Damien Zammit (damien@zamaudio.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/11307
commit 52a1fd5c87e45eba91377c2c53614d8f33bcef06 Author: Damien Zammit damien@zamaudio.com Date: Thu Aug 20 00:37:05 2015 +1000
northbridge/intel/x4x: Native raminit
Passes memtest86+ with either one or two sticks of 2GB ram but memory map needs a hole at 0xa0000000 to 0xc0000000
Change-Id: Ib34d862cb48b49c054a505fffcba1c17aeb39436 Signed-off-by: Damien Zammit damien@zamaudio.com --- src/northbridge/intel/x4x/raminit.c | 495 +++++++ src/northbridge/intel/x4x/raminit_ddr2.c | 2081 ++++++++++++++++++++++++++++++ 2 files changed, 2576 insertions(+)
diff --git a/src/northbridge/intel/x4x/raminit.c b/src/northbridge/intel/x4x/raminit.c new file mode 100644 index 0000000..c783352 --- /dev/null +++ b/src/northbridge/intel/x4x/raminit.c @@ -0,0 +1,495 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Damien Zammit damien@zamaudio.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <arch/io.h> +#include <cbmem.h> +#include <console/console.h> +#include <cpu/x86/cache.h> +#include <cpu/x86/mtrr.h> +#include <delay.h> +#include <halt.h> +#include <lib.h> +#include <northbridge/intel/x4x/x4x.h> +#include <pc80/mc146818rtc.h> +#include <spd.h> +#include <string.h> +#include "debug.h" + +static inline int spd_read_byte(unsigned device, unsigned address) +{ + return smbus_read_byte(device, address); +} + +static void sdram_read_spds(sysinfo_t *s) +{ + u8 i, j, chan; + int status = 0; + FOR_EACH_DIMM(i) { + for (j = 0; j < 64; j++) { + status = spd_read_byte(s->spd_map[i], j); + if (status < 0) { + s->dimms[i].card_type = 0; + break; + } + s->dimms[i].spd_data[j] = (u8) status; + PRINTK_DEBUG("%02x ", (u8) status); + if (j % 16 == 15) + PRINTK_DEBUG("\n"); + if (j == 62) + s->dimms[i].card_type = ((u8) status) & 0x1f; + } + PRINTK_DEBUG("\n"); + } + + s->spd_type = 0; + int fail = 1; + FOR_EACH_POPULATED_DIMM(s->dimms, i) { + switch (s->dimms[i].spd_data[2]) { + case 0x8: + if (s->spd_type == 0) { + s->spd_type = DDR2; + } else if (s->spd_type == DDR3) { + die("DIMM type mismatch\n"); + } + break; + case 0xb: + default: + if (s->spd_type == 0) { + s->spd_type = DDR3; + } else if (s->spd_type == DDR2) { + die("DIMM type mismatch\n"); + } + break; + } + } + if (s->spd_type == DDR3) { + FOR_EACH_POPULATED_DIMM(s->dimms, i) { + s->dimms[i].sides = (s->dimms[i].spd_data[5] & 0x0f) + 1; + s->dimms[i].ranks = ((s->dimms[i].spd_data[7] >> 3) & 0x7) + 1; + s->dimms[i].chip_capacity = (s->dimms[i].spd_data[4] & 0xf); + s->dimms[i].banks = 8; + s->dimms[i].rows = ((s->dimms[i].spd_data[5] >> 3) & 0x7) + 12; + s->dimms[i].cols = (s->dimms[i].spd_data[5] & 0x7) + 9; + s->dimms[i].cas_latencies = 0xfe; + s->dimms[i].cas_latencies &= (s->dimms[i].spd_data[14] << 1); + if (s->dimms[i].cas_latencies == 0) + s->dimms[i].cas_latencies = 0x40; + s->dimms[i].tAAmin = s->dimms[i].spd_data[16]; + s->dimms[i].tCKmin = s->dimms[i].spd_data[12]; + s->dimms[i].width = s->dimms[i].spd_data[7] & 0x7; + s->dimms[i].page_size = s->dimms[i].width * (1 << s->dimms[i].cols); // Bytes + s->dimms[i].tRAS = ((s->dimms[i].spd_data[21] & 0xf) << 8) | + s->dimms[i].spd_data[22]; + s->dimms[i].tRP = s->dimms[i].spd_data[20]; + s->dimms[i].tRCD = s->dimms[i].spd_data[18]; + s->dimms[i].tWR = s->dimms[i].spd_data[17]; + fail = 0; + } + } else if (s->spd_type == DDR2) { + FOR_EACH_POPULATED_DIMM(s->dimms, i) { + s->dimms[i].sides = (s->dimms[i].spd_data[5] & 0x7) + 1; + s->dimms[i].banks = (s->dimms[i].spd_data[17] >> 2) - 1; + s->dimms[i].chip_capacity = s->dimms[i].banks; + s->dimms[i].rows = s->dimms[i].spd_data[3];// - 12; + s->dimms[i].cols = s->dimms[i].spd_data[4];// - 9; + s->dimms[i].cas_latencies = 0x78; + s->dimms[i].cas_latencies &= s->dimms[i].spd_data[18]; + if (s->dimms[i].cas_latencies == 0) + s->dimms[i].cas_latencies = 7; + s->dimms[i].tAAmin = s->dimms[i].spd_data[26]; + s->dimms[i].tCKmin = s->dimms[i].spd_data[25]; + s->dimms[i].width = (s->dimms[i].spd_data[13] >> 3) - 1; + s->dimms[i].page_size = (s->dimms[i].width+1) * (1 << s->dimms[i].cols); // Bytes + s->dimms[i].tRAS = s->dimms[i].spd_data[30]; + s->dimms[i].tRP = s->dimms[i].spd_data[27]; + s->dimms[i].tRCD = s->dimms[i].spd_data[29]; + s->dimms[i].tWR = s->dimms[i].spd_data[36]; + s->dimms[i].ranks = s->dimms[i].sides; // XXX + + PRINTK_DEBUG("DIMM %d\n", i); + PRINTK_DEBUG(" Sides : %d\n", s->dimms[i].sides); + PRINTK_DEBUG(" Banks : %d\n", s->dimms[i].banks); + PRINTK_DEBUG(" Ranks : %d\n", s->dimms[i].ranks); + PRINTK_DEBUG(" Rows : %d\n", s->dimms[i].rows); + PRINTK_DEBUG(" Cols : %d\n", s->dimms[i].cols); + PRINTK_DEBUG(" Page size : %d\n", s->dimms[i].page_size); + PRINTK_DEBUG(" Width : %d\n", (s->dimms[i].width+1)*8); + fail = 0; + } + } + if (fail) { + die("No memory dimms, halt\n"); + } + + FOR_EACH_POPULATED_CHANNEL(s->dimms, chan) { + if (s->dimms[chan>>1].sides == 0) { + // NC + if (s->dimms[(chan>>1) + 1].sides == 0) { + // NC/NC + s->dimm_config[chan] = 0; + } else if (s->dimms[(chan>>1) + 1].sides == 1) { + // NC/SS + if (s->dimms[(chan>>1) + 1].width == 0) { + // NC/8SS + s->dimm_config[chan] = 4; + } else { + // NC/16SS + s->dimm_config[chan] = 12; + } + } else { + // NC/DS + if (s->dimms[(chan>>1) + 1].width == 0) { + // NC/8DS + s->dimm_config[chan] = 8; + } else { + // NOT SUPPORTED + die("16DS Not supported\n"); + } + } + } else if (s->dimms[chan>>1].sides == 1) { + // SS + if (s->dimms[(chan>>1) + 1].sides == 0) { + // SS/NC + if (s->dimms[chan>>1].width == 0) { + // 8SS/NC + s->dimm_config[chan] = 1; + } else { + // 16SS/NC + s->dimm_config[chan] = 3; + } + } else if (s->dimms[(chan>>1) + 1].sides == 1) { + // SS/SS + if (s->dimms[chan>>1].width == 0) { + if (s->dimms[(chan>>1) + 1].width == 0) { + // 8SS/8SS + s->dimm_config[chan] = 5; + } else { + // 8SS/16SS + s->dimm_config[chan] = 13; + } + } else { + if (s->dimms[(chan>>1) + 1].width == 0) { + // 16SS/8SS + s->dimm_config[chan] = 7; + } else { + // 16SS/16SS + s->dimm_config[chan] = 15; + } + } + } else { + // SS/DS + if (s->dimms[chan>>1].width == 0) { + if (s->dimms[(chan>>1) + 1].width == 0) { + // 8SS/8DS + s->dimm_config[chan] = 9; + } else { + die("16DS not supported\n"); + } + } else { + if (s->dimms[(chan>>1) + 1].width == 0) { + // 16SS/8DS + s->dimm_config[chan] = 11; + } else { + die("16DS not supported\n"); + } + } + } + } else { + // DS + if (s->dimms[(chan>>1) + 1].sides == 0) { + // DS/NC + if (s->dimms[chan>>1].width == 0) { + // 8DS/NC + s->dimm_config[chan] = 2; + } else { + die("16DS not supported\n"); + } + } else if (s->dimms[(chan>>1) + 1].sides == 1) { + // DS/SS + if (s->dimms[chan>>1].width == 0) { + if (s->dimms[(chan>>1) + 1].width == 0) { + // 8DS/8SS + s->dimm_config[chan] = 6; + } else { + // 8DS/16SS + s->dimm_config[chan] = 14; + } + } else { + die("16DS not supported\n"); + } + } else { + // DS/DS + if (s->dimms[chan>>1].width == 0 && s->dimms[(chan>>1)+1].width == 0) { + // 8DS/8DS + s->dimm_config[chan] = 10; + } + } + } + PRINTK_DEBUG(" Config[CH%d] : %d\n", chan, s->dimm_config[chan]); + } +} + +static u8 lsbpos(u8 val) //Forward +{ + u8 i; + for (i = 0; (i < 8) && ((val & (1 << i)) == 0); i++); + return i; +} + +static u8 msbpos(u8 val) //Reverse +{ + u8 i; + for (i = 7; (i >= 0) && ((val & (1 << i)) == 0); i--); + return i; +} + +static void mchinfo_ddr2(sysinfo_t *s) +{ + const u32 eax = cpuid_ext(0x04, 0).eax; + s->cores = ((eax >> 26) & 0x3f) + 1; + printk(BIOS_SPEW, "%d CPU cores\n", s->cores); + + u32 capid = pci_read_config16(PCI_DEV(0,0,0), 0xe8); + if (!(capid & (1<<(79-64)))) { + printk(BIOS_SPEW, "iTPM enabled\n"); + } + + capid = pci_read_config32(PCI_DEV(0, 0, 0), 0xe4); + if (!(capid & (1<<(57-32)))) { + printk(BIOS_SPEW, "ME enabled\n"); + } + + if (!(capid & (1<<(56-32)))) { + printk(BIOS_SPEW, "AMT enabled\n"); + } + + s->max_ddr2_mhz = (capid & (1<<(53-32)))?667:800; + printk(BIOS_SPEW, "Capable of DDR2 of %d MHz or lower\n", s->max_ddr2_mhz); + + if (!