Damien Zammit (damien@zamaudio.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/11306
commit 8cafe3ea3c336c52771752c0fcebb24f8ac1b4d1 Author: Damien Zammit damien@zamaudio.com Date: Wed Aug 19 15:23:32 2015 +1000
gigabyte/ga-g41m-es2l: Add mainboard
Board uses x4x native raminit
Board boots into Debian 8 with full graphics
VGA: - VGA native init works in grub with analog connector - Fails to boot with both channels of ram populated
Change-Id: I7417813456817529b8cbaace45cefe47467d0a82 Signed-off-by: Damien Zammit damien@zamaudio.com --- src/mainboard/gigabyte/ga-g41m-es2l/Kconfig | 51 +++++++ src/mainboard/gigabyte/ga-g41m-es2l/Kconfig.name | 2 + src/mainboard/gigabyte/ga-g41m-es2l/Makefile.inc | 1 + src/mainboard/gigabyte/ga-g41m-es2l/acpi/ec.asl | 1 + .../gigabyte/ga-g41m-es2l/acpi/ich7_pci_irqs.asl | 34 +++++ .../gigabyte/ga-g41m-es2l/acpi/platform.asl | 28 ++++ .../gigabyte/ga-g41m-es2l/acpi/superio.asl | 1 + .../gigabyte/ga-g41m-es2l/acpi/x4x_pci_irqs.asl | 66 +++++++++ src/mainboard/gigabyte/ga-g41m-es2l/acpi_tables.c | 37 +++++ src/mainboard/gigabyte/ga-g41m-es2l/board_info.txt | 5 + src/mainboard/gigabyte/ga-g41m-es2l/cstates.c | 37 +++++ src/mainboard/gigabyte/ga-g41m-es2l/devicetree.cb | 85 +++++++++++ src/mainboard/gigabyte/ga-g41m-es2l/dsdt.asl | 46 ++++++ src/mainboard/gigabyte/ga-g41m-es2l/hda_verb.c | 7 + src/mainboard/gigabyte/ga-g41m-es2l/romstage.c | 156 +++++++++++++++++++++ 15 files changed, 557 insertions(+)
diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/Kconfig b/src/mainboard/gigabyte/ga-g41m-es2l/Kconfig new file mode 100644 index 0000000..ed18ca7 --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/Kconfig @@ -0,0 +1,51 @@ +# +# This file is part of the coreboot project. +# +# Copyright (C) 2015 Damien Zammit damien@zamaudio.com +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; version 2 of the License. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +if BOARD_GIGABYTE_GA_G41M_ES2L + +config BOARD_SPECIFIC_OPTIONS + def_bool y + select ARCH_X86 + select CPU_INTEL_SOCKET_LGA775 + select NORTHBRIDGE_INTEL_X4X + select SOUTHBRIDGE_INTEL_I82801GX + select SUPERIO_ITE_IT8718F + select HAVE_ACPI_TABLES + select BOARD_ROMSIZE_KB_1024 + select INTEL_EDID + select MAINBOARD_HAS_NATIVE_VGA_INIT + select MAINBOARD_DO_NATIVE_VGA_INIT + +config MMCONF_BASE_ADDRESS + hex + default 0xe0000000 + +# First 0x100 bytes of rom is protected, +# cant be flashed in-place with external programmer. +# So shrink CBFS to not go there. +config CBFS_SIZE + hex "Size of CBFS filesystem in ROM" + default 0xFFF00 + + +config MAINBOARD_DIR + string + default "gigabyte/ga-g41m-es2l" + +config MAINBOARD_PART_NUMBER + string + default "GA-G41M-ES2L" + +endif # BOARD_GIGABYTE_GA_G41M_ES2L diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/Kconfig.name b/src/mainboard/gigabyte/ga-g41m-es2l/Kconfig.name new file mode 100644 index 0000000..e685ce1 --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_GIGABYTE_GA_G41M_ES2L + bool "GA-G41M-ES2L" diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/Makefile.inc