Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8534
commit 7862086354755ea83ec8e001f1d1f02e970ac2fe Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Thu Feb 26 20:47:47 2015 +0200
devicetree: Discriminate device ops scan_bus()
Use of scan_static_bus() and tree traversals is somewhat convoluted. Start cleaning this up by assigning each path type with separate static scan_bus() function.
For ME, SMBus and LPC paths a bus cannot expose bridges, as those would add to the number of encountered PCI buses.
Change-Id: I8bb11450516faad4fa33b8f69bce5b9978ec75e5 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/device/root_device.c | 84 ++++++++++++++++++------- src/drivers/i2c/i2cmux/i2cmux.c | 7 +-- src/drivers/i2c/i2cmux2/i2cmux2.c | 7 +-- src/include/device/device.h | 3 +- src/mainboard/lippert/frontrunner/devicetree.cb | 6 +- src/northbridge/via/cx700/lpc.c | 2 +- src/northbridge/via/vx800/lpc.c | 2 +- src/northbridge/via/vx900/lpc.c | 2 +- src/northbridge/via/vx900/traf_ctrl.c | 5 +- src/soc/intel/baytrail/southcluster.c | 2 +- src/soc/intel/broadwell/lpc.c | 2 +- src/soc/intel/broadwell/smbus.c | 2 +- src/soc/intel/fsp_baytrail/southcluster.c | 2 +- src/southbridge/amd/agesa/hudson/lpc.c | 2 +- src/southbridge/amd/agesa/hudson/sm.c | 2 +- src/southbridge/amd/amd8111/acpi.c | 2 +- src/southbridge/amd/amd8111/lpc.c | 2 +- src/southbridge/amd/amd8111/smbus.c | 2 +- src/southbridge/amd/amd8111/usb.c | 2 - src/southbridge/amd/cimx/sb700/late.c | 2 +- src/southbridge/amd/cimx/sb800/late.c | 2 +- src/southbridge/amd/cimx/sb900/late.c | 2 +- src/southbridge/amd/cs5535/cs5535.c | 1 - src/southbridge/amd/cs5536/cs5536.c | 9 ++- src/southbridge/amd/pi/hudson/lpc.c | 2 +- src/southbridge/amd/pi/hudson/sm.c | 2 +- src/southbridge/amd/sb600/lpc.c | 2 +- src/southbridge/amd/sb600/sm.c | 2 +- src/southbridge/amd/sb700/lpc.c | 2 +- src/southbridge/amd/sb700/sm.c | 2 +- src/southbridge/amd/sb800/lpc.c | 2 +- src/southbridge/amd/sb800/sm.c | 2 +- src/southbridge/broadcom/bcm5785/lpc.c | 2 +- src/southbridge/broadcom/bcm5785/sb_pci_main.c | 2 +- src/southbridge/dmp/vortex86ex/southbridge.c | 2 +- src/southbridge/intel/bd82x6x/lpc.c | 2 +- src/southbridge/intel/bd82x6x/me.c | 1 - src/southbridge/intel/bd82x6x/me_8.x.c | 1 - src/southbridge/intel/bd82x6x/smbus.c | 2 +- src/southbridge/intel/esb6300/lpc.c | 2 +- src/southbridge/intel/esb6300/smbus.c | 2 +- src/southbridge/intel/fsp_bd82x6x/lpc.c | 2 +- src/southbridge/intel/fsp_bd82x6x/me.c | 1 - src/southbridge/intel/fsp_bd82x6x/me_8.x.c | 1 - src/southbridge/intel/fsp_rangeley/lpc.c | 2 +- src/southbridge/intel/fsp_rangeley/smbus.c | 2 +- src/southbridge/intel/i3100/lpc.c | 2 +- src/southbridge/intel/i3100/smbus.c | 2 +- src/southbridge/intel/i82371eb/isa.c | 2 +- src/southbridge/intel/i82371eb/smbus.c | 2 +- src/southbridge/intel/i82801ax/lpc.c | 2 +- src/southbridge/intel/i82801ax/smbus.c | 2 +- src/southbridge/intel/i82801bx/lpc.c | 2 +- src/southbridge/intel/i82801bx/smbus.c | 2 +- src/southbridge/intel/i82801cx/lpc.c | 2 +- src/southbridge/intel/i82801dx/lpc.c | 2 +- src/southbridge/intel/i82801ex/lpc.c | 2 +- src/southbridge/intel/i82801ex/smbus.c | 2 +- src/southbridge/intel/i82801gx/lpc.c | 2 +- src/southbridge/intel/i82801gx/smbus.c | 2 +- src/southbridge/intel/i82801ix/lpc.c | 2 +- src/southbridge/intel/i82801ix/smbus.c | 2 +- src/southbridge/intel/ibexpeak/lpc.c | 2 +- src/southbridge/intel/ibexpeak/me.c | 1 - src/southbridge/intel/ibexpeak/smbus.c | 2 +- src/southbridge/intel/lynxpoint/lpc.c | 2 +- src/southbridge/intel/lynxpoint/smbus.c | 2 +- src/southbridge/intel/sch/lpc.c | 2 +- src/southbridge/intel/sch/smbus.c | 2 +- src/southbridge/nvidia/ck804/lpc.c | 2 +- src/southbridge/nvidia/ck804/smbus.c | 2 +- src/southbridge/nvidia/mcp55/lpc.c | 2 +- src/southbridge/nvidia/mcp55/smbus.c | 2 +- src/southbridge/rdc/r8610/r8610.c | 1 - src/southbridge/sis/sis966/lpc.c | 2 +- src/southbridge/via/vt8237r/lpc.c | 6 +- src/superio/smsc/lpc47b397/superio.c | 1 - 77 files changed, 140 insertions(+), 117 deletions(-)
diff --git a/src/device/root_device.c b/src/device/root_device.c index d0a3664..4e727f0 100644 --- a/src/device/root_device.c +++ b/src/device/root_device.c @@ -44,51 +44,69 @@ const char mainboard_name[] = CONFIG_MAINBOARD_VENDOR " " CONFIG_MAINBOARD_PART_ * debug device. Those virtual devices have to be listed in the config * file under some static bus in order to be enumerated at run time. * - * This function is the default scan_bus() method for the root device and - * LPC bridges. - * * @param bus Pointer to the device to which the static buses are attached to. * @param max Maximum bus number currently used before scanning. * @return The largest bus number used. */ -static int smbus_max = 0; -unsigned int scan_static_bus(device_t bus, unsigned int max) + +static unsigned int scan_static_bus(device_t bus, unsigned int max) { device_t child; struct bus *link;
- printk(BIOS_SPEW, "%s for %s\n", __func__, dev_path(bus)); - for (link = bus->link_list; link; link = link->next) { - /* For SMBus bus enumerate. */ - child = link->children; - - if (child && child->path.type == DEVICE_PATH_I2C) - link->secondary = ++smbus_max; - for (child = link->children; child; child = child->sibling) { + if (child->chip_ops && child->chip_ops->enable_dev) child->chip_ops->enable_dev(child);
if (child->ops && child->ops->enable) child->ops->enable(child);