(capid & (1<<(48-32)))) { + printk(BIOS_SPEW, "VT-d enabled\n"); + } +} + +static void sdram_detect_ram_speed(sysinfo_t *s) +{ + u8 i; + u8 commoncas = 0; + u8 cas; + u8 lowcas; + u8 highcas; + u8 maxfreq; + u8 freq = 0; + + // Find max FSB speed + switch (MCHBAR32(0xc00) & 0x7) { + case 0x0: + s->max_fsb = FSB_CLOCK_1066MHz; + break; + case 0x2: + s->max_fsb = FSB_CLOCK_800MHz; + break; + case 0x4: + s->max_fsb = FSB_CLOCK_1333MHz; + break; + default: + die("Can't find FSB\n"); + break; + } + + // Find RAM speed + maxfreq = (u8) ((pci_read_config16(PCI_DEV(0,0,0), 0xea) >> 4) & 0x3f); + if (s->spd_type == DDR2) { + + // Limit frequency for MCH + maxfreq &= 0x7; + freq = MEM_CLOCK_800MHz; + if (maxfreq) { + freq = maxfreq; + } + if (freq > MEM_CLOCK_800MHz) { + freq = MEM_CLOCK_800MHz; + } + + // Detect a common CAS latency + commoncas = 0xff; + FOR_EACH_POPULATED_DIMM(s->dimms, i) { + commoncas &= s->dimms[i].spd_data[18]; + } + if (commoncas == 0) { + die("No common CAS among dimms\n"); + } + + // Start with fastest common CAS + cas = 0; + highcas = msbpos(commoncas); + lowcas = lsbpos(commoncas); + + while (cas == 0 && highcas >= lowcas) { + FOR_EACH_POPULATED_DIMM(s->dimms, i) { + switch (freq) { + case MEM_CLOCK_800MHz: + if ((s->dimms[i].spd_data[9] > 0x25) || + (s->dimms[i].spd_data[10] > 0x40)) { + // CAS too fast, lower it + highcas--; + break; + } else { + cas = highcas; + } + break; + case MEM_CLOCK_667MHz: + default: + if ((s->dimms[i].spd_data[9] > 0x30) || + (s->dimms[i].spd_data[10] > 0x45)) { + // CAS too fast, lower it + highcas--; + break; + } else { + cas = highcas; + } + break; + } + } + } + if (highcas < lowcas) { + // Timings not supported by MCH, lower the frequency + freq--; + cas = 0; + highcas = msbpos(commoncas); + lowcas = lsbpos(commoncas); + while (cas == 0 && highcas >= lowcas) { + FOR_EACH_POPULATED_DIMM(s->dimms, i) { + switch (freq) { + case MEM_CLOCK_800MHz: + if ((s->dimms[i].spd_data[23] > 0x25) || + (s->dimms[i].spd_data[24] > 0x40)) { + // CAS too fast, lower it + highcas--; + break; + } else { + cas = highcas; + } + break; + case MEM_CLOCK_667MHz: + default: + if ((s->dimms[i].spd_data[23] > 0x30) || + (s->dimms[i].spd_data[24] > 0x45)) { + // CAS too fast, lower it + highcas--; + break; + } else { + cas = highcas; + } + break; + } + } + } + } + s->selected_timings.mem_clock = freq; + s->selected_timings.CAS = cas; + + } else { // DDR3 + // Limit frequency for MCH + maxfreq >>= 3; + freq = MEM_CLOCK_1333MHz; + if (maxfreq) { + freq = maxfreq + 2; + } + if (freq > MEM_CLOCK_1333MHz) { + freq = MEM_CLOCK_1333MHz; + } + + // Limit DDR speed to FSB speed + switch (s->max_fsb) { + case FSB_CLOCK_800MHz: + if (freq > MEM_CLOCK_800MHz) { + freq = MEM_CLOCK_800MHz; + } + break; + case FSB_CLOCK_1066MHz: + if (freq > MEM_CLOCK_1066MHz) { + freq = MEM_CLOCK_1066MHz; + } + break; + case FSB_CLOCK_1333MHz: + if (freq > MEM_CLOCK_1333MHz) { + freq = MEM_CLOCK_1333MHz; + } + break; + default: + die("Invalid FSB\n"); + break; + } + + // TODO: CAS detection for DDR3 + } +} + +/** + * @param boot_path: 0 = normal, 1 = reset, 2 = resume from s3 + */ +void sdram_initialize(int boot_path, const u8 *spd_map) +{ + sysinfo_t sysinfo; + u8 reg8; + + PRINTK_DEBUG("Setting up RAM controller.\n"); + + pci_write_config8(PCI_DEV(0,0,0), 0xdf, 0xff); + + memset(&sysinfo, 0, sizeof(sysinfo)); + + sysinfo.boot_path = boot_path; + sysinfo.spd_map[0] = spd_map[0]; + sysinfo.spd_map[1] = spd_map[1]; + sysinfo.spd_map[2] = spd_map[2]; + sysinfo.spd_map[3] = spd_map[3]; + + /* Detect dimms per channel */ + sysinfo.dimms_per_ch = 2; + reg8 = pci_read_config8(PCI_DEV(0,0,0), 0xe9); + if (reg8 & 0x10) { + sysinfo.dimms_per_ch = 1; + } + PRINTK_DEBUG("Dimms per channel: %d\n", sysinfo.dimms_per_ch); + + mchinfo_ddr2(&sysinfo); + + sdram_read_spds(&sysinfo); + + /* Choose Common Frequency */ + sdram_detect_ram_speed(&sysinfo); + + switch (sysinfo.spd_type) { + case DDR2: + raminit_ddr2(&sysinfo); + break; + case DDR3: + // FIXME Add: raminit_ddr3(&sysinfo); + break; + default: + die("Unknown DDR type\n"); + break; + } + + reg8 = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xa2); + pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xa2, reg8 & ~0x80); + + reg8 = pci_read_config8(PCI_DEV(0,0,0), 0xf4); + pci_write_config8(PCI_DEV(0,0,0), 0xf4, reg8 | 1); + printk(BIOS_DEBUG, "RAM initialization finished.\n"); +} diff --git a/src/northbridge/intel/x4x/raminit_ddr2.c b/src/northbridge/intel/x4x/raminit_ddr2.c new file mode 100644 index 0000000..0cdd9d5 --- /dev/null +++ b/src/northbridge/intel/x4x/raminit_ddr2.c @@ -0,0 +1,2081 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Damien Zammit damien@zamaudio.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <stdint.h> +#include <arch/io.h> +#include <arch/cpu.h> +#include <console/console.h> +#include <commonlib/helpers.h> +#include <delay.h> +#include "x4x.h" +#include "debug.h" + +#define barrier() __asm__ __volatile__("": : :"memory") + +static u32 fsb2mhz(u32 speed) +{ + return (speed * 267) + 800; +} + +static u32 ddr2mhz(u32 speed) +{ + u32 mhz; + mhz = (speed == 2) ? 667 : + (speed == 3) ? 800 : + (speed == 4) ? 1067 : + (speed == 5) ? 1333 : + 0; + return mhz; +} + +static u8 msbpos(u8 val) //Reverse +{ + u8 i; + for (i = 7; (i >= 0) && ((val & (1 << i)) == 0); i--); + return i; +} + +static void sdram_detect_smallest_params2(sysinfo_t *s) +{ + u16 mult[6] = { + 5000, // 400 + 3750, // 533 + 3000, // 667 + 2500, // 800 + 1875, // 1066 + 1500, // 1333 + }; + + u8 i; + u32 tmp; + u32 maxtras = 0; + u32 maxtrp = 0; + u32 maxtrcd = 0; + u32 maxtwr = 0; + u32 maxtrfc = 0; + u32 maxtwtr = 0; + u32 maxtrrd = 0; + u32 maxtrtp = 0; + + FOR_EACH_POPULATED_DIMM(s->dimms, i) { + maxtras = MAX(maxtras, s->dimms[i].spd_data[30] * 1000); + maxtrp = MAX(maxtrp, (s->dimms[i].spd_data[27] * 1000) >> 2); + maxtrcd = MAX(maxtrcd, (s->dimms[i].spd_data[29] * 1000) >> 2); + maxtwr = MAX(maxtwr, (s->dimms[i].spd_data[36] * 1000) >> 2); + maxtrfc = MAX(maxtrfc, s->dimms[i].spd_data[42] * 1000 + + (s->dimms[i].spd_data[40] & 0xf)); + maxtwtr = MAX(maxtwtr, (s->dimms[i].spd_data[37] * 1000) >> 2); + maxtrrd = MAX(maxtrrd, (s->dimms[i].spd_data[28] * 1000) >> 2); + maxtrtp = MAX(maxtrtp, (s->dimms[i].spd_data[38] * 1000) >> 2); + } + for (i = 9; i < 24; i++) { // 16 + tmp = mult[s->selected_timings.mem_clock] * i; + if (tmp >= maxtras) { + s->selected_timings.tRAS = i; + break; + } + } + for (i = 3; i < 10; i++) { + tmp = mult[s->selected_timings.mem_clock] * i; + if (tmp >= maxtrp) { + s->selected_timings.tRP = i; + break; + } + } + for (i = 3; i < 10; i++) { + tmp = mult[s->selected_timings.mem_clock] * i; + if (tmp >= maxtrcd) { + s->selected_timings.tRCD = i; + break; + } + } + for (i = 3; i < 15; i++) { + tmp = mult[s->selected_timings.mem_clock] * i; + if (tmp >= maxtwr) { + s->selected_timings.tWR = i; + break; + } + } + for (i = 15; i < 78; i++) { + tmp = mult[s->selected_timings.mem_clock] * i; + if (tmp >= maxtrfc) { + s->selected_timings.tRFC = ((i + 16) & 0xfe) - 15; + break; + } + } + for (i = 4; i < 15; i++) { + tmp = mult[s->selected_timings.mem_clock] * i; + if (tmp >= maxtwtr) { + s->selected_timings.tWTR = i; + break; + } + } + for (i = 2; i < 15; i++) { + tmp = mult[s->selected_timings.mem_clock] * i; + if (tmp >= maxtrrd) { + s->selected_timings.tRRD = i; + break; + } + } + for (i = 4; i < 15; i++) { + tmp = mult[s->selected_timings.mem_clock] * i; + if (tmp >= maxtrtp) { + s->selected_timings.tRTP = i; + break; + } + } + + s->selected_timings.fsb_clock = s->max_fsb; + + PRINTK_DEBUG("Selected timings:\n"); + PRINTK_DEBUG(" FSB: %dMHz\n", fsb2mhz(s->selected_timings.fsb_clock)); + PRINTK_DEBUG(" DDR: %dMHz\n", ddr2mhz(s->selected_timings.mem_clock)); + + PRINTK_DEBUG(" CAS: %d\n", s->selected_timings.CAS); + PRINTK_DEBUG(" tRAS: %d\n", s->selected_timings.tRAS); + PRINTK_DEBUG(" tRP: %d\n", s->selected_timings.tRP); + PRINTK_DEBUG(" tRCD: %d\n", s->selected_timings.tRCD); + PRINTK_DEBUG(" tWR: %d\n", s->selected_timings.tWR); + PRINTK_DEBUG(" tRFC: %d\n", s->selected_timings.tRFC); + PRINTK_DEBUG(" tWTR: %d\n", s->selected_timings.tWTR); + PRINTK_DEBUG(" tRRD: %d\n", s->selected_timings.tRRD); + PRINTK_DEBUG(" tRTP: %d\n", s->selected_timings.tRTP); +} + +static void clkcross_ddr2(sysinfo_t *s) +{ + u32 c04, c50, c54, x6d8, x6dc, x6e8, x6ec, x6f8, x6fc, x700, x704, x708, x70c; + + MCHBAR16(0xc1c) = MCHBAR16(0xc1c) | (1 << 15); + + if ((s->selected_timings.fsb_clock == FSB_CLOCK_800MHz) && + (s->selected_timings.mem_clock == MEM_CLOCK_667MHz)) { + c04 = 0x1f1f1f1f; + c50 = 0x1a07070b; + c54 = 0x0; + x6d8 = 0x10000000; + x6dc = 0x20010208; + x6e8 = 0x04080000; + x6ec = 0x10010002; + x6f8 = 0x0; + x6fc = 0x0; + x700 = 0x02000000; + x704 = 0x04000100; + x708 = 0x08000000; + x70c = 0x10200204; + } else if ((s->selected_timings.fsb_clock == FSB_CLOCK_800MHz) && + (s->selected_timings.mem_clock == MEM_CLOCK_800MHz)) { + c04 = 0xffffffff; + c50 = 0x05030305; + c54 = 0x0000ffff; + x6d8 = 0x0; + x6dc = 0x08010204; + x6e8 = 0x0; + x6ec = 0x08010204; + x6f8 = 0x0; + x6fc = 0x0; + x700 = 0x0; + x704 = 0x00020001; + x708 = 0x0; + x70c = 0x04080102; + } else if ((s->selected_timings.fsb_clock == FSB_CLOCK_1066MHz) && + (s->selected_timings.mem_clock == MEM_CLOCK_667MHz)) { + c04 = 0x6d5b1f1f; + c50 = 0x0f0f0f0f; + c54 = 0x0; + x6d8 = 0x20000000; + x6dc = 0x80020410; + x6e8 = 0x02040008; + x6ec = 0x10000100; + x6f8 = 0x0; + x6fc = 0x0; + x700 = 0x04000000; + x704 = 0x08000102; + x708 = 0x20000000; + x70c = 0x40010208; + } else if ((s->selected_timings.fsb_clock == FSB_CLOCK_1066MHz) && + (s->selected_timings.mem_clock == MEM_CLOCK_800MHz)) { + c04 = 0x07070707; + c50 = 0x06030303; + c54 = 0x0; + x6d8 = 0x0; + x6dc = 0x08010200; + x6e8 = 0x0; + x6ec = 0x04000102; + x6f8 = 0x0; + x6fc = 0x0; + x700 = 0x0; + x704 = 0x00020001; + x708 = 0x0; + x70c = 0x02040801; + } else if ((s->selected_timings.fsb_clock == FSB_CLOCK_1066MHz) && + (s->selected_timings.mem_clock == MEM_CLOCK_1066MHz)) { + c04 = 0xffffffff; + c50 = 0x05030305; + c54 = 0x0000ffff; + x6d8 = 0x0; + x6dc = 0x04080102; + x6e8 = 0x0; + x6ec = 0x08010204; + x6f8 = 0x0; + x6fc = 0x0; + x700 = 0x0; + x704 = 0x00020001; + x708 = 0x0; + x70c = 0x02040801; + } else if ((s->selected_timings.fsb_clock == FSB_CLOCK_1333MHz) && + (s->selected_timings.mem_clock == MEM_CLOCK_667MHz)) { + c04 = 0x05050303; + c50 = 0xffffffff; + c54 = 0xffff0000; + x6d8 = 0x0; + x6dc = 0x08020000; + x6e8 = 0x0; + x6ec = 0x00020001; + x6f8 = 0x0; + x6fc = 0x0; + x700 = 0x0; + x704 = 0x08010204; + x708 = 0x0; + x70c = 0x04010000; + } else if ((s->selected_timings.fsb_clock == FSB_CLOCK_1333MHz) && + (s->selected_timings.mem_clock == MEM_CLOCK_800MHz)) { + c04 = 0x0d0b0707; + c50 = 0x3e1f1f2f; + c54 = 0x01010000; + x6d8 = 0x0; + x6dc = 0x10020400; + x6e8 = 0x02000000; + x6ec = 0x00040100; + x6f8 = 0x0; + x6fc = 0x0; + x700 = 0x04080000; + x704 = 0x00100102; + x708 = 0x0; + x70c = 0x08100200; + } else if ((s->selected_timings.fsb_clock == FSB_CLOCK_1333MHz) && + (s->selected_timings.mem_clock == MEM_CLOCK_1066MHz)) { + c04 = 0x0f0f0f0f; + c50 = 0x5b1f1f6d; + c54 = 0x0; + x6d8 = 0x0; + x6dc = 0x08010204; + x6e8 = 0x04000000; + x6ec = 0x00080102; + x6f8 = 0x0; + x6fc = 0x0; + x700 = 0x02000408; + x704 = 0x00100001; + x708 = 0x0; + x70c = 0x04080102; + } else if ((s->selected_timings.fsb_clock == FSB_CLOCK_1333MHz) && + (s->selected_timings.mem_clock == MEM_CLOCK_1333MHz)) { + c04 = 0xffffffff; + c50 = 0x05030305; + c54 = 0x0000ffff; + x6d8 = 0x0; + x6dc = 0x04080102; + x6e8 = 0x0; + x6ec = 0x04080102; + x6f8 = 0x0; + x6fc = 0x0; + x700 = 0x0; + x704 = 0x0; + x708 = 0x0; + x70c = 0x02040801; + } else { + die("Unsupported DDR/FSB configuration\n"); + } + + MCHBAR32(0xc04) = c04; + MCHBAR32(0xc50) = c50; + MCHBAR32(0xc54) = c54; + MCHBAR8(0xc08) = MCHBAR8(0xc08) | (1 << 7); + + MCHBAR32(0x6d8) = x6d8; + MCHBAR32(0x6e0) = x6d8; + MCHBAR32(0x6dc) = x6dc; + MCHBAR32(0x6e4) = x6dc; + MCHBAR32(0x6e8) = x6e8; + MCHBAR32(0x6f0) = x6e8; + MCHBAR32(0x6ec) = x6ec; + MCHBAR32(0x6f4) = x6ec; + MCHBAR32(0x6f8) = x6f8; + MCHBAR32(0x6fc) = x6fc; + MCHBAR32(0x708) = x708; + MCHBAR32(0x70c) = x70c; +} + +static void checkreset_ddr2(sysinfo_t *s) +{ + u8 pmcon2; + u8 reset = 0; + +// MCHBAR32(0xc00) = (MCHBAR32(0xc00) & ~0xf0000) | 0x10000; + + pmcon2 = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xa2); + if (!(pmcon2 & 0x80)) { + pmcon2 |= 0x80; + pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xa2, pmcon2); + reset = 1; + + /* do magic 0xf0 thing. */ + u8 reg8 = pci_read_config8(PCI_DEV(0, 0, 0), 0xf0); + pci_write_config8(PCI_DEV(0, 0, 0), 0xf0, reg8 & ~(1 << 2)); + reg8 = pci_read_config8(PCI_DEV(0, 0, 0), 0xf0); + pci_write_config8(PCI_DEV(0, 0, 0), 0xf0, reg8 | (1 << 2)); + } + if (reset) { + PRINTK_DEBUG("Reset...\n"); + outb(0xe, 0xcf9); + asm ("hlt"); + } + pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xa2, pmcon2 | 0x80); +} + +static void setioclk_ddr2(sysinfo_t *s) +{ + MCHBAR32(0x1bc) = 0x08060402; + MCHBAR16(0x1c0) = MCHBAR16(0x1c0) | 0x200; + MCHBAR16(0x1c0) = MCHBAR16(0x1c0) | 0x100; + MCHBAR16(0x1c0) = MCHBAR16(0x1c0) | 0x20; + MCHBAR16(0x1c0) = MCHBAR16(0x1c0) & ~1; + switch (s->selected_timings.mem_clock) { + default: + case MEM_CLOCK_800MHz: + case MEM_CLOCK_1066MHz: + MCHBAR8(0x5d9) = (MCHBAR8(0x5d9) & ~0x2) | 0x2; + MCHBAR8(0x9d9) = (MCHBAR8(0x9d9) & ~0x2) | 0x2; + MCHBAR8(0x189) = (MCHBAR8(0x189) & ~0xf0) | 0xc0; + MCHBAR8(0x189) = (MCHBAR8(0x189) & ~0xf0) | 0xe0; + MCHBAR8(0x189) = (MCHBAR8(0x189) & ~0xf0) | 0xa0; + break; + case MEM_CLOCK_667MHz: + case MEM_CLOCK_1333MHz: + MCHBAR8(0x5d9) = MCHBAR8(0x5d9) & ~0x2; + MCHBAR8(0x9d9) = MCHBAR8(0x9d9) & ~0x2; + MCHBAR8(0x189) = (MCHBAR8(0x189) & ~0xf0) | 0x40; + break; + } + MCHBAR32(0x594) = MCHBAR32(0x594) | (1 << 31); + MCHBAR32(0x994) = MCHBAR32(0x994) | (1 << 31); +} + +static void launch_ddr2(sysinfo_t *s) +{ + u8 i; + u32 launch1 = 0x58001117; + u32 launch2 = 0; + u32 launch3 = 0; + + if (s->selected_timings.CAS == 5) { + launch2 = 0x00220201; + } else if ((s->selected_timings.mem_clock == MEM_CLOCK_800MHz) && + (s->selected_timings.CAS == 6)) { + launch2 = 0x00230302; + } else { + die("Unsupported CAS & Frequency combination detected\n"); + } + + FOR_EACH_POPULATED_CHANNEL(s->dimms, i) { + MCHBAR32(0x400*i + 0x220) = launch1; + MCHBAR32(0x400*i + 0x224) = launch2; + MCHBAR32(0x400*i + 0x21c) = launch3; + MCHBAR32(0x400*i + 0x248) = MCHBAR32(0x400*i + 0x248) | (1 << 23); + } + + MCHBAR32(0x2c0) = (MCHBAR32(0x2c0) & ~0x58000000) | 0x48000000; + MCHBAR32(0x2c0) = MCHBAR32(0x2c0) | 0x1e0; + MCHBAR32(0x2c4) = (MCHBAR32(0x2c4) & ~0xf) | 0xc; +} + +static void clkset0(u8 ch, u8 setting[5]) +{ + MCHBAR16(0x400*ch + 0x5a0) = (MCHBAR16(0x400*ch + 0x5a0) & ~0xc440) | + (setting[4] << 14) | + (setting[3] << 6) | + (setting[2] << 10); + MCHBAR8(0x400*ch + 0x581) = (MCHBAR8(0x400*ch + 0x581) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x581) = (MCHBAR8(0x400*ch + 0x581) & ~0xf) | + setting[0]; +} + +static void clkset1(u8 ch, u8 setting[5]) +{ + MCHBAR32(0x400*ch + 0x5a0) = (MCHBAR32(0x400*ch + 0x5a0) & ~0x30880) | + (setting[4] << 16) | + (setting[3] << 7) | + (setting[2] << 11); + MCHBAR8(0x400*ch + 0x582) = (MCHBAR8(0x400*ch + 0x582) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x582) = (MCHBAR8(0x400*ch + 0x582) & ~0xf) | + setting[0]; +} + +static void ctrlset0(u8 ch, u8 setting[5]) +{ + MCHBAR32(0x400*ch + 0x59c) = (MCHBAR32(0x400*ch + 0x59c) & ~0x3300000) | + (setting[4] << 24) | + (setting[3] << 20) | + (setting[2] << 21); + MCHBAR8(0x400*ch + 0x584) = (MCHBAR8(0x400*ch + 0x584) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x584) = (MCHBAR8(0x400*ch + 0x584) & ~0xf) | + setting[0]; +} + +static void ctrlset1(u8 ch, u8 setting[5]) +{ + MCHBAR32(0x400*ch + 0x59c) = (MCHBAR32(0x400*ch + 0x59c) & ~0x18c00000) | + (setting[4] << 27) | + (setting[3] << 22) | + (setting[2] << 23); + MCHBAR8(0x400*ch + 0x585) = (MCHBAR8(0x400*ch + 0x585) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x585) = (MCHBAR8(0x400*ch + 0x585) & ~0xf) | + setting[0]; +} + +static void ctrlset2(u8 ch, u8 setting[5]) +{ + MCHBAR32(0x400*ch + 0x598) = (MCHBAR32(0x400*ch + 0x598) & ~0x18c00000) | + (setting[4] << 14) | + (setting[3] << 12) | + (setting[2] << 13); + MCHBAR8(0x400*ch + 0x586) = (MCHBAR8(0x400*ch + 0x586) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x586) = (MCHBAR8(0x400*ch + 0x586) & ~0xf) | + setting[0]; +} + +static void ctrlset3(u8 ch, u8 setting[5]) +{ + MCHBAR32(0x400*ch + 0x598) = (MCHBAR32(0x400*ch + 0x598) & ~0x18c00000) | + (setting[4] << 10) | + (setting[3] << 8) | + (setting[2] << 9); + MCHBAR8(0x400*ch + 0x587) = (MCHBAR8(0x400*ch + 0x587) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x587) = (MCHBAR8(0x400*ch + 0x587) & ~0xf) | + setting[0]; +} + +static void cmdset(u8 ch, u8 setting[5]) +{ + MCHBAR8(0x400*ch + 0x598) = (MCHBAR8(0x400*ch + 0x598) & ~0x30) | + (setting[4] << 4); + MCHBAR8(0x400*ch + 0x594) = (MCHBAR8(0x400*ch + 0x594) & ~0x60) | + (setting[3] << 5) | + (setting[2] << 6); + MCHBAR8(0x400*ch + 0x580) = (MCHBAR8(0x400*ch + 0x580) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x580) = (MCHBAR8(0x400*ch + 0x580) & ~0xf) | + setting[0]; +} + +static void dqsset(u8 ch, u8 lane, u8 setting[5]) +{ + MCHBAR32(0x400*ch + 0x5fc) = MCHBAR32(0x400*ch + 0x5fc) & ~(2 << (lane*4)); + + MCHBAR32(0x400*ch + 0x5b4) = (MCHBAR32(0x400*ch + 0x5b4) & ~(0x201 << lane)) | + (setting[2] << (9 + lane)) | + (setting[3] << lane); + MCHBAR32(0x400*ch + 0x5b8) = (MCHBAR32(0x400*ch + 0x5b8) & ~(0x201 << lane)) | + (setting[2] << (9 + lane)) | + (setting[3] << lane); + MCHBAR32(0x400*ch + 0x5bc) = (MCHBAR32(0x400*ch + 0x5bc) & ~(0x201 << lane)) | + (setting[2] << (9 + lane)) | + (setting[3] << lane); + MCHBAR32(0x400*ch + 0x5c0) = (MCHBAR32(0x400*ch + 0x5c0) & ~(0x201 << lane)) | + (setting[2] << (9 + lane)) | + (setting[3] << lane); + + MCHBAR32(0x400*ch + 0x5c8) = (MCHBAR32(0x400*ch + 0x5c8) & ~(0x3 << (16+lane*2))) | + (setting[4] << (16+lane*2)); + MCHBAR32(0x400*ch + 0x5cc) = (MCHBAR32(0x400*ch + 0x5cc) & ~(0x3 << (16+lane*2))) | + (setting[4] << (16+lane*2)); + MCHBAR32(0x400*ch + 0x5d0) = (MCHBAR32(0x400*ch + 0x5d0) & ~(0x3 << (16+lane*2))) | + (setting[4] << (16+lane*2)); + MCHBAR32(0x400*ch + 0x5d4) = (MCHBAR32(0x400*ch + 0x5d4) & ~(0x3 << (16+lane*2))) | + (setting[4] << (16+lane*2)); + + MCHBAR8(0x400*ch + 0x520 + lane*4) = (MCHBAR8(0x400*ch + 0x520 + lane*4) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x520 + lane*4) = (MCHBAR8(0x400*ch + 0x520 + lane*4) & ~0xf) | + setting[0]; + MCHBAR8(0x400*ch + 0x521 + lane*4) = (MCHBAR8(0x400*ch + 0x521 + lane*4) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x521 + lane*4) = (MCHBAR8(0x400*ch + 0x521 + lane*4) & ~0xf) | + setting[0]; + MCHBAR8(0x400*ch + 0x522 + lane*4) = (MCHBAR8(0x400*ch + 0x522 + lane*4) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x522 + lane*4) = (MCHBAR8(0x400*ch + 0x522 + lane*4) & ~0xf) | + setting[0]; + MCHBAR8(0x400*ch + 0x523 + lane*4) = (MCHBAR8(0x400*ch + 0x523 + lane*4) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x523 + lane*4) = (MCHBAR8(0x400*ch + 0x523 + lane*4) & ~0xf) | + setting[0]; +} + +static