state number is passed in Arg0 + */ + +Method(_PTS,1) +{ + // Call a trap so SMI can prepare for Sleep as well. + // TRAP(0x55) +} + +/* The _WAK method is called on system wakeup */ + +Method(_WAK,1) +{ + // CPU specific part + + // Notify PCI Express slots in case a card + // was inserted while a sleep state was active. + + // Are we going to S3? + If (LEqual(Arg0, 3)) { + // .. + } + + // Are we going to S4? + If (LEqual(Arg0, 4)) { + // .. + } + + // TODO: Windows XP SP2 P-State restore + + Return(Package(){0,0}) +} diff --git a/src/mainboard/nec/945g-m4/acpi/superio.asl b/src/mainboard/nec/945g-m4/acpi/superio.asl new file mode 100644 index 0000000..997a33a --- /dev/null +++ b/src/mainboard/nec/945g-m4/acpi/superio.asl @@ -0,0 +1,92 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + + +Device (SIO1) +{ + Name (_HID, EISAID("PNP0A05")) + Name (_UID, 1) + + Device (UAR1) + { + Name(_HID, EISAID("PNP0501")) + Name(_UID, 1) + Name(_DDN, "COM1") + + Method (_STA, 0) + { + // always enable for now + Return (0x0f) + } + + Method (_DIS, 0) { /* NOOP */ } + + Name (_PRS, ResourceTemplate() { + StartDependentFn(0, 1) { + IO(Decode16, 0x3f8, 0x3f8, 0x8, 0x8) + IRQNoFlags() { 4 } + } EndDependentFn() + }) + + Method (_CRS, 0) + { + Return(ResourceTemplate() { + IO(Decode16, 0x3f8, 0x3f8, 0x8, 0x8) + IRQNoFlags() { 4 } + }) + } + // Some methods need an implementation here: + // missing: _STA, _DIS, _CRS, _PRS, + // missing: _SRS, _PS0, _PS3 + } + + Device (UAR2) + { + Name(_HID, EISAID("PNP0501")) + Name(_UID, 2) + Name(_DDN, "COM2") + + Method (_STA, 0) + { + // always enable for now + Return (0x0f) + } + + Method (_DIS, 0) { /* NOOP */ } + + Name (_PRS, ResourceTemplate() { + StartDependentFn(0, 1) { + IO(Decode16, 0x2f8, 0x2f8, 0x8, 0x8) + IRQNoFlags() { 3 } + } EndDependentFn() + }) + + Method (_CRS, 0) + { + Return(ResourceTemplate() { + IO(Decode16, 0x2f8, 0x2f8, 0x8, 0x8) + IRQNoFlags() { 3 } + }) + } + // Some methods need an implementation here: + // missing: _STA, _DIS, _CRS, _PRS, + // missing: _SRS, _PS0, _PS3 + } +} + diff --git a/src/mainboard/nec/945g-m4/acpi/thermal.asl b/src/mainboard/nec/945g-m4/acpi/thermal.asl new file mode 100644 index 0000000..d1774d4 --- /dev/null +++ b/src/mainboard/nec/945g-m4/acpi/thermal.asl @@ -0,0 +1,94 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +// Thermal Zone + +Scope (_TZ) +{ + ThermalZone (THRM) + { + + // FIXME these could/should be read from the + // GNVS area, so they can be controlled by + // coreboot + Name(TC1V, 0x04) + Name(TC2V, 0x03) + Name(TSPV, 0x64) + + // At which temperature should the OS start + // active cooling? + Method (_AC0, 0, Serialized) + { + Return (0xf5c) // Value for Rocky + } + + // Method (_AC1, 0, Serialized) + // { + // Return (0xf5c) + // } + + // Critical shutdown temperature + Method (_CRT, 0, Serialized) + { + Return (Add (0x0aac, 0x50)) // FIXME + } + + // CPU throttling start temperature + Method (_PSV, 0, Serialized) + { + Return (0xaaf) // FIXME + } + + // Get DTS Temperature + Method (_TMP, 0, Serialized) + { + Return (0xaac) // FIXME + } + + // Processors used for active cooling + Method (_PSL, 0, Serialized) + { + If (MPEN) { + Return (Package() {_PR.CPU1, _PR.CPU2}) + } + Return (Package() {_PR.CPU1}) + } + + // TC1 value for passive cooling + Method (_TC1, 0, Serialized) + { + Return (TC1V) + } + + // TC2 value for passive cooling + Method (_TC2, 0, Serialized) + { + Return (TC2V) + } + + // Sampling period for passive cooling + Method (_TSP, 0, Serialized) + { + Return (TSPV) + } + + + } +} + diff --git a/src/mainboard/nec/945g-m4/acpi/video.asl b/src/mainboard/nec/945g-m4/acpi/video.asl new file mode 100644 index 0000000..3ececa9 --- /dev/null +++ b/src/mainboard/nec/945g-m4/acpi/video.asl @@ -0,0 +1,43 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +// Brightness write +Method (BRTW, 1, Serialized) +{ + // TODO +} + +// Hot Key Display Switch +Method (HKDS, 1, Serialized) +{ + // TODO +} + +// Lid Switch Display Switch +Method (LSDS, 1, Serialized) +{ + // TODO +} + +// Brightness Notification +Method(BRTN,1,Serialized) +{ + // TODO (no displays defined yet) +} + diff --git a/src/mainboard/nec/945g-m4/acpi_tables.c b/src/mainboard/nec/945g-m4/acpi_tables.c new file mode 100644 index 0000000..e6a517e --- /dev/null +++ b/src/mainboard/nec/945g-m4/acpi_tables.c @@ -0,0 +1,230 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <types.h> +#include <string.h> +#include <console/console.h> +#include <arch/acpi.h> +#include <arch/ioapic.h> +#include <arch/acpigen.h> +#include <arch/smp/mpspec.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <cpu/x86/msr.h> + +extern const unsigned char AmlCode[]; +#if CONFIG_HAVE_ACPI_SLIC +unsigned long acpi_create_slic(unsigned long current); +#endif + +#include "southbridge/intel/i82801gx/nvs.h" +static void acpi_create_gnvs(global_nvs_t *gnvs) +{ + memset((void *)gnvs, 0, sizeof(*gnvs)); + gnvs->apic = 1; + gnvs->mpen = 1; /* Enable Multi Processing */ + + /* Enable both COM ports */ + gnvs->cmap = 0x01; + gnvs->cmbp = 0x01; + + /* IGD Displays */ + gnvs->ndid = 3; + gnvs->did[0] = 0x80000100; + gnvs->did[1] = 0x80000240; + gnvs->did[2] = 0x80000410; + gnvs->did[3] = 0x80000410; + gnvs->did[4] = 0x00000005; +} + +unsigned long acpi_fill_madt(unsigned long current) +{ + /* Local APICs */ + current = acpi_create_madt_lapics(current); + + /* IOAPIC */ + current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, + 2, IO_APIC_ADDR, 0); + + /* INT_SRC_OVR */ + current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) + current, 0, 0, 2, 0); + current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) + current, 0, 9, 9, MP_IRQ_TRIGGER_LEVEL | MP_IRQ_POLARITY_HIGH); + + return current; +} + +unsigned long acpi_fill_ssdt_generator(unsigned long current, const char *oem_table_id) +{ + generate_cpu_entries(); + return (unsigned long) (acpigen_get_current()); +} + +unsigned long acpi_fill_slit(unsigned long current) +{ + // Not implemented + return current; +} + +unsigned long acpi_fill_srat(unsigned long current) +{ + /* No NUMA, no SRAT */ + return current; +} + +void smm_setup_structures(void *gnvs, void *tcg, void *smi1); + +#define ALIGN_CURRENT current = (ALIGN(current, 16)) +unsigned long write_acpi_tables(unsigned long start) +{ + unsigned long current; + int i; + acpi_rsdp_t *rsdp; + acpi_rsdt_t *rsdt; + acpi_xsdt_t *xsdt; + acpi_hpet_t *hpet; + acpi_madt_t *madt; + acpi_mcfg_t *mcfg; + acpi_fadt_t *fadt; + acpi_facs_t *facs; +#if CONFIG_HAVE_ACPI_SLIC + acpi_header_t *slic; +#endif + acpi_header_t *ssdt; + acpi_header_t *dsdt; + + current = start; + + /* Align ACPI tables to 16byte */ + ALIGN_CURRENT; + + printk(BIOS_INFO, "ACPI: Writing ACPI tables at %lx.