Aaron Durbin (adurbin@chromium.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11495
commit bd7a4bb41586c7305b4713189c0e437dd518f563 Author: Aaron Durbin adurbin@chromium.org Date: Thu Sep 3 00:41:29 2015 -0500
x86: bootblock: remove linking and program flow from build system
The build system was previously determining the flow and linking scripts bootblock code by the order of files added to the bootblock_inc bootblock-y variables.Those files were then concatenated together and built by a myriad of make rules.
Now bootblock.S and bootblock.ld is added so that bootblock can be built and linked using the default build rules. CHIPSET_BOOTBLOCK_INCLUDE is introduced in order to allow the chipset code to place include files in the path of the bootblock program -- a replacement for the chipset_bootblock_inc make variable.
BUG=chrome-os-partner:44827 BRANCH=None TEST=Built vortex, rambi, and some asus boards.
Change-Id: Ida4571cbe6eed65e77ade98b8d9ad056353c53f9 Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/arch/x86/Makefile.inc | 54 +++++++------------------- src/arch/x86/bootblock.S | 51 ++++++++++++++++++++++++ src/arch/x86/bootblock.ld | 29 ++++++++++++++ src/arch/x86/id.inc | 2 + src/cpu/dmp/vortex86ex/Kconfig | 4 ++ src/cpu/dmp/vortex86ex/Makefile.inc | 2 - src/cpu/dmp/vortex86ex/biosdata.inc | 2 +- src/cpu/dmp/vortex86ex/chipset_bootblock.inc | 2 + src/northbridge/via/vx800/Kconfig | 8 ++++ src/northbridge/via/vx800/Makefile.inc | 1 - src/northbridge/via/vx900/Kconfig | 4 ++ src/northbridge/via/vx900/Makefile.inc | 1 - src/soc/intel/baytrail/Kconfig | 4 ++ src/soc/intel/baytrail/Makefile.inc | 1 - src/soc/intel/baytrail/bootblock/Makefile.inc | 1 - src/soc/intel/braswell/Kconfig | 4 ++ src/soc/intel/braswell/Makefile.inc | 1 - src/soc/intel/braswell/bootblock/Makefile.inc | 1 - src/soc/intel/broadwell/Kconfig | 4 ++ src/soc/intel/broadwell/Makefile.inc | 1 - src/soc/intel/broadwell/bootblock/Makefile.inc | 1 - src/soc/intel/skylake/Kconfig | 4 ++ src/soc/intel/skylake/Makefile.inc | 1 - src/soc/intel/skylake/bootblock/Makefile.inc | 1 - src/southbridge/nvidia/ck804/Kconfig | 5 +++ src/southbridge/nvidia/ck804/Makefile.inc | 1 - src/southbridge/nvidia/mcp55/Kconfig | 4 ++ src/southbridge/nvidia/mcp55/Makefile.inc | 1 - src/southbridge/sis/sis966/Kconfig | 12 +++++- src/southbridge/sis/sis966/Makefile.inc | 1 - src/southbridge/via/k8t890/Kconfig | 4 ++ src/southbridge/via/k8t890/Makefile.inc | 1 - 32 files changed, 155 insertions(+), 58 deletions(-)
diff --git a/src/arch/x86/Makefile.inc b/src/arch/x86/Makefile.inc index a9d708d..f58c142 100644 --- a/src/arch/x86/Makefile.inc +++ b/src/arch/x86/Makefile.inc @@ -67,65 +67,41 @@ CBFS_BASE_ADDRESS=$(call int-add, $(call int-subtract, 0xffffffff $(CONFIG_CBFS_