b/src/mainboard/gigabyte/ga-g41m-es2l/Makefile.inc new file mode 100644 index 0000000..f9621db --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/Makefile.inc @@ -0,0 +1 @@ +ramstage-y += cstates.c diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/acpi/ec.asl b/src/mainboard/gigabyte/ga-g41m-es2l/acpi/ec.asl new file mode 100644 index 0000000..2997587 --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/acpi/ec.asl @@ -0,0 +1 @@ +/* dummy */ diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/acpi/ich7_pci_irqs.asl b/src/mainboard/gigabyte/ga-g41m-es2l/acpi/ich7_pci_irqs.asl new file mode 100644 index 0000000..0a69f3d --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/acpi/ich7_pci_irqs.asl @@ -0,0 +1,34 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Damien Zammit damien@zamaudio.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* This is board specific information: + * IRQ routing for the 0:1e.0 PCI bridge of the ICH7 + */ + +If (PICM) { + Return (Package() { + Package() { 0x001effff, 0, 0, 17}, + Package() { 0x001effff, 1, 0, 20}, + Package() { 0x001effff, 2, 0, 16}, + Package() { 0x001effff, 3, 0, 16}, + }) +} Else { + Return (Package() { + Package() { 0x001effff, 0, _SB.PCI0.LPCB.LNKB, 0}, + Package() { 0x001effff, 1, _SB.PCI0.LPCB.LNKE, 0}, + Package() { 0x001effff, 2, _SB.PCI0.LPCB.LNKA, 0}, + Package() { 0x001effff, 3, _SB.PCI0.LPCB.LNKA, 0}, + }) +} diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/acpi/platform.asl b/src/mainboard/gigabyte/ga-g41m-es2l/acpi/platform.asl new file mode 100644 index 0000000..6c92a4e --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/acpi/platform.asl @@ -0,0 +1,28 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Damien Zammit damien@zamaudio.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +Method(_PIC, 1) +{ + /* Remember the OS' IRQ routing choice. */ + Store(Arg0, PICM) +} + +/* SMI I/O Trap */ +Method(TRAP, 1, Serialized) +{ + Store (Arg0, SMIF) /* SMI Function */ + Store (0, TRP0) /* Generate trap */ + Return (SMIF) /* Return value of SMI handler */ +} diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/acpi/superio.asl b/src/mainboard/gigabyte/ga-g41m-es2l/acpi/superio.asl new file mode 100644 index 0000000..2997587 --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/acpi/superio.asl @@ -0,0 +1 @@ +/* dummy */ diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/acpi/x4x_pci_irqs.asl b/src/mainboard/gigabyte/ga-g41m-es2l/acpi/x4x_pci_irqs.asl new file mode 100644 index 0000000..fdfe73d --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/acpi/x4x_pci_irqs.asl @@ -0,0 +1,66 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Damien Zammit damien@zamaudio.