New patch to review for coreboot: 825bcdd baytrail: Add basic support for ACPI System Wake Source
Aaron Durbin (adurbin@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/5059 -gerrit commit 825bcddc5725c4f71a06d240e2bad962e437405c Author: Duncan Laurie <dlaurie@chromium.org> Date: Tue Jan 21 15:24:40 2014 -0800 baytrail: Add basic support for ACPI System Wake Source This adds the very basic top-level support for determining the system wake source from ACPI. It only implements the _SWS method in the _SB scope which just returns a bit index into the PM1 status register for the first fixed functional block. This can be used to determine wake source of RTC or Power Button but does not help determine wake source for USB or GPIO. The ACPI spec says to return -1 if no source can be determined from PM1 status register. BUG=chrome-os-partner:8127 BRANCH=baytrail TEST=build and boot on rambi 1) Test resume from S3 by RTC: ACPI System Wake Source is PM1 Index 10 (bit 10 is RTC_STS in ACPI spec, ACPI_EVENT_RTC in kernel) 2) Test resume from S3 by power button: ACPI System Wake Source is PM1 Index 8 (bit 8 is PWRBTN_STS in ACPI spec, ACPI_EVENT_POWER_BUTTON in kernel) 3) Test resume from S3 by USB: ACPI System Wake Source is PM1 Index -1 Change-Id: Ifc5c0867f82cf291af157537b8c13fe44923d8f5 Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-on: https://chromium-review.googlesource.com/183333 Reviewed-by: Aaron Durbin <adurbin@chromium.org> Signed-off-by: Aaron Durbin <adurbin@chromium.org> --- src/soc/intel/baytrail/acpi.c | 3 +++ src/soc/intel/baytrail/acpi/globalnvs.asl | 1 + src/soc/intel/baytrail/acpi/platform.asl | 5 +++++ src/soc/intel/baytrail/baytrail/nvs.h | 3 ++- src/soc/intel/baytrail/ramstage.c | 29 +++++++++++++++++++++++++++++ 5 files changed, 40 insertions(+), 1 deletion(-) diff --git a/src/soc/intel/baytrail/acpi.c b/src/soc/intel/baytrail/acpi.c index 57233a9..1ab1eb3 100644 --- a/src/soc/intel/baytrail/acpi.c +++ b/src/soc/intel/baytrail/acpi.c @@ -80,6 +80,9 @@ static acpi_cstate_t cstate_map[] = { void acpi_init_gnvs(global_nvs_t *gnvs) { + /* Set unknown wake source */ + gnvs->pm1i = -1; + /* CPU core count */ gnvs->pcnt = dev_count_cpu(); diff --git a/src/soc/intel/baytrail/acpi/globalnvs.asl b/src/soc/intel/baytrail/acpi/globalnvs.asl index b384cea..a201c03 100644 --- a/src/soc/intel/baytrail/acpi/globalnvs.asl +++ b/src/soc/intel/baytrail/acpi/globalnvs.asl @@ -52,6 +52,7 @@ Field (GNVS, ByteAcc, NoLock, Preserve) TPMP, 8, // 0x12 - TPM Present and Enabled TLVL, 8, // 0x13 - Throttle Level PPCM, 8, // 0x14 - Maximum P-state usable by OS + PM1I, 32, // 0x15 - System Wake Source - PM1 Index /* Device Config */ Offset (0x20), diff --git a/src/soc/intel/baytrail/acpi/platform.asl b/src/soc/intel/baytrail/acpi/platform.asl index e069392..e32880e 100644 --- a/src/soc/intel/baytrail/acpi/platform.asl +++ b/src/soc/intel/baytrail/acpi/platform.asl @@ -71,3 +71,8 @@ Method(_WAK,1) Return(Package(){0,0}) } +Method (_SWS) +{ + /* Index into PM1 for device that caused wake */ + Return (\PM1I) +} diff --git a/src/soc/intel/baytrail/baytrail/nvs.h b/src/soc/intel/baytrail/baytrail/nvs.h index 5bc1b0e..b1561f7 100644 --- a/src/soc/intel/baytrail/baytrail/nvs.h +++ b/src/soc/intel/baytrail/baytrail/nvs.h @@ -43,7 +43,8 @@ typedef struct { u8 tpmp; /* 0x12 - TPM Present and Enabled */ u8 tlvl; /* 0x13 - Throttle Level */ u8 ppcm; /* 0x14 - Maximum P-state usable by OS */ - u8 rsvd1[11]; + u32 pm1i; /* 0x15 - System Wake Source - PM1 Index */ + u8 rsvd1[7]; /* Device Config */ u8 s5u0; /* 0x20 - Enable USB0 in S5 */ diff --git a/src/soc/intel/baytrail/ramstage.c b/src/soc/intel/baytrail/ramstage.c index 9fe6c27..0cc9327 100644 --- a/src/soc/intel/baytrail/ramstage.c +++ b/src/soc/intel/baytrail/ramstage.c @@ -36,6 +36,7 @@ #include <baytrail/nvs.h> #include <baytrail/pattrs.h> #include <baytrail/pci_devs.h> +#include <baytrail/pmc.h> #include <baytrail/ramstage.h> /* Global PATTRS */ @@ -131,6 +132,32 @@ static inline void set_acpi_sleep_type(int val) #endif } +/* Save bit index for first enabled event in PM1_STS for \_SB._SWS */ +static void s3_save_acpi_wake_source(global_nvs_t *gnvs) +{ + struct chipset_power_state *ps = cbmem_find(CBMEM_ID_POWER_STATE); + uint16_t pm1; + + if (!ps) + return; + + pm1 = ps->pm1_sts & ps->pm1_en; + + /* Scan for first set bit in PM1 */ + for (gnvs->pm1i = 0; gnvs->pm1i < 16; gnvs->pm1i++) { + if (pm1 & 1) + break; + pm1 >>= 1; + } + + /* If unable to determine then return -1 */ + if (gnvs->pm1i >= 16) + gnvs->pm1i = -1; + + printk(BIOS_DEBUG, "ACPI System Wake Source is PM1 Index %d\n", + gnvs->pm1i); +} + static void s3_resume_prepare(void) { global_nvs_t *gnvs; @@ -148,6 +175,8 @@ static void s3_resume_prepare(void) } set_acpi_sleep_type(3); + + s3_save_acpi_wake_source(gnvs); } void baytrail_init_pre_device(void)
participants (1)
Aaron Durbin
