Brandon Breitenstein has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/48630 )
Change subject: WIP: drivers/intel/usb4/mux_retimer: Enable retimer FW upgrade mux interaction ......................................................................
In order to update the BB retimers for usb4/tbt they need to be turned on and in a specific mode. This DSM allows for the use of an EC RAM Byte to get the current state of each port and wether or not it has a retimer. It also allows Kernel to issue a state for the retimer to be put into for firmware updates.
Change-Id: I768cfb56790049c231173b0ea0f8e08fe6b64b93 Signed-off-by: Brandon Breitenstein brandon.breitenstein@intel.com --- A src/drivers/intel/usb4/mux_retimer/Kconfig A src/drivers/intel/usb4/mux_retimer/Makefile.inc A src/drivers/intel/usb4/mux_retimer/mux_retimer.c M src/ec/google/chromeec/acpi/emem.asl M src/mainboard/google/volteer/Kconfig 5 files changed, 119 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/30/48630/1
diff --git a/src/drivers/intel/usb4/mux_retimer/Kconfig b/src/drivers/intel/usb4/mux_retimer/Kconfig new file mode 100644 index 0000000..d5dc3f9 --- /dev/null +++ b/src/drivers/intel/usb4/mux_retimer/Kconfig @@ -0,0 +1,6 @@ +config DRIVERS_INTEL_USB4_MUX_RETIMER + bool + depends on HAVE_ACPI_TABLES + help + The mux retimer driver is required when synchronization is needed + between the EC and Kernel on the retimer upgrade path for BB retimer diff --git a/src/drivers/intel/usb4/mux_retimer/Makefile.inc b/src/drivers/intel/usb4/mux_retimer/Makefile.inc new file mode 100644 index 0000000..bca87fc --- /dev/null +++ b/src/drivers/intel/usb4/mux_retimer/Makefile.inc @@ -0,0 +1 @@ +ramstage-$(CONFIG_DRIVERS_INTEL_USB4_MUX_RETIMER) += mux_retimer.c diff --git a/src/drivers/intel/usb4/mux_retimer/mux_retimer.c b/src/drivers/intel/usb4/mux_retimer/mux_retimer.c new file mode 100644 index 0000000..de538e2 --- /dev/null +++ b/src/drivers/intel/usb4/mux_retimer/mux_retimer.c @@ -0,0 +1,110 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <acpi/acpigen.h> +#include <acpi/acpi_device.h> +#include <console/console.h> +#include <device/device.h> +#include <device/path.h> +#include <gpio.h> +#include <string.h> + +/* Unique ID for the Mux Retimer Upgrade _DSM. */ +#define INTEL_USB4_MUX_RETIMER_DSM_UUID "5e7fb958-b2c5-49dc-90b9-f95b1275e824" + +/* + * Arg0: UUID + * Arg1: Revision ID (set to 1) + * Arg2: Function Index + * 0: Query command implemented + * 1: Query current MUX state and ports with retimers + * 2: Set MUX state for retimer upgrade + * Arg3: A package containing parameters for the function specified by the UUID + * revision ID and function index. + * Function 2: Value to set EC RAM + */ + +static void usb4_mux_cb_standard_query(void *arg) +{ + /* + * ToInteger (Arg1, Local2) + * If (Local2 == 1) { + * Return(Buffer() {0x07}) + * } + * Return (Buffer() {0x01}) + */ + acpigen_write_to_integer(ARG1_OP, LOCAL2_OP); + + /* Revision 1 supports 2 Functions beyond the standard query */ + acpigen_write_if_lequal_op_int(LOCAL2_OP, 1); + acpigen_write_return_singleton_buffer(0x07); + acpigen_pop_len(); /* If */ + + /* Other revisions support no additional functions */ + acpigen_write_return_singleton_buffer(0); +} + +static void usb4_mux_cb_get_mux_state(void *arg) +{ + /* + * // Read Mux Retimer info from EC RAM + * Return RFWU + */ + acpigen_write_return_namestr("RFWU"); +} + +static void usb4_mux_cb_set_mux_state(void *arg) +{ + /* + * // Get argument for on/off from Arg3[0] + * Local0 = DeRefOf (Arg3[0]) + */ + acpigen_get_package_op_element(ARG3_OP, 0, LOCAL0_OP); + + /* + * // write the EC RAM for Retimer Upgrade + * RFWU = LOCAL0 + */ + acpigen_write_name_byte("RFWU", LOCAL0_OP); + + /* Return (Zero) */ + acpigen_write_return_integer(0); +} + +static void (*usb4_mux_callbacks[3])(void *) = { + usb4_mux_cb_standard_query, /* Function 0 */ + usb4_mux_cb_get_mux_state, /* Function 1 */ + usb4_mux_cb_set_mux_state, /* Function 2 */ +}; + +static void usb4_mux_fill_ssdt(const struct device *dev) +{ + const char *scope = acpi_device_scope(dev); + + if (!scope) + return; + + /* Write the _DSM that toggles ack with provided GPIO. */ + acpigen_write_scope(scope); + acpigen_write_dsm(INTEL_USB4_MUX_RETIMER_DSM_UUID, usb4_mux_callbacks, + ARRAY_SIZE(usb4_mux_callbacks), NULL); + acpigen_pop_len(); /* Scope */ + + printk(BIOS_INFO, "%s: %s at %s\n", acpi_device_path(dev), dev->chip_ops->name, + dev_path(dev)); +} + +static struct device_operations usb4_mux_dev_ops = { + .read_resources = noop_read_resources, + .set_resources = noop_set_resources, + .acpi_fill_ssdt = usb4_mux_fill_ssdt, +}; + +static void usb4_mux_retimer_enable(struct device *dev) +{ + dev->ops = &usb4_mux_dev_ops; +} + +struct chip_operations drivers_intel_usb4_mux_ops = { + CHIP_NAME("Intel USB4 Mux Retimer Upgrade") + .enable_dev = usb4_mux_retimer_enable +}; diff --git a/src/ec/google/chromeec/acpi/emem.asl b/src/ec/google/chromeec/acpi/emem.asl index 2a556ed..ee50796 100644 --- a/src/ec/google/chromeec/acpi/emem.asl +++ b/src/ec/google/chromeec/acpi/emem.asl @@ -18,7 +18,7 @@ FAN0, 16, // Fan Speed 0 Offset (0x24), BTVR, 8, // Battery structure version -Offset (0x30), +RFWU, 8, // Retimer FW Update LIDS, 1, // Lid Switch State PBTN, 1, // Power Button Pressed WPDI, 1, // Write Protect Disabled diff --git a/src/mainboard/google/volteer/Kconfig b/src/mainboard/google/volteer/Kconfig index c776ba1..5e185a7 100644 --- a/src/mainboard/google/volteer/Kconfig +++ b/src/mainboard/google/volteer/Kconfig @@ -12,6 +12,7 @@ select DRIVERS_INTEL_USB4_RETIMER select DRIVERS_I2C_MAX98373 select DRIVERS_INTEL_SOUNDWIRE + select DRIVERS_INTEL_USB4_MUX_RETIMER select DRIVERS_SPI_ACPI select DRIVERS_SOUNDWIRE_ALC5682 select DRIVERS_SOUNDWIRE_MAX98373
