the following patch was just integrated into master: commit 0e53931fee0178c4f4ac4e2e6b355b103b5e8c42 Author: Sol Boucher solb@chromium.org Date: Thu Mar 5 15:38:03 2015 -0800
cbfstool: Clean up in preparation for adding new files
This enables more warnings on the cbfstool codebase and fixes the issues that surface as a result. A memory leak that used to occur when compressing files with lzma is also found and fixed. Finally, there are several fixes for the Makefile: - Its autodependencies used to be broken because the target for the .dependencies file was misnamed; this meant that Make didn't know how to rebuild the file, and so would silently skip the step of updating it before including it. - The ability to build to a custom output directory by defining the obj variable had bitrotted. - The default value of the obj variable was causing implicit rules not to apply when specifying a file as a target without providing a custom value for obj. - Add a distclean target for removing the .dependencies file.
BUG=chromium:461875 TEST=Build an image with cbfstool both before and after. BRANCH=None
Change-Id: I951919d63443f2b053c2e67c1ac9872abc0a43ca Signed-off-by: Sol Boucher solb@chromium.org Original-Commit-Id: 49293443b4e565ca48d284e9a66f80c9c213975d Original-Change-Id: Ia7350c2c3306905984cfa711d5fc4631f0b43d5b Original-Signed-off-by: Sol Boucher solb@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/257340 Original-Reviewed-by: Julius Werner jwerner@chromium.org Original-Reviewed-by: Stefan Reinauer reinauer@chromium.org Reviewed-on: http://review.coreboot.org/9937 Tested-by: build bot (Jenkins) Reviewed-by: Patrick Georgi pgeorgi@google.com
See http://review.coreboot.org/9937 for details.
