HAOUAS Elyes has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/36164 )
Change subject: soc/{cannonlake,skylake}: Remove unused 'rdmsr(MSR_CONFIG_TDP_NOMINAL)' ......................................................................
MSR_CONFIG_TDP_NOMINAL is used by 'cpu_get_tdp_nominal_ratio' to return the TDP Nominal Ratio.
Change-Id: I4c8df7a4100c185c1430d993f7618ed00fc556ff Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M src/soc/intel/cannonlake/cpu.c M src/soc/intel/skylake/cpu.c 2 files changed, 0 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/64/36164/1
diff --git a/src/soc/intel/cannonlake/cpu.c b/src/soc/intel/cannonlake/cpu.c index c58b9ad..b95d561 100644 --- a/src/soc/intel/cannonlake/cpu.c +++ b/src/soc/intel/cannonlake/cpu.c @@ -220,7 +220,6 @@
/* Use nominal TDP values for CPUs with configurable TDP */ if (cpu_config_tdp_levels()) { - msr = rdmsr(MSR_CONFIG_TDP_NOMINAL); limit.hi = 0; limit.lo = cpu_get_tdp_nominal_ratio(); wrmsr(MSR_TURBO_ACTIVATION_RATIO, limit); diff --git a/src/soc/intel/skylake/cpu.c b/src/soc/intel/skylake/cpu.c index 1f9ecad..3acaa72 100644 --- a/src/soc/intel/skylake/cpu.c +++ b/src/soc/intel/skylake/cpu.c @@ -231,7 +231,6 @@
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36164 )
Patch Set 1: Code-Review+2
https://review.coreboot.org/c/coreboot/+/36164/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/36164/1//COMMIT_MSG@9 PS1, Line 9: MSR_CONFIG_TDP_NOMINAL is used by 'cpu_get_tdp_nominal_ratio' to return the Gerrit breaks commit message lines at 72 chars...
Nico Huber has submitted this change. ( https://review.coreboot.org/c/coreboot/+/36164 )
Change-Id: I4c8df7a4100c185c1430d993f7618ed00fc556ff Signed-off-by: Elyes HAOUAS ehaouas@noos.fr Reviewed-on: https://review.coreboot.org/c/coreboot/+/36164 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Nico Huber nico.h@gmx.de --- M src/soc/intel/cannonlake/cpu.c M src/soc/intel/skylake/cpu.c 2 files changed, 0 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Nico Huber: Looks good to me, approved
diff --git a/src/soc/intel/cannonlake/cpu.c b/src/soc/intel/cannonlake/cpu.c index 7f38279..c3a27ae 100644 --- a/src/soc/intel/cannonlake/cpu.c +++ b/src/soc/intel/cannonlake/cpu.c @@ -220,7 +220,6 @@
/* Use nominal TDP values for CPUs with configurable TDP */ if (cpu_config_tdp_levels()) { - msr = rdmsr(MSR_CONFIG_TDP_NOMINAL); limit.hi = 0; limit.lo = cpu_get_tdp_nominal_ratio(); wrmsr(MSR_TURBO_ACTIVATION_RATIO, limit); diff --git a/src/soc/intel/skylake/cpu.c b/src/soc/intel/skylake/cpu.c index 080dba0..7a45693 100644 --- a/src/soc/intel/skylake/cpu.c +++ b/src/soc/intel/skylake/cpu.c @@ -231,7 +231,6 @@