- if (child->path.type == DEVICE_PATH_I2C) { - printk(BIOS_DEBUG, "smbus: %s[%d]->", - dev_path(child->bus->dev), - child->bus->link_num); - } printk(BIOS_DEBUG, "%s %s\n", dev_path(child), child->enabled ? "enabled" : "disabled"); } }
+ return max; +} + +unsigned int scan_lpc_bus(device_t bus, unsigned int max) +{ + printk(BIOS_SPEW, "%s for %s\n", __func__, dev_path(bus)); + + max = scan_static_bus(bus, max); + + printk(BIOS_SPEW, "%s for %s done\n", __func__, dev_path(bus)); + + return max; +} + +unsigned int scan_smbus(device_t bus, unsigned int max) +{ + device_t child; + struct bus *link; + static int smbus_max = 0; + + printk(BIOS_SPEW, "%s for %s\n", __func__, dev_path(bus)); + for (link = bus->link_list; link; link = link->next) { + + link->secondary = ++smbus_max; + for (child = link->children; child; child = child->sibling) { - if (!child->ops || !child->ops->scan_bus) - continue; - printk(BIOS_SPEW, "%s scanning...\n", dev_path(child)); - max = scan_bus(child, max); + + if (child->chip_ops && child->chip_ops->enable_dev) + child->chip_ops->enable_dev(child); + + if (child->ops && child->ops->enable) + child->ops->enable(child); + + printk(BIOS_DEBUG, "smbus: %s[%d]->", dev_path(child->bus->dev), + child->bus->link_num); + + printk(BIOS_DEBUG, "%s %s\n", dev_path(child), + child->enabled ? "enabled" : "disabled"); } }
@@ -106,9 +124,27 @@ unsigned int scan_static_bus(device_t bus, unsigned int max) * @param max The current bus number scanned so far, usually 0x00. * @return The largest bus number used. */ -static unsigned int root_dev_scan_bus(device_t root, unsigned int max) +static unsigned int root_dev_scan_bus(device_t bus, unsigned int max) { - return scan_static_bus(root, max); + device_t child; + struct bus *link; + + printk(BIOS_SPEW, "%s for %s\n", __func__, dev_path(bus)); + + max = scan_static_bus(bus, max); + + for (link = bus->link_list; link; link = link->next) { + for (child = link->children; child; child = child->sibling) { + if (!child->ops || !child->ops->scan_bus) + continue; + printk(BIOS_SPEW, "%s scanning...\n", dev_path(child)); + max = scan_bus(child, max); + } + } + + printk(BIOS_SPEW, "%s for %s done\n", __func__, dev_path(bus)); + + return max; }
static void root_dev_reset(struct bus *bus) diff --git a/src/drivers/i2c/i2cmux/i2cmux.c b/src/drivers/i2c/i2cmux/i2cmux.c index 1091653..ef5ab3a 100644 --- a/src/drivers/i2c/i2cmux/i2cmux.c +++ b/src/drivers/i2c/i2cmux/i2cmux.c @@ -1,10 +1,5 @@ -#include <console/console.h> #include <device/device.h> #include <device/smbus.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> -#include <cpu/x86/msr.h>
static void i2cmux_set_link(struct device *dev, unsigned int link) { @@ -21,7 +16,7 @@ static struct device_operations i2cmux_operations = { .set_resources = DEVICE_NOOP, .enable_resources = DEVICE_NOOP, .init = DEVICE_NOOP, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .set_link = i2cmux_set_link, };
diff --git a/src/drivers/i2c/i2cmux2/i2cmux2.c b/src/drivers/i2c/i2cmux2/i2cmux2.c index fe48e76..4d1241a 100644 --- a/src/drivers/i2c/i2cmux2/i2cmux2.c +++ b/src/drivers/i2c/i2cmux2/i2cmux2.c @@ -1,10 +1,5 @@ -#include <console/console.h> #include <device/device.h> #include <device/smbus.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> -#include <cpu/x86/msr.h>
static void i2cmux2_set_link(struct device *dev, unsigned int link) { @@ -20,7 +15,7 @@ static struct device_operations i2cmux2_operations = { .set_resources = DEVICE_NOOP, .enable_resources = DEVICE_NOOP, .init = DEVICE_NOOP, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .set_link = i2cmux2_set_link, };
diff --git a/src/include/device/device.h b/src/include/device/device.h index c1c9fdb..559557a 100644 --- a/src/include/device/device.h +++ b/src/include/device/device.h @@ -224,11 +224,12 @@ void show_all_devs_resources(int debug_level, const char* msg); extern struct device_operations default_dev_ops_root; void pci_domain_read_resources(struct device *dev); unsigned int pci_domain_scan_bus(struct device *dev, unsigned int _max); -unsigned int scan_static_bus(device_t bus, unsigned int _max);
void fixed_mem_resource(device_t dev, unsigned long index, unsigned long basek, unsigned long sizek, unsigned long type);
+unsigned int scan_smbus(device_t bus, unsigned int _max); +unsigned int scan_lpc_bus(device_t bus, unsigned int _max);
/* It is the caller's responsibility to adjust regions such that ram_resource() * and mmio_resource() do not overlap. diff --git a/src/mainboard/lippert/frontrunner/devicetree.cb b/src/mainboard/lippert/frontrunner/devicetree.cb index 78d099a..239f1f9 100644 --- a/src/mainboard/lippert/frontrunner/devicetree.cb +++ b/src/mainboard/lippert/frontrunner/devicetree.cb @@ -6,10 +6,10 @@ chip northbridge/amd/gx2 end
device domain 0 on - device pci 0.0 on end + device pci 0.0 on chip southbridge/amd/cs5535 - register "setupflash" = "0" - device pci 12.0 on + register "setupflash" = "0" + device pci 12.0 on end device pci 12.1 off end # SMI device pci 12.2 on end # IDE device pci 12.3 off end # Audio diff --git a/src/northbridge/via/cx700/lpc.c b/src/northbridge/via/cx700/lpc.c index 56842b0..01d62e7 100644 --- a/src/northbridge/via/cx700/lpc.c +++ b/src/northbridge/via/cx700/lpc.c @@ -297,7 +297,7 @@ static struct device_operations cx700_lpc_ops = { .set_resources = cx700_set_resources, .enable_resources = cx700_enable_resources, .init = cx700_lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, };