void dqset(u8 ch, u8 lane, u8 setting[5]) +{ + MCHBAR32(0x400*ch + 0x5fc) = MCHBAR32(0x400*ch + 0x5fc) & ~(1 << (lane*4)); + + MCHBAR32(0x400*ch + 0x5a4) = (MCHBAR32(0x400*ch + 0x5a4) & ~(0x201 << lane)) | + (setting[2] << (9+lane)) | + (setting[3] << lane); + MCHBAR32(0x400*ch + 0x5a8) = (MCHBAR32(0x400*ch + 0x5a8) & ~(0x201 << lane)) | + (setting[2] << (9+lane)) | + (setting[3] << lane); + MCHBAR32(0x400*ch + 0x5ac) = (MCHBAR32(0x400*ch + 0x5ac) & ~(0x201 << lane)) | + (setting[2] << (9+lane)) | + (setting[3] << lane); + MCHBAR32(0x400*ch + 0x5b0) = (MCHBAR32(0x400*ch + 0x5b0) & ~(0x201 << lane)) | + (setting[2] << (9+lane)) | + (setting[3] << lane); + + MCHBAR32(0x400*ch + 0x5c8) = (MCHBAR32(0x400*ch + 0x5c8) & ~(0x3 << (lane*2))) | + (setting[4] << (2*lane)); + MCHBAR32(0x400*ch + 0x5cc) = (MCHBAR32(0x400*ch + 0x5cc) & ~(0x3 << (lane*2))) | + (setting[4] << (2*lane)); + MCHBAR32(0x400*ch + 0x5d0) = (MCHBAR32(0x400*ch + 0x5d0) & ~(0x3 << (lane*2))) | + (setting[4] << (2*lane)); + MCHBAR32(0x400*ch + 0x5d4) = (MCHBAR32(0x400*ch + 0x5d4) & ~(0x3 << (lane*2))) | + (setting[4] << (2*lane)); + + MCHBAR8(0x400*ch + 0x500 + lane*4) = (MCHBAR8(0x400*ch + 0x500 + lane*4) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x500 + lane*4) = (MCHBAR8(0x400*ch + 0x500 + lane*4) & ~0xf) | + setting[0]; + MCHBAR8(0x400*ch + 0x501 + lane*4) = (MCHBAR8(0x400*ch + 0x501 + lane*4) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x501 + lane*4) = (MCHBAR8(0x400*ch + 0x501 + lane*4) & ~0xf) | + setting[0]; + MCHBAR8(0x400*ch + 0x502 + lane*4) = (MCHBAR8(0x400*ch + 0x502 + lane*4) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x502 + lane*4) = (MCHBAR8(0x400*ch + 0x502 + lane*4) & ~0xf) | + setting[0]; + MCHBAR8(0x400*ch + 0x503 + lane*4) = (MCHBAR8(0x400*ch + 0x503 + lane*4) & ~0x70) | + (setting[1] << 4); + MCHBAR8(0x400*ch + 0x503 + lane*4) = (MCHBAR8(0x400*ch + 0x503 + lane*4) & ~0xf) | + setting[0]; +} + +static void timings_ddr2(sysinfo_t *s) +{ + u8 i; + u8 twl, ta1, ta2, ta3, ta4; + u8 reg8; + u8 flag1 = 0; + u8 flag2 = 0; + u16 reg16; + u32 reg32; + u16 ddr, fsb; + u8 trpmod = 0; + u8 bankmod = 1; + u8 pagemod = 0; + + u16 fsb2ps[3] = { + 5000, // 800 + 3750, // 1067 + 3000 // 1333 + }; + + u16 ddr2ps[6] = { + 5000, // 400 + 3750, // 533 + 3000, // 667 + 2500, // 800 + 1875, // 1067 + 1500 // 1333 + }; + + u16 lut1[6] = { + 0, + 0, + 2600, + 3120, + 4171, + 5200 + }; + + ta1 = 6; + ta2 = 6; + ta3 = 5; + ta4 = 8; + + twl = s->selected_timings.CAS - 1; + + FOR_EACH_POPULATED_DIMM(s->dimms, i) { + if (s->dimms[i].banks == 1) { // 8 banks + trpmod = 1; + bankmod = 0; + } + if (s->dimms[i].page_size == 2048) { + pagemod = 1; + } + } + + FOR_EACH_POPULATED_CHANNEL(s->dimms, i) { + MCHBAR8(0x400*i + 0x2f6) = MCHBAR8(0x400*i + 0x2f6) | 0x3; + MCHBAR8(0x400*i + 0x228) = (MCHBAR8(0x400*i + 0x228) & ~0x7) | 0x2; + MCHBAR8(0x400*i + 0x240) = (MCHBAR8(0x400*i + 0x240) & ~0xf0) | (twl << 4); + MCHBAR8(0x400*i + 0x240) = (MCHBAR8(0x400*i + 0x240) & ~0xf) | + s->selected_timings.CAS; + MCHBAR16(0x400*i + 0x265) = (MCHBAR16(0x400*i + 0x265) & ~0x3f00) | + ((s->selected_timings.CAS + 9) << 8); + + reg16 = (s->selected_timings.tRAS << 11) | + ((twl + 4 + s->selected_timings.tWR) << 6) | + ((2 + MAX(s->selected_timings.tRTP, 2)) << 2) | 1; + MCHBAR16(0x400*i + 0x250) = reg16; + + reg32 = (bankmod << 21) | + (s->selected_timings.tRRD << 17) | + (s->selected_timings.tRP << 13) | + ((s->selected_timings.tRP + trpmod) << 9) | + s->selected_timings.tRFC; + reg8 = (MCHBAR8(0x400*i + 0x26f) >> 1) & 1; + if (bankmod) { + switch (s->selected_timings.mem_clock) { + default: + case MEM_CLOCK_667MHz: + if (reg8) { + if (pagemod) { + reg32 |= 16 << 22; + } else { + reg32 |= 12 << 22; + } + } else { + if (pagemod) { + reg32 |= 18 << 22; + } else { + reg32 |= 14 << 22; + } + } + break; + case MEM_CLOCK_800MHz: + if (reg8) { + if (pagemod) { + reg32 |= 18 << 22; + } else { + reg32 |= 14 << 22; + } + } else { + if (pagemod) { + reg32 |= 20 << 22; + } else { + reg32 |= 16 << 22; + } + } + break; + } + } + MCHBAR32(0x400*i + 0x252) = reg32; + + MCHBAR16(0x400*i + 0x256) = (s->selected_timings.tRCD << 12) | + (0x4 << 8) | (ta2 << 4) | ta4; + + MCHBAR32(0x400*i + 0x258) = (s->selected_timings.tRCD << 17) | + ((twl + 4 + s->selected_timings.tWTR) << 12) | + (ta3 << 8) | (4 << 4) | ta1; + + MCHBAR16(0x400*i + 0x25b) = ((s->selected_timings.tRP + trpmod) << 9) | + s->selected_timings.tRFC; + + MCHBAR16(0x400*i + 0x260) = (MCHBAR16(0x400*i + 0x260) & ~0x3fe) | (100 << 1); + MCHBAR8(0x400*i + 0x264) = 0xff; + MCHBAR8(0x400*i + 0x25d) = (MCHBAR8(0x400*i + 0x25d) & ~0x3f) | + s->selected_timings.tRAS; + MCHBAR16(0x400*i + 0x244) = 0x2310; + + switch (s->selected_timings.mem_clock) { + case MEM_CLOCK_667MHz: + reg8 = 0; + break; + default: + reg8 = 1; + break; + } + + MCHBAR8(0x400*i + 0x246) = (MCHBAR8(0x400*i + 0x246) & ~0x1f) | + (reg8 << 2) | 1; + + fsb = fsb2ps[s->selected_timings.fsb_clock]; + ddr = ddr2ps[s->selected_timings.mem_clock]; + reg32 = (u32)((s->selected_timings.CAS + 7 + reg8) * ddr); + reg32 = (u32)((reg32 / fsb) << 8); + reg32 |= 0x0e000000; + if ((fsb2mhz(s->selected_timings.fsb_clock) / + ddr2mhz(s->selected_timings.mem_clock)) > 2) { + reg32 |= 1 << 24; + } + MCHBAR32(0x400*i + 0x248) = (MCHBAR32(0x400*i + 0x248) & ~0x0f001f00) | + reg32; + + if (twl > 2) { + flag1 = 1; + } + if (s->selected_timings.mem_clock >= MEM_CLOCK_800MHz) { + flag2 = 1; + } + reg16 = (u8)(twl - 1 - flag1 - flag2); + reg16 |= reg16 << 4; + if (s->selected_timings.mem_clock == MEM_CLOCK_1333MHz) { + if (reg16) { + reg16--; + } + } + reg16 |= flag1 << 8; + reg16 |= flag2 << 9; + MCHBAR16(0x400*i + 0x24d) = (MCHBAR16(0x400*i + 0x24d) & ~0x1ff) | reg16; + MCHBAR16(0x400*i + 0x25e) = 0x15a5; + MCHBAR32(0x400*i + 0x265) = MCHBAR32(0x400*i + 0x265) & ~0x1f; + MCHBAR32(0x400*i + 0x269) = (MCHBAR32(0x400*i + 0x269) & ~0x000fffff) | + (0x3f << 14) | lut1[s->selected_timings.mem_clock]; + MCHBAR8(0x400*i + 0x274) = MCHBAR8(0x400*i + 0x274) | 1; + MCHBAR8(0x400*i + 0x24c) = MCHBAR8(0x400*i + 0x24c) & ~0x3; + + reg16 = 0; + switch (s->selected_timings.mem_clock) { + default: + case MEM_CLOCK_667MHz: + reg16 = 0x99; + break; + case MEM_CLOCK_800MHz: + if (s->selected_timings.CAS == 5) { + reg16 = 0x19a; + } else if (s->selected_timings.CAS == 6) { + reg16 = 0x9a; + } + break; + } + reg16 &= 0x7; + reg16 += twl + 9; + reg16 <<= 10; + MCHBAR16(0x400*i + 0x24d) = (MCHBAR16(0x400*i + 0x24d) & ~0x7c00) | reg16; + MCHBAR8(0x400*i + 0x267) = (MCHBAR8(0x400*i + 0x267) & ~0x3f) | 0x13; + MCHBAR8(0x400*i + 0x268) = (MCHBAR8(0x400*i + 0x268) & ~0xff) | 0x4a; + + reg16 = (MCHBAR16(0x400*i + 0x269) & 0xc000) >> 2; + reg16 += 2 << 12; + reg16 |= (0x15 << 6) | 0x1f; + MCHBAR16(0x400*i + 0x26d) = (MCHBAR16(0x400*i + 0x26d) & ~0x7fff) | reg16; + + reg32 = (1 << 25) | (6 << 27); + MCHBAR32(0x400*i + 0x269) = (MCHBAR32(0x400*i + 0x269) & ~0xfa300000) | reg32; + MCHBAR8(0x400*i + 0x271) = MCHBAR8(0x400*i + 0x271) & ~0x80; + MCHBAR8(0x400*i + 0x274) = MCHBAR8(0x400*i + 0x274) & ~0x6; + } // END EACH POPULATED CHANNEL + + reg16 = 0x1f << 5; + reg16 |= 0xe << 10; + MCHBAR16(0x125) = (MCHBAR16(0x125) & ~0x3fe0) | reg16; + MCHBAR16(0x127) = (MCHBAR16(0x127) & ~0x7ff) | 0x540; + MCHBAR8(0x129) = MCHBAR8(0x129) | 0x1f; + MCHBAR8(0x12c) = MCHBAR8(0x12c) | 0xa0; + MCHBAR32(0x241) = (MCHBAR32(0x241) & ~0x1ffff) | 0x11; + MCHBAR32(0x641) = (MCHBAR32(0x641) & ~0x1ffff) | 0x11; + MCHBAR8(0x246) = MCHBAR8(0x246) & ~0x10; + MCHBAR8(0x646) = MCHBAR8(0x646) & ~0x10; + MCHBAR32(0x120) = (2 << 29) | (1 << 28) | (1 << 23) | 0xd7f5f; + reg8 = (u8)((MCHBAR32(0x252) & 0x1e000) >> 13); + MCHBAR8(0x12d) = (MCHBAR8(0x12d) & ~0xf0) | (reg8 << 4); + reg8 = (u8)((MCHBAR32(0x258) & ~0x1e0000) >> 17); + MCHBAR8(0x12d) = (MCHBAR8(0x12d) & ~0xf) | reg8; + MCHBAR8(0x12f) = 0x4c; + reg32 = (1 << 31) | (0x80 << 14) | (1 << 13) | (0xa << 9); + MCHBAR32(0x6c0) = (MCHBAR32(0x6c0) & ~0xffffff00) | reg32; + MCHBAR8(0x6c4) = (MCHBAR8(0x6c4) & ~0x7) | 0x2; +} + +static void dll_ddr2(sysinfo_t *s) +{ + u8 i, j, r, reg8, clk, async; + u16 reg16 = 0; + u32 reg32 = 0; + u8 lane; + + MCHBAR16(0x180) = (MCHBAR16(0x180) & ~0x7e06) | 0xc04; + MCHBAR16(0x182) = (MCHBAR16(0x182) & ~0x3ff) | 0xc8; + MCHBAR16(0x18a) = (MCHBAR16(0x18a) & ~0x1f1f) | 0x0f0f; + MCHBAR16(0x1b4) = (MCHBAR16(0x1b4) & ~0x8020) | 0x100; + MCHBAR8(0x194) = (MCHBAR8(0x194) & ~0x77) | 0x33; + switch (s->selected_timings.mem_clock) { + default: + case MEM_CLOCK_667MHz: + reg16 = (0xa << 9) | 0xa; + break; + case MEM_CLOCK_800MHz: + reg16 = (0x9 << 9) | 0x9; + break; + } + MCHBAR16(0x19c) = (MCHBAR16(0x19c) & ~0x1e0f) | reg16; + MCHBAR16(0x19c) = (MCHBAR16(0x19c) & ~0x2030) | 0x2010; + udelay(1); + MCHBAR16(0x198) = MCHBAR16(0x198) & ~0x100; + + MCHBAR16(0x1c8) = (MCHBAR16(0x1c8) & ~0x1f) | 0xd; + + udelay(1); + MCHBAR8(0x190) = MCHBAR8(0x190) & ~1; + udelay(1); // 533ns + MCHBAR32(0x198) = MCHBAR32(0x198) & ~0x11554000; + udelay(1); + MCHBAR32(0x198) = MCHBAR32(0x198) & ~0x1455; + udelay(1); + MCHBAR8(0x583) = MCHBAR8(0x583) & ~0x1c; + MCHBAR8(0x983) = MCHBAR8(0x983) & ~0x1c; + udelay(1); // 