Aaron Durbin (adurbin@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8699
commit 41b64795091ba1237f41a6c33f4733f2463f3551 Author: Aaron Durbin adurbin@chromium.org Date: Mon Mar 16 17:30:09 2015 -0500
bootstate: use structure pointers for scheduling callbacks
The GCC 4.9.2 update showed that the boot_state_init_entry structures were being padded and assumed to be aligned in to an increased size. The bootstate scheduler for static entries, boot_state_schedule_static_entries(), was then calculating the wrong values within the array. To fix this just use a pointer to the boot_state_init_entry structure that needs to be scheduled.
In addition to the previous issue noted above, the .bs_init section was sitting in the read only portion of the image while the fields within it need to be writable. Also, the boot_state_schedule_static_entries() was using symbol comparison to terminate a loop which in C can lead the compiler to always evaluate the loop at least once since the language spec indicates no 2 symbols can be the same value.
Change-Id: I6dc5331c2979d508dde3cd5c3332903d40d8048b Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/arch/arm/ramstage.ld | 1 + src/arch/arm64/ramstage.ld | 2 ++ src/arch/riscv/ramstage.ld | 1 + src/arch/x86/ramstage.ld | 1 + src/cpu/amd/agesa/amd_late_init.c | 6 ++---- src/cpu/amd/pi/amd_late_init.c | 6 ++---- src/drivers/intel/fsp/fsp_util.c | 6 ++---- src/include/bootstate.h | 26 +++++++++++++++++--------- src/lib/dynamic_cbmem.c | 12 +++--------- src/lib/gcov-glue.c | 8 +++----- src/lib/hardwaremain.c | 10 ++++------ src/lib/rmodule.ld | 2 ++ src/mainboard/google/rambi/mainboard.c | 4 +--- src/northbridge/intel/haswell/mrccache.c | 5 +---- src/northbridge/intel/sandybridge/mrccache.c | 5 +---- src/soc/intel/baytrail/dptf.c | 4 +--- src/soc/intel/baytrail/perf_power.c | 6 ++---- src/soc/intel/baytrail/southcluster.c | 8 ++------ src/soc/intel/baytrail/spi.c | 4 +--- src/soc/intel/broadwell/elog.c | 4 +--- src/soc/intel/broadwell/finalize.c | 8 ++------ src/soc/intel/broadwell/spi.c | 4 +--- src/soc/intel/common/mrc_cache.c | 5 +---- src/southbridge/amd/agesa/hudson/pci.c | 5 +---- src/southbridge/amd/cimx/sb800/late.c | 5 +---- src/southbridge/amd/pi/hudson/pci.c | 5 +---- src/southbridge/intel/common/spi.c | 4 +--- src/southbridge/intel/lynxpoint/smi.c | 5 +---- 28 files changed, 59 insertions(+), 103 deletions(-)
diff --git a/src/arch/arm/ramstage.ld b/src/arch/arm/ramstage.ld index 5469509..5e0607d 100644 --- a/src/arch/arm/ramstage.ld +++ b/src/arch/arm/ramstage.ld @@ -64,6 +64,7 @@ SECTIONS ecpu_drivers = . ; _bs_init_begin = .; KEEP(*(.bs_init)); + LONG(0); _bs_init_end = .; *(.rodata) *(.rodata.*) diff --git a/src/arch/arm64/ramstage.ld b/src/arch/arm64/ramstage.ld index de13fcc..784e62d 100644 --- a/src/arch/arm64/ramstage.ld +++ b/src/arch/arm64/ramstage.ld @@ -69,6 +69,8 @@ SECTIONS ecpu_drivers = . ; _bs_init_begin = .; KEEP(*(.bs_init)); + LONG(0); + LONG(0); _bs_init_end = .; *(.rodata) *(.rodata.*) diff --git a/src/arch/riscv/ramstage.ld b/src/arch/riscv/ramstage.ld index 5d9ba3e..2e97a7e 100644 --- a/src/arch/riscv/ramstage.ld +++ b/src/arch/riscv/ramstage.ld @@ -69,6 +69,7 @@ SECTIONS ecpu_drivers = . ; _bs_init_begin = .; *(.bs_init) + LONG(0); _bs_init_end = .; *(.rodata) *(.rodata.*) diff --git a/src/arch/x86/ramstage.ld b/src/arch/x86/ramstage.ld index 0843be7..9c43bd7 100644 --- a/src/arch/x86/ramstage.ld +++ b/src/arch/x86/ramstage.ld @@ -62,6 +62,7 @@ SECTIONS ecpu_drivers = . ; _bs_init_begin = .; KEEP(*(.bs_init)); + LONG(0); _bs_init_end = .;