\n", start); + + /* We need at least an RSDP and an RSDT Table */ + rsdp = (acpi_rsdp_t *) current; + current += sizeof(acpi_rsdp_t); + ALIGN_CURRENT; + rsdt = (acpi_rsdt_t *) current; + current += sizeof(acpi_rsdt_t); + ALIGN_CURRENT; + xsdt = (acpi_xsdt_t *) current; + current += sizeof(acpi_xsdt_t); + ALIGN_CURRENT; + + /* clear all table memory */ + memset((void *) start, 0, current - start); + + acpi_write_rsdp(rsdp, rsdt, xsdt); + acpi_write_rsdt(rsdt); + acpi_write_xsdt(xsdt); + + /* + * We explicitly add these tables later on: + */ + printk(BIOS_DEBUG, "ACPI: * HPET\n"); + + hpet = (acpi_hpet_t *) current; + current += sizeof(acpi_hpet_t); + ALIGN_CURRENT; + acpi_create_hpet(hpet); + acpi_add_table(rsdp, hpet); + + /* If we want to use HPET Timers Linux wants an MADT */ + printk(BIOS_DEBUG, "ACPI: * MADT\n"); + + madt = (acpi_madt_t *) current; + acpi_create_madt(madt); + current += madt->header.length; + ALIGN_CURRENT; + acpi_add_table(rsdp, madt); + + printk(BIOS_DEBUG, "ACPI: * MCFG\n"); + mcfg = (acpi_mcfg_t *) current; + acpi_create_mcfg(mcfg); + current += mcfg->header.length; + ALIGN_CURRENT; + acpi_add_table(rsdp, mcfg); + + printk(BIOS_DEBUG, "ACPI: * FACS\n"); + facs = (acpi_facs_t *) current; + current += sizeof(acpi_facs_t); + ALIGN_CURRENT; + acpi_create_facs(facs); + + dsdt = (acpi_header_t *) current; + memcpy(dsdt, &AmlCode, sizeof(acpi_header_t)); + current += dsdt->length; + memcpy(dsdt, &AmlCode, dsdt->length); + + ALIGN_CURRENT; + + /* Pack GNVS into the ACPI table area */ + for (i=0; i < dsdt->length; i++) { + if (*(u32*)(((u32)dsdt) + i) == 0xC0DEBABE) { + printk(BIOS_DEBUG, "ACPI: Patching up global NVS in DSDT at offset 0x%04x -> 0x%08lx\n", i, current); + *(u32*)(((u32)dsdt) + i) = current; // 0x92 bytes + break; + } + } + + /* And fill it */ + acpi_create_gnvs((global_nvs_t *)current); + + current += 0x100; + ALIGN_CURRENT; + + /* And tell SMI about it */ + smm_setup_structures((void *)current, NULL, NULL); + + /* We patched up the DSDT, so we need to recalculate the checksum */ + dsdt->checksum = 0; + dsdt->checksum = acpi_checksum((void *)dsdt, dsdt->length); + + printk(BIOS_DEBUG, "ACPI: * DSDT @ %p Length %x\n", dsdt, + dsdt->length); + +#if CONFIG_HAVE_ACPI_SLIC + printk(BIOS_DEBUG, "ACPI: * SLIC\n"); + slic = (acpi_header_t *)current; + current += acpi_create_slic(current); + ALIGN_CURRENT; + acpi_add_table(rsdp, slic); +#endif + + printk(BIOS_DEBUG, "ACPI: * FADT\n"); + fadt = (acpi_fadt_t *) current; + current += sizeof(acpi_fadt_t); + ALIGN_CURRENT; + + acpi_create_fadt(fadt, facs, dsdt); + acpi_add_table(rsdp, fadt); + + printk(BIOS_DEBUG, "ACPI: * SSDT\n"); + ssdt = (acpi_header_t *)current; + acpi_create_ssdt_generator(ssdt, ACPI_TABLE_CREATOR); + current += ssdt->length; + acpi_add_table(rsdp, ssdt); + ALIGN_CURRENT; + + printk(BIOS_DEBUG, "current = %lx\n", current); + printk(BIOS_INFO, "ACPI: done.\n"); + return current; +} diff --git a/src/mainboard/nec/945g-m4/board_info.txt b/src/mainboard/nec/945g-m4/board_info.txt new file mode 100644 index 0000000..8c6f8c8 --- /dev/null +++ b/src/mainboard/nec/945g-m4/board_info.txt @@ -0,0 +1,7 @@ +Board name:945G-M4 (Rev: B) +Category: µATX 24.4 cm x 24.4 cm Form Factor +Board URL: http://www.nec-computers.com/support2/pib.asp?platform=spec_veracruz&mod... +ROM package: PLCC +ROM protocol: FWH +ROM socketed: y +Flashrom support: y diff --git a/src/mainboard/nec/945g-m4/cmos.layout b/src/mainboard/nec/945g-m4/cmos.layout new file mode 100644 index 0000000..b3e8c4e --- /dev/null +++ b/src/mainboard/nec/945g-m4/cmos.layout @@ -0,0 +1,194 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2007-2008 coresystems GmbH +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA +## + +# ----------------------------------------------------------------- +entries + +#start-bit length config config-ID name +#0 8 r 0 seconds +#8 8 r 0 alarm_seconds +#16 8 r 0 minutes +#24 8 r 0 alarm_minutes +#32 8 r 0 hours +#40 8 r 0 alarm_hours +#48 8 r 0 day_of_week +#56 8 r 0 day_of_month +#64 8 r 0 month +#72 8 r 0 year +# ----------------------------------------------------------------- +# Status Register A +#80 4 r 0 rate_select +#84 3 r 0 REF_Clock +#87 1 r 0 UIP +# ----------------------------------------------------------------- +# Status Register B +#88 1 r 0 auto_switch_DST +#89 1 r 0 24_hour_mode +#90 1 r 0 binary_values_enable +#91 1 r 0 square-wave_out_enable +#92 1 r 0 update_finished_enable +#93 1 r 0 alarm_interrupt_enable +#94 1 r 0 periodic_interrupt_enable +#95 1 r 0 disable_clock_updates +# ----------------------------------------------------------------- +# Status Register C +#96 4 r 0 status_c_rsvd +#100 1 r 0 uf_flag +#101 1 r 0 af_flag +#102 1 r 0 pf_flag +#103 1 r 0 irqf_flag +# ----------------------------------------------------------------- +# Status Register D +#104 7 r 0 status_d_rsvd +#111 1 r 0 valid_cmos_ram +# ----------------------------------------------------------------- +# Diagnostic Status Register +#112 8 r 0 diag_rsvd1 + +# ----------------------------------------------------------------- +0 120 