Attention is currently required from: Jason Nien, Matt DeVillier, Martin Roth.
Hello build bot (Jenkins), Jason Nien, Martin Roth,
https://review.coreboot.org/c/coreboot/+/70900
Change subject: mb/google/skyrim: Add support for and select USE_SELECTIVE_GOP_INIT ......................................................................
Add a FMAP region to support caching GOP-driver-modified VBIOS tables. Select SOC_AMD_GFX_CACHE_VBIOS_IN_FMAP if CHROMEOS && RUN_FSP_GOP. Default USE_SELECTIVE_GOP_INIT to y if CHROMEOS && RUN_FSP_GOP.
BUG=b:255812886 TEST=build/boot skyrim, verify cached VBIOS data differs from VBIOS in CBFS, cached VBIOS data is used when not booting in recovery or developer modes.
Change-Id: I5857fa4a15250bf6478bffa96b16200e318492b1 Signed-off-by: Matt DeVillier matt.devillier@amd.corp-partner.google.com --- M src/mainboard/google/skyrim/Kconfig M src/mainboard/google/skyrim/chromeos.fmd 2 files changed, 23 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/70900/10
