Vladimir Serbinenko (phcoder@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6738
commit 7ed6f14a17fd2af5d3e14b591929f58f2bbd9cce Author: Vladimir Serbinenko phcoder@gmail.com Date: Fri Aug 22 23:16:14 2014 +0200
coreboot_table: Export mainboard id.
Change-Id: I45f36bef2f2fcabfe13a539fb4736a82995d57d4 Signed-off-by: Vladimir Serbinenko phcoder@gmail.com --- src/include/boot/coreboot_tables.h | 3 +++ src/lib/coreboot_table.c | 21 +++++++++++++++++++++ src/mainboard/apple/macbook21/mainboard.c | 24 ++++++++++++++++++++++++ src/mainboard/artecgroup/dbe61/mainboard.c | 13 +++++++++++++ src/mainboard/asus/a8n_e/mainboard.c | 13 +++++++++++++ src/mainboard/iei/juki-511p/mainboard.c | 13 +++++++++++++ src/mainboard/jetway/j7f2/mainboard.c | 15 +++++++++++++++ src/mainboard/lippert/hurricane-lx/mainboard.c | 1 + src/mainboard/pcengines/alix2d/mainboard.c | 15 +++++++++++++++ src/mainboard/via/epia-m/mainboard.c | 15 +++++++++++++++ 10 files changed, 133 insertions(+)
diff --git a/src/include/boot/coreboot_tables.h b/src/include/boot/coreboot_tables.h index db3c508..7fe2cc1 100644 --- a/src/include/boot/coreboot_tables.h +++ b/src/include/boot/coreboot_tables.h @@ -134,6 +134,7 @@ struct lb_mainboard { #define LB_TAG_COMPILER 0x000b #define LB_TAG_LINKER 0x000c #define LB_TAG_ASSEMBLER 0x000d +#define LB_TAG_MAINBOARD_ID 0x0025 struct lb_string { uint32_t tag; uint32_t size; @@ -336,6 +337,8 @@ void lb_add_console(uint16_t consoletype, void *data); /* Define this in mainboard.c to add board-specific table entries. */ void lb_board(struct lb_header *header);
+const char *__attribute__((weak)) lb_mainboard_id(void); + struct lb_record *lb_new_record(struct lb_header *header);
#endif /* COREBOOT_TABLES_H */ diff --git a/src/lib/coreboot_table.c b/src/lib/coreboot_table.c index 9f9c453..2e78032 100644 --- a/src/lib/coreboot_table.c +++ b/src/lib/coreboot_table.c @@ -298,6 +298,26 @@ static void lb_strings(struct lb_header *header)
+/* Override if you have clones. Return value has to match board_info.txt + directory. */ +const char *__attribute__((weak)) lb_mainboard_id(void) +{ + return CONFIG_MAINBOARD_DIR; +} + +static void lb_record_mainboard_id(struct lb_header *header) +{ + struct lb_string *rec; + size_t len; + const char *mobo; + rec = (struct lb_string *)lb_new_record(header); + mobo = lb_mainboard_id(); + len = strlen(mobo); + rec->tag = LB_TAG_MAINBOARD_ID; + rec->size = (sizeof(*rec) + len + 1 + 3) & ~3; + memcpy(rec->string, mobo, len+1); +} + void __attribute__((weak)) lb_board(struct lb_header *header) { /* NOOP */ }
static struct lb_forward *lb_forward(struct lb_header *header, struct lb_header *next_header) @@ -409,6 +429,7 @@ unsigned long write_coreboot_table(
/* Record our various random string information */ lb_strings(head); + lb_record_mainboard_id(head); /* Record our framebuffer */ lb_framebuffer(head);
diff --git a/src/mainboard/apple/macbook21/mainboard.c b/src/mainboard/apple/macbook21/mainboard.c index b537f78..832d4fd 100644 --- a/src/mainboard/apple/macbook21/mainboard.c +++ b/src/mainboard/apple/macbook21/mainboard.c @@ -35,6 +35,8 @@ #include <smbios.h> #include <x86emu/x86emu.h> #include <device/azalia_device.h> +#include <arch/cpu.h> +#include <boot/coreboot_tables.h> #include "hda_verb.h" #define PANEL INT15_5F35_CL_DISPLAY_DEFAULT
@@ -74,6 +76,28 @@ int get_cst_entries(acpi_cstate_t **entries) return 0; }
+static int has_64bit(void) +{ + static int saved = -1; + if (saved == -1) + saved = (cpuid_edx(0x80000001) >> 29) & 1; + return saved; +} + +const char *smbios_mainboard_product_name(void) +{ + if (has_64bit()) + return "MacBook2,1"; + return "MacBook1,1"; +} + +const char *lb_mainboard_id(void) +{ + if (has_64bit()) + return "apple/macbook21"; + return "apple/macbook11"; +} + static void mainboard_init(device_t dev) { #if CONFIG_PCI_OPTION_ROM_RUN_YABEL || CONFIG_PCI_OPTION_ROM_RUN_REALMODE diff --git a/src/mainboard/artecgroup/dbe61/mainboard.c b/src/mainboard/artecgroup/dbe61/mainboard.c index 692d2ab..8d9a25a 100644 --- a/src/mainboard/artecgroup/dbe61/mainboard.c +++ b/src/mainboard/artecgroup/dbe61/mainboard.c @@ -26,6 +26,19 @@ #include <cpu/x86/msr.h> #include <cpu/amd/lxdef.h> #include "southbridge/amd/cs5536/cs5536.h" +#include <boot/coreboot_tables.h> + +const char *lb_mainboard_id(void) +{ + /* FIXME: we shouldn't rely on user choosing the right variant. */ +#if CONFIG_BOARD_ARTECGROUP_DBE61 + return "artecgroup/dbe61"; +#elif CONFIG_BOARD_LINUTOP_LINUTOP1 + return "linutop/linutop1"; +#else +#error "Unknown machine" +#endif +}
