Frank Wu has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/44409 )
Change subject: mb/google/volteer/halvor: Update settings for audio function ......................................................................
Configure gpio/overridetree settings for audio function.
BUG=b:153680359, b:163382106 TEST=FW_NAME=halvor emerge-volteer coreboot chromeos-bootimage
Signed-off-by: Frank Wu frank_wu@compal.corp-partner.google.com Change-Id: I107f6fc21b99d80d69931139dc50e7d5873a8e52 --- M src/mainboard/google/volteer/variants/halvor/gpio.c M src/mainboard/google/volteer/variants/halvor/overridetree.cb 2 files changed, 9 insertions(+), 8 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/09/44409/1
diff --git a/src/mainboard/google/volteer/variants/halvor/gpio.c b/src/mainboard/google/volteer/variants/halvor/gpio.c index 2a98688..92e33ca 100644 --- a/src/mainboard/google/volteer/variants/halvor/gpio.c +++ b/src/mainboard/google/volteer/variants/halvor/gpio.c @@ -53,6 +53,10 @@ PAD_NC(GPP_C11, NONE), /* C13 : UART1_TXD ==> NC */ PAD_NC(GPP_C13, NONE), + /* C16 : I2C0_SDA ==> PCH_I2C0_1V8_AUDIO_SDA */ + PAD_CFG_NF(GPP_C16, NONE, DEEP, NF1), + /* C17 : I2C0_SCL ==> PCH_I2C0_1V8_AUDIO_SCL */ + PAD_CFG_NF(GPP_C17, NONE, DEEP, NF1),
/* D7 : SRCCLKREQ2# ==> NC */ PAD_NC(GPP_D7, NONE), @@ -141,6 +145,10 @@ PAD_CFG_NF(GPP_S4, NONE, DEEP, NF2), /* S5 : SNDW2_DATA ==> SOC_DMIC_DATA1 */ PAD_CFG_NF(GPP_S5, NONE, DEEP, NF2), + /* S6 : SNDW3_CLK ==> DMIC_CLK0 */ + PAD_CFG_NF(GPP_S6, NONE, DEEP, NF2), + /* S7 : SNDW3_DATA ==> DMIC_DATA0 */ + PAD_CFG_NF(GPP_S7, NONE, DEEP, NF2),
/* GPD11: LANPHYC ==> NC */ PAD_NC(GPD11, NONE), diff --git a/src/mainboard/google/volteer/variants/halvor/overridetree.cb b/src/mainboard/google/volteer/variants/halvor/overridetree.cb index 12e059c..268b1a5 100644 --- a/src/mainboard/google/volteer/variants/halvor/overridetree.cb +++ b/src/mainboard/google/volteer/variants/halvor/overridetree.cb @@ -121,13 +121,6 @@ device i2c 15 on end end end # I2C5 0xA0C6 - device pci 1f.3 on - chip drivers/generic/max98357a - register "hid" = ""MX98357A"" - register "sdmode_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_F18)" - register "sdmode_delay" = "5" - device generic 0 on end - end - end # Intel HD audio 0xA0C8-A0CF + device pci 1f.3 on end # Intel HD audio 0xA0C8-A0CF end end
Hello build bot (Jenkins),
Signed-off-by: Frank Wu frank_wu@compal.corp-partner.google.com Change-Id: I107f6fc21b99d80d69931139dc50e7d5873a8e52 --- M src/mainboard/google/volteer/variants/halvor/gpio.c M src/mainboard/google/volteer/variants/halvor/overridetree.cb 2 files changed, 23 insertions(+), 16 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/09/44409/2
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/09/44409/3
Frank Wu has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44409 )
Patch Set 4:
Hi Google,
Would you help review the CL? Thank you very much.
EricR Lai has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44409 )
Patch Set 4:
Please remove the gpio.c change. We left that in the fw_config.c already.
Patch Set 4:
https://review.coreboot.org/c/coreboot/+/44409/4/src/mainboard/google/voltee... File src/mainboard/google/volteer/variants/halvor/gpio.c:
https://review.coreboot.org/c/coreboot/+/44409/4/src/mainboard/google/voltee... PS4, Line 58: /* C16 : I2C0_SDA ==> PCH_I2C0_1V8_AUDIO_SDA */ Maybe just leave I2C setting here.
Patch Set 4:
Patch Set 4:
Hello build bot (Jenkins), Furquan Shaikh, Caveh Jalali, Tim Wawrzynczak, Paul Fagerburg, Angel Pons, Nick Vaccaro, EricR Lai,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/09/44409/5
Patch Set 5:
Patch Set 4:
The gpio pins about audio are both configured in volteer/gpio.c and fw_config.c. In my point of view, they are fine to configure in halvor/gpio.c.
Ref about GPP_A23 in volteer: volteer/gpio.c: https://github.com/coreboot/coreboot/blob/master/src/mainboard/google/voltee... fw_config.c: https://github.com/coreboot/coreboot/blob/master/src/mainboard/google/voltee...