533ns + MCHBAR8(0x583) = MCHBAR8(0x583) & ~0x3; + MCHBAR8(0x983) = MCHBAR8(0x983) & ~0x3; + udelay(1); // 533ns + + // ME related + MCHBAR32(0x1a0) = (MCHBAR32(0x1a0) & ~0x7ffffff) | 0x551803; + + MCHBAR16(0x1b4) = MCHBAR16(0x1b4) & ~0x800; + MCHBAR8(0x1a8) = MCHBAR8(0x1a8) | 0xf0; + + FOR_EACH_CHANNEL(i) { + reg16 = 0; + MCHBAR16(0x400*i + 0x59c) = MCHBAR16(0x400*i + 0x59c) & ~0x3000; + + reg32 = 0; + FOR_EACH_RANK_IN_CHANNEL(r) if (!RANK_IS_POPULATED(s->dimms, i, r)) { + reg32 |= 0x111 << r; + } + MCHBAR32(0x400*i + 0x59c) = (MCHBAR32(0x400*i + 0x59c) & ~0xfff) | reg32; + MCHBAR8(0x400*i + 0x594) = MCHBAR8(0x400*i + 0x594) & ~1; + + if (!CHANNEL_IS_POPULATED(s->dimms, i)) { + PRINTK_DEBUG("No dimms in channel %d\n", i); + reg8 = 0x3f; + } else if(ONLY_DIMMA_IS_POPULATED(s->dimms, i)) { + PRINTK_DEBUG("DimmA populated only in channel %d\n", i); + reg8 = 0x38; + } else if(ONLY_DIMMB_IS_POPULATED(s->dimms, i)) { + PRINTK_DEBUG("DimmB populated only in channel %d\n", i); + reg8 = 0x7; + } else if(BOTH_DIMMS_ARE_POPULATED(s->dimms, i)) { + PRINTK_DEBUG("Both dimms populated in channel %d\n", i); + reg8 = 0; + } else { + die("Unhandled case\n"); + } + + //reg8 = 0x00; // FIXME dont switch on all clocks anyway + + MCHBAR32(0x400*i + 0x5a0) = (MCHBAR32(0x400*i + 0x5a0) & ~0x3f000000) | + ((u32)(reg8 << 24)); + } // END EACH CHANNEL + + MCHBAR8(0x1a8) = MCHBAR8(0x1a8) | 1; + MCHBAR8(0x1a8) = MCHBAR8(0x1a8) & ~0x4; + + // Update DLL timing + MCHBAR8(0x1a4) = MCHBAR8(0x1a4) & ~0x80; + MCHBAR8(0x1a4) = MCHBAR8(0x1a4) | 0x40; + MCHBAR16(0x5f0) = (MCHBAR16(0x5f0) & ~0x400) | 0x400; + + u8 dll_setting_667[23][5] = { + // tap pi db delay + {13, 0, 1,0, 0}, + {4, 1, 0,0, 0}, + {13, 0, 1,0, 0}, + {4, 5, 0,0, 0}, + {4, 1, 0,0, 0}, + {4, 1, 0,0, 0}, + {4, 1, 0,0, 0}, + {1, 5, 1,1, 1}, + {1, 6, 1,1, 1}, + {2, 0, 1,1, 1}, + {2, 1, 1,1, 1}, + {2, 1, 1,1, 1}, + {14, 6, 1,0, 0}, + {14, 3, 1,0, 0}, + {14, 0, 1,0, 0}, + {9, 0, 0,0, 1}, + {9, 1, 0,0, 1}, + {9, 2, 0,0, 1}, + {9, 2, 0,0, 1}, + {9, 1, 0,0, 1}, + {6, 4, 0,0, 1}, + {6, 2, 0,0, 1}, + {5, 4, 0,0, 1} + }; + + u8 dll_setting_800[23][5] = { + // tap pi db delay + {11, 5, 1,0, 0}, + {0, 5, 1,1, 0}, + {11, 5, 1,0, 0}, + {1, 4, 1,1, 0}, + {0, 5, 1,1, 0}, + {0, 5, 1,1, 0}, + {0, 5, 1,1, 0}, + {2, 5, 1,1, 1}, + {2, 6, 1,1, 1}, + {3, 0, 1,1, 1}, + {3, 0, 1,1, 1}, + {3, 3, 1,1, 1}, + {2, 0, 1,1, 1}, + {1, 3, 1,1, 1}, + {0, 3, 1,1, 1}, + {9, 3, 0,0, 1}, + {9, 4, 0,0, 1}, + {9, 5, 0,0, 1}, + {9, 6, 0,0, 1}, + {10, 0, 0,0, 1}, + {8, 1, 0,0, 1}, + {7, 5, 0,0, 1}, + {6, 2, 0,0, 1} + }; + + FOR_EACH_POPULATED_CHANNEL(s->dimms, i) { + MCHBAR16(0x400*i + 0x5f0) = (MCHBAR16(0x400*i + 0x5f0) & ~0x3fc) | 0x3fc; + MCHBAR32(0x400*i + 0x5fc) = MCHBAR32(0x400*i + 0x5fc) & ~0xcccccccc; + MCHBAR8(0x400*i + 0x5d9) = (MCHBAR8(0x400*i + 0x5d9) & ~0xf0) | 0x70; + MCHBAR16(0x400*i + 0x590) = (MCHBAR16(0x400*i + 0x590) & ~0xffff) | 0x5555; + } + + FOR_EACH_POPULATED_CHANNEL(s->dimms, i) { + if (s->selected_timings.mem_clock == MEM_CLOCK_667MHz) { + clkset0(i, &dll_setting_667[CLKSET0][0]); + clkset1(i, &dll_setting_667[CLKSET1][0]); + ctrlset0(i, &dll_setting_667[CTRL0][0]); + ctrlset1(i, &dll_setting_667[CTRL1][0]); + ctrlset2(i, &dll_setting_667[CTRL2][0]); + ctrlset3(i, &dll_setting_667[CTRL3][0]); + cmdset(i, &dll_setting_667[CMD][0]); + } else { + clkset0(i, &dll_setting_800[CLKSET0][0]); + clkset1(i, &dll_setting_800[CLKSET1][0]); + ctrlset0(i, &dll_setting_800[CTRL0][0]); + ctrlset1(i, &dll_setting_800[CTRL1][0]); + ctrlset2(i, &dll_setting_800[CTRL2][0]); + ctrlset3(i, &dll_setting_800[CTRL3][0]); + cmdset(i, &dll_setting_800[CMD][0]); + } + } + + // XXX if not async mode + MCHBAR16(0x180) = MCHBAR16(0x180) & ~0x8200; + MCHBAR8(0x180) = MCHBAR8(0x180) | 0x4; + j = 0; + for (i = 0; i < 16; i++) { + MCHBAR8(0x1c8) = (MCHBAR8(0x1c8) & ~0x1f) | i; + MCHBAR8(0x180) = MCHBAR8(0x180) | 0x10; + while (MCHBAR8(0x180) & 0x10); + if (MCHBAR32(0x184) == 0xffffffff) { + j++; + if (j >= 2) + break; + + if (s->selected_timings.mem_clock == MEM_CLOCK_667MHz) { + j = 2; + break; + } + } else { + j = 0; + } + } + if (i == 1 || ((i == 0) && s->selected_timings.mem_clock == MEM_CLOCK_667MHz)) { + j = 0; + i++; + for (; i < 16; i++) { + MCHBAR8(0x1c8) = (MCHBAR8(0x1c8) & ~0x1f) | i; + MCHBAR8(0x180) = MCHBAR8(0x180) | 0x4; + while (MCHBAR8(0x180) & 0x10); + if (MCHBAR32(0x184) == 0) { + i++; + break; + } + } + for (; i < 16; i++) { + MCHBAR8(0x1c8) = (MCHBAR8(0x1c8) & ~0x1f) | i; + MCHBAR8(0x180) = MCHBAR8(0x180) | 0x10; + while (MCHBAR8(0x180) & 0x10); + if (MCHBAR32(0x184) == 0xffffffff) { + j++; + if (j >= 2) + break; + } else { + j = 0; + } + } + if (j < 2) { + MCHBAR8(0x1c8) = MCHBAR8(0x1c8) & ~0x1f; + MCHBAR8(0x180) = MCHBAR8(0x180) | 0x10; + while (MCHBAR8(0x180) & 0x10); + j = 2; + } + } + + if (j < 2) { + MCHBAR8(0x1c8) = MCHBAR8(0x1c8) & ~0x1f; + async = 1; + } + + clk = 0x1a; + if (async != 1) { + reg8 = MCHBAR8(0x188) & 0x1e; + if (s->selected_timings.mem_clock == MEM_CLOCK_667MHz && + s->selected_timings.fsb_clock == FSB_CLOCK_800MHz) { + clk = 0x10; + } else if (s->selected_timings.mem_clock == MEM_CLOCK_800MHz) { + clk = 0x10; + } else { + clk = 0x1a; + } + } + MCHBAR8(0x180) = MCHBAR8(0x180) & ~0x80; + + if ((s->selected_timings.fsb_clock == FSB_CLOCK_800MHz) && + (s->selected_timings.mem_clock == MEM_CLOCK_667MHz)) { + i = MCHBAR8(0x180) & 0xf; + i = (i + 10) % 14; + MCHBAR8(0x1c8) = (MCHBAR8(0x1c8) & ~0x1f) | i; + MCHBAR8(0x180) = MCHBAR8(0x180) | 0x10; + while(MCHBAR8(0x180) & 0x10); + } + + reg8 = MCHBAR8(0x188) & ~1; + MCHBAR8(0x188) = reg8; + reg8 &= ~0x3e; + reg8 |= clk; + MCHBAR8(0x188) = reg8; + reg8 |= 1; + MCHBAR8(0x188) = reg8; + + if (s->selected_timings.mem_clock == MEM_CLOCK_1333MHz) { + MCHBAR8(0x18c) = MCHBAR8(0x18c) | 1; + } + + // Program DQ/DQS dll settings + reg32 = 0; + FOR_EACH_POPULATED_CHANNEL(s->dimms, i) { + for (lane = 0; lane < 8; lane++) { + if (s->selected_timings.mem_clock == MEM_CLOCK_667MHz) { + reg32 = 0x06db7777; + } else if (s->selected_timings.mem_clock == MEM_CLOCK_800MHz) { + reg32 = 0x00007777; + } + MCHBAR32(0x400*i + 0x540 + lane*4) = + (MCHBAR32(0x400*i + 0x540 + lane*4) & 0x0fffffff) | + reg32; + } + } + + FOR_EACH_POPULATED_CHANNEL(s->dimms, i) { + if (s->selected_timings.mem_clock == MEM_CLOCK_667MHz) { + for (lane = 0; lane < 8; lane++) { + dqsset(i, lane, &dll_setting_667[DQS1+lane][0]); + } + for (lane = 0; lane < 8; lane++) { + dqset(i, lane, &dll_setting_667[DQ1+lane][0]); + } + } else { + for (lane = 0; lane < 8; lane++) { + dqsset(i, lane, &dll_setting_800[DQS1+lane][0]); + } + for (lane = 0; lane < 8; lane++) { + dqset(i, lane, &dll_setting_800[DQ1+lane][0]); + } + } + } +} + +static void rcomp_ddr2(sysinfo_t *s) +{ + u8 i, j, k; + u32 x32a[8] = { 0x04040404, 0x06050505, 0x09090807, 0x0D0C0B0A, 0x04040404, 0x08070605, 0x0C0B0A09, 0x100F0E0D }; + u16 x378[6] = { 0, 0xAAAA, 0x7777, 0x7777, 0x7777, 0x7777 }; + u32 x382[6] = { 0, 0x02020202, 0x02020202, 0x02020202, 0x04030303, 0x04030303 }; + u32 x386[6] = { 0, 0x03020202, 0x03020202, 0x03020202, 0x05040404, 0x05040404 }; + u32 x38a[6] = { 0, 0x04040303, 0x04040303, 0x04040303, 0x07070605, 0x07070605 }; + u32 x38e[6] = { 0, 0x06060505, 0x06060505, 0x06060505, 0x09090808, 0x09090808 }; + u32 x392[6] = { 0, 0x02020202, 0x02020202, 0x02020202, 0x03030202, 0x03030202 }; + u32 x396[6] = { 0, 0x03030202, 0x03030202, 0x03030202, 0x05040303, 0x05040303 }; + u32 x39a[6] = { 0, 0x04040403, 0x04040403, 0x04040403, 0x07070605, 0x07070605 }; + u32 x39e[6] = { 0, 0x06060505, 0x06060505, 0x06060505, 0x08080808, 0x08080808 }; + u16 addr[6] = { 0x31c, 0x374, 0x3a2, 0x3d0, 0x3fe, 0x42c }; + u8 bit[6] = { 0, 0, 1, 1, 0, 0 }; + + FOR_EACH_POPULATED_CHANNEL(s->dimms, i) { + for (j = 0; j < 6; j++) { + if (j == 0) { + MCHBAR32(0x400*i + addr[j]) = + (MCHBAR32(0x400*i + addr[j]) & ~0xff000) | 0xaa000; + MCHBAR16(0x400*i + 0x320) = (MCHBAR16(0x400*i + 0x320) & ~0xffff) | 0x6666; + for (k = 0; k < 8; k++) { + MCHBAR32(0x400*i + addr[j] + 0xe + (k << 2)) = + (MCHBAR32(0x400*i + addr[j] + 0xe + (k << 2)) & ~0x3f3f3f3f) | x32a[k]; + MCHBAR32(0x400*i + addr[j] + 0x2e + (k << 2)) = + (MCHBAR32(0x400*i + addr[j] + 0x2e + (k << 2)) & ~0x3f3f3f3f) | x32a[k]; + } + } else { + MCHBAR16(0x400*i + addr[j]) = (MCHBAR16(0x400*i + addr[j]) & ~0xf000) | 0xa000; + MCHBAR16(0x400*i + addr[j] + 4) = (MCHBAR16(0x400*i + addr[j] + 4) & ~0xffff) | + x378[j]; + MCHBAR32(0x400*i + addr[j] + 0xe) = + (MCHBAR32(0x400*i + addr[j] + 0xe) & ~0x3f3f3f3f) | x382[j]; + MCHBAR32(0x400*i + addr[j] + 0x12) = + (MCHBAR32(0x400*i + addr[j] + 0x12) & ~0x3f3f3f3f) | x386[j]; + MCHBAR32(0x400*i + addr[j] + 0x16) = + (MCHBAR32(0x400*i + addr[j] + 0x16) & ~0x3f3f3f3f) | x38a[j]; + MCHBAR32(0x400*i + addr[j] + 0x1a) = + (MCHBAR32(0x400*i + addr[j] + 0x1a) & ~0x3f3f3f3f) | x38e[j]; + MCHBAR32(0x400*i + addr[j] + 0x1e) = + (MCHBAR32(0x400*i + addr[j] + 0x1e) & ~0x3f3f3f3f) | x392[j]; + MCHBAR32(0x400*i + addr[j] + 0x22) = + (MCHBAR32(0x400*i + addr[j] + 0x22) & ~0x3f3f3f3f) | x396[j]; + MCHBAR32(0x400*i + addr[j] + 