the following patch was just integrated into master: commit 9f470b1930d1eaec9cd72243a457edb03df151e4 Author: William wu wulf@rock-chips.com Date: Thu Nov 10 19:34:45 2016 +0800
google/gru: Tune USB 2.0 PHY to increase compatibility
When testing USB 2.0 compatibility with different kinds of USB 2.0 devices on Kevin board, we find that some USB HDDs (e.g. seagate SRD00F1 1TB HDD) and some smart phones (e.g. galaxy A5 smart phone) can't be detected. And according to the error log, this issue is related to USB 2.0 PHY signal problem.
For the USB HDD, error log is: [ 592.557724] usb 5-1: new high-speed USB device number 2 using xhci-hcd [ 592.847735] usb 5-1: new high-speed USB device number 3 using xhci-hcd [ 593.473720] usb 5-1: new high-speed USB device number 6 using xhci-hcd [ 594.187717] usb 5-1: new high-speed USB device number 9 using xhci-hcd [ 595.020717] usb 5-1: new high-speed USB device number 13 using xhci-hcd [ 595.284730] usb 5-1: new high-speed USB device number 14 using xhci-hcd [ 595.574816] usb 5-1: new high-speed USB device number 15 using xhci-hcd
The log shows that HDD failed to high-speed handshake.
For the smart phone, error log is: [ 1145.661625] usb 5-1: new high-speed USB device number 2 using xhci-hcd [ 1145.771674] usb 5-1: device descriptor read/64, error -71 [ 1145.979752] usb 5-1: device descriptor read/64, error -71 [ 1146.187721] usb 5-1: new high-speed USB device number 3 using xhci-hcd [ 1146.301754] usb 5-1: device descriptor read/64, error -71 [ 1146.509750] usb 5-1: device descriptor read/64, error -71 [ 1146.717722] usb 5-1: new high-speed USB device number 4 using xhci-hcd [ 1146.724393] usb 5-1: Device not responding to setup address. [ 1146.930795] usb 5-1: Device not responding to setup address. [ 1147.137720] usb 5-1: device not accepting address 4, error -71 [ 1147.246644] usb 5-1: new high-speed USB device number 5 using xhci-hcd [ 1147.253336] usb 5-1: Device not responding to setup address. [ 1147.459786] usb 5-1: Device not responding to setup address. [ 1147.665712] usb 5-1: device not accepting address 5, error -71 [ 1147.671789] usb usb5-port1: unable to enumerate USB device
The log shows that smart phone failed to read device descriptor, error -71 may be caused by PHY signal problem.
This patch aims to tune USB 2.0 PHY with the following parameters to support USB HDD, smart phone and some other potential USB 2.0 devices.
1. Disable the pre-emphasize in chirp state to avoid high-speed handshake failure.
2. Bypass ODT auto compensation to enable set max driver strength manually. (Bit[42] of usbphy_ctrl register is 1'b1 for bypass, and Bit[41:37] of usbphy_ctrl register is 5'b10000 for max driver strength).
3. Bypass ODT auto refresh, and set the max bias current tuning reference. (Bit[57] of usbphy_ctrl register is 1'b1 for bypass, and Bit[52:50] of usbphy_ctrl register is 3b'100 for max bias current tuning reference).
We have done the USB 2.0 compliance test and compatibility test with this patch, it works well.
BRANCH=gru BUG=chrome-os-partner:59623 TEST=plug/unplug USB HDD or smart phone in Type-C port, check if they can be detected successfully.
Change-Id: I275c2236b8e469bfd04e9184d007eb095657225e Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 7735c514d4136978133c2299f2f58da8320bb89f Original-Change-Id: I4e6c10faa1c03af9880a89afe4731a7065eb1e4e Original-Signed-off-by: William wu wulf@rock-chips.com Original-Reviewed-on: https://chromium-review.googlesource.com/409856 Original-Commit-Ready: Eddie Cai eddie.cai.rk@gmail.com Original-Tested-by: Cindy Han cindy.han@samsung.com Original-Reviewed-by: Julius Werner jwerner@chromium.org Reviewed-on: https://review.coreboot.org/17566 Tested-by: build bot (Jenkins) Reviewed-by: Martin Roth martinroth@google.com
See https://review.coreboot.org/17566 for details.
