Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/11958
commit aaff81c9666d38136f7db227b0bd7b97a2747aa4 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Mon May 18 16:04:10 2015 -0500
src/console: Add x86 romstage spinlock option and printk spinlock support
This paves the way for AP printk spinlock on AMD platforms
Change-Id: Ice42a0d3177736bf6e1bc601092e413601866f20 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/Kconfig | 4 ++++ src/arch/x86/include/arch/smp/spinlock.h | 11 ++++++++++- src/console/printk.c | 15 +++++++++++++++ src/cpu/amd/car/post_cache_as_ram.c | 4 ++++ 4 files changed, 33 insertions(+), 1 deletion(-)
diff --git a/src/Kconfig b/src/Kconfig index 8439a00..b8da62a 100644 --- a/src/Kconfig +++ b/src/Kconfig @@ -468,6 +468,10 @@ config HAVE_HARD_RESET This variable specifies whether a given board has a hard_reset function, no matter if it's provided by board code or chipset code.
+config HAVE_ROMSTAGE_CONSOLE_SPINLOCK + bool + default n + config HAVE_MONOTONIC_TIMER def_bool n help diff --git a/src/arch/x86/include/arch/smp/spinlock.h b/src/arch/x86/include/arch/smp/spinlock.h index 32be2f2..74e532c 100644 --- a/src/arch/x86/include/arch/smp/spinlock.h +++ b/src/arch/x86/include/arch/smp/spinlock.h @@ -1,7 +1,7 @@ #ifndef ARCH_SMP_SPINLOCK_H #define ARCH_SMP_SPINLOCK_H
-#ifndef __PRE_RAM__ +#if !defined(__PRE_RAM__) || IS_ENABLED(CONFIG_HAVE_ROMSTAGE_CONSOLE_SPINLOCK)
/* * Your basic SMP spinlocks, allowing only a single CPU anywhere @@ -11,9 +11,18 @@ typedef struct { volatile unsigned int lock; } spinlock_t;
+#ifdef __PRE_RAM__ +spinlock_t *romstage_console_lock(void); +void initialize_romstage_console_lock(void); +#endif
#define SPIN_LOCK_UNLOCKED (spinlock_t) { 1 } + +#ifndef __PRE_RAM__ #define DECLARE_SPIN_LOCK(x) static spinlock_t x = SPIN_LOCK_UNLOCKED; +#else +#define DECLARE_SPIN_LOCK(x) +#endif
/* * Simple spin lock operations. There are two variants, one clears IRQ's diff --git a/src/console/printk.c b/src/console/printk.c index aab7ff5..99f90a8 100644 --- a/src/console/printk.c +++ b/src/console/printk.c @@ -2,6 +2,7 @@ * blatantly copied from linux/kernel/printk.c * * Copyright (C) 1991, 1992 Linus Torvalds + * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering * */
@@ -13,7 +14,9 @@ #include <stddef.h> #include <trace.h>
+#if (!defined(__PRE_RAM__) && IS_ENABLED(CONFIG_HAVE_ROMSTAGE_CONSOLE_SPINLOCK)) || !IS_ENABLED(CONFIG_HAVE_ROMSTAGE_CONSOLE_SPINLOCK) DECLARE_SPIN_LOCK(console_lock) +#endif
void do_putchar(unsigned char byte) { @@ -39,7 +42,13 @@ int do_printk(int msg_level, const char *fmt, ...) #endif
DISABLE_TRACE; +#ifdef __PRE_RAM__ +#if IS_ENABLED(CONFIG_HAVE_ROMSTAGE_CONSOLE_SPINLOCK) + spin_lock(romstage_console_lock()); +#endif +#else spin_lock(&console_lock); +#endif
va_start(args, fmt); i = vtxprintf(wrap_putchar, fmt, args, NULL); @@ -47,7 +56,13 @@ int do_printk(int msg_level, const char *fmt, ...)
console_tx_flush();
+#ifdef __PRE_RAM__ +#if IS_ENABLED(CONFIG_HAVE_ROMSTAGE_CONSOLE_SPINLOCK) + spin_unlock(romstage_console_lock()); +#endif +#else spin_unlock(&console_lock); +#endif ENABLE_TRACE;
return i; diff --git a/src/cpu/amd/car/post_cache_as_ram.c b/src/cpu/amd/car/post_cache_as_ram.c index fb09cd4..8c5757e 100644 --- a/src/cpu/amd/car/post_cache_as_ram.c +++ b/src/cpu/amd/car/post_cache_as_ram.c @@ -76,6 +76,10 @@ static void prepare_ramstage_region(void *resume_backup_memory) memset_((void*)0, 0, CONFIG_RAMTOP - backup_top); }
+#if IS_ENABLED(CONFIG_HAVE_ROMSTAGE_CONSOLE_SPINLOCK) + initialize_romstage_console_lock(); +#endif + print_car_debug(" Done\n"); }