ifeq ($(CONFIG_ARCH_BOOTBLOCK_X86_32)$(CONFIG_ARCH_BOOTBLOCK_X86_64),y)
-bootblock-srcs += $(src)/arch/x86/failover.ld -bootblock-srcs += $(src)/cpu/x86/16bit/entry16.ld -bootblock-srcs += $(src)/cpu/x86/16bit/reset16.ld -bootblock-srcs += $(src)/arch/x86/id.ld -ifeq ($(CONFIG_CPU_INTEL_FIRMWARE_INTERFACE_TABLE),y) -bootblock-srcs += $(src)/cpu/intel/fit/fit.ld -endif - -# TODO: Why can't this use the real bootblock-y += xxx.S mechanism instead? -bootblock_inc = $(src)/arch/x86/prologue.inc -bootblock_inc += $(src)/cpu/x86/16bit/entry16.inc -bootblock_inc += $(src)/cpu/x86/16bit/reset16.inc -bootblock_inc += $(src)/cpu/x86/32bit/entry32.inc -bootblock_inc += $(src)/arch/x86/id.inc -ifeq ($(CONFIG_CPU_INTEL_FIRMWARE_INTERFACE_TABLE),y) -bootblock_inc += $(src)/cpu/intel/fit/fit.inc -endif -bootblock_inc += $(chipset_bootblock_inc) +# Add the assembly file that pulls in the rest of the dependencies in +# the right order. Make sure the auto generated bootblock.inc is a proper +# dependency. Make the same true for the linker sript. +bootblock-y += bootblock.S +$(obj)/arch/x86/bootblock.bootblock.o: $(objgenerated)/bootblock.inc
-ifeq ($(CONFIG_SSE),y) -bootblock_inc += $(src)/cpu/x86/sse_enable.inc -endif -bootblock_inc += $(objgenerated)/bootblock.inc -bootblock_inc += $(src)/arch/x86/walkcbfs.S +bootblock-y += bootblock.ld +$(obj)/arch/x86/bootblock.bootblock.ld: $(objgenerated)/bootblock.ld
bootblock_romccflags := -mcpu=i386 -O2 -D__PRE_RAM__ -D__BOOTBLOCK__ ifeq ($(CONFIG_SSE),y) bootblock_romccflags := -mcpu=k7 -msse -O2 -D__PRE_RAM__ -D__BOOTBLOCK__ endif
-$(objgenerated)/bootblock.ld: $$(filter %.ld,$$(bootblock-objs)) +# This is a hack in case there are no per chipset linker files. +$(objgenerated)/empty: + touch $@ + +$(objgenerated)/bootblock.ld: $$(filter-out, $(obj)/arch/x86/bootblock.bootblock.ld, $$(filter %.ld,$$(bootblock-objs))) $(objgenerated)/empty @printf " GEN $(subst $(obj)/,,$(@))\n" cat $^ >> $@.tmp mv $@.tmp $@
-$(objgenerated)/bootblock_inc.S: $$(bootblock_inc) - @printf " GEN $(subst $(obj)/,,$(@))\n" - printf '$(foreach crt0,$(bootblock_inc),#include "$(crt0)"\n)' > $@ - -$(objgenerated)/bootblock.o: $(objgenerated)/bootblock.s - @printf " CC $(subst $(obj)/,,$(@))\n" - $(CC_bootblock) $(CFLAGS_bootblock) -c -o $@ $< > $(basename $@).disasm - -$(objgenerated)/bootblock.s: $(objgenerated)/bootblock_inc.S $(obj)/config.h $(obj)/build.h - @printf " CC $(subst $(obj)/,,$(@))\n" - $(CC_bootblock) -MMD -x assembler-with-cpp -E -I$(src)/include -I$(src)/arch/x86/include -I$(obj) -include $(obj)/build.h -include $(obj)/config.h -I. -I$(src) $< -o $@ - $(objgenerated)/bootblock.inc: $(src)/arch/x86/$(subst ",,$(CONFIG_BOOTBLOCK_SOURCE)) $(objutil)/romcc/romcc $(OPTION_TABLE_H) $(KCONFIG_AUTOHEADER) @printf " ROMCC $(subst $(obj)/,,$(@))\n" $(CC_bootblock) $(CPPFLAGS_bootblock) -MM -MT$(objgenerated)/bootblock.inc \ $< > $(objgenerated)/bootblock.inc.d $(ROMCC) -c -S $(bootblock_romccflags) -I. $(CPPFLAGS_bootblock) $< -o $@