*(.rodata) diff --git a/src/cpu/amd/agesa/amd_late_init.c b/src/cpu/amd/agesa/amd_late_init.c index 53c2759..b41fa5c 100644 --- a/src/cpu/amd/agesa/amd_late_init.c +++ b/src/cpu/amd/agesa/amd_late_init.c @@ -42,7 +42,5 @@ static void agesawrapper_post_device(void *unused) agesawrapper_amdS3Save(); }
-BOOT_STATE_INIT_ENTRIES(agesa_bscb) = { - BOOT_STATE_INIT_ENTRY(BS_POST_DEVICE, BS_ON_EXIT, - agesawrapper_post_device, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_POST_DEVICE, BS_ON_EXIT, + agesawrapper_post_device, NULL); diff --git a/src/cpu/amd/pi/amd_late_init.c b/src/cpu/amd/pi/amd_late_init.c index 4b08d1b..7ef4c63 100644 --- a/src/cpu/amd/pi/amd_late_init.c +++ b/src/cpu/amd/pi/amd_late_init.c @@ -40,7 +40,5 @@ static void agesawrapper_post_device(void *unused) AGESAWRAPPER(amdS3Save); }
-BOOT_STATE_INIT_ENTRIES(agesa_bscb) = { - BOOT_STATE_INIT_ENTRY(BS_POST_DEVICE, BS_ON_EXIT, - agesawrapper_post_device, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_POST_DEVICE, BS_ON_EXIT, + agesawrapper_post_device, NULL); diff --git a/src/drivers/intel/fsp/fsp_util.c b/src/drivers/intel/fsp/fsp_util.c index 2a53c25..a00cb81 100644 --- a/src/drivers/intel/fsp/fsp_util.c +++ b/src/drivers/intel/fsp/fsp_util.c @@ -318,8 +318,6 @@ static void find_fsp_hob_update_mrc(void *unused) }
/* Update the MRC/fast boot cache as part of the late table writing stage */ -BOOT_STATE_INIT_ENTRIES(fsp_hob_find) = { - BOOT_STATE_INIT_ENTRY(BS_WRITE_TABLES, BS_ON_ENTRY, - find_fsp_hob_update_mrc, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_WRITE_TABLES, BS_ON_ENTRY, + find_fsp_hob_update_mrc, NULL); #endif /* #ifndef __PRE_RAM__ */ diff --git a/src/include/bootstate.h b/src/include/bootstate.h index 202acf7..8b5e4be 100644 --- a/src/include/bootstate.h +++ b/src/include/bootstate.h @@ -22,6 +22,9 @@ #if !defined(__SMM__) && !defined(__PRE_RAM__)
#include <string.h> +#include <stdlib.h> +#include <stddef.h> +#include <stdint.h>
/* Control debugging of the boot state machine. */ #define BOOT_STATE_DEBUG 0 @@ -157,6 +160,10 @@ int boot_state_sched_on_entry(struct boot_state_callback *bscb, boot_state_t state); int boot_state_sched_on_exit(struct boot_state_callback *bscb, boot_state_t state); +/* Schedule an array of entries of size num. */ +struct boot_state_init_entry; +void boot_state_sched_entries(struct boot_state_init_entry *entries, + size_t num);
/* Block/Unblock the (state, seq) pair from transitioning. Returns 0 on * success < 0 when the phase of the (state,seq) has already ran. */ @@ -180,15 +187,16 @@ struct boot_state_init_entry {
#define BOOT_STATE_INIT_ATTR __attribute__ ((used,section (".bs_init")))
-#define BOOT_STATE_INIT_ENTRIES(name_) \ - static struct boot_state_init_entry name_[] BOOT_STATE_INIT_ATTR - -#define BOOT_STATE_INIT_ENTRY(state_, when_, func_, arg_) \ - { \ - .state = state_, \ - .when = when_, \ - .bscb = BOOT_STATE_CALLBACK_INIT(func_, arg_), \ - } +#define BOOT_STATE_INIT_ENTRY(state_, when_, func_, arg_) \ + static struct boot_state_init_entry func_ ##_## state_ ##_## when_ = \ + { \ + .state = state_, \ + .when = when_, \ + .bscb = BOOT_STATE_CALLBACK_INIT(func_, arg_), \ + }; \ + static struct boot_state_init_entry * \ + bsie_ ## func_ ##_## state_ ##_## when_ BOOT_STATE_INIT_ATTR = \ + & func_ ##_## state_ ##_## when_;