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* This is board specific information: IRQ routing for x4x */ + +/* PCI Interrupt Routing */ +Method(_PRT) +{ + If (PICM) { + Return (Package() { + /* Internal GFX */ + Package() { 0x0002ffff, 0, 0, 16 }, + /* High Definition Audio 0:1b.0 */ + Package() { 0x001bffff, 0, 0, 22 }, + /* PCIe Root Ports 0:1c.x */ + Package() { 0x001cffff, 0, 0, 16 }, + Package() { 0x001cffff, 1, 0, 17 }, + Package() { 0x001cffff, 2, 0, 18 }, + Package() { 0x001cffff, 3, 0, 19 }, + /* USB and EHCI 0:1d.x */ + Package() { 0x001dffff, 0, 0, 23 }, + Package() { 0x001dffff, 1, 0, 19 }, + Package() { 0x001dffff, 2, 0, 18 }, + Package() { 0x001dffff, 3, 0, 16 }, + Package() { 0x001dffff, 0, 0, 23 }, + /* SMBUS/SATA/PATA 0:1f.2, 0:1f.3 */ + Package() { 0x001fffff, 1, 0, 19 }, + Package() { 0x001fffff, 1, 0, 19 }, + Package() { 0x001fffff, 0, 0, 18 }, + }) + } Else { + Return (Package() { + /* Internal GFX */ + Package() { 0x0002ffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + /* High Definition Audio 0:1b.0 */ + Package() { 0x001bffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + /* PCIe Root Ports 0:1c.x */ + Package() { 0x001cffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + Package() { 0x001cffff, 1, _SB.PCI0.LPCB.LNKB, 0 }, + Package() { 0x001cffff, 2, _SB.PCI0.LPCB.LNKC, 0 }, + Package() { 0x001cffff, 3, _SB.PCI0.LPCB.LNKD, 0 }, + /* USB and EHCI 0:1d.x */ + Package() { 0x001dffff, 0, _SB.PCI0.LPCB.LNKH, 0 }, + Package() { 0x001dffff, 1, _SB.PCI0.LPCB.LNKD, 0 }, + Package() { 0x001dffff, 2, _SB.PCI0.LPCB.LNKC, 0 }, + Package() { 0x001dffff, 3, _SB.PCI0.LPCB.LNKA, 0 }, + Package() { 0x001dffff, 0, _SB.PCI0.LPCB.LNKH, 0 }, + /* SMBUS/SATA/PATA 0:1f.2, 0:1f.3 */ + Package() { 0x001fffff, 1, _SB.PCI0.LPCB.LNKD, 0 }, + Package() { 0x001fffff, 1, _SB.PCI0.LPCB.LNKD, 0 }, + Package() { 0x001fffff, 0, _SB.PCI0.LPCB.LNKC, 0 }, + }) + } +} diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/acpi_tables.c b/src/mainboard/gigabyte/ga-g41m-es2l/acpi_tables.c new file mode 100644 index 0000000..9e684fe --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/acpi_tables.c @@ -0,0 +1,37 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * Copyright (C) 2015 Damien Zammit damien@zamaudio.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <types.h> +#include <string.h> +#include <console/console.h> +#include <arch/acpi.h> +#include <arch/acpigen.h> +#include <arch/smp/mpspec.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <cpu/x86/msr.h> +#include <arch/ioapic.h> + +#include "southbridge/intel/i82801gx/nvs.h" + +void acpi_create_gnvs(global_nvs_t *gnvs) +{ + memset((void *)gnvs, 0, sizeof(*gnvs)); + gnvs->apic = 1; /* Enable APIC */ + gnvs->mpen = 1; /* Enable Multi Processing */ + gnvs->cmap = 0x01; /* Enable COM 1 port */ +} diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/board_info.txt b/src/mainboard/gigabyte/ga-g41m-es2l/board_info.txt new file mode 100644 index 0000000..44ed73a --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/board_info.txt @@ -0,0 +1,5 @@ +Category: desktop +Board URL: +ROM package: SOIC-8 +ROM protocol: SPI +ROM socketed: n diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/cstates.c b/src/mainboard/gigabyte/ga-g41m-es2l/cstates.c new file mode 100644 index 0000000..dbac2ed --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/cstates.c @@ -0,0 +1,37 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 secunet Security Networks AG + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <arch/acpigen.h> +#include <device/device.h> +#include <southbridge/intel/i82801gx/i82801gx.h> + +static acpi_cstate_t cst_entries[] = { + { + /* acpi C1 / cpu C1 */ + 1, 0x01, 1000, + { ACPI_ADDRESS_SPACE_FIXED, 1, 2, { 1 }, 0, 0 } + }, + { + /* acpi C2 / cpu C2 */ + 2, 0x01, 500, + { ACPI_ADDRESS_SPACE_FIXED, 1, 2, { 1 }, 0x10, 0 } + }, +}; + +int get_cst_entries(acpi_cstate_t **entries) +{ + *entries = cst_entries; + return ARRAY_SIZE(cst_entries); +} diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/devicetree.cb b/src/mainboard/gigabyte/ga-g41m-es2l/devicetree.cb new file mode 100644 index 0000000..78fb2d6 --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/devicetree.cb @@ -0,0 +1,85 @@ +# +# This file is part of the coreboot project. +# +# Copyright (C) 2015 Damien Zammit damien@zamaudio.com +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +chip northbridge/intel/x4x # Northbridge + device cpu_cluster 0 on # APIC cluster + chip cpu/intel/socket_LGA775 + device lapic 0 on end + end + chip cpu/intel/model_1067x # CPU + device lapic 0xACAC off end + register "slfm" = "1" + register "c5" = "1" + register "c6" = "1" + end + end + device domain 0 on # PCI domain + device pci 0.0 on end # Host Bridge + device pci 1.0 off end # PCI Bridge to Management Engine + device pci 2.0 on end # Integrated graphics controller + device pci 3.0 off end # ME + device pci 3.1 off end # ME + chip southbridge/intel/i82801gx # Southbridge + register "pirqa_routing" = "0x0b" + register "pirqb_routing" = "0x0b" + register "pirqc_routing" = "0x0b" + register "pirqd_routing" = "0x0b" + register "pirqe_routing" = "0x0b" + register "pirqf_routing" = "0x0b" + register "pirqg_routing" = "0x0b" + register "pirqh_routing" = "0x0b" + register "ide_legacy_combined" = "0x1" + register "ide_enable_primary" = "0x1" + register "ide_enable_secondary" = "0x0" + register "sata_ahci" = "0x0" + + device pci 1b.0 on end # Audio + device pci 1c.0 on end # PCIe 1 + device pci 1c.1 on end # PCIe 2 + device pci 1d.0 on end # USB + device pci 1d.1 on end # USB + device pci 1d.2 on end # USB + device pci 1d.3 on end # USB + device pci 1d.7 on end # USB + device pci 1e.0 on end # PCI bridge + device pci 1f.0 on # ISA bridge + chip superio/ite/it8718f # Super I/O + device pnp 2e.0 off end # Floppy + device pnp 2e.1 on # COM1 + io 0x60 = 0x3f8 + irq 0x70 = 4 + end + device pnp 2e.2 off end # COM2 + device pnp 2e.3 off end # Parallel port + device pnp 2e.4 off end # Environment controller + device pnp 2e.5 on # Keyboard + io 0x60 = 0x60 + io 0x62 = 0x64 + irq 0x70 = 1 + end + device pnp 2e.6 off end # Mouse + device pnp 2e.7 off end # GPIO + end + end + device pci 1f.1 on end # PATA/IDE + device pci 1f.2 on end # SATA + device pci 1f.3 on end # SMbus + device pci 1f.4 off end + device pci 1f.5 off end + device pci 1f.6 off end + end + end +end diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/dsdt.asl b/src/mainboard/gigabyte/ga-g41m-es2l/dsdt.asl new file mode 100644 index 0000000..dc8f771 --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/dsdt.asl @@ -0,0 +1,46 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * Copyright (C) 2015 Damien Zammit damien@zamaudio.