Aamir Bohra has uploaded this change for review. ( https://review.coreboot.org/21868
Change subject: src/device: Update LTR configuration scheme ......................................................................
This patch moves out LTR programming under L1 substate to pchexp_tune_device function, as substate programming and LTR programming are independent.
LTR programming scheme is updated to check LTR is enabled and supported for entire link and only then LTR for device needs to be enabled to comply with PCI base specification (rev 3.1a, section 6.18). And remove explicit LTR enable programming for root device under L1 substate.
BRANCH=none BUG=b:66722364 TEST=Verify LTR is configured for end point device only when all parent devices in link has LTR enabled and max snoop latency gets configured.
Change-Id: I6be99c3b590c1457adf88bc1b40f128fcade3fbe Signed-off-by: Aamir Bohra aamir.bohra@intel.com --- M src/device/pciexp_device.c M src/include/device/pci_def.h 2 files changed, 43 insertions(+), 9 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/21868/1
diff --git a/src/device/pciexp_device.c b/src/device/pciexp_device.c index 40c3f8c..e3859d8 100644 --- a/src/device/pciexp_device.c +++ b/src/device/pciexp_device.c @@ -149,16 +149,49 @@ root->ops->ops_pci->set_L1_ss_latency(dev, cap + 4); }
-static void pciexp_enable_ltr(device_t dev) +static unsigned int pciexp_is_ltrenable(device_t dev) { unsigned int cap; cap = pci_find_capability(dev, PCI_CAP_ID_PCIE); - if(!cap) { + if (cap && pci_read_config16(dev, cap + PCI_EXP_DEV_CAP2_OFFSET) & + 1 << 11 && pci_read_config16(dev, cap + +PCI__EXP_DEV_CTL_STS2_CAP_OFFSET) & 1 << 10) + return 1; + + return 0; +} + +static void pciexp_enable_ltr(device_t dev) +{ + unsigned int cap; + device_t root; + + cap = pci_find_capability(dev, PCI_CAP_ID_PCIE); + /* Check if capibility pointer is valid and dev ltrms is enabled*/ + if (!cap && pci_read_config16(dev, cap + PCI_EXP_DEV_CAP2_OFFSET) & + 1 << 11) { printk(BIOS_INFO, "Failed to enable LTR for dev = %s\n", dev_path(dev)); return; } - pci_update_config32(dev, cap + 0x28, ~(1 << 10), 1 << 10); + for (root = dev->bus->dev; root->path.type != DEVICE_PATH_DOMAIN; + root = root->bus->dev) { + if (pciexp_is_ltrenable(root)) + continue; + break; + } + if (root->path.type == DEVICE_PATH_DOMAIN) { + pci_update_config32(dev, cap + + PCI__EXP_DEV_CTL_STS2_CAP_OFFSET, + ~(1 << 10), 1 << 10); + pciexp_config_max_latency(dev->bus->dev, dev); + } + else + printk(BIOS_INFO, + " Failed to enable LTR for dev %s" + "as link ltr support is disabled\n", + dev_path(dev)); + return; }
static unsigned char pciexp_L1_substate_cal(device_t dev, unsigned int endp_cap, @@ -232,8 +265,6 @@ printk(BIOS_INFO, "Power On Value = 0x%x, Power On Scale = 0x%x\n", endp_power_on_value, power_on_scale);
- pciexp_enable_ltr(root); - pci_update_config32(root, root_cap + 0x08, ~0xff00, (comm_mode_rst_time << 8));
@@ -255,10 +286,6 @@
pci_update_config32(dev_t, end_cap + 0x08, ~0x1f, L1SubStateSupport); - - pciexp_enable_ltr(dev_t); - - pciexp_config_max_latency(root, dev_t); } }
@@ -391,6 +418,9 @@ if (IS_ENABLED(CONFIG_PCIEXP_L1_SUB_STATE)) pciexp_config_L1_sub_state(root, dev);
+ /* Check for LTR support and enable */ + pciexp_enable_ltr(dev); + /* Check for and enable ASPM */ if (IS_ENABLED(CONFIG_PCIEXP_ASPM)) pciexp_enable_aspm(root, root_cap, dev, cap); diff --git a/src/include/device/pci_def.h b/src/include/device/pci_def.h index 1674ee1..a7e032c 100644 --- a/src/include/device/pci_def.h +++ b/src/include/device/pci_def.h @@ -373,6 +373,10 @@ #define PCI_EXP_DEVCAP 4 /* Device capabilities */ #define PCI_EXP_DEVCAP_PAYLOAD 0x07 /* Max_Payload_Size */ #define PCI_EXP_DEVCAP_PHANTOM 0x18 /* Phantom functions */ +/* Device Capabilities 2 offset */ +#define PCI_EXP_DEV_CAP2_OFFSET 0x24 +/* Device Control Status 2 offset*/ +#define PCI__EXP_DEV_CTL_STS2_CAP_OFFSET 0x28 #define PCI_EXP_DEVCAP_EXT_TAG 0x20 /* Extended tags */ #define PCI_EXP_DEVCAP_L0S 0x1c0 /* L0s Acceptable Latency */ #define PCI_EXP_DEVCAP_L1 0xe00 /* L1 Acceptable Latency */
