Attention is currently required from: Jakub Czapiga, Subrata Banik, Tarun Tuli.
Kapil Porwal has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/76228?usp=email )
Change subject: Revert "soc/intel/meteorlake: Add support for crashlog" ......................................................................
This reverts commit 17e9490e80b2acab61e9937bd6d89bd091c0f81a.
Reason: System is unable to boot reliably with Crashlog.
BUG=b:289749310
Signed-off-by: Kapil Porwal kapilporwal@google.com Change-Id: Ic9b073da5b80239d47348a3f9b4696a7b10b7ea6 --- M src/soc/intel/meteorlake/Makefile.inc D src/soc/intel/meteorlake/crashlog.c D src/soc/intel/meteorlake/include/soc/crashlog.h M src/soc/intel/meteorlake/include/soc/pci_devs.h 4 files changed, 0 insertions(+), 524 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/76228/1
diff --git a/src/soc/intel/meteorlake/Makefile.inc b/src/soc/intel/meteorlake/Makefile.inc index aa82381..fd94cda 100644 --- a/src/soc/intel/meteorlake/Makefile.inc +++ b/src/soc/intel/meteorlake/Makefile.inc @@ -31,7 +31,6 @@ ramstage-y += acpi.c ramstage-y += chip.c ramstage-y += cpu.c -ramstage-$(CONFIG_SOC_INTEL_CRASHLOG) += crashlog.c ramstage-y += elog.c ramstage-y += espi.c ramstage-y += finalize.c diff --git a/src/soc/intel/meteorlake/crashlog.c b/src/soc/intel/meteorlake/crashlog.c deleted file mode 100644 index 2e3c97a..0000000 --- a/src/soc/intel/meteorlake/crashlog.c +++ /dev/null @@ -1,498 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ - -#include <arch/bert_storage.h> -#include <console/console.h> -#include <device/pci_ops.h> -#include <intelblocks/crashlog.h> -#include <intelblocks/pmc_ipc.h> -#include <soc/crashlog.h> -#include <soc/iomap.h> -#include <soc/pci_devs.h> -#include <string.h> - -/* global crashLog info */ -static bool m_pmc_crashLog_support; -static bool m_pmc_crashLog_present; -static bool m_cpu_crashLog_support; -static bool m_cpu_crashLog_present; -static bool m_ioe_crashLog_support; -static bool m_ioe_crashLog_present; -static u32 m_pmc_crashLog_size; -static u32 m_ioe_crashLog_size; -static u32 m_cpu_crashLog_size; -static u32 cpu_crash_version; -static pmc_ipc_discovery_buf_t discovery_buf; -static pmc_crashlog_desc_table_t descriptor_table; -static tel_crashlog_devsc_cap_t cpu_cl_devsc_cap; -static cpu_crashlog_discovery_table_t cpu_cl_disc_tab; - -u32 __weak cl_get_cpu_mb_int_addr(void) -{ - return CRASHLOG_MAILBOX_INTF_ADDRESS; -} - -/* Get the SRAM BAR. */ -static uintptr_t get_sram_bar(pci_devfn_t sram_devfn) -{ - uintptr_t sram_bar; - const struct device *dev; - struct resource *res; - - dev = pcidev_path_on_root(sram_devfn); - if (!dev) { - printk(BIOS_ERR, "device: 0x%x not found!\n", sram_devfn); - return 0; - } - - res = probe_resource(dev, PCI_BASE_ADDRESS_0); - if (!res) { - printk(BIOS_ERR, "SOC SRAM device not found!