Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16769
commit de0ae44aa394dc0c2feb2a2b108b444d247fbceb Author: Julius Werner jwerner@chromium.org Date: Fri Sep 23 16:07:42 2016 -0700
rockchip/rk3399: Actually remove big CPU initialization from bootblock
CL:377541 was supposed to remove the big CPU cluster initialization from rkclk_init() in the bootblock and move it to a more suitable place in ramstage. Except that next to all the code cleanup I did in that patch, I seem to have forgotten to actually remove that old code.
Big thanks to Nico for spotting that in the upstream coreboot review.
BRANCH=gru BUG=chrome-os-partner:54906 TEST=Booted Kevin.
Change-Id: I09fe948b4587536802b42329b813177439e0804f Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 77f9eaf0446b22adfca79d0adf8a0ecfd93c0040 Original-Change-Id: I13dab208225b7e43ad864f2f3cf51b3c104acd4b Original-Reported-by: Nico Huber nico.h@gmx.de Original-Signed-off-by: Julius Werner jwerner@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/389236 Original-Reviewed-by: Douglas Anderson dianders@chromium.org --- src/soc/rockchip/rk3399/clock.c | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/src/soc/rockchip/rk3399/clock.c b/src/soc/rockchip/rk3399/clock.c index b9de844..2596853 100644 --- a/src/soc/rockchip/rk3399/clock.c +++ b/src/soc/rockchip/rk3399/clock.c @@ -411,13 +411,6 @@ void rkclk_init(void) rkclk_set_pll(&cru_ptr->gpll_con[0], &gpll_init_cfg); rkclk_set_pll(&cru_ptr->cpll_con[0], &cpll_init_cfg);
- /* - * coreboot boot from little core, but it seem if apll_b use defalut - * 24MHz it will take a long time to enable big core, and will cause - * a watchdog crash, so we should do apll_b initialization here - */ - rkclk_configure_cpu(APLL_600_MHZ, true); - /* configure perihp aclk, hclk, pclk */ aclk_div = GPLL_HZ / PERIHP_ACLK_HZ - 1; assert((aclk_div + 1) * PERIHP_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f);
