Hello Philip Chen,
https://review.coreboot.org/22323
Change subject: gru: Fix and export SPK_PA_EN GPIO for Scarlet ......................................................................
On older Grus, GPIO0_A2 was an audio voltage rail enable line. On Scarlet, we instead moved the audio codec enable (previously on GPIO1_A2) there. Unfortunately the code still had some hardcoded leftovers that were overlooked in the initial port and make our speakers smell weird.
This patch fixes the incorrect GPIO settings and adds the speaker enable pin to the GPIOs passed through the coreboot table, so that depthcharge doesn't have to keep its own definition of the pin which may go out of sync.
Change-Id: I1ac70ee47ebf04b8b92ff17a46cbf5d839421a61 Signed-off-by: Julius Werner jwerner@chromium.org --- M src/mainboard/google/gru/board.h M src/mainboard/google/gru/chromeos.c M src/mainboard/google/gru/mainboard.c 3 files changed, 6 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/23/22323/1
diff --git a/src/mainboard/google/gru/board.h b/src/mainboard/google/gru/board.h index 7237d46..f95db57 100644 --- a/src/mainboard/google/gru/board.h +++ b/src/mainboard/google/gru/board.h @@ -31,6 +31,7 @@ #define GPIO_P15V_EN dead_code_t(gpio_t, "PP1500 doesn't exist on Scarlet") #define GPIO_P18V_AUDIO_PWREN dead_code_t(gpio_t, "doesn't exist on Scarlet") #define GPIO_P30V_EN GPIO(0, B, 1) +#define GPIO_SPK_PA_EN GPIO(0, A, 2) #define GPIO_TP_RST_L dead_code_t(gpio_t, "don't need TP_RST_L on Scarlet") #define GPIO_TPM_IRQ GPIO(1, C, 1) #define GPIO_WP GPIO(0, B, 5) @@ -41,6 +42,7 @@ #define GPIO_P15V_EN GPIO(0, B, 2) #define GPIO_P18V_AUDIO_PWREN GPIO(0, A, 2) #define GPIO_P30V_EN GPIO(0, B, 4) +#define GPIO_SPK_PA_EN GPIO(1, A, 2) #define GPIO_TP_RST_L GPIO(3, B, 4) /* may also be an I2C pull-up enable */ #define GPIO_TPM_IRQ GPIO(0, A, 5) #define GPIO_WP GPIO(1, C, 2) diff --git a/src/mainboard/google/gru/chromeos.c b/src/mainboard/google/gru/chromeos.c index b28e9fc..0dd03ea 100644 --- a/src/mainboard/google/gru/chromeos.c +++ b/src/mainboard/google/gru/chromeos.c @@ -36,6 +36,7 @@ {GPIO_EC_IN_RW.raw, ACTIVE_HIGH, -1, "EC in RW"}, {GPIO_EC_IRQ.raw, ACTIVE_LOW, -1, "EC interrupt"}, {GPIO_RESET.raw, ACTIVE_HIGH, -1, "reset"}, + {GPIO_SPK_PA_EN.raw, ACTIVE_HIGH, -1, "speaker enable"}, #if IS_ENABLED(CONFIG_GRU_HAS_TPM2) {GPIO_TPM_IRQ.raw, ACTIVE_HIGH, -1, "TPM interrupt"}, #endif diff --git a/src/mainboard/google/gru/mainboard.c b/src/mainboard/google/gru/mainboard.c index 43fbb71..3721ce8 100644 --- a/src/mainboard/google/gru/mainboard.c +++ b/src/mainboard/google/gru/mainboard.c @@ -226,11 +226,9 @@ /* AUDIO IO domain 1.8V voltage selection */ write32(&rk3399_grf->io_vsel, RK_SETBITS(1 << 1));
- /* CPU1_P1.8V_AUDIO_PWREN for P1.8_AUDIO */ - gpio_output(GPIO(0, A, 2), 1); - - /* set CPU1_SPK_PA_EN output */ - gpio_output(GPIO(1, A, 2), 0); + if (!IS_ENABLED(CONFIG_BOARD_GOOGLE_SCARLET)) + gpio_output(GPIO_P18V_AUDIO_PWREN, 1); + gpio_output(GPIO_SPK_PA_EN, 0);
rkclk_configure_i2s(12288000); }