static const struct pci_driver lpc_driver __pci_driver = { diff --git a/src/northbridge/via/vx800/lpc.c b/src/northbridge/via/vx800/lpc.c index c3dee32..2cde9b3 100644 --- a/src/northbridge/via/vx800/lpc.c +++ b/src/northbridge/via/vx800/lpc.c @@ -362,7 +362,7 @@ static struct device_operations vx800_lpc_ops = { .set_resources = vx800_set_resources, .enable_resources = pci_dev_enable_resources, .init = southbridge_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, };
static const struct pci_driver lpc_driver __pci_driver = { diff --git a/src/northbridge/via/vx900/lpc.c b/src/northbridge/via/vx900/lpc.c index 61a8a7b..f6c4c6a 100644 --- a/src/northbridge/via/vx900/lpc.c +++ b/src/northbridge/via/vx900/lpc.c @@ -192,7 +192,7 @@ static struct device_operations vx900_lpc_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = vx900_lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, };
static const struct pci_driver lpc_driver __pci_driver = { diff --git a/src/northbridge/via/vx900/traf_ctrl.c b/src/northbridge/via/vx900/traf_ctrl.c index fb15193..011bb41 100644 --- a/src/northbridge/via/vx900/traf_ctrl.c +++ b/src/northbridge/via/vx900/traf_ctrl.c @@ -134,8 +134,9 @@ static struct device_operations traf_ctrl_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = vx900_traf_ctr_init, - /* Need this here, or the IOAPIC driver won't be called */ - .scan_bus = scan_static_bus, + /* Need this here, or the IOAPIC driver won't be called. + * FIXME: Technically not a LPC bus. */ + .scan_bus = scan_lpc_bus, };
static const struct pci_driver traf_ctrl_driver __pci_driver = { diff --git a/src/soc/intel/baytrail/southcluster.c b/src/soc/intel/baytrail/southcluster.c index a635b0d..a20b4cb 100644 --- a/src/soc/intel/baytrail/southcluster.c +++ b/src/soc/intel/baytrail/southcluster.c @@ -516,7 +516,7 @@ static struct device_operations device_ops = { .enable_resources = NULL, .init = sc_init, .enable = southcluster_enable_dev, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &soc_pci_ops, };
diff --git a/src/soc/intel/broadwell/lpc.c b/src/soc/intel/broadwell/lpc.c index b8eff27..e9a590f 100644 --- a/src/soc/intel/broadwell/lpc.c +++ b/src/soc/intel/broadwell/lpc.c @@ -587,7 +587,7 @@ static struct device_operations device_ops = { .acpi_inject_dsdt_generator = southcluster_inject_dsdt, .write_acpi_tables = acpi_write_hpet, .init = &lpc_init, - .scan_bus = &scan_static_bus, + .scan_bus = &scan_lpc_bus, .ops_pci = &broadwell_pci_ops, };
diff --git a/src/soc/intel/broadwell/smbus.c b/src/soc/intel/broadwell/smbus.c index a1dbdfe..900af82 100644 --- a/src/soc/intel/broadwell/smbus.c +++ b/src/soc/intel/broadwell/smbus.c @@ -94,7 +94,7 @@ static struct device_operations smbus_ops = { .read_resources = &smbus_read_resources, .set_resources = &pci_dev_set_resources, .enable_resources = &pci_dev_enable_resources, - .scan_bus = &scan_static_bus, + .scan_bus = &scan_smbus, .init = &pch_smbus_init, .ops_smbus_bus = &lops_smbus_bus, .ops_pci = &broadwell_pci_ops, diff --git a/src/soc/intel/fsp_baytrail/southcluster.c b/src/soc/intel/fsp_baytrail/southcluster.c index d515286..07a50d8 100644 --- a/src/soc/intel/fsp_baytrail/southcluster.c +++ b/src/soc/intel/fsp_baytrail/southcluster.c @@ -601,7 +601,7 @@ static struct device_operations device_ops = { .enable_resources = NULL, .init = sc_init, .enable = southcluster_enable_dev, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &soc_pci_ops, };
diff --git a/src/southbridge/amd/agesa/hudson/lpc.c b/src/southbridge/amd/agesa/hudson/lpc.c index b784fc4..b9938cb 100644 --- a/src/southbridge/amd/agesa/hudson/lpc.c +++ b/src/southbridge/amd/agesa/hudson/lpc.c @@ -333,7 +333,7 @@ static struct device_operations lpc_ops = { #endif .enable_resources = hudson_lpc_enable_resources, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &lops_pci, }; static const struct pci_driver lpc_driver __pci_driver = { diff --git a/src/southbridge/amd/agesa/hudson/sm.c b/src/southbridge/amd/agesa/hudson/sm.c index bc6564d..a660965 100644 --- a/src/southbridge/amd/agesa/hudson/sm.c +++ b/src/southbridge/amd/agesa/hudson/sm.c @@ -163,7 +163,7 @@ static struct device_operations smbus_ops = { .set_resources = hudson_sm_set_resources, .enable_resources = pci_dev_enable_resources, .init = sm_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .ops_pci = &lops_pci, .ops_smbus_bus = &lops_smbus_bus, }; diff --git a/src/southbridge/amd/amd8111/acpi.c b/src/southbridge/amd/amd8111/acpi.c index 6d0ce26..396b7c4 100644 --- a/src/southbridge/amd/amd8111/acpi.c +++ b/src/southbridge/amd/amd8111/acpi.c @@ -226,7 +226,7 @@ static struct device_operations acpi_ops = { .set_resources = pci_dev_set_resources, .enable_resources = acpi_enable_resources, .init = acpi_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, /* We don't need amd8111_enable, chip ops takes care of it. * It could be useful if these devices were not * enabled by default. diff --git a/src/southbridge/amd/amd8111/lpc.c b/src/southbridge/amd/amd8111/lpc.c index d75723c..a02e69d 100644 --- a/src/southbridge/amd/amd8111/lpc.c +++ b/src/southbridge/amd/amd8111/lpc.c @@ -151,7 +151,7 @@ static struct device_operations lpc_ops = { .write_acpi_tables = acpi_write_hpet, .acpi_fill_ssdt_generator = southbridge_acpi_fill_ssdt_generator, #endif - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .enable = amd8111_enable, .ops_pci = &lops_pci, }; diff --git a/src/southbridge/amd/amd8111/smbus.c b/src/southbridge/amd/amd8111/smbus.c index 0a0c58d..def1377 100644 --- a/src/southbridge/amd/amd8111/smbus.c +++ b/src/southbridge/amd/amd8111/smbus.c @@ -28,7 +28,7 @@ static struct device_operations smbus_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = 0, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .enable = amd8111_enable, .ops_pci = &lops_pci, .ops_smbus_bus = &lops_smbus_bus, diff --git a/src/southbridge/amd/amd8111/usb.c b/src/southbridge/amd/amd8111/usb.c index 13dccf4..feb7793 100644 --- a/src/southbridge/amd/amd8111/usb.c +++ b/src/southbridge/amd/amd8111/usb.c @@ -25,8 +25,6 @@ static struct device_operations usb_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = 0, - .scan_bus = scan_static_bus, -// .enable = amd8111_enable, .ops_pci = &lops_pci, };
diff --git a/src/southbridge/amd/cimx/sb700/late.c b/src/southbridge/amd/cimx/sb700/late.c index 1e1357e..517d685 100644 --- a/src/southbridge/amd/cimx/sb700/late.c +++ b/src/southbridge/amd/cimx/sb700/late.c @@ -111,7 +111,7 @@ static struct device_operations lpc_ops = { .write_acpi_tables = acpi_write_hpet, #endif .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &lops_pci, };
diff --git a/src/southbridge/amd/cimx/sb800/late.c b/src/southbridge/amd/cimx/sb800/late.c index f4a7aa3..c2c1bfd 100644 --- a/src/southbridge/amd/cimx/sb800/late.c +++ b/src/southbridge/amd/cimx/sb800/late.c @@ -161,7 +161,7 @@ static struct device_operations lpc_ops = { .write_acpi_tables = acpi_write_hpet, #endif .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &lops_pci, };
diff --git a/src/southbridge/amd/cimx/sb900/late.c b/src/southbridge/amd/cimx/sb900/late.c index 6d47f05..77f45ee 100644 --- a/src/southbridge/amd/cimx/sb900/late.c +++ b/src/southbridge/amd/cimx/sb900/late.c @@ -132,7 +132,7 @@ static struct device_operations lpc_ops = { #if IS_ENABLED(CONFIG_HAVE_ACPI_TABLES) && IS_ENABLED(CONFIG_PER_DEVICE_ACPI_TABLES) .write_acpi_tables = acpi_write_hpet, #endif - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &lops_pci, };
diff --git a/src/southbridge/amd/cs5535/cs5535.c b/src/southbridge/amd/cs5535/cs5535.c index e66a1e2..70b8386 100644 --- a/src/southbridge/amd/cs5535/cs5535.c +++ b/src/southbridge/amd/cs5535/cs5535.c @@ -94,7 +94,6 @@ static struct device_operations southbridge_ops = { .enable_resources = pci_dev_enable_resources, .init = southbridge_init, .enable = southbridge_enable, - .scan_bus = scan_static_bus, };
static const struct pci_driver cs5535_pci_driver __pci_driver = { diff --git a/src/southbridge/amd/cs5536/cs5536.c b/src/southbridge/amd/cs5536/cs5536.c index da79a67..dd0ff0f 100644 --- a/src/southbridge/amd/cs5536/cs5536.c +++ b/src/southbridge/amd/cs5536/cs5536.c @@ -688,13 +688,18 @@ static struct smbus_bus_operations lops_smbus_bus = { .read_byte = lsmbus_read_byte, };
+static unsigned int scan_lpc_smbus(device_t dev, unsigned int max) +{ + /* FIXME. Do we have mixed LPC/SMBus device node here. */ + return scan_smbus(dev, max); +} + static struct device_operations southbridge_ops = { .read_resources = cs5536_read_resources, .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = southbridge_init, -// .enable = southbridge_enable, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_smbus, .ops_smbus_bus = &lops_smbus_bus, };
diff --git a/src/southbridge/amd/pi/hudson/lpc.c b/src/southbridge/amd/pi/hudson/lpc.c index 7e2ec00..847d750 100644 --- a/src/southbridge/amd/pi/hudson/lpc.c +++ b/src/southbridge/amd/pi/hudson/lpc.c @@ -332,7 +332,7 @@ static struct device_operations lpc_ops = { .write_acpi_tables = acpi_write_hpet, #endif .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &lops_pci, }; static const struct pci_driver lpc_driver __pci_driver = { diff --git a/src/southbridge/amd/pi/hudson/sm.c b/src/southbridge/amd/pi/hudson/sm.c index bc6564d..a660965 100644 --- a/src/southbridge/amd/pi/hudson/sm.c +++ b/src/southbridge/amd/pi/hudson/sm.c @@ -163,7 +163,7 @@ static struct device_operations smbus_ops = { .set_resources = hudson_sm_set_resources, .enable_resources = pci_dev_enable_resources, .init = sm_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .ops_pci = &lops_pci, .ops_smbus_bus = &lops_smbus_bus, }; diff --git a/src/southbridge/amd/sb600/lpc.c b/src/southbridge/amd/sb600/lpc.c index dc2f31b..973f01d 100644 --- a/src/southbridge/amd/sb600/lpc.c +++ b/src/southbridge/amd/sb600/lpc.c @@ -242,7 +242,7 @@ static struct device_operations lpc_ops = { .acpi_fill_ssdt_generator = southbridge_acpi_fill_ssdt_generator, #endif .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, /* .enable = sb600_enable, */ .ops_pci = &lops_pci, }; diff --git a/src/southbridge/amd/sb600/sm.c b/src/southbridge/amd/sb600/sm.c index 3ce5f02..a8d690e 100644 --- a/src/southbridge/amd/sb600/sm.c +++ b/src/southbridge/amd/sb600/sm.c @@ -361,7 +361,7 @@ static struct device_operations smbus_ops = { .set_resources = sb600_sm_set_resources, .enable_resources = pci_dev_enable_resources, .init = sm_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, /* .enable = sb600_enable, */ .ops_pci = &lops_pci, .ops_smbus_bus = &lops_smbus_bus, diff --git a/src/southbridge/amd/sb700/lpc.c b/src/southbridge/amd/sb700/lpc.c index 7bb21d2..d36baf0 100644 --- a/src/southbridge/amd/sb700/lpc.c +++ b/src/southbridge/amd/sb700/lpc.c @@ -287,7 +287,7 @@ static struct device_operations lpc_ops = { .acpi_fill_ssdt_generator = southbridge_acpi_fill_ssdt_generator, #endif .