Hannah Williams (hannah.williams@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15459
commit 07968685ba3b6f45151bb83b68a0d6226a86ed3d Author: Brandon Breitenstein brandon.breitenstein@intel.com Date: Fri Jun 24 10:41:39 2016 -0700
soc/intel/apollolake: Update Upd header files for FSP Label 143_10
New UPDs added to header files as well as many comment fixes. Memory infor is now defined in FspmUpd.h and added ability to skip CSE RBP for coreboot. Removes some UPDs that are no longer available from source.
BUG=chrome-os-partner:54677 BRANCH=none TEST=built and tested with FSP 143_10 version
Change-Id: I7e1f531ebbe343b45151a265ac715ae74aeffcad Signed-off-by: Brandon Breitenstein brandon.breitenstein@intel.com --- src/soc/intel/apollolake/chip.c | 6 -- src/soc/intel/apollolake/include/soc/fsp/FspmUpd.h | 47 +++++++++++- src/soc/intel/apollolake/include/soc/fsp/FspsUpd.h | 83 +++++++++++----------- 3 files changed, 85 insertions(+), 51 deletions(-)
diff --git a/src/soc/intel/apollolake/chip.c b/src/soc/intel/apollolake/chip.c index 821570b..044ef91 100644 --- a/src/soc/intel/apollolake/chip.c +++ b/src/soc/intel/apollolake/chip.c @@ -253,12 +253,6 @@ void platform_fsp_silicon_init_params_cb(struct FSPS_UPD *silupd) if (cfg->emmc_rx_cmd_data_cntl2 != 0) silconfig->EmmcRxCmdDataCntl2 = cfg->emmc_rx_cmd_data_cntl2;
- /* Our defaults may not match FSP defaults, so set them explicitly */ - silconfig->AcpiBase = ACPI_PMIO_BASE; - /* First 4k in BAR0 is used for IPC, real registers start at 4k offset */ - silconfig->PmcBase = PMC_BAR0 + 0x1000; - silconfig->P2sbBase = P2SB_BAR; - silconfig->IshEnable = cfg->integrated_sensor_hub_enable;
/* Disable setting of EISS bit in FSP. */ diff --git a/src/soc/intel/apollolake/include/soc/fsp/FspmUpd.h b/src/soc/intel/apollolake/include/soc/fsp/FspmUpd.h index 5f5f367..3712fd7 100644 --- a/src/soc/intel/apollolake/include/soc/fsp/FspmUpd.h +++ b/src/soc/intel/apollolake/include/soc/fsp/FspmUpd.h @@ -36,6 +36,42 @@ are permitted provided that the following conditions are met: #include "FspUpd.h" #include <fsp/upd.h>
+#define MAX_CHANNELS_NUM 4 +#define MAX_DIMMS_NUM 1 + +struct DIMM_INFO { + uint8_t DimmId; + uint32_t SizeInMb; + uint16_t MfgId; + /** Module part number for DRR3 is 18 bytes + but DRR4 is 20 bytes as per JEDEC Spec, so + reserving 20 bytes **/ + uint8_t ModulePartNum[20]; +} __attribute__((packed)); + +struct CHANNEL_INFO { + uint8_t ChannelId; + uint8_t DimmCount; + struct DIMM_INFO DimmInfo[MAX_DIMMS_NUM]; +} __attribute__((packed)); + +struct FSP_SMBIOS_MEMORY_INFO { + uint8_t Revision; + uint8_t DataWidth; + /** As defined in SMBIOS 3.0 spec + Section 7.18.2 and Table 75 + **/ + uint16_t MemoryType; + uint16_t MemoryFrequencyInMHz; + /** As defined in SMBIOS 3.0 spec + Section 7.17.3 and Table 72 + **/ + uint8_t ErrorCorrectionType; + uint8_t ChannelCount; + struct CHANNEL_INFO ChannelInfo[MAX_CHANNELS_NUM]; +} __attribute__((packed)); + + /** Fsp M Configuration **/ struct FSP_M_CONFIG { @@ -528,9 +564,16 @@ struct FSP_M_CONFIG { **/ void* MrcBootDataPtr;
-/** Offset 0x0135 +/** Offset 0x0135 - Skip CSE RBP to support zero sized IBB + Enable/Disable skip CSE RBP for bootloader which loads IBB without assistance of + CSE. 0x00:Disable(Default), 0x01:Enable. + $EN_DIS +**/ + uint8_t SkipCseRbp; + +/** Offset 0x0136 **/ - uint8_t ReservedFspmUpd[27]; + uint8_t ReservedFspmUpd[26]; } __attribute__((packed));
