Attention is currently required from: Pratikkumar V Prajapati, Subrata Banik.
Hello Subrata Banik, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/77237?usp=email
The following approvals got outdated and were removed: Code-Review+2 by Subrata Banik, Verified+1 by build bot (Jenkins)
The change is no longer submittable: Code-Review and Verified are unsatisfied now.
Change subject: soc/intel/common: Make common cpu_cl_clear_data() weak ......................................................................
Not all SOC follow the same programming to clear crashlog data. So make common implementation of cpu_cl_clear_data() weak.
BUG=b:262501347 TEST=Able to build google/rex.
Change-Id: Ic2b4631d57703abff0ab1880fb272ef67bb1b8e9 Signed-off-by: Pratikkumar Prajapati pratikkumar.v.prajapati@intel.com --- M src/soc/intel/common/block/crashlog/crashlog.c 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/37/77237/5