-$(objcbfs)/bootblock.debug: $(objgenerated)/bootblock.o $(objgenerated)/bootblock.ld +$(objcbfs)/bootblock.debug: $(obj)/arch/x86/bootblock.bootblock.o $(obj)/arch/x86/bootblock.bootblock.ld @printf " LINK $(subst $(obj)/,,$(@))\n" ifeq ($(CONFIG_ARCH_BOOTBLOCK_X86_32),y) - $(LD_bootblock) -m elf_i386 --oformat elf32-i386 -static -o $@ -L$(obj) $< -T $(objgenerated)/bootblock.ld + $(LD_bootblock) -m elf_i386 --oformat elf32-i386 -static -o $@ -L$(obj) $< -T $(obj)/arch/x86/bootblock.bootblock.ld else - $(LD_bootblock) -m elf_x86_64 --oformat elf64-x86-64 -static -o $@ -L$(obj) $< -T $(objgenerated)/bootblock.ld + $(LD_bootblock) -m elf_x86_64 --oformat elf64-x86-64 -static -o $@ -L$(obj) $< -T $(obj)/arch/x86/bootblock.bootblock.ld endif
diff --git a/src/arch/x86/bootblock.S b/src/arch/x86/bootblock.S new file mode 100644 index 0000000..7276c7a --- /dev/null +++ b/src/arch/x86/bootblock.S @@ -0,0 +1,51 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +/* This file assembles the bootblock program by the order of the includes. Thus, + * it's extremely important that one pays very careful attention to the order + * of the includes. */ + +#include <arch/x86/prologue.inc> +#include <cpu/x86/16bit/entry16.inc> +#include <cpu/x86/16bit/reset16.inc> +#include <cpu/x86/32bit/entry32.inc> +#include <arch/x86/id.inc> + +#if IS_ENABLED(CONFIG_CPU_INTEL_FIRMWARE_INTERFACE_TABLE) +#include <cpu/intel/fit/fit.inc> +#endif + +#ifdef CONFIG_CHIPSET_BOOTBLOCK_INCLUDE +#include CONFIG_CHIPSET_BOOTBLOCK_INCLUDE +#endif + +#if IS_ENABLED(CONFIG_SSE) +#include <cpu/x86/sse_enable.inc> +#endif + +/* + * This bootblock.inc file is generated by ROMCC. The above program flow + * falls through to this point. ROMCC assumes the last function it parsed + * is the main function and it places its instructions at the beginning of + * the generated file. Moreover, any library/common code needed in bootblock + * needs to come after bootblock.inc. + */ +#include <generated/bootblock.inc> + +#include <arch/x86/walkcbfs.S> diff --git a/src/arch/x86/bootblock.ld b/src/arch/x86/bootblock.ld new file mode 100644 index 0000000..6835430 --- /dev/null +++ b/src/arch/x86/bootblock.ld @@ -0,0 +1,29 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <arch/x86/failover.ld> +#include <cpu/x86/16bit/entry16.ld> +#include <cpu/x86/16bit/reset16.ld> +#include <arch/x86/id.ld> +#if IS_ENABLED(CONFIG_CPU_INTEL_FIRMWARE_INTERFACE_TABLE) +#include <cpu/intel/fit/fit.ld> +#endif + +/* Include generated .ld files. */ +#include <generated/bootblock.ld> diff --git a/src/arch/x86/id.inc b/src/arch/x86/id.inc index f8aba0b..a3df25e 100644 --- a/src/arch/x86/id.inc +++ b/src/arch/x86/id.inc @@ -1,3 +1,5 @@ +#include <build.h> + .section ".id", "a", @progbits