Done
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/09/44409/6
Caveh Jalali has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44409 )
Patch Set 6:
please have a look at https://review.coreboot.org/c/coreboot/+/44783.
it proposes to pass the audio config hint up to the kernel based on the audio config specified in CBI.FW_CONFIG. this means we'll need to keep FW_CONFIG enabled. when FW_CONFIG is enabled, volteer/fw_config.c:fw_config_handle() is going to run and as soon as someone adds a different audio config for UP4, we'll have to handle both cases. right now, fw_config_handle() does nothing for halvor, so the settings in gpio.c are sufficient, but i think this will break if we have another UP4 board that supports multiple audio configs.
perhaps one way out is allow a compile-time (kconfig?) over-ride for the FW_CONFIG audio DB value.
Patch Set 6:
Patch Set 6:
Hi Caveh and Google,
We have another CL for fw_config MAX98373_ALC5682I_I2S_UP4. https://review.coreboot.org/c/coreboot/+/44560
Could you give us advise to merge the CL? Thank you.
Patch Set 6:
Patch Set 6:
Patch Set 6:
Hi Google,
Is there suggestion for us to merge the CL? Thank you.
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44409 )
Patch Set 6:
Patch Set 6:
Patch Set 6:
Patch Set 6:
Hi Google,
If we add the fw_config CL, this one shouldn't be needed, correct?
Patch Set 6:
Patch Set 6:
Patch Set 6:
Patch Set 6:
Patch Set 6:
Hi Google,
Thanks for the comment. I will drop the CL later.
Configure overridetree settings for audio function.
Signed-off-by: Frank Wu frank_wu@compal.corp-partner.google.com Change-Id: I107f6fc21b99d80d69931139dc50e7d5873a8e52 --- M src/mainboard/google/volteer/variants/halvor/overridetree.cb 1 file changed, 7 insertions(+), 10 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/09/44409/7
Patch Set 7:
Update the CL based on https://partnerissuetracker.corp.google.com/issues/163382106#comment31 . Would you help review it? Thank you very much.
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44409 )
Patch Set 7: Code-Review+1
Sathyanarayana Nujella has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44409 )
Patch Set 7: Code-Review+2
https://review.coreboot.org/c/coreboot/+/44409/7//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/44409/7//COMMIT_MSG@13 PS7, Line 13: Did you test if audio works now with this and the kernel patch?
Nick Vaccaro has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44409 )
Patch Set 7:
I do not have a halvor board now. I will test that once I get one. Thank you.
Tim Wawrzynczak has submitted this change. ( https://review.coreboot.org/c/coreboot/+/44409 )
Signed-off-by: Frank Wu frank_wu@compal.corp-partner.google.com Change-Id: I107f6fc21b99d80d69931139dc50e7d5873a8e52 Reviewed-on: https://review.coreboot.org/c/coreboot/+/44409 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Angel Pons th3fanbus@gmail.com Reviewed-by: Sathyanarayana Nujella sathyanarayana.nujella@intel.com Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org Reviewed-by: Nick Vaccaro nvaccaro@google.com --- M src/mainboard/google/volteer/variants/halvor/overridetree.cb 1 file changed, 7 insertions(+), 10 deletions(-)
Approvals: build bot (Jenkins): Verified Sathyanarayana Nujella: Looks good to me, but someone else must approve Nick Vaccaro: Looks good to me, approved Angel Pons: Looks good to me, but someone else must approve Tim Wawrzynczak: Looks good to me, approved
diff --git a/src/mainboard/google/volteer/variants/halvor/overridetree.cb b/src/mainboard/google/volteer/variants/halvor/overridetree.cb index e337a02..73767c6 100644 --- a/src/mainboard/google/volteer/variants/halvor/overridetree.cb +++ b/src/mainboard/google/volteer/variants/halvor/overridetree.cb @@ -29,7 +29,9 @@ register "uid" = "0" register "desc" = ""Right Speaker Amp"" register "name" = ""MAXR"" - device i2c 31 on end + device i2c 31 on + probe AUDIO MAX98373_ALC5682I_I2S_UP4 + end end chip drivers/i2c/max98373 register "vmon_slot_no" = "2" @@ -37,7 +39,9 @@ register "uid" = "1" register "desc" = ""Left Speaker Amp"" register "name" = ""MAXL"" - device i2c 32 on end + device i2c 32 on + probe AUDIO MAX98373_ALC5682I_I2S_UP4 + end end end # I2C #0 0xA0E8 device pci 15.1 on @@ -113,13 +117,6 @@ device i2c 15 on end end end # I2C5 0xA0C6 - device pci 1f.3 on - chip drivers/generic/max98357a - register "hid" = ""MX98357A"" - register "sdmode_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_F18)" - register "sdmode_delay" = "5" - device generic 0 on end - end - end # Intel HD audio 0xA0C8-A0CF + device pci 1f.3 on end # Intel HD audio 0xA0C8-A0CF end end
