Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16722
commit e2d4588220d85dd61f0a6812d81e5bbfba93992a Author: Lin Huang hl@rock-chips.com Date: Wed Sep 21 18:19:24 2016 +0800
rockchip/rk3399: dram: improve dram stability when run high frequency
there are two modify in the driver: 1. correctly set speeds base on DDR frequency. Controls the speeds in the predriver circuits to reduce power. SPEED[1:0] 2'b00:less than 800Mbps(400MHz) 2b01 : 800Mbps(400MHz) to 1600Mbps(800MHz) 2b10 : 1600Mbsp(800MHz) to 2400Mbps(1200MHz) 2b11 : 3200Mbps and greater 2. config the number of cycles phy clock pll wait time after locking base on ddr config file.
BRANCH=none BUG=chrome-os-partner:56940 TEST=do memtester on kevin board, and pass
Change-Id: Iaf6da59c6c5c290867e0922a2a99de272f4c7bde Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 125cf8afac3a682d33896fe74a20ba1d498a3bd2 Original-Change-Id: Iabc17df37a701c4f052540c3c259f209a1db3c59 Original-Signed-off-by: Lin Huang hl@rock-chips.com Original-Reviewed-on: https://chromium-review.googlesource.com/387428 Original-Reviewed-by: Douglas Anderson dianders@chromium.org Original-Reviewed-by: Julius Werner jwerner@chromium.org --- src/soc/rockchip/rk3399/sdram.c | 35 ++++++++++++++++++++++++----------- 1 file changed, 24 insertions(+), 11 deletions(-)
diff --git a/src/soc/rockchip/rk3399/sdram.c b/src/soc/rockchip/rk3399/sdram.c index 9211895..1021c6b 100644 --- a/src/soc/rockchip/rk3399/sdram.c +++ b/src/soc/rockchip/rk3399/sdram.c @@ -322,6 +322,7 @@ static void phy_io_config(u32 channel, u32 mode_sel = 0; u32 reg_value; u32 drv_value, odt_value; + u32 speed;
/* vref setting */ if (sdram_params->dramtype == LPDDR4) { @@ -436,22 +437,33 @@ static void phy_io_config(u32 channel, /* PHY_939 PHY_PAD_CS_DRIVE */ clrsetbits_le32(&denali_phy[939], 0x7 << 14, mode_sel << 14);
+ + /* speed setting */ + if (sdram_params->ddr_freq < 400*MHz) + speed = 0x0; + else if (sdram_params->ddr_freq < 800*MHz) + speed = 0x1; + else if (sdram_params->ddr_freq < 1200*MHz) + speed = 0x2; + else + speed = 0x3; + /* PHY_924 PHY_PAD_FDBK_DRIVE */ - clrsetbits_le32(&denali_phy[924], 0x3 << 21, mode_sel << 21); + clrsetbits_le32(&denali_phy[924], 0x3 << 21, speed << 21); /* PHY_926 PHY_PAD_DATA_DRIVE */ - clrsetbits_le32(&denali_phy[926], 0x3 << 9, mode_sel << 9); + clrsetbits_le32(&denali_phy[926], 0x3 << 9, speed << 9); /* PHY_927 PHY_PAD_DQS_DRIVE */ - clrsetbits_le32(&denali_phy[927], 0x3 << 9, mode_sel << 9); + clrsetbits_le32(&denali_phy[927], 0x3 << 9, speed << 9); /* PHY_928 PHY_PAD_ADDR_DRIVE */ - clrsetbits_le32(&denali_phy[928], 0x3 << 17, mode_sel << 17); + clrsetbits_le32(&denali_phy[928], 0x3 << 17, speed << 17); /* PHY_929 PHY_PAD_CLK_DRIVE */ - clrsetbits_le32(&denali_phy[929], 0x3 << 17, mode_sel << 17); + clrsetbits_le32(&denali_phy[929], 0x3 << 17, speed << 17); /* PHY_935 PHY_PAD_CKE_DRIVE */ - clrsetbits_le32(&denali_phy[935], 0x3 << 17, mode_sel << 17); + clrsetbits_le32(&denali_phy[935], 0x3 << 17, speed << 17); /* PHY_937 PHY_PAD_RST_DRIVE */ - clrsetbits_le32(&denali_phy[937], 0x3 << 17, mode_sel << 17); + clrsetbits_le32(&denali_phy[937], 0x3 << 17, speed << 17); /* PHY_939 PHY_PAD_CS_DRIVE */ - clrsetbits_le32(&denali_phy[939], 0x3 << 17, mode_sel << 17); + clrsetbits_le32(&denali_phy[939], 0x3 << 17, speed << 17); }
static void pctl_cfg(u32 channel, @@ -477,9 +489,10 @@ static void pctl_cfg(u32 channel, /* rank count need to set for init */ set_memory_map(channel, sdram_params);
- write32(&denali_phy[910], 0x6400); - write32(&denali_phy[911], 0x01221102); - write32(&denali_phy[912], 0x0); + write32(&denali_phy[910], sdram_params->phy_regs.denali_phy[910]); + write32(&denali_phy[911], sdram_params->phy_regs.denali_phy[911]); + write32(&denali_phy[912], sdram_params->phy_regs.denali_phy[912]); + pwrup_srefresh_exit = read32(&denali_ctl[68]) & PWRUP_SREFRESH_EXIT; clrbits_le32(&denali_ctl[68], PWRUP_SREFRESH_EXIT);