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &lops_pci, }; static const struct pci_driver lpc_driver __pci_driver = { diff --git a/src/southbridge/amd/sb700/sm.c b/src/southbridge/amd/sb700/sm.c index 1db637b..2b8dfb4 100644 --- a/src/southbridge/amd/sb700/sm.c +++ b/src/southbridge/amd/sb700/sm.c @@ -452,7 +452,7 @@ static struct device_operations smbus_ops = { .set_resources = sb700_sm_set_resources, .enable_resources = pci_dev_enable_resources, .init = sm_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .ops_pci = &lops_pci, .ops_smbus_bus = &lops_smbus_bus, }; diff --git a/src/southbridge/amd/sb800/lpc.c b/src/southbridge/amd/sb800/lpc.c index 87c09a2..1973e36 100644 --- a/src/southbridge/amd/sb800/lpc.c +++ b/src/southbridge/amd/sb800/lpc.c @@ -254,7 +254,7 @@ static struct device_operations lpc_ops = { .write_acpi_tables = acpi_write_hpet, #endif .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &lops_pci, }; static const struct pci_driver lpc_driver __pci_driver = { diff --git a/src/southbridge/amd/sb800/sm.c b/src/southbridge/amd/sb800/sm.c index 2f5dfa1..2137996 100644 --- a/src/southbridge/amd/sb800/sm.c +++ b/src/southbridge/amd/sb800/sm.c @@ -343,7 +343,7 @@ static struct device_operations smbus_ops = { .set_resources = sb800_sm_set_resources, .enable_resources = pci_dev_enable_resources, .init = sm_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .ops_pci = &lops_pci, .ops_smbus_bus = &lops_smbus_bus, }; diff --git a/src/southbridge/broadcom/bcm5785/lpc.c b/src/southbridge/broadcom/bcm5785/lpc.c index af79892..2fdc5d0 100644 --- a/src/southbridge/broadcom/bcm5785/lpc.c +++ b/src/southbridge/broadcom/bcm5785/lpc.c @@ -135,7 +135,7 @@ static struct device_operations lpc_ops = { .set_resources = pci_dev_set_resources, .enable_resources = bcm5785_lpc_enable_resources, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, // .enable = bcm5785_enable, .ops_pci = &lops_pci, }; diff --git a/src/southbridge/broadcom/bcm5785/sb_pci_main.c b/src/southbridge/broadcom/bcm5785/sb_pci_main.c index 3745cef..7a92c96 100644 --- a/src/southbridge/broadcom/bcm5785/sb_pci_main.c +++ b/src/southbridge/broadcom/bcm5785/sb_pci_main.c @@ -154,7 +154,7 @@ static struct device_operations sb_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = sb_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, // .enable = bcm5785_enable, .ops_pci = &lops_pci, .ops_smbus_bus = &lops_smbus_bus, diff --git a/src/southbridge/dmp/vortex86ex/southbridge.c b/src/southbridge/dmp/vortex86ex/southbridge.c index 2fe1bc2..0eaeeee 100644 --- a/src/southbridge/dmp/vortex86ex/southbridge.c +++ b/src/southbridge/dmp/vortex86ex/southbridge.c @@ -619,7 +619,7 @@ static struct device_operations vortex_sb_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = &southbridge_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .enable = 0, .ops_pci = 0, }; diff --git a/src/southbridge/intel/bd82x6x/lpc.c b/src/southbridge/intel/bd82x6x/lpc.c index c323f73..f16c8c3 100644 --- a/src/southbridge/intel/bd82x6x/lpc.c +++ b/src/southbridge/intel/bd82x6x/lpc.c @@ -855,7 +855,7 @@ static struct device_operations device_ops = { .acpi_fill_ssdt_generator = southbridge_fill_ssdt, .init = lpc_init, .enable = pch_lpc_enable, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &pci_ops, };
diff --git a/src/southbridge/intel/bd82x6x/me.c b/src/southbridge/intel/bd82x6x/me.c index df18830..42ecca3 100644 --- a/src/southbridge/intel/bd82x6x/me.c +++ b/src/southbridge/intel/bd82x6x/me.c @@ -761,7 +761,6 @@ static struct device_operations device_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = intel_me_init, - .scan_bus = scan_static_bus, .ops_pci = &pci_ops, };
diff --git a/src/southbridge/intel/bd82x6x/me_8.x.c b/src/southbridge/intel/bd82x6x/me_8.x.c index 3fa3269..3e681b7 100644 --- a/src/southbridge/intel/bd82x6x/me_8.x.c +++ b/src/southbridge/intel/bd82x6x/me_8.x.c @@ -764,7 +764,6 @@ static struct device_operations device_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = intel_me_init, - .scan_bus = scan_static_bus, .ops_pci = &pci_ops, };
diff --git a/src/southbridge/intel/bd82x6x/smbus.c b/src/southbridge/intel/bd82x6x/smbus.c index 6d4e457..1a997d9 100644 --- a/src/southbridge/intel/bd82x6x/smbus.c +++ b/src/southbridge/intel/bd82x6x/smbus.c @@ -151,7 +151,7 @@ static struct device_operations smbus_ops = { .read_resources = smbus_read_resources, .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .init = pch_smbus_init, .ops_smbus_bus = &lops_smbus_bus, .ops_pci = &smbus_pci_ops, diff --git a/src/southbridge/intel/esb6300/lpc.c b/src/southbridge/intel/esb6300/lpc.c index 22bb150..e1718bb 100644 --- a/src/southbridge/intel/esb6300/lpc.c +++ b/src/southbridge/intel/esb6300/lpc.c @@ -362,7 +362,7 @@ static struct device_operations lpc_ops = { .set_resources = pci_dev_set_resources, .enable_resources = esb6300_lpc_enable_resources, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .enable = esb6300_enable, .ops_pci = &lops_pci, }; diff --git a/src/southbridge/intel/esb6300/smbus.c b/src/southbridge/intel/esb6300/smbus.c index 92cb288..2c026b8 100644 --- a/src/southbridge/intel/esb6300/smbus.c +++ b/src/southbridge/intel/esb6300/smbus.c @@ -35,7 +35,7 @@ static struct device_operations smbus_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = 0, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .enable = esb6300_enable, .ops_pci = &lops_pci, .ops_smbus_bus = &lops_smbus_bus, diff --git a/src/southbridge/intel/fsp_bd82x6x/lpc.c b/src/southbridge/intel/fsp_bd82x6x/lpc.c index f9961f9..2d9485d 100644 --- a/src/southbridge/intel/fsp_bd82x6x/lpc.c +++ b/src/southbridge/intel/fsp_bd82x6x/lpc.c @@ -796,7 +796,7 @@ static struct device_operations device_ops = { .acpi_inject_dsdt_generator = southbridge_inject_dsdt, .init = lpc_init, .enable = pch_lpc_enable, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &pci_ops, };
