Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8564
commit 1444110ea468efe728acdd23a34c73cd4fb2da20 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Sun Feb 22 08:54:45 2015 +0200
AMD K8 fam10: Drop local is_sblink in scan_chains
We can define is_sblink = (max == 0) as sblink is always the very first chain we scan.
Change-Id: Ibd6b3ea23954ca919ae148604bca2495e9f8753b Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/northbridge/amd/amdfam10/northbridge.c | 9 +++------ src/northbridge/amd/amdk8/northbridge.c | 9 +++------ 2 files changed, 6 insertions(+), 12 deletions(-)
diff --git a/src/northbridge/amd/amdfam10/northbridge.c b/src/northbridge/amd/amdfam10/northbridge.c index 224d451..4b18948 100644 --- a/src/northbridge/amd/amdfam10/northbridge.c +++ b/src/northbridge/amd/amdfam10/northbridge.c @@ -160,9 +160,6 @@ static u32 amdfam10_scan_chain(struct bus *link, u32 max) u32 ht_unitid_base[4]; // here assume only 4 HT device on chain u32 max_devfn;
- u32 nodeid = amdfam10_nodeid(link->dev); - bool is_sblink = (nodeid == 0) && (link->link_num == sysconf.sblk); - /* See if there is an available configuration space mapping * register in function 1. */ @@ -174,11 +171,11 @@ static u32 amdfam10_scan_chain(struct bus *link, u32 max) * so we set the subordinate bus number to 0xff for the moment. */
- if (!is_sblink) + if (max != 0) max++;
/* One node can have 8 link and segn is the same. */ - if (CONFIG_HT_CHAIN_DISTRIBUTE && !is_sblink) + if (CONFIG_HT_CHAIN_DISTRIBUTE) max = ALIGN_UP(max, 8);
link->secondary = max; @@ -202,7 +199,7 @@ static u32 amdfam10_scan_chain(struct bus *link, u32 max) else max_devfn = (0x1f<<3) | 7;
- next_unitid = hypertransport_scan_chain(link, 0, max_devfn, ht_unitid_base, offset_unit_id(is_sblink)); + next_unitid = hypertransport_scan_chain(link, 0, max_devfn, ht_unitid_base, offset_unit_id(link->secondary == 0));
/* Now that nothing is overlapping it is safe to scan the children. */ pci_scan_bus(link, 0x00, ((next_unitid - 1) << 3) | 7); diff --git a/src/northbridge/amd/amdk8/northbridge.c b/src/northbridge/amd/amdk8/northbridge.c index 2100cba..e179237 100644 --- a/src/northbridge/amd/amdk8/northbridge.c +++ b/src/northbridge/amd/amdk8/northbridge.c @@ -108,10 +108,7 @@ static u32 amdk8_scan_chain(struct bus *link, u32 max) u32 free_reg, config_reg; u32 ht_unitid_base[4]; // here assume only 4 HT device on chain u32 max_devfn; - u32 nodeid = amdk8_nodeid(link->dev); - unsigned int sblink = (pci_read_config32(link->dev, 0x64)>>8) & 3; - bool is_sblink = (nodeid == 0) && (link->link_num == sblink);
/* See if there is an available configuration space mapping * register in function 1. @@ -145,11 +142,11 @@ static u32 amdk8_scan_chain(struct bus *link, u32 max) * so we set the subordinate bus number to 0xff for the moment. */
/* Second chain will be on 0x40, third 0x80, forth 0xc0. */ - if (CONFIG_HT_CHAIN_DISTRIBUTE && !is_sblink) + if (CONFIG_HT_CHAIN_DISTRIBUTE) max = ALIGN_UP(max, 0x40);
link->secondary = max; @@ -179,7 +176,7 @@ static u32 amdk8_scan_chain(struct bus *link, u32 max) else max_devfn = (0x1f<<3) | 7;
