Vladimir Serbinenko (phcoder@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/7672
commit e444ffbde6efada7a2e5ba24889c89acfedf1493 Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Sun Dec 7 02:46:07 2014 +1100
TEST clang warn as error
Change-Id: Iac4efa59f63437fd6c7678368f4c62ba005d2103 Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- Makefile | 2 +- src/Kconfig | 3 +-- 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index eaba3e4..5a7e687 100644 --- a/Makefile +++ b/Makefile @@ -117,7 +117,7 @@ ifeq ($(CONFIG_COMPILER_LLVM_CLANG),y) # FIXME: armv7/aarch64 won't build right now # NOTE: clang puts compiler-rt under lib/linux/libclang_rt.builtins-i386.a # this means the triple is i386-linux-elf instead of i386-none-elf -CFLAGS_x86_32 = -no-integrated-as -Qunused-arguments -target i386-linux-elf -m32 +CFLAGS_x86_32 = -no-integrated-as -Qunused-arguments -target i386-linux-elf -m32 -Wno-unused-variable -Wno-unused-function CC_x86_32:=clang HOSTCC := clang
diff --git a/src/Kconfig b/src/Kconfig index 533bc5c..7f033a2 100644 --- a/src/Kconfig +++ b/src/Kconfig @@ -1131,8 +1131,7 @@ config ENABLE_APIC_EXT_ID # the whole treee. config WARNINGS_ARE_ERRORS bool - default y if !COMPILER_LLVM_CLANG - default n if COMPILER_LLVM_CLANG + default y
# The four POWER_BUTTON_DEFAULT_ENABLE, POWER_BUTTON_DEFAULT_DISABLE, # POWER_BUTTON_FORCE_ENABLE and POWER_BUTTON_FORCE_DISABLE options are