diff --git a/src/southbridge/intel/fsp_bd82x6x/me.c b/src/southbridge/intel/fsp_bd82x6x/me.c index bcaeeeb..89569e5 100644 --- a/src/southbridge/intel/fsp_bd82x6x/me.c +++ b/src/southbridge/intel/fsp_bd82x6x/me.c @@ -760,7 +760,6 @@ static struct device_operations device_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = intel_me_init, - .scan_bus = scan_static_bus, .ops_pci = &pci_ops, };
diff --git a/src/southbridge/intel/fsp_bd82x6x/me_8.x.c b/src/southbridge/intel/fsp_bd82x6x/me_8.x.c index 9af5f93..74ecf52 100644 --- a/src/southbridge/intel/fsp_bd82x6x/me_8.x.c +++ b/src/southbridge/intel/fsp_bd82x6x/me_8.x.c @@ -763,7 +763,6 @@ static struct device_operations device_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = intel_me_init, - .scan_bus = scan_static_bus, .ops_pci = &pci_ops, };
diff --git a/src/southbridge/intel/fsp_rangeley/lpc.c b/src/southbridge/intel/fsp_rangeley/lpc.c index 80673a6..27e555c 100644 --- a/src/southbridge/intel/fsp_rangeley/lpc.c +++ b/src/southbridge/intel/fsp_rangeley/lpc.c @@ -463,7 +463,7 @@ static struct device_operations device_ops = { .write_acpi_tables = acpi_write_hpet, .acpi_inject_dsdt_generator = southbridge_inject_dsdt, .enable = soc_lpc_enable, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &pci_ops, };
diff --git a/src/southbridge/intel/fsp_rangeley/smbus.c b/src/southbridge/intel/fsp_rangeley/smbus.c index 83158cc..aae62d3 100644 --- a/src/southbridge/intel/fsp_rangeley/smbus.c +++ b/src/southbridge/intel/fsp_rangeley/smbus.c @@ -87,7 +87,7 @@ static struct device_operations smbus_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = 0, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .ops_smbus_bus = &lops_smbus_bus, .ops_pci = &smbus_pci_ops, }; diff --git a/src/southbridge/intel/i3100/lpc.c b/src/southbridge/intel/i3100/lpc.c index 737ec65..a20550d 100644 --- a/src/southbridge/intel/i3100/lpc.c +++ b/src/southbridge/intel/i3100/lpc.c @@ -457,7 +457,7 @@ static struct device_operations lpc_ops = { #if IS_ENABLED(CONFIG_HAVE_ACPI_TABLES) .write_acpi_tables = acpi_write_hpet, #endif - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .enable = i3100_enable, .ops_pci = &lops_pci, }; diff --git a/src/southbridge/intel/i3100/smbus.c b/src/southbridge/intel/i3100/smbus.c index 849a25c..c9457fc 100644 --- a/src/southbridge/intel/i3100/smbus.c +++ b/src/southbridge/intel/i3100/smbus.c @@ -74,7 +74,7 @@ static struct device_operations smbus_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = 0, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .enable = i3100_enable, .ops_pci = &lops_pci, .ops_smbus_bus = &lops_smbus_bus, diff --git a/src/southbridge/intel/i82371eb/isa.c b/src/southbridge/intel/i82371eb/isa.c index 1deddf6..cf15eb7 100644 --- a/src/southbridge/intel/i82371eb/isa.c +++ b/src/southbridge/intel/i82371eb/isa.c @@ -145,7 +145,7 @@ static const struct device_operations isa_ops = { .acpi_fill_ssdt_generator = southbridge_acpi_fill_ssdt_generator, #endif .init = isa_init, - .scan_bus = scan_static_bus, /* TODO: Needed? */ + .scan_bus = scan_lpc_bus, /* TODO: Needed? */ .enable = 0, .ops_pci = 0, /* No subsystem IDs on 82371EB! */ }; diff --git a/src/southbridge/intel/i82371eb/smbus.c b/src/southbridge/intel/i82371eb/smbus.c index 6341751..d5a8051 100644 --- a/src/southbridge/intel/i82371eb/smbus.c +++ b/src/southbridge/intel/i82371eb/smbus.c @@ -121,7 +121,7 @@ static const struct device_operations smbus_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = 0, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .enable = pwrmgt_enable, .ops_pci = 0, /* No subsystem IDs on 82371EB! */ .ops_smbus_bus = &lops_smbus_bus, diff --git a/src/southbridge/intel/i82801ax/lpc.c b/src/southbridge/intel/i82801ax/lpc.c index aece452..c95bce8 100644 --- a/src/southbridge/intel/i82801ax/lpc.c +++ b/src/southbridge/intel/i82801ax/lpc.c @@ -286,7 +286,7 @@ static struct device_operations lpc_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .enable = i82801ax_enable, };
diff --git a/src/southbridge/intel/i82801ax/smbus.c b/src/southbridge/intel/i82801ax/smbus.c index bbcf629..108e225 100644 --- a/src/southbridge/intel/i82801ax/smbus.c +++ b/src/southbridge/intel/i82801ax/smbus.c @@ -48,7 +48,7 @@ static const struct device_operations smbus_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = 0, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .enable = i82801ax_enable, .ops_smbus_bus = &lops_smbus_bus, }; diff --git a/src/southbridge/intel/i82801bx/lpc.c b/src/southbridge/intel/i82801bx/lpc.c index ee0b521..d9fb2d3 100644 --- a/src/southbridge/intel/i82801bx/lpc.c +++ b/src/southbridge/intel/i82801bx/lpc.c @@ -304,7 +304,7 @@ static struct device_operations lpc_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .enable = i82801bx_enable, };
