Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8365
commit f7bdf18d63637a8be7ce2c53d8d3662345d6676c Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Thu Feb 5 13:36:54 2015 +0200
AMD K8 fam10: Refactor logic around SB_HT_CHAIN_ON_BUS0
Change-Id: I452a93af452073eeac4e6cb9bbc232dc59e911c1 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/northbridge/amd/amdfam10/northbridge.c | 14 +++----------- src/northbridge/amd/amdk8/northbridge.c | 12 ++++-------- 2 files changed, 7 insertions(+), 19 deletions(-)
diff --git a/src/northbridge/amd/amdfam10/northbridge.c b/src/northbridge/amd/amdfam10/northbridge.c index fb963f6..98f41f3 100644 --- a/src/northbridge/amd/amdfam10/northbridge.c +++ b/src/northbridge/amd/amdfam10/northbridge.c @@ -216,20 +216,12 @@ static u32 amdfam10_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool * so we set the subordinate bus number to 0xff for the moment. */
- if (CONFIG_SB_HT_CHAIN_ON_BUS0 == 0) { + if ((CONFIG_SB_HT_CHAIN_ON_BUS0 == 0) || !is_sblink) max++; - } else if (is_sblink) {
- } else if (CONFIG_SB_HT_CHAIN_ON_BUS0 == 1) { - max++; - } else if (CONFIG_SB_HT_CHAIN_ON_BUS0 > 1) { - // We can have 16 segmment and every segment have 256 bus, - // For that case need the kernel support mmio pci config. - - /* One node can have 8 link and segn is the same. */ - max++; + /* One node can have 8 link and segn is the same. */ + if ((CONFIG_SB_HT_CHAIN_ON_BUS0 > 1) && !is_sblink) max = ALIGN_UP(max, 8); - }
link->secondary = max; link->subordinate = link->secondary; diff --git a/src/northbridge/amd/amdk8/northbridge.c b/src/northbridge/amd/amdk8/northbridge.c index e087888..7184c38 100644 --- a/src/northbridge/amd/amdk8/northbridge.c +++ b/src/northbridge/amd/amdk8/northbridge.c @@ -178,17 +178,13 @@ static u32 amdk8_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool is_ * We have no idea how many busses are behind this bridge yet, * so we set the subordinate bus number to 0xff for the moment. */ - if (CONFIG_SB_HT_CHAIN_ON_BUS0 == 0) { - max++; - } else if (is_sblink) {
- } else if (CONFIG_SB_HT_CHAIN_ON_BUS0 == 1) { - max++; - } else if (CONFIG_SB_HT_CHAIN_ON_BUS0 > 1) { - /* Second chain will be on 0x40, third 0x80, forth 0xc0. */ + if ((CONFIG_SB_HT_CHAIN_ON_BUS0 == 0) || !is_sblink) max++; + + /* Second chain will be on 0x40, third 0x80, forth 0xc0. */ + if ((CONFIG_SB_HT_CHAIN_ON_BUS0 > 1) && !is_sblink) max = ALIGN_UP(max, 0x40); - }