.globl __id_start diff --git a/src/cpu/dmp/vortex86ex/Kconfig b/src/cpu/dmp/vortex86ex/Kconfig index 2c893ac..3bd6c2c 100644 --- a/src/cpu/dmp/vortex86ex/Kconfig +++ b/src/cpu/dmp/vortex86ex/Kconfig @@ -77,4 +77,8 @@ config PLL_500_375_33
endchoice
+config CHIPSET_BOOTBLOCK_INCLUDE + string + default "cpu/dmp/vortex86ex/chipset_bootblock.inc" + endif diff --git a/src/cpu/dmp/vortex86ex/Makefile.inc b/src/cpu/dmp/vortex86ex/Makefile.inc index 7924ca4..15ea4ea 100644 --- a/src/cpu/dmp/vortex86ex/Makefile.inc +++ b/src/cpu/dmp/vortex86ex/Makefile.inc @@ -23,8 +23,6 @@ subdirs-y += ../../x86/lapic subdirs-y += ../../x86/cache subdirs-y += ../../x86/smm
-chipset_bootblock_inc += $(src)/cpu/dmp/vortex86ex/biosdata.inc -chipset_bootblock_inc += $(src)/cpu/dmp/vortex86ex/biosdata_ex.inc bootblock-y += biosdata.ld bootblock-y += biosdata_ex.ld
diff --git a/src/cpu/dmp/vortex86ex/biosdata.inc b/src/cpu/dmp/vortex86ex/biosdata.inc index 5e6a70f..4f408b4 100644 --- a/src/cpu/dmp/vortex86ex/biosdata.inc +++ b/src/cpu/dmp/vortex86ex/biosdata.inc @@ -37,7 +37,7 @@
.section ".dmp_kbd_fw_part1", "a", @progbits
- #include "src/cpu/dmp/vortex86ex/dmp_kbd_fw_part1.inc" + #include "dmp_kbd_fw_part1.inc"
.previous
diff --git a/src/cpu/dmp/vortex86ex/chipset_bootblock.inc b/src/cpu/dmp/vortex86ex/chipset_bootblock.inc new file mode 100644 index 0000000..bdcda1d --- /dev/null +++ b/src/cpu/dmp/vortex86ex/chipset_bootblock.inc @@ -0,0 +1,2 @@ +#include "biosdata.inc" +#include "biosdata_ex.inc" diff --git a/src/northbridge/via/vx800/Kconfig b/src/northbridge/via/vx800/Kconfig index 9eb84fb..d7d5349 100644 --- a/src/northbridge/via/vx800/Kconfig +++ b/src/northbridge/via/vx800/Kconfig @@ -3,3 +3,11 @@ config NORTHBRIDGE_VIA_VX800 select HAVE_DEBUG_RAM_SETUP select HAVE_DEBUG_SMBUS select LATE_CBMEM_INIT + +if NORTHBRIDGE_VIA_VX800 + +config CHIPSET_BOOTBLOCK_INCLUDE + string + default "northbridge/via/vx800/romstrap.inc" + +endif diff --git a/src/northbridge/via/vx800/Makefile.inc b/src/northbridge/via/vx800/Makefile.inc index 90ab0af..d3c4c7b 100644 --- a/src/northbridge/via/vx800/Makefile.inc +++ b/src/northbridge/via/vx800/Makefile.inc @@ -25,7 +25,6 @@ ramstage-y += vga.c ramstage-y += lpc.c ramstage-y += ide.c
-chipset_bootblock_inc += $(src)/northbridge/via/vx800/romstrap.inc bootblock-y += romstrap.ld
endif diff --git a/src/northbridge/via/vx900/Kconfig b/src/northbridge/via/vx900/Kconfig index 617074f..335c265 100644 --- a/src/northbridge/via/vx900/Kconfig +++ b/src/northbridge/via/vx900/Kconfig @@ -42,4 +42,8 @@ config VGA_BIOS_ID string default "1106,7122"
