Attention is currently required from: Felix Singer, Subrata Banik, Michael Niewöhner, Patrick Rudolph. Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/60943 )
Change subject: soc/intel/tgl/pcie_rp: correct root port map ......................................................................
Patch Set 1:
File src/soc/intel/tigerlake/pcie_rp.c:
https://review.coreboot.org/c/coreboot/+/60943/comment/01e0d2e1_6b89861f PS1, Line 21: static bool is_part_of_group(const struct device *dev, : const struct pcie_rp_group *groups) : { : if (dev->path.type != DEVICE_PATH_PCI) : return false; : : const unsigned int slot_to_find = PCI_SLOT(dev->path.pci.devfn); : const unsigned int fn_to_find = PCI_FUNC(dev->path.pci.devfn); : const struct pcie_rp_group *group; : unsigned int i; : unsigned int fn; : : for (group = groups; group->count; ++group) { : for (i = 0, fn = rp_start_fn(group); i < group->count; i++, fn++) { : if (slot_to_find == group->slot && fn_to_find == fn) : return true; : } : } : : return false; : } :
This seems pretty generic and could be common code. The inner loop […]
It could be. The only consumer of it for now is the PMC IPC driver, which IIUC is only applicable for TGL onwards. I believe prior to TGL the RTD3 sequence for PCIe RPs was quite different and did not involve sending any PMC IPC messages.
