Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3902
commit 5ee885fa43973bc40fdd270f0670a1cc97bbc360 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Wed Sep 4 13:05:01 2013 +0300
CBMEM: Add cbmem_late_set_table() and drop references to high_tables_base
This helper function is for compatibility only for chipsets that do not implement get_top_of_ram() to support early CBMEM.
Also remove references to globals high_tables_base and _size under arch/ and from two ARMv7 boards.
Change-Id: I17eee30635a0368b2ada06e0698425c5ef0ecc53 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/arch/armv7/tables.c | 7 ------- src/arch/x86/boot/cbmem.c | 5 +---- src/arch/x86/boot/tables.c | 13 ++++++++++--- src/include/cbmem.h | 1 + src/lib/cbmem.c | 10 ++++++++++ src/mainboard/google/pit/mainboard.c | 17 +++++++++++------ src/mainboard/google/snow/mainboard.c | 17 +++++++++++------ 7 files changed, 44 insertions(+), 26 deletions(-)
diff --git a/src/arch/armv7/tables.c b/src/arch/armv7/tables.c index 0fc7399..0f174d3 100644 --- a/src/arch/armv7/tables.c +++ b/src/arch/armv7/tables.c @@ -29,13 +29,6 @@
#define MAX_COREBOOT_TABLE_SIZE (8 * 1024)
-/* - * TODO: "High" tables are a convention used on x86. Maybe we can - * clean up that naming at some point. - */ -uint64_t high_tables_base = 0; -uint64_t high_tables_size; - void cbmem_arch_init(void) { } diff --git a/src/arch/x86/boot/cbmem.c b/src/arch/x86/boot/cbmem.c index 3f738be..6ec005d 100644 --- a/src/arch/x86/boot/cbmem.c +++ b/src/arch/x86/boot/cbmem.c @@ -25,9 +25,6 @@ */ void set_top_of_ram(uint64_t ramtop) { - high_tables_base = ramtop - HIGH_MEMORY_SIZE; - high_tables_size = HIGH_MEMORY_SIZE; - printk(BIOS_DEBUG, "high_tables_base: %08llx, size %lld\n", - high_tables_base, high_tables_size); + cbmem_late_set_table(ramtop - HIGH_MEMORY_SIZE, HIGH_MEMORY_SIZE); } #endif diff --git a/src/arch/x86/boot/tables.c b/src/arch/x86/boot/tables.c index 67d7911..31d0fc7 100644 --- a/src/arch/x86/boot/tables.c +++ b/src/arch/x86/boot/tables.c @@ -32,8 +32,6 @@ #include <lib.h> #include <smbios.h>
void cbmem_arch_init(void) { @@ -227,9 +225,18 @@ struct lb_memory *write_tables(void) if (high_table_pointer) { unsigned long new_high_table_pointer;
+ /* FIXME: The high_table_base parameter is not reference when tables are high, + * or high_table_pointer >1 MB. + */ +#if CONFIG_DYNAMIC_CBMEM + u64 fixme_high_tables_base = 0; +#else + u64 fixme_high_tables_base = high_tables_base; +#endif + /* Also put a forwarder entry into 0-4K */ new_high_table_pointer = write_coreboot_table(low_table_start, low_table_end, - high_tables_base, high_table_pointer); + fixme_high_tables_base, high_table_pointer);
if (new_high_table_pointer > (high_table_pointer + MAX_COREBOOT_TABLE_SIZE)) diff --git a/src/include/cbmem.h b/src/include/cbmem.h index 00d74d6..3d04763 100644 --- a/src/include/cbmem.h +++ b/src/include/cbmem.h @@ -137,6 +137,7 @@ void cbmem_add_lb_mem(struct lb_memory *mem); #ifndef __PRE_RAM__ extern uint64_t high_tables_base, high_tables_size; void set_top_of_ram(uint64_t ramtop); +void cbmem_late_set_table(uint64_t base, uint64_t size); void set_cbmem_toc(struct cbmem_entry *); #endif
diff --git a/src/lib/cbmem.c b/src/lib/cbmem.c index 9e2ce0d..206fdbf 100644 --- a/src/lib/cbmem.c +++ b/src/lib/cbmem.c @@ -42,6 +42,8 @@ struct cbmem_entry { } __attribute__((packed));
#ifndef __PRE_RAM__ +uint64_t high_tables_base = 0; +uint64_t high_tables_size = 0; static struct cbmem_entry *bss_cbmem_toc;
struct cbmem_entry *__attribute__((weak)) get_cbmem_toc(void) @@ -60,7 +62,15 @@ struct cbmem_entry *__attribute__((weak)) get_cbmem_toc(void) printk(BIOS_WARNING, "WARNING: you need to define get_cbmem_toc() for your chipset\n"); return NULL; } +#endif
+#if !defined(__PRE_RAM__) +void cbmem_late_set_table(uint64_t base, uint64_t size) +{ + printk(BIOS_DEBUG, "CBMEM region %llx-%llx (%s)\n", base, base+size-1, __FUNCTION__); + high_tables_base = base; + high_tables_size = size; +} #endif
/** diff --git a/src/mainboard/google/pit/mainboard.c b/src/mainboard/google/pit/mainboard.c index 54ea042..7dd8388 100644 --- a/src/mainboard/google/pit/mainboard.c +++ b/src/mainboard/google/pit/mainboard.c @@ -221,17 +221,22 @@ static void mainboard_init(device_t dev) // gpio_info(); }
+static void setup_cbmem(void) +{ + u64 size = CONFIG_COREBOOT_TABLES_SIZE; + u64 base = CONFIG_SYS_SDRAM_BASE + + ((unsigned)CONFIG_DRAM_SIZE_MB << 20ULL) - + CONFIG_COREBOOT_TABLES_SIZE; + cbmem_late_set_table(base, size); + cbmem_init(base, size); +} + static void mainboard_enable(device_t dev) { dev->ops->init = &mainboard_init;
/* set up coreboot tables */ - /* FIXME: this should happen somewhere else */ - high_tables_size = CONFIG_COREBOOT_TABLES_SIZE; - high_tables_base = CONFIG_SYS_SDRAM_BASE + - ((unsigned)CONFIG_DRAM_SIZE_MB << 20ULL) - - CONFIG_COREBOOT_TABLES_SIZE; - cbmem_init(high_tables_base, high_tables_size); + setup_cbmem();
/* set up dcache and MMU */ /* FIXME: this should happen via resource allocator */ diff --git a/src/mainboard/google/snow/mainboard.c b/src/mainboard/google/snow/mainboard.c index 5aedac9..8805be5 100644 --- a/src/mainboard/google/snow/mainboard.c +++ b/src/mainboard/google/snow/mainboard.c @@ -262,17 +262,22 @@ static void mainboard_init(device_t dev) // gpio_info(); }