#endif #endif /* BOOTSTATE_H */ diff --git a/src/lib/dynamic_cbmem.c b/src/lib/dynamic_cbmem.c index daa3717..3b008c7 100644 --- a/src/lib/dynamic_cbmem.c +++ b/src/lib/dynamic_cbmem.c @@ -435,11 +435,7 @@ static void init_cbmem_pre_device(void *unused) cbmem_initialize(); }
-BOOT_STATE_INIT_ENTRIES(cbmem_bscb) = { - BOOT_STATE_INIT_ENTRY(BS_PRE_DEVICE, BS_ON_ENTRY, - init_cbmem_pre_device, NULL), -}; - +BOOT_STATE_INIT_ENTRY(BS_PRE_DEVICE, BS_ON_ENTRY, init_cbmem_pre_device, NULL); #else
static void init_cbmem_post_device(void *unused) @@ -450,10 +446,8 @@ static void init_cbmem_post_device(void *unused) cbmem_initialize_empty(); }
-BOOT_STATE_INIT_ENTRIES(cbmem_bscb) = { - BOOT_STATE_INIT_ENTRY(BS_POST_DEVICE, BS_ON_ENTRY, - init_cbmem_post_device, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_POST_DEVICE, BS_ON_ENTRY, + init_cbmem_post_device, NULL); #endif
void cbmem_add_bootmem(void) diff --git a/src/lib/gcov-glue.c b/src/lib/gcov-glue.c index ab9062b..615624f 100644 --- a/src/lib/gcov-glue.c +++ b/src/lib/gcov-glue.c @@ -150,8 +150,6 @@ static void coverage_exit(void *unused) __gcov_flush(); }
-BOOT_STATE_INIT_ENTRIES(gcov_bscb) = { - BOOT_STATE_INIT_ENTRY(BS_PRE_DEVICE, BS_ON_ENTRY, coverage_init, NULL), - BOOT_STATE_INIT_ENTRY(BS_OS_RESUME, BS_ON_ENTRY, coverage_exit, NULL), - BOOT_STATE_INIT_ENTRY(BS_PAYLOAD_LOAD, BS_ON_EXIT, coverage_exit, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_PRE_DEVICE, BS_ON_ENTRY, coverage_init, NULL); +BOOT_STATE_INIT_ENTRY(BS_OS_RESUME, BS_ON_ENTRY, coverage_exit, NULL); +BOOT_STATE_INIT_ENTRY(BS_PAYLOAD_LOAD, BS_ON_EXIT, coverage_exit, NULL); diff --git a/src/lib/hardwaremain.c b/src/lib/hardwaremain.c index 32162eb..d16aa09 100644 --- a/src/lib/hardwaremain.c +++ b/src/lib/hardwaremain.c @@ -432,18 +432,16 @@ int boot_state_sched_on_exit(struct boot_state_callback *bscb,
static void boot_state_schedule_static_entries(void) { - extern struct boot_state_init_entry _bs_init_begin; - extern struct boot_state_init_entry _bs_init_end; - struct boot_state_init_entry *cur; + extern struct boot_state_init_entry *_bs_init_begin[]; + struct boot_state_init_entry **slot;
- cur = &_bs_init_begin; + for (slot = &_bs_init_begin[0]; *slot != NULL; slot++) { + struct boot_state_init_entry *cur = *slot;
- while (cur != &_bs_init_end) { if (cur->when == BS_ON_ENTRY) boot_state_sched_on_entry(&cur->bscb, cur->state); else boot_state_sched_on_exit(&cur->bscb, cur->state); - cur++; } }
diff --git a/src/lib/rmodule.ld b/src/lib/rmodule.ld index c1669be..065b5b6 100644 --- a/src/lib/rmodule.ld +++ b/src/lib/rmodule.ld @@ -49,6 +49,8 @@ SECTIONS . = ALIGN(8); _bs_init_begin = .; KEEP(*(.bs_init)); + LONG(0); + LONG(0); _bs_init_end = .;
. = ALIGN(8); diff --git a/src/mainboard/google/rambi/mainboard.c b/src/mainboard/google/rambi/mainboard.c index 1290a15..7128448 100644 --- a/src/mainboard/google/rambi/mainboard.c +++ b/src/mainboard/google/rambi/mainboard.c @@ -182,6 +182,4 @@ static void edp_vdden_cb(void *unused) ncore_select_func(SOC_DDI1_VDDEN_PAD, PAD_FUNC2); }
