Attention is currently required from: Bora Guvendik, Zhixing Ma, Anil Kumar K, Hannah Williams, Cliff Huang, Tarun Tuli, Nico Huber, Michał Żygowski, Subrata Banik, Paul Menzel, Angel Pons, Arthur Heymans.
Jérémy Compostella has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/70276 )
Change subject: drivers/intel/gma: Hook up libgfxinit in romstage
Patch Set 23:
File src/soc/intel/common/block/graphics/graphics.c:
https://review.coreboot.org/c/coreboot/+/70276/comment/6deb6e49_3c446562
PS23, Line 181: if (CONFIG(HWBASE_STATIC_MMIO)) {
Not really as the GOP driver uses its own BAR address anyway which is way more into the middle the 2GB memory hole.
[INFO]:[InitializeGfxMmioBase()]:[GfxMmio Base address: 0xAF000000]
Is this even when we are overriding GtMmAdd UPD with 0xfa00_0000. if yes, then this is wrong. FSP/GFX PEIM should reuse the IGD base and avoid overriding.
You are correct, I looked at old logs without this UPD override and I assumed that since we are freeing this resources end of romstage it was gone.
But I am very curious, since we are clearing BAR 0 between romstage and ramstage, how does this address persist. Is there sone FSP-M UPD data persistence I am unaware of ? I can't see how this address is being saved. The FSP-M UPD is on stack in `do_memory_init`. Is is saved somewhere in memory by FSP-M for FSP-S to consume later ?
@Tarun, I don't think we should bind it to `RUN_FSP_GOP` flag but bind it to libgfxinit like instead:
if (CONFIG(MAINBOARD_USE_LIBGFXINIT) && CONFIG(HWBASE_STATIC_MMIO)) {
What do you think ?
To view, visit
Gerrit-Project: coreboot
Gerrit-Branch: master
Gerrit-Change-Id: I3c2101de10dc5df54fe873e43bbe0f1c4dccff44
Gerrit-Change-Number: 70276
Gerrit-PatchSet: 23
Gerrit-Owner: Jérémy Compostella
jeremy.compostella@intel.com
Gerrit-Reviewer: Angel Pons
th3fanbus@gmail.com
Gerrit-Reviewer: Anil Kumar K
anil.kumar.k@intel.com
Gerrit-Reviewer: Arthur Heymans
arthur@aheymans.xyz
Gerrit-Reviewer: Bora Guvendik
bora.guvendik@intel.com
Gerrit-Reviewer: Boris Mittelberg
bmbm@google.com
Gerrit-Reviewer: Cliff Huang
cliff.huang@intel.com
Gerrit-Reviewer: Jérémy Compostella
Gerrit-Reviewer: Michał Żygowski
michal.zygowski@3mdeb.com
Gerrit-Reviewer: Nick Vaccaro
nvaccaro@google.com
Gerrit-Reviewer: Nico Huber
nico.h@gmx.de
Gerrit-Reviewer: Paul Menzel
paulepanter@mailbox.org
Gerrit-Reviewer: Subrata Banik
subratabanik@google.com
Gerrit-Reviewer: Tarun Tuli
taruntuli@google.com
Gerrit-Reviewer: Zhixing Ma
zhixing.ma@intel.com
no-reply@coreboot.org
Gerrit-CC: Hannah Williams
hannah.williams@intel.com
Gerrit-Attention: Bora Guvendik
Gerrit-Attention: Zhixing Ma
Gerrit-Attention: Anil Kumar K
Gerrit-Attention: Hannah Williams
Gerrit-Attention: Cliff Huang
Gerrit-Attention: Tarun Tuli
Gerrit-Attention: Nico Huber
nico.h@gmx.de
Gerrit-Attention: Michał Żygowski
Gerrit-Attention: Subrata Banik
Gerrit-Attention: Paul Menzel
Gerrit-Attention: Angel Pons
th3fanbus@gmail.com
Gerrit-Attention: Arthur Heymans
arthur@aheymans.xyz
Gerrit-Comment-Date: Fri, 06 Jan 2023 19:27:50 +0000
Gerrit-HasComments: Yes
Gerrit-Has-Labels: No
Comment-In-Reply-To: Tarun Tuli
Comment-In-Reply-To: Subrata Banik
Comment-In-Reply-To: Jérémy Compostella
Gerrit-MessageType: comment
