HAOUAS Elyes (ehaouas@noos.fr) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6324
commit cb4b93305ac006372478879fc2c5bc31bc66111f Author: Elyes HAOUAS ehaouas@noos.fr Date: Tue Jul 22 19:03:14 2014 +0200
supermicro/h8qgi & h8scm: Remove a trailing whitespace
Change-Id: I9d44679f32b917dae42b9a6920c3d3c54626dcda Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- src/mainboard/supermicro/h8qgi/buildOpts.c | 18 +++++++++--------- src/mainboard/supermicro/h8qgi/platform_cfg.h | 4 ++-- src/mainboard/supermicro/h8scm/buildOpts.c | 18 +++++++++--------- src/mainboard/supermicro/h8scm/platform_cfg.h | 4 ++-- 4 files changed, 22 insertions(+), 22 deletions(-)
diff --git a/src/mainboard/supermicro/h8qgi/buildOpts.c b/src/mainboard/supermicro/h8qgi/buildOpts.c index 1a1181e..40dbc57 100644 --- a/src/mainboard/supermicro/h8qgi/buildOpts.c +++ b/src/mainboard/supermicro/h8qgi/buildOpts.c @@ -30,15 +30,15 @@ * coreboot enable -Wundef option, so we should make sure we have all contanstand defined */ /* MEMORY_BUS_SPEED */ -#define DDR400_FREQUENCY 200 ///< DDR 400 -#define DDR533_FREQUENCY 266 ///< DDR 533 -#define DDR667_FREQUENCY 333 ///< DDR 667 -#define DDR800_FREQUENCY 400 ///< DDR 800 -#define DDR1066_FREQUENCY 533 ///< DDR 1066 -#define DDR1333_FREQUENCY 667 ///< DDR 1333 -#define DDR1600_FREQUENCY 800 ///< DDR 1600 -#define DDR1866_FREQUENCY 933 ///< DDR 1866 -#define UNSUPPORTED_DDR_FREQUENCY 934 ///< Highest limit of DDR frequency +#define DDR400_FREQUENCY 200 ///< DDR 400 +#define DDR533_FREQUENCY 266 ///< DDR 533 +#define DDR667_FREQUENCY 333 ///< DDR 667 +#define DDR800_FREQUENCY 400 ///< DDR 800 +#define DDR1066_FREQUENCY 533 ///< DDR 1066 +#define DDR1333_FREQUENCY 667 ///< DDR 1333 +#define DDR1600_FREQUENCY 800 ///< DDR 1600 +#define DDR1866_FREQUENCY 933 ///< DDR 1866 +#define UNSUPPORTED_DDR_FREQUENCY 934 ///< Highest limit of DDR frequency
/* QUANDRANK_TYPE*/ #define QUADRANK_REGISTERED 0 ///< Quadrank registered DIMM diff --git a/src/mainboard/supermicro/h8qgi/platform_cfg.h b/src/mainboard/supermicro/h8qgi/platform_cfg.h index 1663685..2569680 100644 --- a/src/mainboard/supermicro/h8qgi/platform_cfg.h +++ b/src/mainboard/supermicro/h8qgi/platform_cfg.h @@ -31,13 +31,13 @@ * Enable check for PCIe endpoint to be ready for PCI enumeration. * */ -//#define EPREADY_WORKAROUND_DISABLED +//#define EPREADY_WORKAROUND_DISABLED
/** * Enable IOMMU support. Initialize IOMMU subsystem, generate IVRS ACPI table. * */ -#define IOMMU_SUPPORT_DISABLE //TODO: enable it +#define IOMMU_SUPPORT_DISABLE //TODO: enable it
/** * Disable server PCIe hotplug support. diff --git a/src/mainboard/supermicro/h8scm/buildOpts.c b/src/mainboard/supermicro/h8scm/buildOpts.c index 543bc4f..95dffaa 100644 --- a/src/mainboard/supermicro/h8scm/buildOpts.c +++ b/src/mainboard/supermicro/h8scm/buildOpts.c @@ -30,15 +30,15 @@ * coreboot enable -Wundef option, so we should make sure we have all contanstand defined */ /* MEMORY_BUS_SPEED */ -#define DDR400_FREQUENCY 200 ///< DDR 400 -#define DDR533_FREQUENCY 266 ///< DDR 533 -#define DDR667_FREQUENCY 333 ///< DDR 667 -#define DDR800_FREQUENCY 400 ///< DDR 800 -#define DDR1066_FREQUENCY 533 ///< DDR 1066 -#define DDR1333_FREQUENCY 667 ///< DDR 1333 -#define DDR1600_FREQUENCY 800 ///< DDR 1600 -#define DDR1866_FREQUENCY 933 ///< DDR 1866 -#define UNSUPPORTED_DDR_FREQUENCY 934 ///< Highest limit of DDR frequency +#define DDR400_FREQUENCY 200 ///< DDR 400 +#define DDR533_FREQUENCY 266 ///< DDR 533 +#define DDR667_FREQUENCY 333 ///< DDR 667 +#define DDR800_FREQUENCY 400 ///< DDR 800 +#define DDR1066_FREQUENCY 533 ///< DDR 1066 +#define DDR1333_FREQUENCY 667 ///< DDR 1333 +#define DDR1600_FREQUENCY 800 ///< DDR 1600 +#define DDR1866_FREQUENCY 933 ///< DDR 1866 +#define UNSUPPORTED_DDR_FREQUENCY 934 ///< Highest limit of DDR frequency
/* QUANDRANK_TYPE */ #define QUADRANK_REGISTERED 0 ///< Quadrank registered DIMM diff --git a/src/mainboard/supermicro/h8scm/platform_cfg.h b/src/mainboard/supermicro/h8scm/platform_cfg.h index 1663685..2569680 100644 --- a/src/mainboard/supermicro/h8scm/platform_cfg.h +++ b/src/mainboard/supermicro/h8scm/platform_cfg.h @@ -31,13 +31,13 @@ * Enable check for PCIe endpoint to be ready for PCI enumeration. * */ -//#define EPREADY_WORKAROUND_DISABLED +//#define EPREADY_WORKAROUND_DISABLED