r 0 reserved_memory +#120 264 r 0 unused + +# ----------------------------------------------------------------- +# RTC_BOOT_BYTE (coreboot hardcoded) +384 1 e 4 boot_option +385 1 e 4 last_boot +388 4 r 0 reboot_bits +#390 2 r 0 unused? + +# ----------------------------------------------------------------- +# coreboot config options: console +392 3 e 5 baud_rate +395 4 e 6 debug_level +#399 1 r 0 unused + +# coreboot config options: cpu +400 1 e 2 hyper_threading +#401 7 r 0 unused + +# coreboot config options: southbridge +408 1 e 1 nmi +409 2 e 7 power_on_after_fail +#411 5 r 0 unused + +# coreboot config options: bootloader +416 512 s 0 boot_devices +#928 40 r 0 unused + +# coreboot config options: mainboard specific options +948 2 e 8 cpufan_cruise_control +950 2 e 8 sysfan_cruise_control +952 4 e 9 cpufan_speed +#956 4 e 10 cpufan_temperature +960 4 e 9 sysfan_speed +#964 4 e 10 sysfan_temperature + +968 1 e 2 ethernet1 +969 1 e 2 ethernet2 +970 1 e 2 ethernet3 + +#971 13 r 0 unused + +# coreboot config options: check sums +984 16 h 0 check_sum +#1000 24 r 0 amd_reserved + +# ram initialization internal data +1024 8 r 0 C0WL0REOST +1032 8 r 0 C1WL0REOST +1040 8 r 0 RCVENMT +1048 4 r 0 C0DRT1 +1052 4 r 0 C1DRT1 + +# ----------------------------------------------------------------- + +enumerations + +#ID value text +1 0 Disable +1 1 Enable +2 0 Enable +2 1 Disable +4 0 Fallback +4 1 Normal +5 0 115200 +5 1 57600 +5 2 38400 +5 3 19200 +5 4 9600 +5 5 4800 +5 6 2400 +5 7 1200 +6 1 Emergency +6 2 Alert +6 3 Critical +6 4 Error +6 5 Warning +6 6 Notice +6 7 Info +6 8 Debug +6 9 Spew +7 0 Disable +7 1 Enable +7 2 Keep +# Fan Cruise Control +8 0 Disabled +8 1 Speed +#8 2 Thermal +# Fan Speed (Rotations per Minute) +9 0 5625 +9 1 5192 +9 2 4753 +9 3 4326 +9 4 3924 +9 5 3552 +9 6 3214 +9 7 2909 +9 8 2636 +9 9 2393 +9 10 2177 +9 11 1985 +9 12 1814 +9 13 1662 +9 14 1527 +9 15 1406 +# +# Temperature (�C/�F) +#10 0 30/86 +#10 1 33/91 +#10 2 36/96 +#10 3 39/102 +#10 4 42/107 +#10 5 45/113 +#10 6 48/118 +#10 7 51/123 +#10 8 54/129 +#10 9 57/134 +#10 10 60/140 +#10 11 63/145 +#10 12 66/150 +#10 13 69/156 +#10 14 72/161 +#10 15 75/167 +# ----------------------------------------------------------------- +checksums + +checksum 392 983 984 + + diff --git a/src/mainboard/nec/945g-m4/devicetree.cb b/src/mainboard/nec/945g-m4/devicetree.cb new file mode 100644 index 0000000..9978fcf --- /dev/null +++ b/src/mainboard/nec/945g-m4/devicetree.cb @@ -0,0 +1,116 @@ +chip northbridge/intel/i945 + device cpu_cluster 0 on + chip cpu/intel/socket_LGA775 + device lapic 0 on end + end + end + device domain 0 on + device pci 00.0 on end # 82945G/GZ/P/PL Memory Controller Hub [8086:2770] + device pci 02.0 off end # 82945G/GZ Integrated Graphics Controller [8086:2772] + chip southbridge/intel/i82801gx + register "pirqa_routing" = "0x8a" + register "pirqb_routing" = "0x85" + register "pirqc_routing" = "0x8a" + register "pirqd_routing" = "0x8b" + register "pirqe_routing" = "0x80" + register "pirqf_routing" = "0x80" + register "pirqg_routing" = "0x80" + register "pirqh_routing" = "0x87" + + # GPI routing + # 0 No effect (default) + # 1 SMI# (if corresponding ALT_GPI_SMI_EN bit is also set) + # 2 SCI (if corresponding GPIO_EN bit is also set) + register "gpi13_routing" = "1" + register "ide_legacy_combined" = "0x0" + register "ide_enable_primary" = "0x1" + register "ide_enable_secondary" = "0x0" + register "sata_ahci" = "0x1" + + device pci 1c.0 on end # PCI Express Gigabit Ethernet Controller [10ec:8168] + device pci 1d.0 on end # NM10/ICH7 Family USB UHCI Controller #1 [8086:27c8] + device pci 1d.1 on end # NM10/ICH7 Family USB UHCI Controller #2 [8086:27c9] + device pci 1d.2 on end # NM10/ICH7 Family USB UHCI Controller #3 [8086:27ca] + device pci 1d.3 on end # NM10/ICH7 Family USB UHCI Controller #4 [8086:27cb] + device pci 1d.7 on end # NM10/ICH7 Family USB2 EHCI Controller [8086:27cc] + device pci 1e.0 on end # 82801 PCI Bridge [8086:244e] + device pci 1e.2 on end # 82801G (ICH7 Family) AC'97 Audio Controller [8086:27de] + device pci 1f.0 on # 82801GB/GR (ICH7 Family) LPC Interface Bridge [8086:27b8] + + chip superio/winbond/w83627ehg # Super I/O Winbond + device pnp 2e.0 on # Floppy + io 0x60 = 0x3f0 + irq 0x70 = 6 + drq 0x74 = 2 + end + + device pnp 2e.1 on # Parallel port + io 0x60 = 0x378 + irq 0x70 = 7 + drq 0x74 = 3 + end + + device pnp 2e.2 on # COM1 + io 0x60 = 0x3f8 + irq 0x70 = 4 + end + + device pnp 2e.3 off # COM2 + io 0x60 = 0x2f8 + irq 0x70 = 3 + end + + device pnp 2e.5 on # Keyboard + end + + device pnp 2e.106 on # Serial flash interface + io 0x60 = 0x100 + end + + device pnp 2e.007 on # GPIO 1 + end + + device pnp 2e.107 off # Game port + io 0x60 = 0x201 + end + + device pnp 2e.207 on # MIDI + io 0x62 = 0x330 + irq 0x70 = 0xa + end + + device pnp 2e.307 on # GPIO 6 + end + + device pnp 2e.8 off # WDTO#, PLED + end + + device pnp 2e.009 on # GPIO 2 + end + + device pnp 2e.109 on # GPIO 3 + end + + device pnp 2e.209 on # GPIO 4 + end + + device pnp 2e.309 on # GPIO 5 + end + + device pnp 2e.a on # ACPI + end + + device pnp 2e.b on # Hardware monitor + io 0x60 = 0xa10 + irq 0x70 = 0 + end + + end # Winbond + end # LPC + + device pci 1f.1 on end # 82801G (ICH7 Family) IDE Controller [8086:27df] + device pci 1f.2 on end # NM10/ICH7 Family SATA Controller [IDE mode] [8086:27c0] + device pci 1f.3 on end # NM10/ICH7 Family SMBus Controller [8086:27da] + end # i82801gx + end # domain 0 +end diff --git a/src/mainboard/nec/945g-m4/dsdt.asl b/src/mainboard/nec/945g-m4/dsdt.asl new file mode 100644 index 0000000..f30c12d --- /dev/null +++ b/src/mainboard/nec/945g-m4/dsdt.asl @@ -0,0 +1,43 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +DefinitionBlock ("dsdt.aml", "DSDT", 1, "COREv4", "COREBOOT", 0x00000108) +{ + // Some generic macros + #include "acpi/platform.asl" + + // global NVS and variables + #include <southbridge/intel/i82801gx/acpi/globalnvs.asl> + + // General Purpose Events + //#include "acpi/gpe.asl" + + //#include "acpi/thermal.asl" + + Scope (_SB) { + Device (PCI0) + { + #include <northbridge/intel/i945/acpi/i945.asl> + #include <southbridge/intel/i82801gx/acpi/ich7.asl> + } + } + + /* Chipset specific sleep states */ + #include <southbridge/intel/i82801gx/acpi/sleepstates.asl> +} diff --git a/src/mainboard/nec/945g-m4/fadt.c b/src/mainboard/nec/945g-m4/fadt.c new file mode 100644 index 0000000..b55f628 --- /dev/null +++ b/src/mainboard/nec/945g-m4/fadt.c @@ -0,0 +1,155 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <string.h> +#include <device/pci.h> +#include <arch/acpi.h> +#include <cpu/x86/smm.h> + +void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) +{ + acpi_header_t *header = &(fadt->header); + u16 pmbase = pci_read_config16(dev_find_slot(0, PCI_DEVFN(0x1f,0)), 0x40) & 0xfffe; + + memset((void *) fadt, 0, sizeof(acpi_fadt_t)); + memcpy(header->signature, "FACP", 4); + header->length = sizeof(acpi_fadt_t); + header->revision = 3; + memcpy(header->oem_id, OEM_ID, 6); + memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); + memcpy(header->asl_compiler_id, ASLC, 4); + header->asl_compiler_revision = 1; + + fadt->firmware_ctrl = (unsigned long) facs; + fadt->dsdt = (unsigned long) dsdt; + fadt->model = 1; + fadt->preferred_pm_profile = PM_MOBILE; + + fadt->sci_int = 0x9; + fadt->smi_cmd = APM_CNT; + fadt->acpi_enable = APM_CNT_ACPI_ENABLE; + fadt->acpi_disable = APM_CNT_ACPI_DISABLE; + fadt->s4bios_req = 0x0; + fadt->pstate_cnt = APM_CNT_PST_CONTROL; + + fadt->pm1a_evt_blk = pmbase; + fadt->pm1b_evt_blk = 0x0; + fadt->pm1a_cnt_blk = pmbase + 0x4; + fadt->pm1b_cnt_blk = 0x0; + fadt->pm2_cnt_blk = pmbase + 0x20; + fadt->pm_tmr_blk = pmbase + 0x8; + fadt->gpe0_blk = pmbase + 0x28; + fadt->gpe1_blk = 0; + + fadt->pm1_evt_len = 4; + fadt->pm1_cnt_len = 2; + // XXX: pm2_cnt_len is probably wrong. find out right value (hint: it's != 0) + fadt->pm2_cnt_len = 2; + fadt->pm_tmr_len = 4; + fadt->gpe0_blk_len = 8; + fadt->gpe1_blk_len = 0; + fadt->gpe1_base = 0; + fadt->cst_cnt = APM_CNT_CST_CONTROL; + fadt->p_lvl2_lat = 1; + fadt->p_lvl3_lat = 85; + fadt->flush_size = 1024; + fadt->flush_stride = 16; + fadt->duty_offset = 1; + fadt->duty_width = 0; + fadt->day_alrm = 0xd; + fadt->mon_alrm = 0x00; + fadt->century = 0x00; + fadt->iapc_boot_arch = 0x03; + + fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | + ACPI_FADT_C2_MP_SUPPORTED | ACPI_FADT_SLEEP_BUTTON | + ACPI_FADT_S4_RTC_WAKE | ACPI_FADT_PLATFORM_CLOCK; + + fadt->reset_reg.space_id = 0; + fadt->reset_reg.bit_width = 0; + fadt->reset_reg.bit_offset = 0; + fadt->reset_reg.resv = 0; + fadt->reset_reg.addrl = 0x0; + fadt->reset_reg.addrh = 0x0; + + fadt->reset_value = 0; + fadt->x_firmware_ctl_l = (unsigned long)facs; + fadt->x_firmware_ctl_h = 0; + fadt->x_dsdt_l = (unsigned long)dsdt; + fadt->x_dsdt_h = 0; + + fadt->x_pm1a_evt_blk.space_id = 1; + fadt->x_pm1a_evt_blk.bit_width = 32; + fadt->x_pm1a_evt_blk.bit_offset = 0; + fadt->x_pm1a_evt_blk.resv = 0; + fadt->x_pm1a_evt_blk.addrl = pmbase; + fadt->x_pm1a_evt_blk.addrh = 0x0; + + fadt->x_pm1b_evt_blk.space_id = 1; + fadt->x_pm1b_evt_blk.bit_width = 0; + fadt->x_pm1b_evt_blk.bit_offset = 0; + fadt->x_pm1b_evt_blk.resv = 0; + fadt->x_pm1b_evt_blk.addrl = 0x0; + fadt->x_pm1b_evt_blk.addrh = 0x0; + + fadt->x_pm1a_cnt_blk.space_id = 1; + fadt->x_pm1a_cnt_blk.bit_width = 16; + fadt->x_pm1a_cnt_blk.bit_offset = 0; + fadt->x_pm1a_cnt_blk.resv = 0; + fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; + fadt->x_pm1a_cnt_blk.addrh = 0x0; + + fadt->x_pm1b_cnt_blk.space_id = 1; + fadt->x_pm1b_cnt_blk.bit_width = 0; + fadt->x_pm1b_cnt_blk.bit_offset = 0; + fadt->x_pm1b_cnt_blk.resv = 0; + fadt->x_pm1b_cnt_blk.addrl = 0x0; + fadt->x_pm1b_cnt_blk.addrh = 0x0; + + fadt->x_pm2_cnt_blk.space_id = 1; + fadt->x_pm2_cnt_blk.bit_width = 8; + fadt->x_pm2_cnt_blk.bit_offset = 0; + fadt->x_pm2_cnt_blk.resv = 0; + fadt->x_pm2_cnt_blk.addrl = pmbase + 0x20; + fadt->x_pm2_cnt_blk.addrh = 0x0; + + fadt->x_pm_tmr_blk.space_id = 1; + fadt->x_pm_tmr_blk.bit_width = 32; + fadt->x_pm_tmr_blk.bit_offset = 0; + fadt->x_pm_tmr_blk.resv = 0; + fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; + fadt->x_pm_tmr_blk.addrh = 0x0; + + fadt->x_gpe0_blk.space_id = 1; + fadt->x_gpe0_blk.bit_width = 64; + fadt->x_gpe0_blk.bit_offset = 0; + fadt->x_gpe0_blk.resv = 0; + fadt->x_gpe0_blk.addrl = pmbase + 0x28; + fadt->x_gpe0_blk.addrh = 0x0; + + fadt->x_gpe1_blk.space_id = 1; + fadt->x_gpe1_blk.bit_width = 0; + fadt->x_gpe1_blk.bit_offset = 0; + fadt->x_gpe1_blk.resv = 0; + fadt->x_gpe1_blk.addrl = 0x0; + fadt->x_gpe1_blk.addrh = 0x0; + + header->checksum = + acpi_checksum((void *) fadt, header->length); +} diff --git a/src/mainboard/nec/945g-m4/irq_tables.c b/src/mainboard/nec/945g-m4/irq_tables.c new file mode 100644 index 0000000..4b050fe --- /dev/null +++ b/src/mainboard/nec/945g-m4/irq_tables.c @@ -0,0 +1,61 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2008 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <arch/pirq_routing.h> + + +const struct irq_routing_table intel_irq_routing_table = { + PIRQ_SIGNATURE, /* u32 signature */ + PIRQ_VERSION, /* u16 version */ + 32 + 16 * 14, /* Max. number of devices on the bus */ + 0x00, /* Interrupt router bus */ + (0x1f << 3) | 0x0, /* Interrupt router dev */ + 0, /* IRQs devoted exclusively to PCI usage */ + 0x8086, /* Vendor */ + 0x27b0, /* Device */ + 0, /* Miniport */ + { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, /* u8 rfu[11] */ + 0xb, /* Checksum (has to be set to some value that + * would give 0 after the sum of all bytes + * for this structure (including checksum). + */ + { + /* bus, dev | fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ + {0x00, (0x01 << 3) | 0x0, {{0x60, 0xdcf8}, {0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0xdcf8}}, 0x0, 