\n"); - return 0; - } - - /* Get the base address of the resource */ - sram_bar = res->base; - - return sram_bar; -} - -static void configure_sram(const struct device *sram_dev, u32 base_addr) -{ - pci_update_config16(sram_dev, PCI_COMMAND, ~(PCI_COMMAND_IO | PCI_COMMAND_MEMORY), 0); - - /* Program BAR 0 and enable command register memory space decoding */ - pci_write_config32(sram_dev, PCI_BASE_ADDRESS_0, base_addr); - pci_or_config16(sram_dev, PCI_COMMAND, PCI_COMMAND_MEMORY); -} - -void cl_get_pmc_sram_data(void) -{ - u32 *soc_pmc_dest = NULL, *ioe_pmc_dest = NULL; - u32 pmc_sram_base = cl_get_cpu_tmp_bar(); - u32 ioe_sram_base = get_sram_bar(PCI_DEVFN_IOE_SRAM); - u32 pmc_crashLog_size = cl_get_pmc_record_size(); - u32 ioe_crashLog_size = 0; - - if (!pmc_sram_base) { - printk(BIOS_ERR, "PMC SRAM base not valid\n"); - return; - } - - if (!pmc_crashLog_size) { - printk(BIOS_ERR, "No PMC crashlog records\n"); - return; - } - - if (!ioe_sram_base) { - printk(BIOS_ERR, "IOE SRAM base not valid\n"); - return; - } - - configure_sram(PCI_DEV_IOE_SRAM, ioe_sram_base); - - if (!cl_pmc_sram_has_mmio_access()) - return; - - if (!cl_ioe_sram_has_mmio_access()) - return; - - printk(BIOS_DEBUG, "PMC crashLog size : 0x%x\n", pmc_crashLog_size); - - /* allocate memory for the PMC crash records to be copied */ - unsigned long pmc_cl_cbmem_addr; - - pmc_cl_cbmem_addr = (unsigned long) cbmem_add(CBMEM_ID_PMC_CRASHLOG, - pmc_crashLog_size); - if (!pmc_cl_cbmem_addr) { - printk(BIOS_ERR, "Unable to allocate CBMEM PMC crashLog entry.\n"); - return; - } - - memset((void *)pmc_cl_cbmem_addr, 0, pmc_crashLog_size); - soc_pmc_dest = (u32 *)(uintptr_t) pmc_cl_cbmem_addr; - - bool pmc_sram = true; - - /* process crashlog records for SOC PMC SRAM */ - for (int i = 0; i < descriptor_table.numb_regions + 1; i++) { - printk(BIOS_DEBUG, "Region[0x%x].Tag=0x%x offset=0x%x, size=0x%x\n", - i, - descriptor_table.regions[i].bits.assign_tag, - descriptor_table.regions[i].bits.offset, - descriptor_table.regions[i].bits.size); - - if (!descriptor_table.regions[i].bits.size) - continue; - - if (descriptor_table.regions[i].bits.assign_tag == - CRASHLOG_DESCRIPTOR_TABLE_TAG_SOC) { - - if (cl_copy_data_from_sram(pmc_sram_base, - descriptor_table.regions[i].bits.offset, - descriptor_table.regions[i].bits.size, - soc_pmc_dest, - i, - pmc_sram)) { - soc_pmc_dest = (u32 *)((u32)soc_pmc_dest + - (descriptor_table.regions[i].bits.size - * sizeof(u32))); - } else { - pmc_crashLog_size -= descriptor_table.regions[i].bits.size * - sizeof(u32); - printk(BIOS_DEBUG, "PMC crashlog size adjusted to: 0x%x\n", - pmc_crashLog_size); - } - } else if (descriptor_table.regions[i].bits.assign_tag == - CRASHLOG_DESCRIPTOR_TABLE_TAG_IOE) { - /* - * SOC PMC crashlog records contains information about IOE SRAM - * records as well. Calculate IOE records size while