Richard Spiegel has uploaded this change for review. ( https://review.coreboot.org/22792
Change subject: soc/amd/common: Move AGESA related source files ......................................................................
Move AGESA related source files in soc/amd/common under block directory. Folder soc/amd/common/block subfolders should mimic soc/intel/common/block subfolders (one subfolder per subject).
BUG=b:69262110 TEST=Build with no error gardenia and kahlee (no code change, just folder reorg).
Change-Id: I497cdefe64e8dff00aaff7153c4ffa9c57c9acf8 Signed-off-by: Richard Spiegel richard.spiegel@silverbackltd.com --- M src/soc/amd/common/Makefile.inc A src/soc/amd/common/block/pi/Kconfig A src/soc/amd/common/block/pi/Makefile.inc R src/soc/amd/common/block/pi/amd_late_init.c M src/soc/amd/stoneyridge/Kconfig 5 files changed, 11 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/92/22792/1
diff --git a/src/soc/amd/common/Makefile.inc b/src/soc/amd/common/Makefile.inc index b485bb3..7146bd9 100644 --- a/src/soc/amd/common/Makefile.inc +++ b/src/soc/amd/common/Makefile.inc @@ -11,7 +11,6 @@ romstage-y += heapmanager.c
ramstage-y += agesawrapper.c -ramstage-y += amd_late_init.c ramstage-y += def_callouts.c ramstage-y += heapmanager.c
diff --git a/src/soc/amd/common/block/pi/Kconfig b/src/soc/amd/common/block/pi/Kconfig new file mode 100644 index 0000000..273598b --- /dev/null +++ b/src/soc/amd/common/block/pi/Kconfig @@ -0,0 +1,5 @@ +config SOC_AMD_COMMON_BLOCK_PI + bool + default n + help + This option builds functions that interface AMD's AGESA. diff --git a/src/soc/amd/common/block/pi/Makefile.inc b/src/soc/amd/common/block/pi/Makefile.inc new file mode 100644 index 0000000..b18c304 --- /dev/null +++ b/src/soc/amd/common/block/pi/Makefile.inc @@ -0,0 +1,5 @@ +ifeq ($(CONFIG_SOC_AMD_COMMON_BLOCK_PI),y) + +ramstage-y += amd_late_init.c + +endif diff --git a/src/soc/amd/common/amd_late_init.c b/src/soc/amd/common/block/pi/amd_late_init.c similarity index 100% rename from src/soc/amd/common/amd_late_init.c rename to src/soc/amd/common/block/pi/amd_late_init.c diff --git a/src/soc/amd/stoneyridge/Kconfig b/src/soc/amd/stoneyridge/Kconfig index 2f75307..a9bc382 100644 --- a/src/soc/amd/stoneyridge/Kconfig +++ b/src/soc/amd/stoneyridge/Kconfig @@ -47,6 +47,7 @@ select SOC_AMD_COMMON select SOC_AMD_COMMON_BLOCK select SOC_AMD_COMMON_BLOCK_PCI + select SOC_AMD_COMMON_BLOCK_PI select SOC_AMD_COMMON_BLOCK_PSP select SOC_AMD_COMMON_BLOCK_CAR select SOC_AMD_COMMON_BLOCK_S3