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +DefinitionBlock( + "dsdt.aml", + "DSDT", + 0x02, // DSDT revision: ACPI v2.0 + "COREv4", // OEM id + "COREBOOT", // OEM table id + 0x20090419 // OEM revision +) +{ + // global NVS and variables + #include "acpi/platform.asl" + #include <southbridge/intel/i82801gx/acpi/globalnvs.asl> + + Scope (_SB) { + Device (PCI0) + { + Method(_INI, 0) + { + /* Assume at least Windows XP SP2 */ + Store (2002, OSYS) + } + #include <northbridge/intel/x4x/acpi/x4x.asl> + #include <southbridge/intel/i82801gx/acpi/ich7.asl> + #include <drivers/intel/gma/acpi/default_brightness_levels.asl> + } + } + + /* Chipset specific sleep states */ + #include <southbridge/intel/i82801gx/acpi/sleepstates.asl> +} diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/hda_verb.c b/src/mainboard/gigabyte/ga-g41m-es2l/hda_verb.c new file mode 100644 index 0000000..072a306 --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/hda_verb.c @@ -0,0 +1,7 @@ +#include <device/azalia_device.h> + +const u32 cim_verb_data[0] = {}; + +const u32 pc_beep_verbs[0] = {}; + +AZALIA_ARRAY_SIZES; diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/romstage.c b/src/mainboard/gigabyte/ga-g41m-es2l/romstage.c new file mode 100644 index 0000000..514f5ba --- /dev/null +++ b/src/mainboard/gigabyte/ga-g41m-es2l/romstage.c @@ -0,0 +1,156 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Damien Zammit damien@zamaudio.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <stdint.h> +#include <stdlib.h> +#include <device/pci_def.h> +#include <arch/io.h> +#include <device/pnp_def.h> +#include <console/console.h> +#include <southbridge/intel/i82801gx/i82801gx.h> +#include <northbridge/intel/x4x/x4x.h> +#include <cpu/x86/bist.h> +#include <superio/ite/it8718f/it8718f.h> +#include <superio/ite/common/ite.h> +#include <lib.h> +#include <cpu/intel/romstage.h> +#include <arch/stages.h> +#include <cbmem.h> + +#define SERIAL_DEV PNP_DEV(0x2e, IT8718F_SP1) +#define GPIO_DEV PNP_DEV(0x2e, IT8718F_GPIO) +#define SUPERIO_DEV PNP_DEV(0x2e, 0) + +/* Early mainboard specific GPIO setup. + * We should use standard gpio.h eventually + */ + +static void mb_gpio_init(void) +{ + device_t dev; + + /* Southbridge GPIOs. */ + dev = PCI_DEV(0x0, 0x1f, 0x0); + + /* Set the value for GPIO base address register and enable GPIO. */ + pci_write_config32(dev, GPIO_BASE, (DEFAULT_GPIOBASE | 1)); + pci_write_config8(dev, GPIO_CNTL, 0x10); + + outl(0x1f15f7c0, DEFAULT_GPIOBASE + 0x00); /* GPIO_USE_SEL */ + outl(0xe2e9ffc3, DEFAULT_GPIOBASE + 0x04); /* GP_IO_SEL */ + outl(0xe0d7fcc3, DEFAULT_GPIOBASE + 0x0c); /* GP_LVL */ + outl(0x000039ff, DEFAULT_GPIOBASE + 0x2c); /* GPI_INV */ + outl(0x000000e7, DEFAULT_GPIOBASE + 