0x0}, + {0x00, (0x02 << 3) | 0x0, {{0x60, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x0000}}, 0x0, 0x0}, + {0x00, (0x1e << 3) | 0x0, {{0x61, 0xdcf8}, {0x68, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x0000}}, 0x0, 0x0}, + {0x00, (0x1f << 3) | 0x0, {{0x62, 0xdcf8}, {0x63, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x0000}}, 0x0, 0x0}, + {0x00, (0x1d << 3) | 0x0, {{0x6b, 0xdcf8}, {0x63, 0xdcf8}, {0x62, 0xdcf8}, {0x60, 0xdcf8}}, 0x0, 0x0}, + {0x00, (0x1b << 3) | 0x0, {{0x60, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x0000}}, 0x0, 0x0}, + {0x00, (0x1c << 3) | 0x0, {{0x60, 0xdcf8}, {0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0xdcf8}}, 0x0, 0x0}, + {0x02, (0x00 << 3) | 0x0, {{0x60, 0xdcf8}, {0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0xdcf8}}, 0x20, 0x0}, + {0x03, (0x03 << 3) | 0x0, {{0x63, 0xdcf8}, {0x62, 0xdcf8}, {0x69, 0xdcf8}, {0x6a, 0xdcf8}}, 0x4, 0x0}, + {0x03, (0x04 << 3) | 0x0, {{0x62, 0xdcf8}, {0x6b, 0xdcf8}, {0x60, 0xdcf8}, {0x68, 0xdcf8}}, 0x5, 0x0}, + {0x03, (0x05 << 3) | 0x0, {{0x61, 0xdcf8}, {0x68, 0xdcf8}, {0x69, 0xdcf8}, {0x6a, 0xdcf8}}, 0x6, 0x0}, + {0x03, (0x01 << 3) | 0x0, {{0x62, 0xdcf8}, {0x63, 0xdcf8}, {0x68, 0xdcf8}, {0x69, 0xdcf8}}, 0x1, 0x0}, + {0x03, (0x02 << 3) | 0x0, {{0x63, 0xdcf8}, {0x68, 0xdcf8}, {0x69, 0xdcf8}, {0x6a, 0xdcf8}}, 0x2, 0x0}, + {0x03, (0x08 << 3) | 0x0, {{0x68, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x0000}}, 0x0, 0x0}, + } +}; + +unsigned long write_pirq_routing_table(unsigned long addr) +{ + return copy_pirq_routing_table(addr, &intel_irq_routing_table); +} diff --git a/src/mainboard/nec/945g-m4/mainboard.c b/src/mainboard/nec/945g-m4/mainboard.c new file mode 100644 index 0000000..d872d95 --- /dev/null +++ b/src/mainboard/nec/945g-m4/mainboard.c @@ -0,0 +1,94 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <types.h> +#include <device/device.h> +#include <console/console.h> +#if CONFIG_VGA_ROM_RUN +#include <x86emu/x86emu.h> +#endif +#include <pc80/mc146818rtc.h> +#include <arch/io.h> +#include <arch/interrupt.h> +#include "superio_hwm.h" + +#if CONFIG_VGA_ROM_RUN +static int int15_handler(void) +{ +#define BOOT_DISPLAY_DEFAULT 0 +#define BOOT_DISPLAY_CRT (1 << 0) +#define BOOT_DISPLAY_TV (1 << 1) +#define BOOT_DISPLAY_EFP (1 << 2) +#define BOOT_DISPLAY_LCD (1 << 3) +#define BOOT_DISPLAY_CRT2 (1 << 4) +#define BOOT_DISPLAY_TV2 (1 << 5) +#define BOOT_DISPLAY_EFP2 (1 << 6) +#define BOOT_DISPLAY_LCD2 (1 << 7) + + printk(BIOS_DEBUG, "%s: AX=%04x BX=%04x CX=%04x DX=%04x\n", + __func__, X86_AX, X86_BX, X86_CX, X86_DX); + + switch (X86_AX) { + case 0x5f35: /* Boot Display */ + X86_AX = 0x005f; // Success + X86_CL = BOOT_DISPLAY_DEFAULT; + break; + case 0x5f40: /* Boot Panel Type */ + // M.x86.R_AX = 0x015f; // Supported but failed + X86_AX = 0x005f; // Success + X86_CL = 3; // Display ID + break; + default: + /* Interrupt was not handled */ + return 0; + } + + /* Interrupt handled */ + return 1; +} +#endif +/* Audio Setup */ + +extern u32 * cim_verb_data; +extern u32 cim_verb_data_size; + +static void verb_setup(void) +{ + // Default VERB is fine on this mainboard. + cim_verb_data = NULL; + cim_verb_data_size = 0; +} + +// mainboard_enable is executed as first thing after +// enumerate_buses(). + +static void mainboard_enable(device_t dev) +{ +#if CONFIG_VGA_ROM_RUN + /* Install custom int15 handler for VGA OPROM */ + mainboard_interrupt_handlers(0x15, &int15_handler); +#endif + verb_setup(); +// hwm_setup(); /* commented while debugging */ +} + +struct chip_operations mainboard_ops = { + .enable_dev = mainboard_enable, +}; + diff --git a/src/mainboard/nec/945g-m4/mptable.c b/src/mainboard/nec/945g-m4/mptable.c new file mode 100644 index 0000000..aaa3069 --- /dev/null +++ b/src/mainboard/nec/945g-m4/mptable.c @@ -0,0 +1,106 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2008 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <console/console.h> +#include <arch/smp/mpspec.h> +#include <arch/ioapic.h> +#include <device/pci.h> +#include <string.h> +#include <stdint.h> +#define INTA 0x00 +#define INTB 0x01 +#define INTC 0x02 +#define INTD 0x03 +static void smp_add_mpc_entry(struct mp_config_table *mc, unsigned length) +{ + mc->mpc_length += length; + mc->mpc_entry_count++; +} +static void my_smp_write_bus(struct mp_config_table *mc, + unsigned char id, const char *bustype) +{ + struct mpc_config_bus *mpc; + mpc = smp_next_mpc_entry(mc); + memset(mpc, '\0', sizeof(*mpc)); + mpc->mpc_type = MP_BUS; + mpc->mpc_busid = id; + memcpy(mpc->mpc_bustype, bustype, sizeof(mpc->mpc_bustype)); + smp_add_mpc_entry(mc, sizeof(*mpc)); +} +static void *smp_write_config_table(void *v) +{ + struct mp_config_table *mc; + mc = (void *)(((char *)v) + SMP_FLOATING_TABLE_LEN); + mptable_init(mc, LOCAL_APIC_ADDR); + smp_write_processors(mc); + /* Bus: Bus ID Type */ + my_smp_write_bus(mc, 0, "PCI "); + my_smp_write_bus(mc, 1, "PCI "); + my_smp_write_bus(mc, 2, "PCI "); + my_smp_write_bus(mc, 3, "PCI "); + my_smp_write_bus(mc, 4, "ISA "); + /* I/O APICs: APIC ID Version State Address */ + smp_write_ioapic(mc, 0x1, 0x20, 0xfec00000); + /* I/O Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN#*/ + smp_write_intsrc(mc, mp_ExtINT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x4, 0x0, 0x1, 0x0); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x4, 0x1, 0x1, 0x1); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x4, 0x0, 0x1, 0x2); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x4, 0x3, 0x1, 0x3); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x4, 0x4, 0x1, 0x4); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x4, 0x6, 0x1, 0x6); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x4, 0x7, 0x1, 0x7); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_EDGE|MP_IRQ_POLARITY_HIGH, 0x4, 0x8, 0x1, 0x8); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x4, 0x9, 0x1, 0x9); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x4, 