parsing SOC - * PME SRAM. - */ - ioe_crashLog_size += descriptor_table.regions[i].bits.size * sizeof(u32); - } - } - - pmc_crashLog_size -= ioe_crashLog_size; - update_new_pmc_crashlog_size(&pmc_crashLog_size); - - if (ioe_crashLog_size) - m_ioe_crashLog_present = true; - else - goto pmc_send_re_arm_after_reset; - - /* allocate memory for the IOE crashlog records to be copied */ - unsigned long ioe_cl_cbmem_addr; - - ioe_cl_cbmem_addr = (unsigned long) cbmem_add(CBMEM_ID_IOE_CRASHLOG, - ioe_crashLog_size); - if (!ioe_cl_cbmem_addr) { - printk(BIOS_ERR, "Unable to allocate CBMEM IOE crashLog entry.\n"); - return; - } - - memset((void *)ioe_cl_cbmem_addr, 0, ioe_crashLog_size); - ioe_pmc_dest = (u32 *)(uintptr_t) ioe_cl_cbmem_addr; - - /* process crashlog records for IOE SRAM */ - for (int i = 0; i < descriptor_table.numb_regions + 1; i++) { - printk(BIOS_DEBUG, "Region[0x%x].Tag=0x%x offset=0x%x, size=0x%x\n", - i, - descriptor_table.regions[i].bits.assign_tag, - descriptor_table.regions[i].bits.offset, - descriptor_table.regions[i].bits.size); - - if (!descriptor_table.regions[i].bits.size) - continue; - - if (descriptor_table.regions[i].bits.assign_tag == - CRASHLOG_DESCRIPTOR_TABLE_TAG_IOE) { - - if (cl_copy_data_from_sram(ioe_sram_base, - descriptor_table.regions[i].bits.offset, - descriptor_table.regions[i].bits.size, - ioe_pmc_dest, - i, - pmc_sram)) { - ioe_pmc_dest = (u32 *)((u32)ioe_pmc_dest + - (descriptor_table.regions[i].bits.size - * sizeof(u32))); - } else { - - ioe_crashLog_size -= descriptor_table.regions[i].bits.size * - sizeof(u32); - printk(BIOS_DEBUG, "IOE crashlog size adjusted to: 0x%x\n", - ioe_crashLog_size); - } - } - } - - update_new_ioe_crashlog_size(&ioe_crashLog_size); - -pmc_send_re_arm_after_reset: - /* when bit 7 of discov cmd resp is set -> bit 2 of size field */ - cl_pmc_re_arm_after_reset(); - - /* Clear the SSRAM region after copying the error log */ - cl_pmc_clear(); -} - -bool pmc_cl_discovery(void) -{ - u32 bar_addr = 0, desc_table_addr = 0; - - const struct pmc_ipc_buffer req = { 0 }; - struct pmc_ipc_buffer res; - uint32_t cmd_reg; - int r; - - cmd_reg = pmc_make_ipc_cmd(PMC_IPC_CMD_CRASHLOG, - PMC_IPC_CMD_ID_CRASHLOG_DISCOVERY, - PMC_IPC_CMD_SIZE_SHIFT); - printk(BIOS_DEBUG, "cmd_reg from pmc_make_ipc_cmd %d in %s\n", cmd_reg, __func__); - - r = pmc_send_ipc_cmd(cmd_reg, &req, &res); - - if (r < 0) { - printk(BIOS_ERR, "pmc_send_ipc_cmd failed in %s\n", __func__); - return false; - } - discovery_buf.conv_val_64_bits = ((u64)res.buf[1] << 32) | res.buf[0]; - - if ((discovery_buf.conv_bits64.supported != 1) || - (discovery_buf.conv_bits64.discov_mechanism == 0) || - (discovery_buf.conv_bits64.crash_dis_sts == 1)) { - printk(BIOS_INFO, "PCH crashlog feature not supported.