+config CHIPSET_BOOTBLOCK_INCLUDE + string + default "northbridge/via/vx900/romstrap.inc" + endif diff --git a/src/northbridge/via/vx900/Makefile.inc b/src/northbridge/via/vx900/Makefile.inc index 6178c11..e761f90 100644 --- a/src/northbridge/via/vx900/Makefile.inc +++ b/src/northbridge/via/vx900/Makefile.inc @@ -46,7 +46,6 @@ ramstage-y += lpc.c ramstage-y += ./../../../drivers/pc80/vga/vga_io.c
-chipset_bootblock_inc += $(src)/northbridge/via/vx900/romstrap.inc bootblock-y += romstrap.ld
endif diff --git a/src/soc/intel/baytrail/Kconfig b/src/soc/intel/baytrail/Kconfig index 5754c15..921f568 100644 --- a/src/soc/intel/baytrail/Kconfig +++ b/src/soc/intel/baytrail/Kconfig @@ -171,4 +171,8 @@ config REFCODE_BLOB_FILE
endif # HAVE_REFCODE_BLOB
+config CHIPSET_BOOTBLOCK_INCLUDE + string + default "soc/intel/baytrail/bootblock/timestamp.inc" + endif diff --git a/src/soc/intel/baytrail/Makefile.inc b/src/soc/intel/baytrail/Makefile.inc index 7417526..e8c5022 100644 --- a/src/soc/intel/baytrail/Makefile.inc +++ b/src/soc/intel/baytrail/Makefile.inc @@ -1,6 +1,5 @@ ifeq ($(CONFIG_SOC_INTEL_BAYTRAIL),y)
-subdirs-y += bootblock subdirs-y += microcode subdirs-y += romstage subdirs-y += ../../../cpu/x86/lapic diff --git a/src/soc/intel/baytrail/bootblock/Makefile.inc b/src/soc/intel/baytrail/bootblock/Makefile.inc deleted file mode 100644 index 3a40251..0000000 --- a/src/soc/intel/baytrail/bootblock/Makefile.inc +++ /dev/null @@ -1 +0,0 @@ -chipset_bootblock_inc += $(src)/soc/intel/baytrail/bootblock/timestamp.inc diff --git a/src/soc/intel/braswell/Kconfig b/src/soc/intel/braswell/Kconfig index 4c9c8aa..ab99a08 100644 --- a/src/soc/intel/braswell/Kconfig +++ b/src/soc/intel/braswell/Kconfig @@ -198,4 +198,8 @@ config ME_BIN_PATH depends on HAVE_ME_BIN default "3rdparty/blobs/mainboard/$(MAINBOARDDIR)/me.bin"
+config CHIPSET_BOOTBLOCK_INCLUDE + string + default "soc/intel/braswell/bootblock/timestamp.inc" + endif diff --git a/src/soc/intel/braswell/Makefile.inc b/src/soc/intel/braswell/Makefile.inc index 9bf6cb2..755c15a 100644 --- a/src/soc/intel/braswell/Makefile.inc +++ b/src/soc/intel/braswell/Makefile.inc @@ -1,6 +1,5 @@ ifeq ($(CONFIG_SOC_INTEL_BRASWELL),y)
-subdirs-y += bootblock subdirs-y += microcode subdirs-y += romstage subdirs-y += ../../../cpu/x86/lapic diff --git a/src/soc/intel/braswell/bootblock/Makefile.inc b/src/soc/intel/braswell/bootblock/Makefile.inc deleted file mode 100644 index 17d1ee8..0000000 --- a/src/soc/intel/braswell/bootblock/Makefile.inc +++ /dev/null @@ -1 +0,0 @@ -chipset_bootblock_inc += $(src)/soc/intel/braswell/bootblock/timestamp.inc diff --git a/src/soc/intel/broadwell/Kconfig b/src/soc/intel/broadwell/Kconfig index 30c0093..c2db2a1 100644 --- a/src/soc/intel/broadwell/Kconfig +++ b/src/soc/intel/broadwell/Kconfig @@ -272,4 +272,8 @@ config LOCK_MANAGEMENT_ENGINE
If unsure, say N.