0x26) = + (MCHBAR32(0x400*i + addr[j] + 0x26) & ~0x3f3f3f3f) | x39a[j]; + MCHBAR32(0x400*i + addr[j] + 0x2a) = + (MCHBAR32(0x400*i + addr[j] + 0x2a) & ~0x3f3f3f3f) | x39e[j]; + } + MCHBAR8(0x400*i + addr[j]) = (MCHBAR8(0x400*i + addr[j]) & ~1) | bit[j]; + } + MCHBAR8(0x400*i + 0x45a) = (MCHBAR8(0x400*i + 0x45a) & ~0x3f) | 0x12; + MCHBAR8(0x400*i + 0x45e) = (MCHBAR8(0x400*i + 0x45e) & ~0x3f) | 0x12; + MCHBAR8(0x400*i + 0x462) = (MCHBAR8(0x400*i + 0x462) & ~0x3f) | 0x12; + MCHBAR8(0x400*i + 0x466) = (MCHBAR8(0x400*i + 0x466) & ~0x3f) | 0x12; + } // END EACH POPULATED CHANNEL + + MCHBAR32(0x134) = (MCHBAR32(0x134) & ~0x63c00) | 0x63c00; + MCHBAR16(0x174) = (MCHBAR16(0x174) & ~0x63ff) | 0x63ff; + MCHBAR16(0x178) = 0x0135; + MCHBAR32(0x130) = (MCHBAR32(0x130) & ~0x7bdffe0) | 0x7a9ffa0; + + if (!CHANNEL_IS_POPULATED(s->dimms, 0)) { + MCHBAR32(0x130) = MCHBAR32(0x130) & ~(1 << 27); + } + if (!CHANNEL_IS_POPULATED(s->dimms, 1)) { + MCHBAR32(0x130) = MCHBAR32(0x130) & ~(1 << 28); + } + + MCHBAR8(0x130) = MCHBAR8(0x130) | 1; +} + +static void odt_ddr2(sysinfo_t *s) +{ + u8 i; + u16 odt[16][2] = { + { 0x0000,0x0000 }, // NC_NC + { 0x0000,0x0001 }, // x8SS_NC + { 0x0000,0x0011 }, // x8DS_NC + { 0x0000,0x0001 }, // x16SS_NC + { 0x0004,0x0000 }, // NC_x8SS + { 0x0101,0x0404 }, // x8SS_x8SS + { 0x0101,0x4444 }, // x8DS_x8SS + { 0x0101,0x0404 }, // x16SS_x8SS + { 0x0044,0x0000 }, // NC_x8DS + { 0x1111,0x0404 }, // x8SS_x8DS + { 0x1111,0x4444 }, // x8DS_x8DS + { 0x1111,0x0404 }, // x16SS_x8DS + { 0x0004,0x0000 }, // NC_x16SS + { 0x0101,0x0404 }, // x8SS_x16SS + { 0x0101,0x4444 }, // x8DS_x16SS + { 0x0101,0x0404 }, // x16SS_x16SS + }; + + FOR_EACH_POPULATED_CHANNEL(s->dimms, i) { + MCHBAR16(0x400*i + 0x298) = odt[s->dimm_config[i]][1]; + MCHBAR16(0x400*i + 0x294) = odt[s->dimm_config[i]][0]; + MCHBAR16(0x400*i + 0x29c) = (MCHBAR16(0x400*i + 0x29c) & ~0xfff) | 0x66b; + MCHBAR32(0x400*i + 0x260) = (MCHBAR32(0x400*i + 0x260) & ~0x70e3c00) | 0x3063c00; + } +} + +static void dojedec_ddr2(u8 r, u8 ch, u8 cmd, u16 val) +{ + u32 addr = (ch << 29) | (r*0x08000000); + volatile u32 rubbish; + + MCHBAR8(0x271) = (MCHBAR8(0x271) & ~0x3e) | cmd; + MCHBAR8(0x671) = (MCHBAR8(0x671) & ~0x3e) | cmd; + rubbish = read32((void*)((val<<3) | addr)); + udelay(10); + MCHBAR8(0x271) = (MCHBAR8(0x271) & ~0x3e) | NORMALOP_CMD; + MCHBAR8(0x671) = (MCHBAR8(0x671) & ~0x3e) | NORMALOP_CMD; +} + +static void jedec_ddr2(sysinfo_t *s) +{ + u8 i; + u16 mrsval, ch, r, v; + + u8 odt[16][4] = { + {0x00, 0x00, 0x00, 0x00}, + {0x01, 0x00, 0x00, 0x00}, + {0x01, 0x01, 0x00, 0x00}, + {0x01, 0x00, 0x00, 0x00}, + {0x00, 0x00, 0x01, 0x00}, + {0x11, 0x00, 0x11, 0x00}, + {0x11, 0x11, 0x11, 0x00}, + {0x11, 0x00, 0x11, 0x00}, + {0x00, 0x00, 0x01, 0x01}, + {0x11, 0x00, 0x11, 0x11}, + {0x11, 0x11, 0x11, 0x11}, + {0x11, 0x00, 0x11, 0x11}, + {0x00, 0x00, 0x01, 0x00}, + {0x11, 0x00, 0x11, 0x00}, + {0x11, 0x11, 0x11, 0x00}, + {0x11, 0x00, 0x11, 0x00} + }; + + u16 jedec[12][2] = { + {NOP_CMD, 0x0}, + {PRECHARGE_CMD, 0x0}, + {EMRS2_CMD, 0x0}, + {EMRS3_CMD, 0x0}, + {EMRS1_CMD, 0x0}, + {MRS_CMD, 0x100}, // DLL Reset + {PRECHARGE_CMD, 0x0}, + {CBR_CMD, 0x0}, + {CBR_CMD, 0x0}, + {MRS_CMD, 0x0}, // DLL out of reset + {EMRS1_CMD, 0x380}, // OCD calib default + {EMRS1_CMD, 0x0} + }; + + mrsval = (s->selected_timings.CAS << 4) | ((s->selected_timings.tWR - 1) << 9) | 0xb; + + PRINTK_DEBUG("MRS...\n"); + + udelay(200); + + FOR_EACH_POPULATED_RANK(s->dimms, ch, r) { + PRINTK_DEBUG("CH%d: Found Rank %d\n", ch, r); + for (i = 0; i < 12; i++) { + v = jedec[i][1]; + switch (jedec[i][0]) { + case EMRS1_CMD: + v |= (odt[s->dimm_config[ch]][r] << 2); + break; + case MRS_CMD: + v |= mrsval; + break; + default: + break; + } + dojedec_ddr2(r + ch*4, ch, jedec[i][0], v); + udelay(1); + //PRINTK_DEBUG("Jedec step %d\n", i); + } + } + PRINTK_DEBUG("MRS done\n"); +} + +static u8 sampledqs(u16 mchloc, u32 addr, u8 hilow, u8 repeat) +{ + u8 dqsmatch = 1; + volatile u32 strobe; + + while (repeat-- > 0) { + MCHBAR8(0x5d8) = MCHBAR8(0x5d8) & ~0x2; + udelay(2); + MCHBAR8(0x5d8) = MCHBAR8(0x5d8) | 0x2; + udelay(2); + MCHBAR8(0x9d8) = MCHBAR8(0x9d8) & ~0x2; + udelay(2); + MCHBAR8(0x9d8) = MCHBAR8(0x9d8) | 0x2; + udelay(2); + barrier(); + strobe = read32((u32 *)addr); + barrier(); + if (((MCHBAR32(mchloc) & 0x40) >> 6) != hilow) { + dqsmatch = 0; + } + } + return dqsmatch; +} + +static void rcven_ddr2(sysinfo_t *s) +{ + u8 i, reg8, ch, lane; + u32 addr; + u8 tap = 0; + u8 savecc, savemedium, savetap, coarsecommon, medium; + u8 lanecoarse[8] = {0}; + u8 mincoarse = 0xff; + u8 pitap[2][8]; + u16 coarsectrl[2]; + u16 coarsedelay[2]; + u16 mediumphase[2]; + u16 readdelay[2]; + u16 mchbar; + MCHBAR8(0x5d8) = MCHBAR8(0x5d8) & ~0xc; + MCHBAR8(0x9d8) = MCHBAR8(0x9d8) & ~0xc; + MCHBAR8(0x5dc) = MCHBAR8(0x5dc) & ~0x80; + + FOR_EACH_POPULATED_CHANNEL(s->dimms, ch) { + addr = (ch << 29); + for (i = 0; !RANK_IS_POPULATED(s->dimms, ch, i); i++) { + addr += 128*1024*1024; + } + for (lane = 0; lane < 8; lane++) { + PRINTK_DEBUG("Channel %d, Lane %d addr=0x%08x\n", ch, lane, addr); +//trylaneagain: + coarsecommon = (s->selected_timings.CAS - 1); + switch (lane) { + case 0: case 1: medium = 0; break; + case 2: case 3: medium = 1; break; + case 4: case 5: medium = 2; break; + case 6: case 7: medium = 3; break; + default: medium = 0; break; + } + mchbar = 0x400*ch + 0x561 + (lane << 2); + tap = 0; + MCHBAR32(0x400*ch + 0x248) = (MCHBAR32(0x400*ch + 0x248) & ~0xf0000) | + (coarsecommon << 16); + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & ~(3 << (lane*2))) | + (medium << (lane*2)); + MCHBAR8(0x400*ch + 0x560 + lane*4) = MCHBAR8(0x400*ch + 0x560 + lane*4) & ~0xf; + MCHBAR8(0x400*ch + 0x560 + lane*4) = MCHBAR8(0x400*ch + 0x560 + lane*4) & ~0x70; + savecc = coarsecommon; + savemedium = medium; + savetap = 0; + + MCHBAR16(0x400*ch + 0x588) = (MCHBAR16(0x400*ch + 0x588) & ~(3 << (lane*2))) | + (1 << (lane*2)); + + PRINTK_VERBOSE("rcven 0.1 coarse=%d\n", coarsecommon); + while (sampledqs(mchbar, addr, 1, 1) == 1) { + if (medium < 3) { + medium++; + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & + ~(3 << (lane*2))) | (medium << (lane*2)); + } else { + medium = 0; + coarsecommon++; + MCHBAR32(0x400*ch + 0x248) = (MCHBAR32(0x400*ch + 0x248) & + ~0xf0000) | (coarsecommon << 16); + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & + ~(3 << (lane*2))) | (medium << (lane*2)); + } + if (coarsecommon > 16) { + die("Coarse > 16: DQS tuning failed, halt\n"); + break; + } + } + PRINTK_VERBOSE(" GOT IT (high -> low transition) coarse=%d medium=%d\n", coarsecommon, medium); + + savemedium = medium; + savecc = coarsecommon; + if (medium < 3) { + medium++; + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & + ~(3 << (lane*2))) | (medium << (lane*2)); + } else { + medium = 0; + coarsecommon++; + + MCHBAR32(0x400*ch + 0x248) = (MCHBAR32(0x400*ch + 0x248) & ~0xf0000) | + (coarsecommon << 16); + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & ~(3 << (lane*2))) | + (medium << (lane*2)); + } + + PRINTK_VERBOSE("rcven 0.2\n"); + while (sampledqs(mchbar, addr, 0, 1) == 1) { + savemedium = medium; + savecc = coarsecommon; + if (medium < 3) { + medium++; + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & + ~(3 << (lane*2))) | (medium << (lane*2)); + } else { + medium = 0; + coarsecommon++; + MCHBAR32(0x400*ch + 0x248) = (MCHBAR32(0x400*ch + 0x248) & + ~0xf0000) | (coarsecommon << 16); + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & + ~(3 << (lane*2))) | (medium << (lane*2)); + } + if (coarsecommon > 16) { + die("Coarse DQS tuning 2 failed, halt\n"); + break; + } + } + PRINTK_VERBOSE(" GOT IT (low -> high transition) coarse=%d medium=%d\n", coarsecommon, medium); + + + coarsecommon = savecc; + medium = savemedium; + MCHBAR32(0x400*ch + 0x248) = (MCHBAR32(0x400*ch + 0x248) & + ~0xf0000) | (coarsecommon << 16); + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & + ~(3 << (lane*2))) | (medium << (lane*2)); + + PRINTK_VERBOSE("rcven 0.3\n"); + tap = 0; + while (sampledqs(mchbar, addr, 1, 1) == 0) { + savetap = tap; + tap++; + if (tap > 14) { + break; + } + MCHBAR8(0x400*ch + 0x560 + (lane*4)) = + (MCHBAR8(0x400*ch + 0x560 + (lane*4)) & ~0xf) | tap; + } + + tap = savetap; + MCHBAR8(0x400*ch + 0x560 + (lane*4)) = + (MCHBAR8(0x400*ch + 0x560 + (lane*4)) & ~0xf) | tap; + MCHBAR8(0x400*ch + 0x560 + (lane*4)) = + (MCHBAR8(0x400*ch + 0x560 + (lane*4)) & ~0x70) | 0x30; + if (medium < 3) { + medium++; + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & + ~(3 << (lane*2))) | (medium << (lane*2)); + } else { + medium = 0; + coarsecommon++; + MCHBAR32(0x400*ch + 0x248) = (MCHBAR32(0x400*ch + 0x248) & + ~0xf0000) | (coarsecommon << 16); + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & + ~(3 << (lane*2))) | (medium << (lane*2)); + } + if (sampledqs(mchbar, addr, 1, 1) == 0) { + die("Not at DQS high, doh\n"); + } + + PRINTK_VERBOSE("rcven 0.4\n"); + while (sampledqs(mchbar, addr, 1, 1) == 1) { + coarsecommon--; + MCHBAR32(0x400*ch + 0x248) = (MCHBAR32(0x400*ch + 0x248) & + ~0xf0000) | (coarsecommon << 16); + if (coarsecommon == 0) { + die("Couldn't find DQS-high 0 indicator, halt\n"); + break; + } + } + PRINTK_VERBOSE(" GOT IT (high -> low transition) coarse=%d medium=%d\n", coarsecommon, medium); + + PRINTK_VERBOSE("rcven 0.5\n"); + while (sampledqs(mchbar, addr, 0, 1) == 1) { + savemedium = medium; + savecc = coarsecommon; + if (medium < 3) { + medium++; + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & + ~(3 << (lane*2))) | (medium << (lane*2)); + } else { + medium = 0; + coarsecommon++; + MCHBAR32(0x400*ch + 0x248) = (MCHBAR32(0x400*ch + 0x248) & + ~0xf0000) | (coarsecommon << 16); + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & + ~(3 << (lane*2))) | (medium << (lane*2)); + } + if (coarsecommon > 16) { + die("Coarse DQS tuning 5 failed, halt\n"); + break; + } + } + PRINTK_VERBOSE(" GOT IT (low -> high transition) coarse=%d medium=%d\n", coarsecommon, medium); + + PRINTK_VERBOSE("rcven 0.6\n"); + coarsecommon = savecc; + medium = savemedium; + MCHBAR32(0x400*ch + 0x248) = (MCHBAR32(0x400*ch + 0x248) & + ~0xf0000) | (coarsecommon << 16); + MCHBAR16(0x400*ch + 0x58c) = (MCHBAR16(0x400*ch + 0x58c) & + ~(3 << (lane*2))) | (medium << (lane*2)); + while (sampledqs(mchbar, addr, 1, 1) == 0) { + savetap = tap; + tap++; + if (tap > 14) { + break; + } + MCHBAR8(0x400*ch + 0x560 + lane*4) = + (MCHBAR8(0x400*ch + 0x560 + lane*4) & ~0xf) | tap; + } + tap = savetap; + MCHBAR8(0x400*ch + 0x560 + lane*4) = + (MCHBAR8(0x400*ch + 0x560 + lane*4) & ~0xf) | tap; + MCHBAR8(0x400*ch + 0x560 + lane*4) = + (MCHBAR8(0x400*ch + 0x560 + lane*4) & ~0x70) | 0x70; + + pitap[ch][lane] = 0x70 | tap; + + MCHBAR16(0x400*ch + 0x588) = MCHBAR16(0x400*ch + 0x588) & ~(3 << (lane*2)); + lanecoarse[lane] = coarsecommon; + PRINTK_VERBOSE("rcven 0.7\n"); + } // END EACH LANE + + // Find minimum coarse value + for (lane = 0; lane < 8; lane++) { + if (mincoarse > lanecoarse[lane]) { + mincoarse = lanecoarse[lane]; + } + } + + PRINTK_DEBUG("Found min coarse value = %d\n", mincoarse); + + for (lane = 0; lane < 8; lane++) { + reg8 = (lanecoarse[lane] == 0) ? 0 : lanecoarse[lane] - mincoarse; + MCHBAR16(0x400*ch + 0x5fa) = (MCHBAR16(0x400*ch + 0x5fa) & ~(3 << (lane*2))) | + (reg8 << (lane*2)); + } + MCHBAR32(0x400*ch + 0x248) = (MCHBAR32(0x400*ch + 0x248) & ~0xf0000) | (mincoarse << 16); + coarsectrl[ch] = mincoarse; + coarsedelay[ch] = MCHBAR16(0x400*ch + 0x5fa); + mediumphase[ch] = MCHBAR16(0x400*ch + 0x58c); + readdelay[ch] = MCHBAR16(0x400*ch + 0x588); + } // END EACH POPULATED CHANNEL + +/* Resume support */ + FOR_EACH_CHANNEL(ch) { + for (lane = 0; lane < 8; lane++) { + MCHBAR8(0x400*ch + 0x560 + (lane*4)) = + (MCHBAR8(0x400*ch + 0x560 + (lane*4)) & ~0xf) | pitap[ch][lane]; + } + MCHBAR32(0x400*ch + 0x248) = (MCHBAR32(0x400*ch + 0x248) & ~0xf0000) | + (coarsectrl[ch] << 16); + MCHBAR16(0x400*ch + 0x5fa) = coarsedelay[ch]; + MCHBAR16(0x400*ch + 0x58c) = mediumphase[ch]; + } + PRINTK_DEBUG("End rcven\n"); +} + +static void dradrb_ddr2(sysinfo_t *s) +{ + u8 map, i, ch, r, rankpop0, rankpop1; + u32 c0dra = 0; + u32 c1dra = 0; + u32 c0drb = 0; + u32 c1drb = 0; + u32 dra; + u32 dra0; + u32 dra1; + u16 totalmemorymb; + u16 size, offset; + u8 dratab[2][2][2][4] = { + { + { + {0xff, 0xff, 0xff, 0xff}, + {0xff, 0x00, 0x02, 0xff} + }, + { + {0xff, 0x01, 0xff, 0xff}, + {0xff, 0x03, 0xff, 0xff} + } + }, + { + { + {0xff, 0xff, 0xff, 0xff}, + {0xff, 0x04, 0x06, 0x08} + }, + { + {0xff, 0xff, 0xff, 0xff}, + {0x05, 0x07, 0x09, 0xff} + } + } + }; + + u8 drbtab[10] = {0x04, 0x02, 0x08, 0x04, 0x08, 0x04, 0x10, 0x08, 0x20, 0x10}; + + // DRA + rankpop0 = 0; + rankpop1 = 0; + FOR_EACH_POPULATED_RANK(s->dimms, ch, r) { + if ((s->dimms[ch<<1].card_type && ((r) < s->dimms[ch<<1].ranks))) { + i = ch << 1; + } else { + i = (ch << 1) + 1; + } + dra = dratab[s->dimms[i].banks] + [s->dimms[i].width] + [s->dimms[i].cols-9] + [s->dimms[i].rows-12]; + if (s->dimms[i].banks == 1) { + dra |= 0x80; + } + if (ch == 0) { + c0dra |= dra << (r*8); + rankpop0 |= 1 << r; + } else { + c1dra |= dra << (r*8); + rankpop1 |= 1 << r; + } + } + MCHBAR32(0x208) = c0dra; + MCHBAR32(0x608) = c1dra; + + MCHBAR8(0x262) = (MCHBAR8(0x262) & ~0xf0) | ((rankpop0 << 4) & 0xf0); + MCHBAR8(0x662) = (MCHBAR8(0x662) & ~0xf0) | ((rankpop1 << 4) & 0xf0); + + if (ONLY_DIMMA_IS_POPULATED(s->dimms, 0) || ONLY_DIMMB_IS_POPULATED(s->dimms, 0)) { + MCHBAR8(0x260) = MCHBAR8(0x260) | 1; + } + if (ONLY_DIMMA_IS_POPULATED(s->dimms, 1) || ONLY_DIMMB_IS_POPULATED(s->dimms, 1)) { + MCHBAR8(0x660) = MCHBAR8(0x660) | 1; + } + + // DRB + FOR_EACH_POPULATED_RANK(s->dimms, ch, r) { + if ((s->dimms[ch<<1].card_type && ((r) < s->dimms[ch<<1].ranks))) { + i = ch << 1; + } else { + i = (ch << 1) + 1; + } + if (ch == 0) { + dra0 = (c0dra >> (8*r)) & 0x7f; + c0drb = (u16)(c0drb + drbtab[dra0]); + s->dimms[i].rank_capacity_mb = drbtab[dra0] << 6; + MCHBAR16(0x200 + 2*r) = c0drb; + } else { + dra1 = (c1dra >> (8*r)) & 0x7f; + c1drb = (u16)(c1drb + drbtab[dra1]); + s->dimms[i].rank_capacity_mb = drbtab[dra1] << 6; + MCHBAR16(0x600 + 2*r) = c1drb; + } + } + + s->channel_capacity[0] = c0drb << 6; + s->channel_capacity[1] = c1drb << 6; + totalmemorymb = s->channel_capacity[0] + s->channel_capacity[1]; + PRINTK_DEBUG("Total memory: %d + %d = %dMiB\n", + s->channel_capacity[0], s->channel_capacity[1], totalmemorymb); + + rankpop1 >>= 4; + if (rankpop1) { + MCHBAR16(0x600 + 2*msbpos(rankpop1)) = c0drb + c1drb; + MCHBAR16(0x602 + 2*msbpos(rankpop1)) = c0drb + c1drb; + MCHBAR16(0x604 + 2*msbpos(rankpop1)) = c0drb + c1drb; + MCHBAR16(0x606 + 2*msbpos(rankpop1)) = c0drb + c1drb; + } + + MCHBAR8(0x111) = MCHBAR8(0x111) | 0x2; + MCHBAR16(0x104) = 0; + size = s->channel_capacity[0] + s->channel_capacity[1]; + MCHBAR16(0x102) = size; + map = 0; + if (s->channel_capacity[0] == 0) { + map = 0; + } else if (s->channel_capacity[1] == 0) { + map |= 0x20; + } else { + map |= 0x40; + } + map |= 0x18; + if (s->channel_capacity[0] <= s->channel_capacity[1]) { + map |= 0x5; + } else if (s->channel_capacity[0] > s->channel_capacity[1]) { + map |= 0x4; + } + MCHBAR8(0x110) = map; + MCHBAR16(0x10e) = 0; + if (s->channel_capacity[1] != 0) { + offset = 0; + } else if (s->channel_capacity[0] > s->channel_capacity[1]) { + offset = size; + } else { + offset = 0; + } + MCHBAR16(0x108) = offset; + MCHBAR16(0x10a) = 0; +} + +static void mmap_ddr2(sysinfo_t *s) +{ + u32 gfxsize, gttsize, tsegsize, mmiosize, tom, tolud, touud, gfxbase, gttbase, tsegbase; + u16 ggc; + u16 ggc2uma[] = { 0, 0, 0, 0, 0, 32, 48, 64, 128, 256, 96, 160, 224, 352 }; + u8 ggc2gtt[] = { 0, 1, 0, 2, 0, 0, 0, 0, 0, 2, 3, 4}; + + ggc = pci_read_config16(PCI_DEV(0,0,0), 0x52); + gfxsize = ggc2uma[(ggc & 0xf0) >> 4]; + gttsize = ggc2gtt[(ggc & 0xf00) >> 8]; + tsegsize = 1; // 1MB TSEG + mmiosize = 0x400; // 1GB MMIO + tom = s->channel_capacity[0] + s->channel_capacity[1]; + tolud = MIN(0x1000 - mmiosize, tom); + touud = tom; + gfxbase = tolud - gfxsize; + gttbase = gfxbase - gttsize; + tsegbase = gttbase - tsegsize; + + pci_write_config16(PCI_DEV(0,0,0), 0xb0, tolud << 4); + pci_write_config16(PCI_DEV(0,0,0), 0xa0, tom >> 6); + pci_write_config16(PCI_DEV(0,0,0), 0xa2, touud); + pci_write_config32(PCI_DEV(0,0,0), 0xa4, gfxbase << 20); + pci_write_config32(PCI_DEV(0,0,0), 0xa8, gttbase << 20); + pci_write_config32(PCI_DEV(0,0,0), 0xac, tsegbase << 20); +} + +static void enhanced_ddr2(sysinfo_t *s) +{ + u8 ch, reg8; + + MCHBAR32(0xfb0) = 0x1000d024; + MCHBAR32(0xfb4) = 0xc842; + MCHBAR32(0xfbc) = 0xf; + MCHBAR32(0xfc4) = 0xfe22244; + MCHBAR8(0x12f) = 0x5c; + MCHBAR8(0xfb0) = (MCHBAR8(0xfb0) & ~1) | 1; + MCHBAR8(0x12f) = MCHBAR8(0x12f) | 0x2; + MCHBAR8(0x6c0) = (MCHBAR8(0x6c0) & ~0xf0) | 0xa0; + MCHBAR32(0xfa8) = 0x30d400; + + FOR_EACH_POPULATED_CHANNEL(s->dimms, ch) { + MCHBAR8(0x400*ch + 0x26c) = MCHBAR8(0x400*ch + 0x26c) | 1; + MCHBAR32(0x400*ch + 0x278) = 0x88141881; + MCHBAR16(0x400*ch + 0x27c) = 0x0041; + MCHBAR8(0x400*ch + 0x292) = 0xf2; + MCHBAR16(0x400*ch + 0x272) = MCHBAR16(0x400*ch + 0x272) | 0x100; + MCHBAR8(0x400*ch + 0x243) = (MCHBAR8(0x400*ch + 0x243) & ~0x2) | 1; + MCHBAR32(0x400*ch + 0x288) = 0x8040200; + MCHBAR32(0x400*ch + 0x28c) = 0xff402010; + MCHBAR32(0x400*ch + 0x290) = 0x4f2091c; + } + + reg8 = pci_read_config8(PCI_DEV(0,0,0), 0xf0); + pci_write_config8(PCI_DEV(0,0,0), 0xf0, reg8 | 1); + MCHBAR32(0xfa0) = (MCHBAR32(0xfa0) & ~0x20002) | 0x2; + MCHBAR32(0xfa4) = (MCHBAR32(0xfa4) & ~0x219100c3) | 0x219100c2; + MCHBAR32(0x2c) = 0x44a53; + MCHBAR32(0x30) = 0x1f5a86; + MCHBAR32(0x34) = 0x1902810; + MCHBAR32(0x38) = 0xf7000000; + MCHBAR32(0x3c) = 0x23014410; + MCHBAR32(0x40) = (MCHBAR32(0x40) & ~0x8f038000) | 0x8f038000; + MCHBAR32(0x20) = 0x33001; + pci_write_config8(PCI_DEV(0,0,0), 0xf0, reg8 & ~1); +} + +static void power_ddr2(sysinfo_t *s) +{ + u32 reg1, reg2, reg3, reg4, clkgate, x592; + u8 lane, ch; + u8 twl = 0; + u16 x264, x23c; + + twl = s->selected_timings.CAS - 1; + x264 = 0x78; + switch (s->selected_timings.mem_clock) { + default: + case MEM_CLOCK_667MHz: + reg1 = 0x99; + reg2 = 0x1048a9; + clkgate = 0x230000; + x23c = 0x7a89; + break; + case MEM_CLOCK_800MHz: + if (s->selected_timings.CAS == 5) { + reg1 = 0x19a; + reg2 = 0x1048aa; + } else { + reg1 = 0x9a; + reg2 = 0x2158aa; + x264 = 0x89; + } + clkgate = 0x280000; + x23c = 0x7b89; + break; + } + reg3 = 0x232; + reg4 = 0x2864; + + if (CHANNEL_IS_POPULATED(s->dimms, 0) && CHANNEL_IS_POPULATED(s->dimms, 1)) { + MCHBAR32(0x14) = 0x0010461f; + } else { + MCHBAR32(0x14) = 0x0010691f; + } + MCHBAR32(0x18) = 0xdf6437f7; + MCHBAR32(0x1c) = 0x0; + MCHBAR32(0x24) = (MCHBAR32(0x24) & ~0xe0000000) | 0x30000000; + MCHBAR32(0x44) = (MCHBAR32(0x44) & ~0x1fef0000) | 0x6b0000; + MCHBAR16(0x115) = (u16) reg1; + MCHBAR32(0x117) = (MCHBAR32(0x117) & ~0xffffff) | reg2; + MCHBAR8(0x124) = 0x7; + MCHBAR16(0x12a) = (MCHBAR16(0x12a) & 0) | 0x80; + MCHBAR8(0x12c) = (MCHBAR8(0x12c) & 0) | 0xa0; + MCHBAR16(0x174) = MCHBAR16(0x174) & ~(1 << 15); + MCHBAR16(0x188) = (MCHBAR16(0x188) & ~0x1f00) | 0x1f00; + MCHBAR8(0x18c) = MCHBAR8(0x18c) & ~0x8; + MCHBAR8(0x192) = (MCHBAR8(0x192) & ~1) | 1; + MCHBAR8(0x193) = (MCHBAR8(0x193) & ~0xf) | 0xf; + MCHBAR16(0x1b4) = (MCHBAR16(0x1b4) & ~0x480) | 0x80; + MCHBAR16(0x210) = (MCHBAR16(0x210) & ~0x1fff) | 0x3f; // | clockgatingiii + MCHBAR32(0x6d1) = (MCHBAR32(0x6d1) & ~0xff03ff) | 0x100 | clkgate; + MCHBAR8(0x212) = (MCHBAR8(0x212) & ~0x7f) | 0x7f; + MCHBAR32(0x2c0) = (MCHBAR32(0x2c0) & ~0xffff0) | 0xcc5f0; + MCHBAR8(0x2c4) = (MCHBAR8(0x2c4) & ~0x70) | 0x70; + MCHBAR32(0x2d1) = (MCHBAR32(0x2d1) & ~0xffffff) | 0xff2831; // | clockgatingi + MCHBAR32(0x2d4) = 0x40453600; + MCHBAR32(0x300) = 0xc0b0a08; + MCHBAR32(0x304) = 0x6040201; + MCHBAR32(0x30c) = (MCHBAR32(0x30c) & ~0x43c0f) | 0x41405; + MCHBAR16(0x610) = 0x232; + MCHBAR16(0x612) = 0x2864; + MCHBAR32(0x62c) = (MCHBAR32(0x62c) & ~0xc000000) | 0x4000000; + MCHBAR32(0xae4) = 0; + MCHBAR32(0xc00) = (MCHBAR32(0xc00) & ~0xf0000) | 0x10000; + MCHBAR32(0xf00) = 0x393a3b3c; + MCHBAR32(0xf04) = 0x3d3e3f40; + MCHBAR32(0xf08) = 0x393a3b3c; + MCHBAR32(0xf0c) = 0x3d3e3f40; + MCHBAR32(0xf18) = MCHBAR32(0xf18) & ~0xfff00001; + MCHBAR32(0xf48) = 0xfff0ffe0; + MCHBAR32(0xf4c) = 0xffc0ff00; + MCHBAR32(0xf50) = 0xfc00f000; + MCHBAR32(0xf54) = 0xc0008000; + MCHBAR32(0xf6c) = (MCHBAR32(0xf6c) & ~0xffff0000) | 0xffff0000; + MCHBAR32(0xfac) = MCHBAR32(0xfac) & ~0x80000000; + MCHBAR32(0xfb8) = MCHBAR32(0xfb8) & ~0xff000000; + MCHBAR32(0xfbc) = (MCHBAR32(0xfbc) & ~0x7f800) | 0xf000; + MCHBAR32(0x1104) = 0x3003232; + MCHBAR32(0x1108) = 0x74; + if (s->selected_timings.fsb_clock == FSB_CLOCK_800MHz) { + MCHBAR32(0x110c) = 0xaa; + } else { + MCHBAR32(0x110c) = 0x100; + } + MCHBAR32(0x1110) = 0x10810350 & ~0x78; + MCHBAR32(0x1114) = 0; + if (s->selected_timings.mem_clock == MEM_CLOCK_667MHz) { + twl = 5; + } else { + twl = 6; + } + x592 = 0xff; + if (pci_read_config8(PCI_DEV(0,0,0), 0x8) < 3) { + x592 = ~0x4; + } + FOR_EACH_POPULATED_CHANNEL(s->dimms, ch) { + MCHBAR8(0x400*ch + 0x239) = twl + 15; + MCHBAR16(0x400*ch + 0x23c) = x23c; + MCHBAR32(0x400*ch + 0x248) = (MCHBAR32(0x400*ch + 0x248) & ~0x706033) | 0x406033; + MCHBAR32(0x400*ch + 0x260) = (MCHBAR32(0x400*ch + 0x260) & ~(1 << 16)) | (1 << 16); + MCHBAR8(0x400*ch + 0x264) = x264; + MCHBAR8(0x400*ch + 0x592) = (MCHBAR8(0x400*ch + 0x592) & ~0x3f) | (0x3c & x592); + MCHBAR8(0x400*ch + 0x593) = (MCHBAR8(0x400*ch + 0x593) & ~0x1f) | 0x1e; + } + + for (lane = 0; lane < 8; lane++) { + MCHBAR8(0x561 + (lane << 2)) = MCHBAR8(0x561 + (lane << 2)) & ~(1 << 3); + } +} + +void raminit_ddr2(sysinfo_t *s) +{ + u8 ch; + u8 r, bank; + u32 reg32; + + // Select timings based on SPD info + sdram_detect_smallest_params2(s); + + // Reset if required + checkreset_ddr2(s); + + // Clear self refresh + MCHBAR32(0xf14) = MCHBAR32(0xf14) | 0x3; + + // Clear host clk gate reg + MCHBAR32(0x1c) = MCHBAR32(0x1c) | 0xffffffff; + + // Select DDR2 + MCHBAR8(0x1a8) = MCHBAR8(0x1a8) & ~0x4; + + // Set freq + MCHBAR32(0xc00) = (MCHBAR32(0xc00) & ~0x70) | + (s->selected_timings.mem_clock << 4) | (1 << 10); + + // Overwrite freq if chipset rejects it + s->selected_timings.mem_clock = (MCHBAR8(0xc00) & 0x70) >> 4; + if (s->selected_timings.mem_clock > (s->max_fsb + 3)) { + die("Error: DDR is faster than FSB, halt\n"); + } + + udelay(250000); + + // Program clock crossing + clkcross_ddr2(s); + PRINTK_DEBUG("Done clk crossing\n"); + + // DDR2 IO + setioclk_ddr2(s); + PRINTK_DEBUG("Done I/O clk\n"); + + // Grant to launch + launch_ddr2(s); + PRINTK_DEBUG("Done launch\n"); + + // Program DDR2 timings + timings_ddr2(s); + PRINTK_DEBUG("Done timings\n"); + + // Program DLL + dll_ddr2(s); + + // RCOMP + rcomp_ddr2(s); + PRINTK_DEBUG("RCOMP\n"); + + // ODT + odt_ddr2(s); + PRINTK_DEBUG("Done ODT\n"); + + // RCOMP update + while ((MCHBAR8(0x130) & 1) != 0 ); + PRINTK_DEBUG("Done RCOMP update\n"); + + // Set defaults + MCHBAR32(0x260) = (MCHBAR32(0x260) & ~1) | 0xf00000; + MCHBAR32(0x660) = (MCHBAR32(0x660) & ~1) | 0xf00000; + MCHBAR32(0x208) = 0x01010101; + MCHBAR32(0x608) = 0x01010101; + MCHBAR32(0x200) = 0x00040002; + MCHBAR32(0x204) = 0x00080006; + MCHBAR32(0x600) = 0x00040002; + MCHBAR32(0x604) = 0x00100006; + MCHBAR8(0x111) = MCHBAR8(0x111) | 0x2; + MCHBAR32(0x104) = 0; + MCHBAR16(0x102) = 0x400; + MCHBAR8(0x100) = (2 << 5) | (3 << 3); + MCHBAR16(0x10e) = 0; + MCHBAR32(0x108) = 0; + pci_write_config16(PCI_DEV(0,0,0), 0xb0, 0x4000); + pci_write_config16(PCI_DEV(0,0,0), 0xa0, 0x0010); + pci_write_config16(PCI_DEV(0,0,0), 0xa2, 0x0400); + pci_write_config32(PCI_DEV(0,0,0), 0xa4, 0x40000000); + pci_write_config32(PCI_DEV(0,0,0), 0xa8, 0x40000000); + pci_write_config32(PCI_DEV(0,0,0), 0xac, 0x40000000); + + // IOBUFACT + if (CHANNEL_IS_POPULATED(s->dimms, 0)) { + MCHBAR8(0x5dd) = (MCHBAR8(0x5dd) & ~0x3f) | 0x3f; + MCHBAR8(0x5d8) = MCHBAR8(0x5d8) | 0x7; + } + if (CHANNEL_IS_POPULATED(s->dimms, 1)) { + if (pci_read_config8(PCI_DEV(0,0,0), 0x8) < 2) { + MCHBAR8(0x5dd) = (MCHBAR8(0x5dd) & ~0x3f) | 0x3f; + MCHBAR8(0x5d8) = MCHBAR8(0x5d8) | 1; + } + MCHBAR8(0x9dd) = (MCHBAR8(0x9dd) & ~0x3f) | 0x3f; + MCHBAR8(0x9d8) = MCHBAR8(0x9d8) | 0x7; + } + + // Pre jedec + MCHBAR8(0x40) = MCHBAR8(0x40) | 0x2; + FOR_EACH_POPULATED_CHANNEL(s->dimms, ch) { + MCHBAR32(0x400*ch + 0x260) = MCHBAR32(0x400*ch + 0x260) | (1 << 27); + } + MCHBAR16(0x212) = (MCHBAR16(0x212) & ~0xf000) | 0xf000; + MCHBAR16(0x212) = (MCHBAR16(0x212) & ~0xf00) | 0xf00; + PRINTK_DEBUG("Done pre-jedec\n"); + + // JEDEC reset + jedec_ddr2(s); + + PRINTK_DEBUG("Done jedec steps\n"); + + // After JEDEC reset + MCHBAR8(0x40) = MCHBAR8(0x40) & ~0x2; + FOR_EACH_POPULATED_CHANNEL(s->dimms, ch) { + if (s->selected_timings.mem_clock == MEM_CLOCK_667MHz) { + reg32 = (2 << 18) | (3 << 13) | (5 << 8); + } else { + reg32 = (2 << 18) | (3 << 13) | (4 << 8); + } + MCHBAR32(0x400*ch + 0x274) = (MCHBAR32(0x400*ch + 0x274) & ~0xfff00) | reg32; + MCHBAR8(0x400*ch + 0x274) = MCHBAR8(0x400*ch + 0x274) & ~0x80; + MCHBAR8(0x400*ch + 0x26c) = MCHBAR8(0x400*ch + 0x26c) | 1; + MCHBAR32(0x400*ch + 0x278) = 0x88141881; + MCHBAR16(0x400*ch + 0x27c) = 0x41; + MCHBAR8(0x400*ch + 0x292) = 0xf2; + MCHBAR8(0x400*ch + 0x271) = (MCHBAR8(0x400*ch + 0x271) & ~0xe) | 0xe; + } + MCHBAR8(0x2c4) = MCHBAR8(0x2c4) | 0x8; + MCHBAR8(0x2c3) = MCHBAR8(0x2c3) | 0x40; + MCHBAR8(0x2c4) = MCHBAR8(0x2c4) | 0x4; + + PRINTK_DEBUG("Done post-jedec\n"); + + // Set DDR2 init complete + FOR_EACH_POPULATED_CHANNEL(s->dimms, ch) { + MCHBAR32(0x400*ch + 0x268) = (MCHBAR32(0x400*ch + 0x268) & ~0xc0000000) | 0xc0000000; + } + + // Receive enable + rcven_ddr2(s); + PRINTK_DEBUG("Done rcven\n"); + + // Finish rcven + FOR_EACH_CHANNEL(ch) { + MCHBAR8(0x400*ch + 0x5d8) = MCHBAR8(0x400*ch + 0x5d8) & ~0xe; + MCHBAR8(0x400*ch + 0x5d8) = MCHBAR8(0x400*ch + 0x5d8) | 0x2; + MCHBAR8(0x400*ch + 0x5d8) = MCHBAR8(0x400*ch + 0x5d8) | 0x4; + MCHBAR8(0x400*ch + 0x5d8) = MCHBAR8(0x400*ch + 0x5d8) | 0x8; + } + MCHBAR8(0x5dc) = MCHBAR8(0x5dc) | 0x80; + MCHBAR8(0x5dc) = MCHBAR8(0x5dc) & ~0x80; + MCHBAR8(0x5dc) = MCHBAR8(0x5dc) | 0x80; + + // Dummy writes / reads + volatile u32 data; + FOR_EACH_POPULATED_RANK(s->dimms, ch, r) { + for (bank = 0; bank < 4; bank++) { + reg32 = (ch << 29) | (r*0x8000000) | (bank << 12); + write32((u32 *)reg32, 0xffffffff); + data = read32((u32 *)reg32); + PRINTK_DEBUG("Wrote ones, Read: [0x%08x]=0x%08x\n", reg32, data); + write32((u32 *)reg32, 0x00000000); + data = read32((u32 *)reg32); + PRINTK_DEBUG("Wrote zeros, Read: [0x%08x]=0x%08x\n", reg32, data); + } + } + PRINTK_DEBUG("Done dummy reads\n"); + + // XXX tRD + + // XXX Write training + + // XXX Read training + + // DRADRB + dradrb_ddr2(s); + PRINTK_DEBUG("Done DRADRB\n"); + + // Memory map + mmap_ddr2(s); + PRINTK_DEBUG("Done memory map\n"); + + // Enhanced mode + enhanced_ddr2(s); + PRINTK_DEBUG("Done enhanced mode\n"); + + // Periodic RCOMP + MCHBAR16(0x160) = (MCHBAR16(0x160) & ~0xfff) | 0x999; + MCHBAR16(0x1b4) = MCHBAR16(0x1b4) | 0x3000; + MCHBAR8(0x130) = MCHBAR8(0x130) | 0x82; + PRINTK_DEBUG("Done PRCOMP\n"); + + // Power settings + power_ddr2(s); + PRINTK_DEBUG("Done power settings\n"); + + // ME related + //MCHBAR32(0xa30) = MCHBAR32(0xa30) | (1 << 26); + + PRINTK_DEBUG("Done ddr2\n"); +}