\n"); - m_pmc_crashLog_support = false; - m_ioe_crashLog_support = false; - m_pmc_crashLog_size = 0; - m_ioe_crashLog_size = 0; - printk(BIOS_DEBUG, "discovery_buf supported: %d, mechanism: %d, CrashDisSts: %d\n", - discovery_buf.conv_bits64.supported, - discovery_buf.conv_bits64.discov_mechanism, - discovery_buf.conv_bits64.crash_dis_sts); - return false; - } - - printk(BIOS_INFO, "PMC crashlog feature is supported.\n"); - m_pmc_crashLog_support = true; - - /* Program BAR 0 and enable command register memory space decoding */ - bar_addr = get_sram_bar(PCI_DEVFN_SRAM); - if (bar_addr == 0) { - printk(BIOS_ERR, "PCH SRAM not available, crashlog feature can't be enabled.\n"); - return false; - } - - configure_sram(PCI_DEV_SRAM, bar_addr); - - desc_table_addr = bar_addr + discovery_buf.conv_bits64.desc_tabl_offset; - m_pmc_crashLog_size = pmc_cl_gen_descriptor_table(desc_table_addr, - &descriptor_table); - printk(BIOS_DEBUG, "PMC CrashLog size in discovery mode: 0x%X\n", - m_pmc_crashLog_size); - m_pmc_crashLog_present = m_pmc_crashLog_size > 0; - - return true; -} - -u32 cl_get_cpu_bar_addr(void) -{ - u32 base_addr = 0; - if (cpu_cl_devsc_cap.discovery_data.fields.t_bir_q == TEL_DVSEC_TBIR_BAR0) { - base_addr = pci_read_config32(PCI_DEV_TELEMETRY, PCI_BASE_ADDRESS_0) & - ~PCI_BASE_ADDRESS_MEM_ATTR_MASK; - } else if (cpu_cl_devsc_cap.discovery_data.fields.t_bir_q == TEL_DVSEC_TBIR_BAR1) { - base_addr = pci_read_config32(PCI_DEV_TELEMETRY, PCI_BASE_ADDRESS_1) & - ~PCI_BASE_ADDRESS_MEM_ATTR_MASK; - } else { - printk(BIOS_ERR, "Invalid TEL_CFG_BAR value %d, discovery failure expected.\n", - cpu_cl_devsc_cap.discovery_data.fields.t_bir_q); - } - - return base_addr; -} - -u32 cl_get_cpu_tmp_bar(void) -{ - return get_sram_bar(PCI_DEVFN_SRAM); -} - -bool cl_pmc_sram_has_mmio_access(void) -{ - if (pci_read_config16(PCI_DEV_SRAM, PCI_VENDOR_ID) == 0xFFFF) { - printk(BIOS_ERR, "PMC SSRAM PCI device disabled. Can be enabled in device tree.\n"); - return false; - } - - return true; -} - -bool cl_ioe_sram_has_mmio_access(void) -{ - if (pci_read_config16(PCI_DEV_IOE_SRAM, PCI_VENDOR_ID) == 0xFFFF) { - printk(BIOS_ERR, "IOE SSRAM PCI device disabled. Can be enabled in device tree.\n"); - return false; - } - return true; -} - -static bool cpu_cl_get_capability(tel_crashlog_devsc_cap_t *cl_devsc_cap) -{ - cl_devsc_cap->cap_data.data = pci_read_config32(PCI_DEV_TELEMETRY, - TEL_DVSEC_OFFSET + TEL_DVSEC_PCIE_CAP_ID); - if (cl_devsc_cap->cap_data.fields.pcie_cap_id != TELEMETRY_EXTENDED_CAP_ID) { - printk(BIOS_DEBUG, "Read ID for Telemetry: 0x%x differs from expected: 0x%x\n", - cl_devsc_cap->cap_data.fields.pcie_cap_id, TELEMETRY_EXTENDED_CAP_ID); - return false; - } - - /* walk through the entries until crashLog entry */ - cl_devsc_cap->devsc_data.data_32[1] = pci_read_config32(PCI_DEV_TELEMETRY, TEL_DVSEV_ID); - int new_offset = 0; - while (cl_devsc_cap->devsc_data.fields.devsc_id != CRASHLOG_DVSEC_ID) { - if (cl_devsc_cap->cap_data.fields.next_cap_offset == 0 - || cl_devsc_cap->cap_data.fields.next_cap_offset == 0xFFFF) { - printk(BIOS_DEBUG, "Read invalid pcie_cap_id value: 0x%x\n", - cl_devsc_cap->cap_data.fields.pcie_cap_id); - return false; - } - new_offset = cl_devsc_cap->cap_data.fields.next_cap_offset; - cl_devsc_cap->cap_data.data = pci_read_config32(PCI_DEV_TELEMETRY, - new_offset + TEL_DVSEC_PCIE_CAP_ID); - cl_devsc_cap->devsc_data.data_32[1] = pci_read_config32(PCI_DEV_TELEMETRY, - new_offset + TEL_DVSEV_ID); - } - cpu_crash_version = cl_devsc_cap->devsc_data.fields.devsc_ver; - - cl_devsc_cap->discovery_data.data = pci_read_config32(PCI_DEV_TELEMETRY, new_offset - + TEL_DVSEV_DISCOVERY_TABLE_OFFSET); - - return true; -} - -static bool cpu_cl_gen_discovery_table(void) -{ - u32 bar_addr = 0, disc_tab_addr = 0; - bar_addr = cl_get_cpu_bar_addr(); - - if (!bar_addr) - return false; - - disc_tab_addr = bar_addr + - cpu_cl_devsc_cap.discovery_data.fields.discovery_table_offset; - memset(&cpu_cl_disc_tab, 0, sizeof(cpu_crashlog_discovery_table_t)); - - printk(BIOS_DEBUG, "cpu discovery table offset: 0x%x\n", - cpu_cl_devsc_cap.discovery_data.fields.discovery_table_offset); - - cpu_cl_disc_tab.header.data = ((u64)read32((u32 *)disc_tab_addr) + - ((u64)read32((u32 *)(disc_tab_addr + 4)) << 32)); - - printk(BIOS_DEBUG, "cpu_crashlog_discovery_table buffer count: 0x%x\n", - cpu_cl_disc_tab.header.fields.count); - - int cur_offset = 0; - for (int i = 0; i < cpu_cl_disc_tab.header.fields.count; i++) { - cur_offset = 8 + 24*i; - cpu_cl_disc_tab.buffers[i].data = ((u64)read32((u32 *)(disc_tab_addr + - cur_offset)) + ((u64)read32((u32 *) - (disc_tab_addr + cur_offset + 4)) << 32)); - printk(BIOS_DEBUG, "cpu_crashlog_discovery_table buffer: 0x%x size: " - "0x%x offset: 0x%x\n", i, cpu_cl_disc_tab.buffers[i].fields.size, - cpu_cl_disc_tab.buffers[i].fields.offset); - m_cpu_crashLog_size += cpu_cl_disc_tab.buffers[i].fields.size * sizeof(u32); - } - - if (m_cpu_crashLog_size > 0) - m_cpu_crashLog_present = true; - else - m_cpu_crashLog_present = false; - - return true; -} - -bool cpu_cl_discovery(void) -{ - memset(&cpu_cl_devsc_cap, 0, sizeof(tel_crashlog_devsc_cap_t)); - - if (!cpu_cl_get_capability(&cpu_cl_devsc_cap)) { - printk(BIOS_ERR, "CPU crashlog capability not found.\n"); - m_cpu_crashLog_support = false; - return false; - } - - m_cpu_crashLog_support = true; - - if (!cpu_cl_gen_discovery_table()) { - printk(BIOS_ERR, "CPU crashlog discovery table not valid.