+config CHIPSET_BOOTBLOCK_INCLUDE + string + default "soc/intel/broadwell/bootblock/timestamp.inc" + endif diff --git a/src/soc/intel/broadwell/Makefile.inc b/src/soc/intel/broadwell/Makefile.inc index 4b14ff8..ca295fc 100644 --- a/src/soc/intel/broadwell/Makefile.inc +++ b/src/soc/intel/broadwell/Makefile.inc @@ -1,6 +1,5 @@ ifeq ($(CONFIG_SOC_INTEL_BROADWELL),y)
-subdirs-y += bootblock subdirs-y += microcode subdirs-y += romstage subdirs-y += ../../../cpu/x86/lapic diff --git a/src/soc/intel/broadwell/bootblock/Makefile.inc b/src/soc/intel/broadwell/bootblock/Makefile.inc deleted file mode 100644 index 2ca5a45..0000000 --- a/src/soc/intel/broadwell/bootblock/Makefile.inc +++ /dev/null @@ -1 +0,0 @@ -chipset_bootblock_inc += $(src)/soc/intel/broadwell/bootblock/timestamp.inc diff --git a/src/soc/intel/skylake/Kconfig b/src/soc/intel/skylake/Kconfig index d53e67e..843cb8a 100644 --- a/src/soc/intel/skylake/Kconfig +++ b/src/soc/intel/skylake/Kconfig @@ -200,4 +200,8 @@ config UART_DEBUG select DRIVERS_UART_8250MEM select DRIVERS_UART_8250MEM_32
+config CHIPSET_BOOTBLOCK_INCLUDE + string + default "soc/intel/skylake/bootblock/timestamp.inc" + endif diff --git a/src/soc/intel/skylake/Makefile.inc b/src/soc/intel/skylake/Makefile.inc index defb945..2e119a1 100644 --- a/src/soc/intel/skylake/Makefile.inc +++ b/src/soc/intel/skylake/Makefile.inc @@ -1,6 +1,5 @@ ifeq ($(CONFIG_SOC_INTEL_SKYLAKE),y)
-subdirs-y += bootblock subdirs-y += microcode subdirs-y += romstage subdirs-y += ../../../cpu/intel/microcode diff --git a/src/soc/intel/skylake/bootblock/Makefile.inc b/src/soc/intel/skylake/bootblock/Makefile.inc deleted file mode 100644 index a31f588..0000000 --- a/src/soc/intel/skylake/bootblock/Makefile.inc +++ /dev/null @@ -1 +0,0 @@ -chipset_bootblock_inc += $(src)/soc/intel/skylake/bootblock/timestamp.inc diff --git a/src/southbridge/nvidia/ck804/Kconfig b/src/southbridge/nvidia/ck804/Kconfig index 4126355..42dce07 100644 --- a/src/southbridge/nvidia/ck804/Kconfig +++ b/src/southbridge/nvidia/ck804/Kconfig @@ -41,4 +41,9 @@ config CK804_NUM config HPET_MIN_TICKS hex default 0xfa + +config CHIPSET_BOOTBLOCK_INCLUDE + string + default "southbridge/nvidia/ck804/romstrap.inc" + endif diff --git a/src/southbridge/nvidia/ck804/Makefile.inc b/src/southbridge/nvidia/ck804/Makefile.inc index de1162a..69dd4b2 100644 --- a/src/southbridge/nvidia/ck804/Makefile.inc +++ b/src/southbridge/nvidia/ck804/Makefile.inc @@ -21,7 +21,6 @@ romstage-$(CONFIG_USBDEBUG_IN_ROMSTAGE) += enable_usbdebug.c ramstage-$(CONFIG_USBDEBUG) += enable_usbdebug.c romstage-y += early_smbus.c
-chipset_bootblock_inc += $(src)/southbridge/nvidia/ck804/romstrap.inc bootblock-y += romstrap.ld
