Nico Huber has uploaded this change for review. ( https://review.coreboot.org/27057
Change subject: gma registers: Add Read_GTT() procedure ......................................................................
Change-Id: I0f8091b8958d0c228430fad4b8343fc362a2dbb7 Signed-off-by: Nico Huber nico.h@gmx.de --- M common/hw-gfx-gma-registers.adb M common/hw-gfx-gma-registers.ads M common/hw-gfx-gma.adb M common/hw-gfx-gma.ads 4 files changed, 54 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/libgfxinit refs/changes/57/27057/1
diff --git a/common/hw-gfx-gma-registers.adb b/common/hw-gfx-gma-registers.adb index 368b259..c0187f6 100644 --- a/common/hw-gfx-gma-registers.adb +++ b/common/hw-gfx-gma-registers.adb @@ -69,7 +69,7 @@ Index_T => GTT_Range, Array_T => GTT_Registers_64);
- GTT_PTE_Valid : constant Word32 := 1; + GTT_PTE_Valid : constant := 1;
@@ -177,6 +177,33 @@ end if; end Write_GTT;
+ procedure Read_GTT + (Device_Address : out GTT_Address_Type; + Valid : out Boolean; + GTT_Page : in GTT_Range) + is + begin + if Config.Has_64bit_GTT then + declare + PTE : GTT_PTE_32; + begin + GTT_32.Read (PTE, GTT_Page); + Valid := (PTE and GTT_PTE_Valid) /= 0; + Device_Address := GTT_Address_Type + (Shift_Left (Word64 (PTE and 16#07f0#), 32 - 4) or + Word64 (PTE and 16#ffff_f000#)); + end; + else + declare + PTE : GTT_PTE_64; + begin + GTT_64.Read (PTE, GTT_Page); + Valid := (PTE and GTT_PTE_Valid) /= 0; + Device_Address := GTT_Address_Type (PTE and 16#7f_ffff_f000#); + end; + end if; + end Read_GTT; + ----------------------------------------------------------------------------
package Rep is diff --git a/common/hw-gfx-gma-registers.ads b/common/hw-gfx-gma-registers.ads index 99efba9..3be2ec7 100644 --- a/common/hw-gfx-gma-registers.ads +++ b/common/hw-gfx-gma-registers.ads @@ -1720,17 +1720,21 @@
procedure Remove_Fence (First_Page, Last_Page : GTT_Range);
- pragma Warnings (Off, "declaration of ""Write_GTT"" hides one at *"); procedure Write_GTT (GTT_Page : GTT_Range; Device_Address : GTT_Address_Type; Valid : Boolean) with Global => (In_Out => GTT_State), - Depends => (GTT_State =>+ (GTT_Page, Device_Address, Valid)), - Pre => True, - Post => True; - pragma Warnings (On, "declaration of ""Write_GTT"" hides one at *"); + Depends => (GTT_State =>+ (GTT_Page, Device_Address, Valid)); + + procedure Read_GTT + (Device_Address : out GTT_Address_Type; + Valid : out Boolean; + GTT_Page : in GTT_Range) + with + Global => (In_Out => GTT_State), + Depends => ((Device_Address, Valid, GTT_State) => (GTT_State, GTT_Page));
procedure Set_Register_Base (Base : Word64; GTT_Base : Word64 := 0) with diff --git a/common/hw-gfx-gma.adb b/common/hw-gfx-gma.adb index ad686c3..48b211e 100644 --- a/common/hw-gfx-gma.adb +++ b/common/hw-gfx-gma.adb @@ -585,6 +585,15 @@ Registers.Write_GTT (GTT_Page, Device_Address, Valid); end Write_GTT;
+ procedure Read_GTT + (Device_Address : out GTT_Address_Type; + Valid : out Boolean; + GTT_Page : in GTT_Range) + is + begin + Registers.Read_GTT (Device_Address, Valid, GTT_Page); + end Read_GTT; + procedure Setup_Default_GTT (FB : Framebuffer_Type; Phys_Base : Word32) with Pre => Is_Initialized and Valid_Phys_FB (FB, Phys_Base) diff --git a/common/hw-gfx-gma.ads b/common/hw-gfx-gma.ads index 7f44a0f..dcb3975 100644 --- a/common/hw-gfx-gma.ads +++ b/common/hw-gfx-gma.ads @@ -163,6 +163,14 @@ Global => (In_Out => Device_State, Proof_In => Init_State), Pre => Is_Initialized;
+ procedure Read_GTT + (Device_Address : out GTT_Address_Type; + Valid : out Boolean; + GTT_Page : in GTT_Range) + with + Global => (In_Out => Device_State, Proof_In => Init_State), + Pre => Is_Initialized; + procedure Setup_Default_FB (FB : in Framebuffer_Type; Clear : in Boolean := True;