\n"); - m_cpu_crashLog_present = false; - return false; - } - - return true; -} - -void reset_discovery_buffers(void) -{ - memset(&discovery_buf, 0, sizeof(pmc_ipc_discovery_buf_t)); - memset(&descriptor_table, 0, sizeof(pmc_crashlog_desc_table_t)); - memset(&cpu_cl_devsc_cap, 0, sizeof(tel_crashlog_devsc_cap_t)); -} - -int cl_get_total_data_size(void) -{ - printk(BIOS_DEBUG, "crashlog size:pmc-0x%x, ioe-pmc-0x%x cpu-0x%x\n", - m_pmc_crashLog_size, m_ioe_crashLog_size, m_cpu_crashLog_size); - return m_pmc_crashLog_size + m_cpu_crashLog_size + m_ioe_crashLog_size; -} - -pmc_ipc_discovery_buf_t cl_get_pmc_discovery_buf(void) -{ - return discovery_buf; -} - -pmc_crashlog_desc_table_t cl_get_pmc_descriptor_table(void) -{ - return descriptor_table; -} - -int cl_get_pmc_record_size(void) -{ - return m_pmc_crashLog_size; -} - -int cl_get_cpu_record_size(void) -{ - return m_cpu_crashLog_size; -} - -int cl_get_ioe_record_size(void) -{ - return m_ioe_crashLog_size; -} - -bool cl_cpu_data_present(void) -{ - return m_cpu_crashLog_present; -} - -bool cl_pmc_data_present(void) -{ - return m_pmc_crashLog_present; -} - -bool cl_ioe_data_present(void) -{ - return m_ioe_crashLog_present; -} - -bool cpu_crashlog_support(void) -{ - return m_cpu_crashLog_support; -} - -bool pmc_crashlog_support(void) -{ - return m_pmc_crashLog_support; -} - -void update_new_pmc_crashlog_size(u32 *pmc_crash_size) -{ - m_pmc_crashLog_size = *pmc_crash_size; -} - -void update_new_ioe_crashlog_size(u32 *ioe_crash_size) -{ - m_ioe_crashLog_size = *ioe_crash_size; -} - -cpu_crashlog_discovery_table_t cl_get_cpu_discovery_table(void) -{ - return cpu_cl_disc_tab; -} - -void update_new_cpu_crashlog_size(u32 *cpu_crash_size) -{ - m_cpu_crashLog_size = *cpu_crash_size; -} diff --git a/src/soc/intel/meteorlake/include/soc/crashlog.h b/src/soc/intel/meteorlake/include/soc/crashlog.h deleted file mode 100644 index 841492d..0000000 --- a/src/soc/intel/meteorlake/include/soc/crashlog.h +++ /dev/null @@ -1,21 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ - -#ifndef _SOC_METEORLAKE_CRASHLOG_H_ -#define _SOC_METEORLAKE_CRASHLOG_H_ - -#include <types.h> - -/* DVSEC capability Registers */ -#define TEL_DVSEC_OFFSET 0x100 -#define TEL_DVSEC_PCIE_CAP_ID 0x0 -#define TEL_DVSEV_ID 0x8 -#define TEL_DVSEV_DISCOVERY_TABLE_OFFSET 0xC -#define TELEMETRY_EXTENDED_CAP_ID 0x23 -#define CRASHLOG_DVSEC_ID 0x04 -#define TEL_DVSEC_TBIR_BAR0 0 -#define TEL_DVSEC_TBIR_BAR1 1 - -/* CPU CrashLog MMIO Registers */ -#define CRASHLOG_MAILBOX_INTF_ADDRESS 0x6038 - -#endif /* _SOC_METEORLAKE_CRASHLOG_H_ */ diff --git a/src/soc/intel/meteorlake/include/soc/pci_devs.h b/src/soc/intel/meteorlake/include/soc/pci_devs.h index 10d8bde..1c4e9b2 100644 --- a/src/soc/intel/meteorlake/include/soc/pci_devs.h +++ b/src/soc/intel/meteorlake/include/soc/pci_devs.h @@ -60,10 +60,6 @@ #define PCI_DEVFN_GNA _PCI_DEVFN(GNA, 0) #define PCI_DEV_GNA _PCI_DEV(GNA, 0)
-#define PCI_DEV_SLOT_TELEMETRY 0x0a -#define PCI_DEVFN_TELEMETRY _PCI_DEVFN(TELEMETRY, 0) -#define PCI_DEV_TELEMETRY _PCI_DEV(TELEMETRY, 0) - #define PCI_DEV_SLOT_TCSS 0x0d #define NUM_TCSS_DMA_FUNCTIONS 2 #define PCI_DEVFN_TCSS_DMA(x) _PCI_DEVFN(TCSS, ((x) + 2))
