Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6329
commit 0a8e17cb7a881b0f6f033e1387aeed2f233eb9bf Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Mon Jul 21 18:45:14 2014 +0300
AGESA fam15: Use local bus_isa storage
Do not use a global as the value gets discarded anyway.
Change-Id: I86aac304e073f0d74b011548d079e139891ec140 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/mainboard/supermicro/h8qgi/mptable.c | 3 +-- src/mainboard/supermicro/h8scm/mptable.c | 3 +-- src/mainboard/tyan/s8226/mptable.c | 3 +-- 3 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/src/mainboard/supermicro/h8qgi/mptable.c b/src/mainboard/supermicro/h8qgi/mptable.c index 8b36bc7..8a248cc 100644 --- a/src/mainboard/supermicro/h8qgi/mptable.c +++ b/src/mainboard/supermicro/h8qgi/mptable.c @@ -32,12 +32,11 @@ extern u8 bus_sr5650[14]; extern u8 bus_sp5100[2]; extern u32 sbdn_sr5650; extern u32 sbdn_sp5100; -extern int bus_isa; -
static void *smp_write_config_table(void *v) { struct mp_config_table *mc; + int bus_isa; u32 apicid_sp5100; u32 apicid_sr5650; device_t dev; diff --git a/src/mainboard/supermicro/h8scm/mptable.c b/src/mainboard/supermicro/h8scm/mptable.c index 8b36bc7..8a248cc 100644 --- a/src/mainboard/supermicro/h8scm/mptable.c +++ b/src/mainboard/supermicro/h8scm/mptable.c @@ -32,12 +32,11 @@ extern u8 bus_sr5650[14]; extern u8 bus_sp5100[2]; extern u32 sbdn_sr5650; extern u32 sbdn_sp5100; -extern int bus_isa; -
static void *smp_write_config_table(void *v) { struct mp_config_table *mc; + int bus_isa; u32 apicid_sp5100; u32 apicid_sr5650; device_t dev; diff --git a/src/mainboard/tyan/s8226/mptable.c b/src/mainboard/tyan/s8226/mptable.c index 8b36bc7..8a248cc 100644 --- a/src/mainboard/tyan/s8226/mptable.c +++ b/src/mainboard/tyan/s8226/mptable.c @@ -32,12 +32,11 @@ extern u8 bus_sr5650[14]; extern u8 bus_sp5100[2]; extern u32 sbdn_sr5650; extern u32 sbdn_sp5100; -extern int bus_isa; -