0xc, 0x1, 0xc); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x4, 0xd, 0x1, 0xd); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x4, 0xe, 0x1, 0xe); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x4, 0xf, 0x1, 0xf); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0x0, (0x01 << 2) | INTA, 0x1, 0x10); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0x1, (0x00 << 2) | INTA, 0x1, 0x10); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0x0, (0x1e << 2) | INTA, 0x1, 0x11); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0x0, (0x1f << 2) | INTA, 0x1, 0x12); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0x0, (0x1f << 2) | INTB, 0x1, 0x13); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0x0, (0x1d << 2) | INTA, 0x1, 0x17); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0x0, (0x1d << 2) | INTB, 0x1, 0x13); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0x0, (0x1d << 2) | INTC, 0x1, 0x12); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0x0, (0x1d << 2) | INTD, 0x1, 0x10); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0x0, (0x1c << 2) | INTA, 0x1, 0x10); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0x2, (0x00 << 2) | INTA, 0x1, 0x10); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0x3, (0x02 << 2) | INTA, 0x1, 0x13); + /* Local Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN# */ + smp_write_lintsrc(mc, mp_ExtINT, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x0, 0x0, MP_APIC_ALL, 0x0); + smp_write_lintsrc(mc, mp_NMI, MP_IRQ_TRIGGER_DEFAULT|MP_IRQ_POLARITY_DEFAULT, 0x0, 0x0, MP_APIC_ALL, 0x1); +/* mptable_lintsrc(mc, isa_bus); */ + /* Compute the checksums */ + return mptable_finalize(mc); +} +unsigned long write_smp_table(unsigned long addr) +{ + void *v; + v = smp_write_floating_table(addr, 1); + return (unsigned long)smp_write_config_table(v); +} +/*MP Config Extended Table Entries: +-- +System Address Space + bus ID: 0 address type: I/O address + address base: 0x600000000000 + address range: 0x148000000000 +Extended Table HOSED! +*/ diff --git a/src/mainboard/nec/945g-m4/romstage.c b/src/mainboard/nec/945g-m4/romstage.c new file mode 100644 index 0000000..6122437 --- /dev/null +++ b/src/mainboard/nec/945g-m4/romstage.c @@ -0,0 +1,224 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2014 coreboot + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ +#include <stdint.h> +#include <string.h> +#include <arch/io.h> +#include <device/pci_def.h> +#include <device/pnp_def.h> +#include <cpu/x86/lapic.h> +#include <cpu/intel/romstage.h> +#include <lib.h> +#include <arch/acpi.h> +#include <cbmem.h> +#include <superio/winbond/common/winbond.h> +#include <superio/winbond/w83627ehg/w83627ehg.h> +#include <pc80/mc146818rtc.h> +#include <console/console.h> +#include <cpu/x86/bist.h> +#include <cpu/intel/romstage.h> +#include <halt.h> +#include <northbridge/intel/i945/i945.h> +#include <northbridge/intel/i945/raminit.h> +#include <southbridge/intel/i82801gx/i82801gx.h> + +#define SERIAL_DEV PNP_DEV(0x2e, W83627EHG_SP1) +#define LPC_DEV PCI_DEV(0, 0x1f, 0) + +void setup_ich7_gpios(void) +{ + +/* values found unsing ./inteltool -g on nec bios */ + printk(BIOS_DEBUG, "GPIOS..."); + /* General Registers */ + outl(0x1f9fffc3, DEFAULT_GPIOBASE + 0x00); /* GPIO_USE_SEL */ + outl(0xe0e8ffc3, DEFAULT_GPIOBASE + 0x04); /* GP_IO_SEL */ + outl(0xebffffbf, DEFAULT_GPIOBASE + 0x0c); /* GP_LVL */ + /* Output Control Registers */ + outl(0x00000000, DEFAULT_GPIOBASE + 0x18); /* GPO_BLINK */ + /* Input Control Registers */ + outl(0x0000af03, DEFAULT_GPIOBASE + 0x2c); /* GPI_INV */ + outl(0x000000ff, DEFAULT_GPIOBASE + 0x30); /* GPIO_USE_SEL2 */ + outl(0x000000f0, DEFAULT_GPIOBASE + 0x34); /* GP_IO_SEL2 */ + outl(0x000000f7, DEFAULT_GPIOBASE + 0x38); /* GP_LVL2 */ +} + +static void ich7_enable_lpc(void) +{ + // Enable Serial IRQ + pci_write_config8(LPC_DEV, 0x64, 0xd0); + // LPC I/O decode range + pci_write_config16(LPC_DEV, 0x80, 0x0010); + // LPC Interface Enables + pci_write_config16(LPC_DEV, 0x82, 0x340f); + // GEN1_DEC. LPC interface generic decode Rang1 + pci_write_config32(LPC_DEV, 0x84, 0x00fc0a01); + // GEN2_DEC. LPC interface generic decode Rang2 + pci_write_config32(LPC_DEV, 0x88, 0x00fc4701); + +} + +static void rcba_config(void) +{ + /* Set up virtual channel 0 */ + RCBA32(0x0014) = 0x80000001; + RCBA32(0x001c) = 0x03128010; + +/* Device 1f interrupt pin register */ + RCBA32(0x3100) = 0x00042210; + /* Device 1d interrupt pin register */ + RCBA32(0x310c) = 0x00214321; + /* HD Audio Interrupt */ + RCBA32(0x3110) = 0x00000001; + /* dev irq route register */ + RCBA16(0x3140) = 0x0132; + RCBA16(0x3142) = 0x0146; + RCBA16(0x3144) = 0x0237; + RCBA16(0x3146) = 0x3201; + RCBA16(0x3148) = 0x0146; + /* Enable IOAPIC */ + RCBA8(0x31ff) |= 3 << 24; + /* Enable upper 128bytes of CMOS */ + RCBA32(0x3400) = (1 << 2); + /* Enable PCIe Root Port Clock Gate */ + RCBA32(0x341c) = 0x00000001; +} +static void early_ich7_init(void) +{ + uint8_t reg8; + uint32_t reg32; + // program secondary mlt XXX byte? + pci_write_config8(PCI_DEV(0, 0x1e, 0), 0x1b, 0x20); + // reset rtc power status + reg8 = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xa4); + reg8 &= ~(1 << 2); + pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xa4, reg8); + // usb transient disconnect + reg8 = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xad); + reg8 |= (3 << 0); + pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xad, reg8); + reg32 = pci_read_config32(PCI_DEV(0, 0x1d, 7), 0xfc); + reg32 |= (1 << 29) | (1 << 17); + pci_write_config32(PCI_DEV(0, 0x1d, 7), 0xfc, reg32); + reg32 = pci_read_config32(PCI_DEV(0, 0x1d, 7), 0xdc); + reg32 |= (1 << 31) | (1 << 27); + pci_write_config32(PCI_DEV(0, 0x1d, 7), 0xdc, reg32); + + /*./inteltool -r on vendor bios*/ + RCBA32(0x0088) = 0x0011d000; + RCBA16(0x01fc) = 0x060f; + RCBA32(0x01f4) = 0x86000040; + RCBA32(0x0214) = 