diff --git a/src/southbridge/intel/i82801bx/smbus.c b/src/southbridge/intel/i82801bx/smbus.c index 5bb5119..7571c35 100644 --- a/src/southbridge/intel/i82801bx/smbus.c +++ b/src/southbridge/intel/i82801bx/smbus.c @@ -48,7 +48,7 @@ static const struct device_operations smbus_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = 0, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .enable = i82801bx_enable, .ops_smbus_bus = &lops_smbus_bus, }; diff --git a/src/southbridge/intel/i82801cx/lpc.c b/src/southbridge/intel/i82801cx/lpc.c index 22671c3..a348c95 100644 --- a/src/southbridge/intel/i82801cx/lpc.c +++ b/src/southbridge/intel/i82801cx/lpc.c @@ -230,7 +230,7 @@ static struct device_operations lpc_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .enable = 0, };
diff --git a/src/southbridge/intel/i82801dx/lpc.c b/src/southbridge/intel/i82801dx/lpc.c index 83d6178..ccfeaa3 100644 --- a/src/southbridge/intel/i82801dx/lpc.c +++ b/src/southbridge/intel/i82801dx/lpc.c @@ -336,7 +336,7 @@ static struct device_operations lpc_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .enable = i82801dx_enable, };
diff --git a/src/southbridge/intel/i82801ex/lpc.c b/src/southbridge/intel/i82801ex/lpc.c index 0a2f6e3..630484a 100644 --- a/src/southbridge/intel/i82801ex/lpc.c +++ b/src/southbridge/intel/i82801ex/lpc.c @@ -369,7 +369,7 @@ static struct device_operations lpc_ops = { .set_resources = pci_dev_set_resources, .enable_resources = i82801ex_lpc_enable_resources, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .enable = i82801ex_enable, .ops_pci = &lops_pci, }; diff --git a/src/southbridge/intel/i82801ex/smbus.c b/src/southbridge/intel/i82801ex/smbus.c index fe49e11..75ea119 100644 --- a/src/southbridge/intel/i82801ex/smbus.c +++ b/src/southbridge/intel/i82801ex/smbus.c @@ -35,7 +35,7 @@ static struct device_operations smbus_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = 0, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .enable = i82801ex_enable, .ops_pci = &lops_pci, .ops_smbus_bus = &lops_smbus_bus, diff --git a/src/southbridge/intel/i82801gx/lpc.c b/src/southbridge/intel/i82801gx/lpc.c index cbc0106..7349c8d 100644 --- a/src/southbridge/intel/i82801gx/lpc.c +++ b/src/southbridge/intel/i82801gx/lpc.c @@ -644,7 +644,7 @@ static struct device_operations device_ops = { .acpi_inject_dsdt_generator = southbridge_inject_dsdt, .write_acpi_tables = acpi_write_hpet, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .enable = i82801gx_enable, .ops_pci = &pci_ops, }; diff --git a/src/southbridge/intel/i82801gx/smbus.c b/src/southbridge/intel/i82801gx/smbus.c index 750da51..bcaa2a0 100644 --- a/src/southbridge/intel/i82801gx/smbus.c +++ b/src/southbridge/intel/i82801gx/smbus.c @@ -258,7 +258,7 @@ static struct device_operations smbus_ops = { .read_resources = smbus_read_resources, .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .enable = i82801gx_enable, .ops_smbus_bus = &lops_smbus_bus, .ops_pci = &smbus_pci_ops, diff --git a/src/southbridge/intel/i82801ix/lpc.c b/src/southbridge/intel/i82801ix/lpc.c index 0ba33d6..9ac9a61 100644 --- a/src/southbridge/intel/i82801ix/lpc.c +++ b/src/southbridge/intel/i82801ix/lpc.c @@ -576,7 +576,7 @@ static struct device_operations device_ops = { .write_acpi_tables = acpi_write_hpet, .acpi_fill_ssdt_generator = southbridge_fill_ssdt, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &pci_ops, };
diff --git a/src/southbridge/intel/i82801ix/smbus.c b/src/southbridge/intel/i82801ix/smbus.c index 25b21fa..9410315 100644 --- a/src/southbridge/intel/i82801ix/smbus.c +++ b/src/southbridge/intel/i82801ix/smbus.c @@ -101,7 +101,7 @@ static struct device_operations smbus_ops = { .read_resources = smbus_read_resources, .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .init = pch_smbus_init, .ops_smbus_bus = &lops_smbus_bus, .ops_pci = &smbus_pci_ops, diff --git a/src/southbridge/intel/ibexpeak/lpc.c b/src/southbridge/intel/ibexpeak/lpc.c index db73b0a..1267b84 100644 --- a/src/southbridge/intel/ibexpeak/lpc.c +++ b/src/southbridge/intel/ibexpeak/lpc.c @@ -838,7 +838,7 @@ static struct device_operations device_ops = { .write_acpi_tables = acpi_write_hpet, .init = lpc_init, .enable = pch_lpc_enable, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &pci_ops, };
diff --git a/src/southbridge/intel/ibexpeak/me.c b/src/southbridge/intel/ibexpeak/me.c index 9592b23..413579c 100644 --- a/src/southbridge/intel/ibexpeak/me.c +++ b/src/southbridge/intel/ibexpeak/me.c @@ -635,7 +635,6 @@ static struct device_operations device_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = intel_me_init, - .scan_bus = scan_static_bus, .ops_pci = &pci_ops, };
diff --git a/src/southbridge/intel/ibexpeak/smbus.c b/src/southbridge/intel/ibexpeak/smbus.c index 9ef5bcb..6331071 100644 --- a/src/southbridge/intel/ibexpeak/smbus.c +++ b/src/southbridge/intel/ibexpeak/smbus.c @@ -108,7 +108,7 @@ static struct device_operations smbus_ops = { .read_resources = smbus_read_resources, .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .init = pch_smbus_init, .ops_smbus_bus = &lops_smbus_bus, .ops_pci = &smbus_pci_ops, diff --git a/src/southbridge/intel/lynxpoint/lpc.c b/src/southbridge/intel/lynxpoint/lpc.c index d753bea..bd0d643 100644 --- a/src/southbridge/intel/lynxpoint/lpc.c +++ b/src/southbridge/intel/lynxpoint/lpc.c @@ -828,7 +828,7 @@ static struct device_operations device_ops = { .write_acpi_tables = southbridge_write_acpi_tables, .init = lpc_init, .enable = pch_lpc_enable, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &pci_ops, };