/** Fsp M Test Configuration diff --git a/src/soc/intel/apollolake/include/soc/fsp/FspsUpd.h b/src/soc/intel/apollolake/include/soc/fsp/FspsUpd.h index d4ecd36..8dd824b 100644 --- a/src/soc/intel/apollolake/include/soc/fsp/FspsUpd.h +++ b/src/soc/intel/apollolake/include/soc/fsp/FspsUpd.h @@ -587,10 +587,9 @@ struct FSP_S_CONFIG { **/ uint8_t HpetFunctionNumber;
-/** Offset 0x00AF - Hpet Base Address - Hpet Base Address. 0xFED00000(Default). +/** Offset 0x00AF **/ - uint32_t HpetBase; + uint32_t UnusedUpdSpace1;
/** Offset 0x00B3 - IoApic Valid BDF Value Enable/Disable IoApic Valid BDF Value. 0:Disable(Default), 1:Enable. @@ -635,7 +634,7 @@ struct FSP_S_CONFIG { **/ uint8_t IshEnable;
-/** Offset 0x00BB - ISH Controller +/** Offset 0x00BB - BIOS Interface Lock Down Enable/Disable BIOS Interface Lock Down bit to prevent writes to the Backup Control Register. 0:Disable, 1:Enable(Default). $EN_DIS @@ -663,7 +662,7 @@ struct FSP_S_CONFIG { Enable/Disable LPSS IOSF Bridge PMCTL Register S0ix Bits. 0:Disable(Default), 1:Enable. $EN_DIS **/ - uint8_t S0ixEnable; + uint8_t LPSS_S0ixEnable;
/** Offset 0x00C0 - LPSS I2C Clock Gating Configuration Enable/Disable LPSS I2C Clock Gating. 0:Disable, 1:Enable(Default). @@ -770,8 +769,8 @@ struct FSP_S_CONFIG { **/ uint8_t Spi2Enable;
-/** Offset 0x00DE - UART Debug Bass Address - UART Debug Bass Address. 0x00000000(Default). +/** Offset 0x00DE - UART Debug Base Address + UART Debug Base Address. 0x00000000(Default). **/ uint32_t Uart2KernelDebugBaseAddress;
@@ -810,7 +809,7 @@ struct FSP_S_CONFIG { **/ uint8_t PcieRootPortPeerMemoryWriteEnable;
-/** Offset 0x00E8 - PCIE SWSMI Nubmer +/** Offset 0x00E8 - PCIE SWSMI Number This member describes the SwSmi value for override PCIe ASPM table. 0xAA(Default). **/ uint8_t PcieAspmSwSmiNumber; @@ -932,7 +931,7 @@ struct FSP_S_CONFIG { uint8_t PcieRpCompletionTimeout[6];
/** Offset 0x0173 - PTM Support - Enable/Diable PTM Support. 0:Disable(Default), 1:Enable. + Enable/Disable PTM Support. 0:Disable(Default), 1:Enable. **/ uint8_t PtmEnable[6];
@@ -957,7 +956,7 @@ struct FSP_S_CONFIG { **/ uint8_t PcieRpLtrConfigLock[6];
-/** Offset 0x0191 - PME_B0_S5 Diable bit +/** Offset 0x0191 - PME_B0_S5 Disable bit PME_B0_S5_DIS bit in the General PM Configuration B (GEN_PMCON_B) register. 0:Disable(Default), 1:Enable. $EN_DIS **/ @@ -1029,8 +1028,8 @@ struct FSP_S_CONFIG { uint8_t SataPortsHotPlug[2];
/** Offset 0x01A0 - Mechanical Presence Switch - Controls reporting if this port has an Mechanical Presence Switch.\nNote:Requires - hardware support. 0:Disable, 1:Enable(Default). + Controls reporting if this port has an Mechanical Presence Switch.\n + Note:Requires hardware support. 0:Disable, 1:Enable(Default). **/ uint8_t SataPortsInterlockSw[2];
@@ -1075,20 +1074,9 @@ struct FSP_S_CONFIG { **/ uint16_t SubSystemId;
-/** Offset 0x01B4 - PM Base Address - PM Base Address. 0x400(Default). +/** Offset 0x01B4 **/ - uint16_t AcpiBase; - -/** Offset 0x01B6 - PMC Base Address - PMC Base Address. 0xD10010000(Default). -**/ - uint32_t PmcBase; - -/** Offset 0x01BA - P2SB Base Address - P2SB Base Address. 0xD0000000(Default). -**/ - uint32_t P2sbBase; + uint8_t UnusedUpdSpace2[10];
/** Offset 0x01BE - CRIDSettings PMC CRID setting. 0:Disable(Default), 1:CRID_1, 2:CRID_2, 3:CRID_3. @@ -1150,7 +1138,7 @@ struct FSP_S_CONFIG {
/** Offset 0x01C8 - Start Frame Pulse Width Start Frame Pulse Width Value. 0:ScSfpw4Clk(Default), 1: ScSfpw6Clk, 2:ScSfpw8Clk. - $EN_DIS + 0:ScSfpw4Clk, 1:ScSfpw6Clk, 2:ScSfpw8Clk **/ uint8_t StartFramePulse;
@@ -1166,10 +1154,9 @@ struct FSP_S_CONFIG { **/ uint8_t ArpEnable;
