Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15253
commit 002495949b47bd40f0784b32bd40798a4783d152 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Sat Jun 18 16:55:51 2016 +0300
AGESA: Use common ACPI S3 recovery
Previous behaviour was to halt() on S3 wakeup in case resume backup memory was missing. In this odd case we now continue to normal boot.
Change-Id: I8ce91088c5fa1a2d2abc53b23e423939fe759117 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/cpu/amd/agesa/s3_resume.c | 32 +++++++------------------------- 1 file changed, 7 insertions(+), 25 deletions(-)
diff --git a/src/cpu/amd/agesa/s3_resume.c b/src/cpu/amd/agesa/s3_resume.c index 3a60b8d..54e41c1 100644 --- a/src/cpu/amd/agesa/s3_resume.c +++ b/src/cpu/amd/agesa/s3_resume.c @@ -25,29 +25,11 @@ #include <halt.h> #include "s3_resume.h"
-static void *backup_resume(void) -{ - void *resume_backup_memory; - - printk(BIOS_DEBUG, "Find resume memory location\n"); - - if (cbmem_recovery(1)) { - printk(BIOS_EMERG, "Unable to recover CBMEM\n"); - halt(); - } - - resume_backup_memory = cbmem_find(CBMEM_ID_RESUME); - if (resume_backup_memory == NULL) { - printk(BIOS_EMERG, "No storage for low-memory backup\n"); - halt(); - } - - return resume_backup_memory; -} - static void move_stack_high_mem(void) { void *high_stack = cbmem_find(CBMEM_ID_ROMSTAGE_RAM_STACK); + if (high_stack == NULL) + halt();
/* TODO: Make the switch with empty stack instead. */ memcpy(high_stack, (void *)BSP_STACK_BASE_ADDR, HIGH_ROMSTAGE_STACK_SIZE); @@ -93,7 +75,10 @@ static void set_resume_cache(void)
void prepare_for_resume(void) { - void *resume_backup_memory = backup_resume(); + if (cbmem_recovery(1)) { + printk(BIOS_EMERG, "Unable to recover CBMEM\n"); + halt(); + }
post_code(0x62); printk(BIOS_DEBUG, "Move CAR stack.\n"); @@ -108,8 +93,5 @@ void prepare_for_resume(void) * Copy the system memory that is in the ramstage area to the * reserved area. */ - if (resume_backup_memory) - memcpy(resume_backup_memory, (void *)(CONFIG_RAMBASE), HIGH_MEMORY_SAVE); - - printk(BIOS_DEBUG, "System memory saved. OK to load ramstage.\n"); + acpi_prepare_for_resume(); }
