Andrey Petrov (andrey.petrov@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14469
commit 912a31e08db6338dbc3a6862babdd4b87da1f3bd Author: Divya Sasidharan divya.s.sasidharan@intel.com Date: Fri Feb 5 11:27:44 2016 -0800
soc/intel/apollolake: Enable LPC bus interface
Enables LPC serial IRQ as well as adds some LPC constants.
Change-Id: Ic270e66dbf07240229d4783f80e2ec02007c36c2 Signed-off-by: Divya Sasidharan divya.s.sasidharan@intel.com Signed-off-by: Freddy Paul freddy.paul@intel.com --- src/soc/intel/apollolake/chip.h | 4 ++++ src/soc/intel/apollolake/include/soc/lpc.h | 30 ++++++++++++++++++++++++++++++ src/soc/intel/apollolake/lpc.c | 23 ++++++++++++++++++++++- 3 files changed, 56 insertions(+), 1 deletion(-)
diff --git a/src/soc/intel/apollolake/chip.h b/src/soc/intel/apollolake/chip.h index 9d2bc46..a5c7ac2 100644 --- a/src/soc/intel/apollolake/chip.h +++ b/src/soc/intel/apollolake/chip.h @@ -32,6 +32,10 @@ struct soc_intel_apollolake_config { uint8_t pcie_rp3_clkreq_pin; uint8_t pcie_rp4_clkreq_pin; uint8_t pcie_rp5_clkreq_pin; + + /* Generic IO decode ranges */ + uint32_t gen1_dec; + uint32_t gen2_dec; };
#endif /* _SOC_APOLLOLAKE_CHIP_H_ */ diff --git a/src/soc/intel/apollolake/include/soc/lpc.h b/src/soc/intel/apollolake/include/soc/lpc.h new file mode 100644 index 0000000..87e92c3 --- /dev/null +++ b/src/soc/intel/apollolake/include/soc/lpc.h @@ -0,0 +1,30 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Intel Corp. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _SOC_APOLLOLAKE_LPC_H +#define _SOC_APOLLOLAKE_LPC_H + +/* PCI Configuration Space (D31:F0): LPC */ +#define SERIRQ_CNTL 0x64 /* Serial IRQ Control Register */ +#define LPC_IO_DEC 0x80 /* IO Decode Ranges Register */ +#define LPC_EN 0x82 /* LPC IF Enables Register */ +#define MC_LPC_EN (1 << 11) /* 0x62/0x66 */ +#define KBC_LPC_EN (1 << 10) /* 0x60/0x64 */ +#define GAMEL_LPC_EN (1 << 8) /* 0x200/0x207 */ +#define LPC_GEN1_DEC 0x84 /* LPC IF Generic Decode Range 1 */ +#define LPC_GEN2_DEC 0x88 /* LPC IF Generic Decode Range 2 */ + +#endif //_SOC_APOLLOLAKE_LPC_H diff --git a/src/soc/intel/apollolake/lpc.c b/src/soc/intel/apollolake/lpc.c index 902ada2..aadf18b 100644 --- a/src/soc/intel/apollolake/lpc.c +++ b/src/soc/intel/apollolake/lpc.c @@ -1,7 +1,7 @@ /* * This file is part of the coreboot project. * - * Copyright (C) 2016 Intel Corp. + * Copyright (C) 2015 Intel Corp. * (Written by Lance Zhao lijian.zhao@intel.com for Intel Corp.) * * This program is free software; you can redistribute it and/or modify @@ -20,6 +20,25 @@ #include <device/pci_ids.h> #include <soc/acpi.h> #include <soc/pci_ids.h> +#include <reg_script.h> +#include <vendorcode/google/chromeos/chromeos.h> +#include <soc/lpc.h> +#include "chip.h" + +static const struct reg_script lpc_serirq_enable[] = { + /* Setup SERIRQ, enable continuous mode */ + REG_PCI_OR8(SERIRQ_CNTL, (1 << 7) | (1 << 6)), +#if !IS_ENABLED(CONFIG_SERIRQ_CONTINUOUS_MODE) + REG_PCI_RMW8(SERIRQ_CNTL, ~(1 << 6), 0), +#endif + REG_SCRIPT_END +}; + +static void lpc_init(struct device *dev) +{ + reg_script_run_on_dev(dev, lpc_serirq_enable); +} +
static void soc_lpc_add_io_resources(device_t dev) { @@ -45,7 +64,9 @@ static struct device_operations device_ops = { .read_resources = &soc_lpc_read_resources, .set_resources = &pci_dev_set_resources, .enable_resources = &pci_dev_enable_resources, + .acpi_inject_dsdt_generator = southbridge_inject_dsdt, .write_acpi_tables = southbridge_write_acpi_tables, + .init = &lpc_init };
static const struct pci_driver soc_lpc __pci_driver = {