0x10030549; + RCBA32(0x0218) = 0x00020504; + RCBA8(0x0220) = 0xc5; + reg32 = RCBA32(0x3410); + reg32 |= (1 << 6); + RCBA32(0x3410) = reg32; + reg32 = RCBA32(0x3430); + reg32 &= ~(3 << 0); + reg32 |= (1 << 0); + RCBA32(0x3430) = reg32; + RCBA32(0x3418) |= (1 << 0); + RCBA16(0x0200) = 0x2008; + //RCBA8(0x2027) = 0x0d; + RCBA16(0x3e08) |= (1 << 7); + RCBA16(0x3e48) |= (1 << 7); + RCBA32(0x3e0e) |= (1 << 7); + RCBA32(0x3e4e) |= (1 << 7); + // next step only on ich7m b0 and later: + reg32 = RCBA32(0x2034); + reg32 &= ~(0x0f << 16); + reg32 |= (5 << 16); + RCBA32(0x2034) = reg32; +} + +void main(unsigned long bist) +{ + int s3resume = 0; + + if (bist == 0) + enable_lapic(); + + ich7_enable_lpc(); + /* Set up the console */ + winbond_enable_serial(SERIAL_DEV,CONFIG_TTYS0_BASE); + console_init(); + + report_bist_failure(bist); + if (MCHBAR16(SSKPD) == 0xCAFE) { + printk(BIOS_DEBUG, "soft reset detected, rebooting properly\n"); + outb(0x6, 0xcf9); + halt(); + } + /* Perform some early chipset initialization required + * before RAM initialization can work + */ + + i945_early_initialization(); + s3resume = southbridge_detect_s3_resume(); + + /* Enable SPD ROMs and DDR-II DRAM */ + enable_smbus(); + +#if CONFIG_DEFAULT_CONSOLE_LOGLEVEL > 8 + dump_spd_registers(); +#endif + sdram_initialize(s3resume ? 2 : 0, NULL); + /* Perform some initialization that must run before stage2 */ + early_ich7_init(); + /* This should probably go away. Until now it is required + * and mainboard specific + */ + rcba_config(); + /* Chipset Errata! */ + //fixup_i945_errata(); + +// u32 tom = pci_read_config32(PCI_DEV(0,2,0), 0x5c); +// printk(BIOS_DEBUG, "TOM: 0x%08x\n", tom); +// ram_check(0x00000000, 0x000a0000); +// ram_check(0x100000, 0x0); + + /* Initialize the internal PCIe links before we go into stage2 */ + i945_late_initialization(s3resume); + +sdram_dump_mchbar_registers(); +//dump_pci_devices(); +//ram_check_nodie(0<<20,0); +//ram_check_nodie(2<<20,0); +//ram_check_nodie(1<<20,0); +// quick_ram_check(); +// MCHBAR16(SSKPD) = 0x4254 /*0xCAFE*/; +// cbmem_was_initted = !cbmem_recovery(boot_mode==2); +//#if CONFIG_HAVE_ACPI_RESUME /* !CONFIG_HAVE_ACPI_RESUME */ + /* If there is no high memory area, we didn't boot before, so + * this is not a resume. In that case we just create the cbmem toc. + */ +// if ((boot_mode == 2) && cbmem_was_initted) { +// void *resume_backup_memory = cbmem_find(CBMEM_ID_RESUME); + /* copy 1MB - 64K to high tables ram_base to prevent memory corruption + * through stage 2. We could keep stuff like stack and heap in high tables + * memory completely, but that's a wonderful clean up task for another + * day. + */ +// if (resume_backup_memory) +// memcpy(resume_backup_memory, (void *)CONFIG_RAMBASE, HIGH_MEMORY_SAVE); + /* Magic for S3 resume */ +// pci_write_config32(PCI_DEV(0, 0x00, 0), SKPAD, SKPAD_ACPI_S3_MAGIC); +// } +//#endif /* CONFIG_HAVE_ACPI_RESUME */ +} diff --git a/src/mainboard/nec/945g-m4/smihandler.c b/src/mainboard/nec/945g-m4/smihandler.c new file mode 100644 index 0000000..d1f4f7b --- /dev/null +++ b/src/mainboard/nec/945g-m4/smihandler.c @@ -0,0 +1,49 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2008-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <arch/io.h> +#include <console/console.h> +#include <cpu/x86/smm.h> +#include <southbridge/intel/i82801gx/nvs.h> + +/* The southbridge SMI handler checks whether gnvs has a + * valid pointer before calling the trap handler + */ +extern global_nvs_t *gnvs; + +int mainboard_io_trap_handler(int smif) +{ + switch (smif) { + case 0x99: + printk(BIOS_DEBUG, "Sample\n"); + gnvs->smif = 0; + break; + default: + return 0; + } + + /* On success, the IO Trap Handler returns 0 + * On failure, the IO Trap Handler returns a value != 0 + * + * For now, we force the return value to 0 and log all traps to + * see what's going on. + */ + //gnvs->smif = 0; + return 1; +} diff --git a/src/mainboard/nec/945g-m4/superio_hwm.c b/src/mainboard/nec/945g-m4/superio_hwm.c new file mode 100644 index 0000000..622f8e8 --- /dev/null +++ b/src/mainboard/nec/945g-m4/superio_hwm.c @@ -0,0 +1,161 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * Copyright (C) 2014 Edward O'Callaghan eocallaghan@alterapraxis.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <types.h> +#include <device/device.h> +#include <console/console.h> +#include <arch/io.h> +#include <pc80/mc146818rtc.h> + +#include "superio_hwm.h" + +/* Hardware Monitor */ + +#define FAN_CRUISE_CONTROL_DISABLED 0 +#define FAN_CRUISE_CONTROL_SPEED 1 +#define FAN_CRUISE_CONTROL_THERMAL 2 + +#define FAN_SPEED_5625 0 +//#define FAN_TEMPERATURE_30DEGC 0 + +#define HWM_BASE 0x290 + +static void hwm_write(u8 reg, u8 value) +{ + outb(reg, HWM_BASE + 0x05); // Index port + outb(value, HWM_BASE + 0x06); // Data port +} + +static void hwm_bank(u8 bank) +{ + hwm_write(0x2e, bank); +} + +struct fan_speed { + u8 fan_in; + u16 fan_speed; +}; + +// FANIN Target Speed Register +// FANIN = 337500 / RPM +struct fan_speed fan_speeds[] = { + { 0x3c, 5625 }, { 0x41, 5192 }, { 0x47, 4753 }, { 0x4e, 4326 }, + { 0x56, 3924 }, { 0x5f, 3552 }, { 0x69, 3214 }, { 0x74, 2909 }, + { 0x80, 2636 }, { 0x8d, 2393 }, { 0x9b, 2177 }, { 0xaa, 1985 }, + { 0xba, 1814 }, { 0xcb, 1662 }, { 0xdd, 1527 }, { 0xf0, 1406 } +}; + +struct temperature { + u8 deg_celsius; + u8 deg_fahrenheit; +}; + +struct temperature temperatures[] = { + { 30, 86 }, { 33, 91 }, { 36, 96 }, { 39, 102 }, + { 42, 107 }, { 45, 113 }, { 48, 118 }, { 51, 123 }, + { 54, 129 }, { 57, 134 }, { 60, 140 }, { 63, 145 }, + { 66, 150 }, { 69, 156 }, { 72, 161 }, { 75, 167 } +}; + +void hwm_setup(void) +{ + int cpufan_control = 0, sysfan_control = 0; + int cpufan_speed = 0, sysfan_speed = 0; + int cpufan_temperature = 0, sysfan_temperature = 0; + + if (get_option(&cpufan_control, "cpufan_cruise_control") != CB_SUCCESS) + cpufan_control = FAN_CRUISE_CONTROL_DISABLED; + if (get_option(&cpufan_speed, "cpufan_speed") != CB_SUCCESS) + cpufan_speed = FAN_SPEED_5625; + //if (get_option(&cpufan_temperature, "cpufan_temperature") != CB_SUCCESS) + // cpufan_temperature = FAN_TEMPERATURE_30DEGC; + + if (get_option(&sysfan_control, "sysfan_cruise_control") != CB_SUCCESS) + sysfan_control = FAN_CRUISE_CONTROL_DISABLED; + if (get_option(&sysfan_speed, "sysfan_speed") != CB_SUCCESS) + sysfan_speed = FAN_SPEED_5625; + //if (get_option(&sysfan_temperature, "sysfan_temperature") != CB_SUCCESS) + // sysfan_temperature = FAN_TEMPERATURE_30DEGC; + + // hwm_write(0x31, 0x20); // AVCC high limit + // hwm_write(0x34, 0x06); // VIN2 low limit + + hwm_bank(0); + hwm_write(0x59, 0x20); // Diode Selection + hwm_write(0x5d, 0x0f); // All Sensors Diode, not Thermistor + + hwm_bank(4); + hwm_write(0x54, 0xf1); // SYSTIN temperature offset + hwm_write(0x55, 0x19); // CPUTIN temperature offset + hwm_write(0x56, 0xfc); // AUXTIN temperature offset + + hwm_bank(0x80); // Default + + u8 fan_config = 0; + // 00 FANOUT is Manual Mode + // 01 FANOUT is Thermal Cruise Mode + // 10 FANOUT is Fan Speed Cruise Mode + switch (cpufan_control) { + case FAN_CRUISE_CONTROL_SPEED: fan_config |= (2 << 4); break; + case FAN_CRUISE_CONTROL_THERMAL: fan_config |= (1 << 4); break; + } + switch (sysfan_control) { + case FAN_CRUISE_CONTROL_SPEED: fan_config |= (2 << 2); break; + case FAN_CRUISE_CONTROL_THERMAL: fan_config |= (1 << 2); break; + } + // This register must be written first + hwm_write(0x04, fan_config); + + switch (cpufan_control) { + case FAN_CRUISE_CONTROL_SPEED: + printk(BIOS_DEBUG, "Fan Cruise Control setting CPU fan to %d RPM\n", + fan_speeds[cpufan_speed].fan_speed); + hwm_write(0x06, fan_speeds[cpufan_speed].fan_in); // CPUFANIN target speed + break; + case FAN_CRUISE_CONTROL_THERMAL: + printk(BIOS_DEBUG, "Fan Cruise Control setting CPU fan to activation at %d deg C/%d deg F\n", + temperatures[cpufan_temperature].deg_celsius, + temperatures[cpufan_temperature].deg_fahrenheit); + hwm_write(0x06, temperatures[cpufan_temperature].deg_celsius); // CPUFANIN target temperature + break; + } + + switch (sysfan_control) { + case FAN_CRUISE_CONTROL_SPEED: + printk(BIOS_DEBUG, "Fan Cruise Control setting system fan to %d RPM\n", + fan_speeds[sysfan_speed].fan_speed); + hwm_write(0x05, fan_speeds[sysfan_speed].fan_in); // SYSFANIN target speed + break; + case FAN_CRUISE_CONTROL_THERMAL: + printk(BIOS_DEBUG, "Fan Cruise Control setting system fan to activation at %d deg C/%d deg F\n", + temperatures[sysfan_temperature].deg_celsius, + temperatures[sysfan_temperature].deg_fahrenheit); + hwm_write(0x05, temperatures[sysfan_temperature].deg_celsius); // SYSFANIN target temperature + break; + } + + hwm_write(0x0e, 0x02); // Fan Output Step Down Time + hwm_write(0x0f, 0x02); // Fan Output Step Up Time + + hwm_write(0x47, 0xaf); // FAN divisor register + hwm_write(0x4b, 0x84); // AUXFANIN speed divisor + + hwm_write(0x40, 0x01); // Init, but no SMI# +} diff --git a/src/mainboard/nec/945g-m4/superio_hwm.h b/src/mainboard/nec/945g-m4/superio_hwm.h new file mode 100644 index 0000000..346b97c --- /dev/null +++ b/src/mainboard/nec/945g-m4/superio_hwm.h @@ -0,0 +1,25 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Edward O'Callaghan eocallaghan@alterapraxis.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef SUPERIO_HWM_H +#define SUPERIO_HWM_H + +void hwm_setup(void); + +#endif /* SUPERIO_HWM_H */ diff --git a/src/mainboard/nec/Kconfig b/src/mainboard/nec/Kconfig index 30a2c67..b8bb2d6 100644 --- a/src/mainboard/nec/Kconfig +++ b/src/mainboard/nec/Kconfig @@ -21,11 +21,16 @@ if VENDOR_NEC choice prompt "Mainboard model"
-source "src/mainboard/nec/*/Kconfig.name" +config BOARD_NEC_POWERMATE_2000 + bool "PowerMate 2000" + +config BOARD_NEC_945G_M4 + bool "945g-m4"
endchoice
-source "src/mainboard/nec/*/Kconfig" +source "src/mainboard/nec/powermate2000/Kconfig" +source "src/mainboard/nec/945g-m4/Kconfig"
config MAINBOARD_VENDOR string diff --git a/src/northbridge/intel/i945/raminit.c b/src/northbridge/intel/i945/raminit.c index bd6e0c9..1b8ccf0 100644 --- a/src/northbridge/intel/i945/raminit.c +++ b/src/northbridge/intel/i945/raminit.c @@ -2326,18 +2326,32 @@ static void sdram_pre_jedec_initialization(void) u32 reg32;
reg32 = MCHBAR32(WCC); - reg32 &= 0x113ff3ff; - reg32 |= (4 << 29) | (3 << 25) | (1 << 10); - MCHBAR32(WCC) = reg32; + if (pci_read_config32(PCI_DEV(0, 0x00,0), 0x02) == 0x2770) + { + reg32 &= 0xf3fff7ff; + reg32 |= (1 << 25) | (3 << 22) | (1 << 10); + MCHBAR32(WCC) = reg32; + MCHBAR32(MMARB0) |= (3 << 7)|(3 << 8); + MCHBAR32(MMARB1) |= (1 << 18)|(3 << 12); + if (pci_read_config32(PCI_DEV(0, 0x00,0), 0xe4) & 0x2000 && pci_read_config32(PCI_DEV(0, 0x00,0), 0x54) & 8) + { + MCHBAR32(MMARB1) &= ~(7 << 8); + } + MCHBAR32(MMARB1 +4) |= (3 << 12); + } else { + reg32 &= 0x113ff3ff; + reg32 |= (4 << 29) | (3 << 25) | (1 << 10);
- MCHBAR32(SMVREFC) |= (1 << 6); + MCHBAR32(WCC) = reg32;
- MCHBAR32(MMARB0) &= ~(3 << 17); - MCHBAR32(MMARB0) |= (1 << 21) | (1 << 16); + MCHBAR32(SMVREFC) |= (1 << 6);
- MCHBAR32(MMARB1) &= ~(7 << 8); - MCHBAR32(MMARB1) |= (3 << 8); + MCHBAR32(MMARB0) &= ~(3 << 17); + MCHBAR32(MMARB0) |= (1 << 21) | (1 << 16);
+ MCHBAR32(MMARB1) &= ~(7 << 8); + MCHBAR32(MMARB1) |= (3 << 8); + } /* Adaptive Idle Timer Control */ MCHBAR32(C0AIT) = 0x000006c4; MCHBAR32(C0AIT+4) = 0x871a066d; @@ -2617,6 +2631,11 @@ static void sdram_power_management(struct sys_info *sysinfo) reg8 |= (1 << 2); pci_write_config8(PCI_DEV(0, 0x2, 0), 0xc1, reg8);
+if (pci_read_config32(PCI_DEV(0, 0x00,0), 0x02) == 0x2770) { + MCHBAR16(MIPMC4) |= 0x6000; + MCHBAR16(MIPMC5) |= 0x6000; + MCHBAR16(MIPMC6) |= 0x6000; +}else{ #ifdef C2_SELF_REFRESH_DISABLE
if (integrated_graphics) { @@ -2641,7 +2660,7 @@ static void sdram_power_management(struct sys_info *sysinfo) }
#endif - +} reg32 = MCHBAR32(PMCFG); reg32 &= ~(3 << 17); reg32 |= (2 << 17);