static void init_gpio(void) { diff --git a/src/mainboard/asus/a8n_e/mainboard.c b/src/mainboard/asus/a8n_e/mainboard.c new file mode 100644 index 0000000..014d6b0 --- /dev/null +++ b/src/mainboard/asus/a8n_e/mainboard.c @@ -0,0 +1,13 @@ +#include <boot/coreboot_tables.h> + +const char *lb_mainboard_id(void) +{ + /* FIXME: we shouldn't rely on user choosing the right variant. */ +#if CONFIG_BOARD_ASUS_A8N_E + return "asus/a8n_e"; +#elif CONFIG_BOARD_ASUS_A8N_SLI + return "asus/a8n_sli"; +#else +#error "Unknown machine" +#endif +} diff --git a/src/mainboard/iei/juki-511p/mainboard.c b/src/mainboard/iei/juki-511p/mainboard.c new file mode 100644 index 0000000..72e3f54 --- /dev/null +++ b/src/mainboard/iei/juki-511p/mainboard.c @@ -0,0 +1,13 @@ +#include <boot/coreboot_tables.h> + +const char *lb_mainboard_id(void) +{ + /* FIXME: we shouldn't rely on user choosing the right variant. */ +#if CONFIG_BOARD_IEI_JUKI_511P + return "iei/juki-511p"; +#elif CONFIG_BOARD_IEI_ROCKY_512 + return "iei/rocky-512"; +#else +#error "Unknown machine" +#endif +} diff --git a/src/mainboard/jetway/j7f2/mainboard.c b/src/mainboard/jetway/j7f2/mainboard.c new file mode 100644 index 0000000..8ddd1ec --- /dev/null +++ b/src/mainboard/jetway/j7f2/mainboard.c @@ -0,0 +1,15 @@ +#include <boot/coreboot_tables.h> + +const char *lb_mainboard_id(void) +{ + /* FIXME: we shouldn't rely on user choosing the right variant. */ +#if CONFIG_BOARD_JETWAY_J7F2 + return "jetway/j7f2"; +#elif CONFIG_BOARD_BOARD_JETWAY_J7F4K1G2E + return "jetway/j7f4k2g2e"; +#elif CONFIG_BOARD_BOARD_JETWAY_J7F4K1G5D + return "jetway/j7f4k1g5d"; +#else +#error "Unknown machine" +#endif +} diff --git a/src/mainboard/lippert/hurricane-lx/mainboard.c b/src/mainboard/lippert/hurricane-lx/mainboard.c index 56f6a0a..e1c9cdf 100644 --- a/src/mainboard/lippert/hurricane-lx/mainboard.c +++ b/src/mainboard/lippert/hurricane-lx/mainboard.c @@ -27,6 +27,7 @@ #include <arch/io.h> #include <device/pci.h> #include <device/pci_ids.h> +#include <boot/coreboot_tables.h>
/* Bit1 switches Com1 to RS485, bit2 same for Com2. */ #if CONFIG_ONBOARD_UARTS_RS485 diff --git a/src/mainboard/pcengines/alix2d/mainboard.c b/src/mainboard/pcengines/alix2d/mainboard.c index 3cd08c8..862a86a 100644 --- a/src/mainboard/pcengines/alix2d/mainboard.c +++ b/src/mainboard/pcengines/alix2d/mainboard.c @@ -19,6 +19,21 @@
#include <console/console.h> #include <device/device.h> +#include <boot/coreboot_tables.h> + +const char *lb_mainboard_id(void) +{ + /* FIXME: we shouldn't rely on user choosing the right variant. */ +#if CONFIG_BOARD_PCENGINES_ALIX2C + return "pcengines/alix2c"; +#elif CONFIG_BOARD_PCENGINES_ALIX2D + return "pcengines/alix2d"; +#elif CONFIG_BOARD_PCENGINES_ALIX6 + return "pcengines/alix6"; +#else +#error "Unknown machine" +#endif +}
static void init(struct device *dev) { diff --git a/src/mainboard/via/epia-m/mainboard.c b/src/mainboard/via/epia-m/mainboard.c new file mode 100644 index 0000000..ed60e4c --- /dev/null +++ b/src/mainboard/via/epia-m/mainboard.c @@ -0,0 +1,15 @@ +#include <boot/coreboot_tables.h> + +const char *lb_mainboard_id(void) +{ + /* FIXME: we shouldn't rely on user choosing the right variant. */ +#if CONFIG_BOARD_VIA_EPIA_M + return "via/epia-m"; +#elif CONFIG_BOARD_VIA_EPIA_MII + return "via/epia-mii"; +#elif CONFIG_BOARD_VIA_EPIA_ML + return "via/epia-ml"; +#else +#error "Unknown machine" +#endif +}