diff --git a/src/southbridge/intel/lynxpoint/smbus.c b/src/southbridge/intel/lynxpoint/smbus.c index fa68605..b020636 100644 --- a/src/southbridge/intel/lynxpoint/smbus.c +++ b/src/southbridge/intel/lynxpoint/smbus.c @@ -155,7 +155,7 @@ static struct device_operations smbus_ops = { .read_resources = smbus_read_resources, .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .init = pch_smbus_init, .ops_smbus_bus = &lops_smbus_bus, .ops_pci = &smbus_pci_ops, diff --git a/src/southbridge/intel/sch/lpc.c b/src/southbridge/intel/sch/lpc.c index dcf9e33..086a3f3 100644 --- a/src/southbridge/intel/sch/lpc.c +++ b/src/southbridge/intel/sch/lpc.c @@ -216,7 +216,7 @@ static struct device_operations device_ops = { .acpi_inject_dsdt_generator = southbridge_inject_dsdt, .write_acpi_tables = acpi_write_hpet, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &pci_ops, };
diff --git a/src/southbridge/intel/sch/smbus.c b/src/southbridge/intel/sch/smbus.c index 0a12987..0d6ff2c 100644 --- a/src/southbridge/intel/sch/smbus.c +++ b/src/southbridge/intel/sch/smbus.c @@ -65,7 +65,7 @@ static struct device_operations smbus_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = 0, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .ops_smbus_bus = &lops_smbus_bus, .ops_pci = &smbus_pci_ops, }; diff --git a/src/southbridge/nvidia/ck804/lpc.c b/src/southbridge/nvidia/ck804/lpc.c index 5df8acf..bcbed94 100644 --- a/src/southbridge/nvidia/ck804/lpc.c +++ b/src/southbridge/nvidia/ck804/lpc.c @@ -329,7 +329,7 @@ static struct device_operations lpc_ops = { .write_acpi_tables = acpi_write_hpet, #endif .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &ck804_pci_ops, };
diff --git a/src/southbridge/nvidia/ck804/smbus.c b/src/southbridge/nvidia/ck804/smbus.c index 270d085..ee7065b 100644 --- a/src/southbridge/nvidia/ck804/smbus.c +++ b/src/southbridge/nvidia/ck804/smbus.c @@ -96,7 +96,7 @@ static struct device_operations smbus_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = 0, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, .ops_pci = &ck804_pci_ops, .ops_smbus_bus = &lops_smbus_bus, }; diff --git a/src/southbridge/nvidia/mcp55/lpc.c b/src/southbridge/nvidia/mcp55/lpc.c index 5f190b8..1926bec 100644 --- a/src/southbridge/nvidia/mcp55/lpc.c +++ b/src/southbridge/nvidia/mcp55/lpc.c @@ -261,7 +261,7 @@ static struct device_operations lpc_ops = { .set_resources = pci_dev_set_resources, .enable_resources = mcp55_lpc_enable_resources, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, // .enable = mcp55_enable, .ops_pci = &mcp55_pci_ops, }; diff --git a/src/southbridge/nvidia/mcp55/smbus.c b/src/southbridge/nvidia/mcp55/smbus.c index 3e0b87e..5193dd0 100644 --- a/src/southbridge/nvidia/mcp55/smbus.c +++ b/src/southbridge/nvidia/mcp55/smbus.c @@ -127,7 +127,7 @@ static struct device_operations smbus_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = mcp55_sm_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_smbus, // .enable = mcp55_enable, .ops_pci = &mcp55_pci_ops, .ops_smbus_bus = &lops_smbus_bus, diff --git a/src/southbridge/rdc/r8610/r8610.c b/src/southbridge/rdc/r8610/r8610.c index c87d5fe..9a65ffc 100644 --- a/src/southbridge/rdc/r8610/r8610.c +++ b/src/southbridge/rdc/r8610/r8610.c @@ -105,7 +105,6 @@ static struct device_operations r8610_sb_ops = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = &southbridge_init, - .scan_bus = scan_static_bus, .enable = 0, .ops_pci = 0, }; diff --git a/src/southbridge/sis/sis966/lpc.c b/src/southbridge/sis/sis966/lpc.c index c9f1ff6..eb7aa88 100644 --- a/src/southbridge/sis/sis966/lpc.c +++ b/src/southbridge/sis/sis966/lpc.c @@ -259,7 +259,7 @@ static struct device_operations lpc_ops = { .set_resources = pci_dev_set_resources, .enable_resources = sis966_lpc_enable_resources, .init = lpc_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, // .enable = sis966_enable, .ops_pci = &lops_pci, }; diff --git a/src/southbridge/via/vt8237r/lpc.c b/src/southbridge/via/vt8237r/lpc.c index d85006c..7d0f63a 100644 --- a/src/southbridge/via/vt8237r/lpc.c +++ b/src/southbridge/via/vt8237r/lpc.c @@ -657,7 +657,7 @@ static const struct device_operations vt8237r_lpc_ops_s = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = vt8237s_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &lops_pci, };
@@ -666,7 +666,7 @@ static const struct device_operations vt8237r_lpc_ops_r = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = vt8237r_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &lops_pci, };
@@ -675,7 +675,7 @@ static const struct device_operations vt8237r_lpc_ops_a = { .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, .init = vt8237a_init, - .scan_bus = scan_static_bus, + .scan_bus = scan_lpc_bus, .ops_pci = &lops_pci, };
diff --git a/src/superio/smsc/lpc47b397/superio.c b/src/superio/smsc/lpc47b397/superio.c index 9c4a3b6..d9b2735 100644 --- a/src/superio/smsc/lpc47b397/superio.c +++ b/src/superio/smsc/lpc47b397/superio.c @@ -146,7 +146,6 @@ static struct device_operations ops_hwm = { .enable_resources = lpc47b397_pnp_enable_resources, .enable = pnp_alt_enable, .init = lpc47b397_init, - .scan_bus = scan_static_bus, .ops_smbus_bus = &lops_smbus_bus, .ops_pnp_mode = &pnp_conf_mode_55_aa, };