endif diff --git a/src/southbridge/nvidia/mcp55/Kconfig b/src/southbridge/nvidia/mcp55/Kconfig index 89aa452..666d3f8 100644 --- a/src/southbridge/nvidia/mcp55/Kconfig +++ b/src/southbridge/nvidia/mcp55/Kconfig @@ -42,4 +42,8 @@ config MCP55_PCI_E_X_3 int default 4
+config CHIPSET_BOOTBLOCK_INCLUDE + string + default "southbridge/nvidia/mcp55/romstrap.inc" + endif diff --git a/src/southbridge/nvidia/mcp55/Makefile.inc b/src/southbridge/nvidia/mcp55/Makefile.inc index fb9c3fb..74ef14c 100644 --- a/src/southbridge/nvidia/mcp55/Makefile.inc +++ b/src/southbridge/nvidia/mcp55/Makefile.inc @@ -24,7 +24,6 @@ ifeq ($(CONFIG_MCP55_USE_AZA),y) ramstage-srcs += src/mainboard/$(MAINBOARDDIR)/hda_verb.c endif
-chipset_bootblock_inc += $(src)/southbridge/nvidia/mcp55/romstrap.inc bootblock-y += romstrap.ld
endif diff --git a/src/southbridge/sis/sis966/Kconfig b/src/southbridge/sis/sis966/Kconfig index 390589c..20f3bff 100644 --- a/src/southbridge/sis/sis966/Kconfig +++ b/src/southbridge/sis/sis966/Kconfig @@ -4,10 +4,18 @@ config SOUTHBRIDGE_SIS_SIS966 select HAVE_USBDEBUG select HAVE_HARD_RESET
+if SOUTHBRIDGE_SIS_SIS966 + config BOOTBLOCK_SOUTHBRIDGE_INIT string - default "southbridge/sis/sis966/bootblock.c" if SOUTHBRIDGE_SIS_SIS966 + default "southbridge/sis/sis966/bootblock.c"
config EHCI_BAR hex - default 0xfef00000 if SOUTHBRIDGE_SIS_SIS966 + default 0xfef00000 + +config CHIPSET_BOOTBLOCK_INCLUDE + string + default "southbridge/sis/sis966/romstrap.inc" + +endif diff --git a/src/southbridge/sis/sis966/Makefile.inc b/src/southbridge/sis/sis966/Makefile.inc index 71fff02..e703e1f 100644 --- a/src/southbridge/sis/sis966/Makefile.inc +++ b/src/southbridge/sis/sis966/Makefile.inc @@ -15,7 +15,6 @@ ramstage-y += reset.c romstage-$(CONFIG_USBDEBUG_IN_ROMSTAGE) += enable_usbdebug.c ramstage-$(CONFIG_USBDEBUG) += enable_usbdebug.c
-chipset_bootblock_inc += $(src)/southbridge/sis/sis966/romstrap.inc bootblock-y += romstrap.ld
endif diff --git a/src/southbridge/via/k8t890/Kconfig b/src/southbridge/via/k8t890/Kconfig index f6e51dc..76be0c1 100644 --- a/src/southbridge/via/k8t890/Kconfig +++ b/src/southbridge/via/k8t890/Kconfig @@ -51,4 +51,8 @@ config VIDEO_MB default -1 if K8M890_VIDEO_MB_CMOS depends on SOUTHBRIDGE_VIA_K8M890_VGA_EN
+config CHIPSET_BOOTBLOCK_INCLUDE + string + default "southbridge/via/k8t890/romstrap.inc" + endif # SOUTHBRIDGE_K8T890 diff --git a/src/southbridge/via/k8t890/Makefile.inc b/src/southbridge/via/k8t890/Makefile.inc index 18cb5aa..2789499 100644 --- a/src/southbridge/via/k8t890/Makefile.inc +++ b/src/southbridge/via/k8t890/Makefile.inc @@ -10,7 +10,6 @@ ramstage-y += traf_ctrl.c ramstage-y += error.c ramstage-y += chrome.c
-chipset_bootblock_inc += $(src)/southbridge/via/k8t890/romstrap.inc bootblock-y += romstrap.ld
endif