-/** Offset 0x01CB - SMBus Base Address (IO space) - SMBUS Base Address (IO space). 0xEFA0(Default). +/** Offset 0x01CB **/ - uint16_t SmbusIoBase; + uint16_t UnusedUpdSpace3;
/** Offset 0x01CD - SMBus Table Elements The number of elements in the Reserved SMBus Address Table. 0x0080(Default). @@ -1189,14 +1176,14 @@ struct FSP_S_CONFIG { uint8_t DisableComplianceMode;
/** Offset 0x0250 - USB Per-Port Control - Control each of the USB ports (0~3) enable/disable. 0:Disable(Default), 1:Enable. + Control each of the USB ports enable/disable. 0:Disable(Default), 1:Enable. $EN_DIS **/ uint8_t UsbPerPortCtl;
/** Offset 0x0251 - xHCI Mode - Mode of operation of xHCI controller. 0:Disable, 1:Enable, 2:Auto(Default), 3:SmartAuto. - $EN_DIS + Mode of operation of xHCI controller. 0:Disable, 1:Enable, 2:Auto(Default) + 0:Disable, 1:Enable, 2:Auto **/ uint8_t Usb30Mode;
@@ -1224,7 +1211,7 @@ struct FSP_S_CONFIG {
/** Offset 0x026E - XDCI Support Enable/Disable XDCI. 0:Disable, 1:PCI_Mode(Default), 2:ACPI_mode. - $EN_DIS + 0:Disable, 1:PCI_Mode, 2:ACPI_mode **/ uint8_t UsbOtg;
@@ -1293,8 +1280,10 @@ struct FSP_S_CONFIG { uint16_t PcieRpLtrMaxSnoopLatency[6];
/** Offset 0x028A - Snoop Latency Override - Snoop Latency Override for PCH PCIE. \nDisabled:Disable override.\nManual:Manually - enter override values.\nAuto:Maintain default BIOS flow. 0:Disable, 1:Enable, 2:Auto(Default). + Snoop Latency Override for PCH PCIE. \n + Disabled:Disable override.\n + Manual:Manually enter override values.\n + Auto:Maintain default BIOS flow. 0:Disable, 1:Enable, 2:Auto(Default). **/ uint8_t PcieRpSnoopLatencyOverrideMode[6];
@@ -1315,9 +1304,10 @@ struct FSP_S_CONFIG { uint16_t PcieRpLtrMaxNonSnoopLatency[6];
/** Offset 0x02AE - Non Snoop Latency Override - Non Snoop Latency Override for PCH PCIE. \nDisabled:Disable override.\nManual:Manually - enter override values.\nAuto: Maintain default BIOS flow. 0:Disable, 1:Enable, - 2:Auto(Default). + Non Snoop Latency Override for PCH PCIE. \n + Disabled:Disable override.\n + Manual:Manually enter override values.\n + Auto: Maintain default BIOS flow. 0:Disable, 1:Enable, 2:Auto(Default). **/ uint8_t PcieRpNonSnoopLatencyOverrideMode[6];
@@ -1361,7 +1351,7 @@ struct FSP_S_CONFIG { **/ uint8_t TcoTimerHaltLock;
-/** Offset 0x02D5 - Power Button Override Peroid +/** Offset 0x02D5 - Power Button Override Period specifies how long will PMC wait before initiating a global reset. 000b-4s(default), 001b-6s, 010b-8s, 011b-10s, 100b-12s, 101b-14s.) 0x0:4s, 0x1:6s, 0x2:8s, 0x3:10s, 0x4:12s, 0x5:14s @@ -1369,7 +1359,7 @@ struct FSP_S_CONFIG { uint8_t PwrBtnOverridePeriod;
/** Offset 0x02D6 - Power Button Native Mode Disable - Diable power button native mode, when 1, this will result in the PMC logic constantly + Disable power button native mode, when 1, this will result in the PMC logic constantly seeing the power button as de-asserted. 0 (default)) $EN_DIS **/ @@ -1479,13 +1469,20 @@ struct FSP_S_CONFIG {
/** Offset 0x0326 - Os Selection Mode Select OS mode. 0:Windows(default), 1:Android, 2:Win7 - $EN_DIS + 0:Windows, 1:Android, 2:Win7 **/ uint8_t OsSelection;
-/** Offset 0x0327 +/** Offset 0x0327 - Monitor Mwait Enable + Enable/Disable Monitor Mwait. For Windows* OS, this should be Enabled. For Linux + based OS, this should be Disabled. 0:Disable, 1:Enable(Default). + $EN_DIS +**/ + uint8_t MonitorMwaitEnable; + +/** Offset 0x0328 **/ - uint8_t ReservedFspsUpd[9]; + uint8_t ReservedFspsUpd[8]; } __attribute__((packed));
/** Fsp S Test Configuration
