Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17999
commit 2d8a6a41d2829cffc8f82a06967a8b7b7df160b8 Author: Martin Roth gaumless@gmail.com Date: Fri Dec 30 16:12:30 2016 -0700
util/docker: Update makefile with command to kill docker images
Kill running docker containers before trying to remove images or containers.
Change-Id: Id2de90edbe5d0dc6ecb906be7101ad9744dbd11e Signed-off-by: Martin Roth gaumless@gmail.com --- util/docker/Makefile | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/util/docker/Makefile b/util/docker/Makefile index 45e23b0..113e1ca 100644 --- a/util/docker/Makefile +++ b/util/docker/Makefile @@ -39,10 +39,15 @@ coreboot-jenkins-node: test_docker upload-coreboot-jenkins-node: test_docker_login $(DOCKER) push coreboot/coreboot-jenkins-node:$(crossgcc_version)
-clean_coreboot_containers: test_docker +docker-killall: test_docker + @if [ -n "$$($(DOCKER) ps | grep 'coreboot')" ]; then \ + $(DOCKER) kill $$($(DOCKER) ps | grep 'coreboot' | cut -f1 -d ' '); \ + fi + +clean_coreboot_containers: docker-killall $(DOCKER) rm $(docker ps -a | grep 'coreboot' | sed 's|\s.*$||')
-clean_coreboot_images: test_docker +clean_coreboot_images: docker-killall $(DOCKER) rmi $(docker images | grep coreboot | sed 's|^\S+\s+\S+\s+||' | sed 's|\s.*$||')
docker_build_coreboot: test_docker