0x30); + outl(0x000000f0, DEFAULT_GPIOBASE + 0x34); + outl(0x00000083, DEFAULT_GPIOBASE + 0x38); + + /* Set default power management registers */ + pci_write_config32(dev, PMBASE, DEFAULT_PMBASE | 1); + outw(0x0011, DEFAULT_PMBASE + 0x00); + outw(0x0120, DEFAULT_PMBASE + 0x02); + outl(0x00001c01, DEFAULT_PMBASE + 0x04); + outl(0x00bb29d2, DEFAULT_PMBASE + 0x08); + outl(0x000000a0, DEFAULT_PMBASE + 0x10); + outl(0xc5000000, DEFAULT_PMBASE + 0x28); + outl(0x00000040, DEFAULT_PMBASE + 0x2c); + outw(0x13e0, DEFAULT_PMBASE + 0x44); + outw(0x003f, DEFAULT_PMBASE + 0x60); + outw(0x0800, DEFAULT_PMBASE + 0x68); + outw(0x0008, DEFAULT_PMBASE + 0x6a); + outw(0x003f, DEFAULT_PMBASE + 0x72); + + /* Set default GPIOs on superio */ + ite_reg_write(GPIO_DEV, 0x25, 0x00); + ite_reg_write(GPIO_DEV, 0x26, 0xc7); + ite_reg_write(GPIO_DEV, 0x27, 0x80); + ite_reg_write(GPIO_DEV, 0x28, 0x41); + ite_reg_write(GPIO_DEV, 0x29, 0x0a); + ite_reg_write(GPIO_DEV, 0x2c, 0x01); + ite_reg_write(GPIO_DEV, 0x62, 0x08); + ite_reg_write(GPIO_DEV, 0x62, 0x08); + ite_reg_write(GPIO_DEV, 0x72, 0x00); + ite_reg_write(GPIO_DEV, 0x73, 0x00); + ite_reg_write(GPIO_DEV, 0xbb, 0x40); + ite_reg_write(GPIO_DEV, 0xc0, 0x00); + ite_reg_write(GPIO_DEV, 0xc1, 0xc7); + ite_reg_write(GPIO_DEV, 0xc2, 0x80); + ite_reg_write(GPIO_DEV, 0xc3, 0x01); + ite_reg_write(GPIO_DEV, 0xc4, 0x0a); + ite_reg_write(GPIO_DEV, 0xc8, 0x00); + ite_reg_write(GPIO_DEV, 0xc9, 0x04); + ite_reg_write(GPIO_DEV, 0xcb, 0x00); + ite_reg_write(GPIO_DEV, 0xcc, 0x02); + ite_reg_write(GPIO_DEV, 0xf0, 0x10); + ite_reg_write(GPIO_DEV, 0xf1, 0x40); + ite_reg_write(GPIO_DEV, 0xf6, 0x26); + ite_reg_write(GPIO_DEV, 0xfc, 0x52); + + /* IRQ routing */ + RCBA32(0x3100) = 0x00002210; + RCBA32(0x3104) = 0x00002100; + RCBA32(0x3108) = 0x10004321; + RCBA32(0x310c) = 0x00214321; + RCBA32(0x3110) = 0x00000001; + RCBA32(0x3140) = 0x00410032; + RCBA32(0x3144) = 0x32100237; + + /* Enable IOAPIC */ + RCBA8(0x31ff) = 0x03; + RCBA8(0x31ff); +} + +static void ich7_enable_lpc(void) +{ + /* Disable Serial IRQ */ + pci_write_config8(PCI_DEV(0, 0x1f, 0), 0x64, 0x00); + /* Decode range */ + pci_write_config16(PCI_DEV(0, 0x1f, 0), 0x80, 0x0010); + pci_write_config16(PCI_DEV(0, 0x1f, 0), LPC_EN, + CNF1_LPC_EN | CNF2_LPC_EN | KBC_LPC_EN | COMA_LPC_EN | COMB_LPC_EN); + + pci_write_config16(PCI_DEV(0, 0x1f, 0), 0x88, 0x0291); + pci_write_config16(PCI_DEV(0, 0x1f, 0), 0x8a, 0x007c); +} + +void main(unsigned long bist) +{ + // ch0 ch1 + const u8 spd_addrmap[4] = { 0x50, 0, 0x52, 0 }; + + /* Disable watchdog timer and route port 80 to LPC */ + RCBA32(0x3410) = (RCBA32(0x3410) | 0x20);// & ~0x4; + + /* Set southbridge and Super I/O GPIOs. */ + mb_gpio_init(); + + ich7_enable_lpc(); + ite_enable_serial(SERIAL_DEV, CONFIG_TTYS0_BASE); + + /* Disable SIO reboot */ + ite_reg_write(GPIO_DEV, 0xEF, 0x7E); + + console_init(); + + report_bist_failure(bist); + enable_smbus(); + + x4x_early_init(); + + printk(BIOS_DEBUG, "Initializing memory\n"); + sdram_initialize(0, spd_addrmap); + quick_ram_check(); + printk(BIOS_DEBUG, "Memory initialized\n"); +}
