Marc Jones (marc@marcjonesconsulting.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18433
commit 155ba75b0d214e4394d4affe0c161ae6ef93bc84 Author: Marshall Dawson marshalldawson3rd@gmail.com Date: Sun Jan 29 18:27:02 2017 -0700
amd/pi/stoney: Change to early cbmem init
Remove the flexibility of using early or late cbmem init. Use early 100% of the time.
Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com Reviewed-by: Marc Jones marcj303@gmail.com (cherry picked from commit 4c1b4615516dfbd46a768968c2be017cdeb51ee4)
Change-Id: Id1c22a15752a07eebf39530ba8549ef1f74265ec Signed-off-by: Marc Jones marcj303@gmail.com --- src/cpu/amd/pi/00670F00/romstage.c | 3 +++ src/northbridge/amd/pi/00670F00/Kconfig | 2 +- src/northbridge/amd/pi/00670F00/memmap.c | 13 ------------- src/northbridge/amd/pi/00670F00/northbridge.c | 9 --------- 4 files changed, 4 insertions(+), 23 deletions(-)
diff --git a/src/cpu/amd/pi/00670F00/romstage.c b/src/cpu/amd/pi/00670F00/romstage.c index e305a05..79fb351 100644 --- a/src/cpu/amd/pi/00670F00/romstage.c +++ b/src/cpu/amd/pi/00670F00/romstage.c @@ -52,5 +52,8 @@ void romstage_common(void) AGESAWRAPPER(amdinitpost);
post_code(0x41); + cbmem_initialize_empty(); + + post_code(0x42); AGESAWRAPPER(amdinitenv); } diff --git a/src/northbridge/amd/pi/00670F00/Kconfig b/src/northbridge/amd/pi/00670F00/Kconfig index c8ce668..b47a3e6 100644 --- a/src/northbridge/amd/pi/00670F00/Kconfig +++ b/src/northbridge/amd/pi/00670F00/Kconfig @@ -14,7 +14,7 @@ ## config NORTHBRIDGE_AMD_PI_00670F00 bool - select LATE_CBMEM_INIT + select EARLY_CBMEM_INIT
if NORTHBRIDGE_AMD_PI_00670F00
diff --git a/src/northbridge/amd/pi/00670F00/memmap.c b/src/northbridge/amd/pi/00670F00/memmap.c index 02bfc13..982ea62 100644 --- a/src/northbridge/amd/pi/00670F00/memmap.c +++ b/src/northbridge/amd/pi/00670F00/memmap.c @@ -82,20 +82,7 @@ uint32_t uma_base_auto(void) return (uint32_t)topmem - uma_size_auto(); }
-#if IS_ENABLED(CONFIG_LATE_CBMEM_INIT) -unsigned long get_top_of_ram(void) -{ - AMD_CONFIG_PARAMS StdHeader; - UINT64 MsrReg; - - LibAmdMsrRead (0xC001001A, &MsrReg, &StdHeader); - return (unsigned long)MsrReg; -} -#endif - -#if !IS_ENABLED(CONFIG_LATE_CBMEM_INIT) void *cbmem_top(void) { return (void *)uma_base_auto(); } -#endif diff --git a/src/northbridge/amd/pi/00670F00/northbridge.c b/src/northbridge/amd/pi/00670F00/northbridge.c index 69478d6..e1b3862 100644 --- a/src/northbridge/amd/pi/00670F00/northbridge.c +++ b/src/northbridge/amd/pi/00670F00/northbridge.c @@ -805,16 +805,7 @@ static void domain_set_resources(device_t dev) ramtop = limitk * 1024; }
-#if IS_ENABLED(CONFIG_LATE_CBMEM_INIT) -#if CONFIG_GFXUMA - set_top_of_ram(uma_memory_base); uma_resource(dev, 7, uma_memory_base >> 10, uma_memory_size >> 10); -#else - set_top_of_ram(ramtop); -#endif -#else /* IS_ENABLED(CONFIG_LATE_CBMEM_INIT) */ - uma_resource(dev, 7, uma_memory_base >> 10, uma_memory_size >> 10); -#endif
for (link = dev->link_list; link; link = link->next) { if (link->children) {