-BOOT_STATE_INIT_ENTRIES(edp_vdden_bscb) = { - BOOT_STATE_INIT_ENTRY(BS_DEV_INIT, BS_ON_EXIT, edp_vdden_cb, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_DEV_INIT, BS_ON_EXIT, edp_vdden_cb, NULL); diff --git a/src/northbridge/intel/haswell/mrccache.c b/src/northbridge/intel/haswell/mrccache.c index 540bbf6..b66e9fd 100644 --- a/src/northbridge/intel/haswell/mrccache.c +++ b/src/northbridge/intel/haswell/mrccache.c @@ -222,10 +222,7 @@ static void update_mrc_cache(void *unused) current->mrc_data_size + sizeof(*current), current); }
-BOOT_STATE_INIT_ENTRIES(mrc_cache_update) = { - BOOT_STATE_INIT_ENTRY(BS_WRITE_TABLES, BS_ON_ENTRY, - update_mrc_cache, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_WRITE_TABLES, BS_ON_ENTRY, update_mrc_cache, NULL); #endif
struct mrc_data_container *find_current_mrc_cache(void) diff --git a/src/northbridge/intel/sandybridge/mrccache.c b/src/northbridge/intel/sandybridge/mrccache.c index c84ff82..127ca3d 100644 --- a/src/northbridge/intel/sandybridge/mrccache.c +++ b/src/northbridge/intel/sandybridge/mrccache.c @@ -223,10 +223,7 @@ static void update_mrc_cache(void *unused) current->mrc_data_size + sizeof(*current), current); }
struct mrc_data_container *find_current_mrc_cache(void) diff --git a/src/soc/intel/baytrail/dptf.c b/src/soc/intel/baytrail/dptf.c index 044a807..e875319 100644 --- a/src/soc/intel/baytrail/dptf.c +++ b/src/soc/intel/baytrail/dptf.c @@ -49,6 +49,4 @@ static void dptf_init(void *unused) reg_script_run(dptf_init_settings); }
-BOOT_STATE_INIT_ENTRIES(dptf_init_bscb) = { - BOOT_STATE_INIT_ENTRY(BS_DEV_INIT, BS_ON_ENTRY, dptf_init, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_DEV_INIT, BS_ON_ENTRY, dptf_init, NULL); diff --git a/src/soc/intel/baytrail/perf_power.c b/src/soc/intel/baytrail/perf_power.c index 2cde77f..dade339 100644 --- a/src/soc/intel/baytrail/perf_power.c +++ b/src/soc/intel/baytrail/perf_power.c @@ -288,7 +288,5 @@ static void perf_power(void *unused) reg_script_run(perf_power_settings); }
-BOOT_STATE_INIT_ENTRIES(disable_rom_cache_bscb) = { - BOOT_STATE_INIT_ENTRY(BS_OS_RESUME, BS_ON_ENTRY, perf_power, NULL), - BOOT_STATE_INIT_ENTRY(BS_PAYLOAD_LOAD, BS_ON_EXIT, perf_power, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_OS_RESUME, BS_ON_ENTRY, perf_power, NULL); +BOOT_STATE_INIT_ENTRY(BS_PAYLOAD_LOAD, BS_ON_EXIT, perf_power, NULL); diff --git a/src/soc/intel/baytrail/southcluster.c b/src/soc/intel/baytrail/southcluster.c index c392447..a635b0d 100644 --- a/src/soc/intel/baytrail/southcluster.c +++ b/src/soc/intel/baytrail/southcluster.c @@ -568,9 +568,5 @@ static void finalize_chipset(void *unused) outb(APM_CNT_FINALIZE, APM_CNT); }
-BOOT_STATE_INIT_ENTRIES(finalize_bscb) = { - BOOT_STATE_INIT_ENTRY(BS_OS_RESUME, BS_ON_ENTRY, - finalize_chipset, NULL), - BOOT_STATE_INIT_ENTRY(BS_PAYLOAD_LOAD, BS_ON_EXIT, - finalize_chipset, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_OS_RESUME, BS_ON_ENTRY, finalize_chipset, NULL); +BOOT_STATE_INIT_ENTRY(BS_PAYLOAD_LOAD, BS_ON_EXIT, finalize_chipset, NULL); diff --git a/src/soc/intel/baytrail/spi.c b/src/soc/intel/baytrail/spi.c index a83fb8e..cf40140 100644 --- a/src/soc/intel/baytrail/spi.c +++ b/src/soc/intel/baytrail/spi.c @@ -323,9 +323,7 @@ static void spi_init_cb(void *unused) spi_init(); }
-BOOT_STATE_INIT_ENTRIES(spi_init_bscb) = { - BOOT_STATE_INIT_ENTRY(BS_DEV_INIT, BS_ON_ENTRY, spi_init_cb, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_DEV_INIT, BS_ON_ENTRY, spi_init_cb, NULL); #endif
int spi_claim_bus(struct spi_slave *slave) diff --git a/src/soc/intel/broadwell/elog.c b/src/soc/intel/broadwell/elog.c index a6a2813..79484a9 100644 --- a/src/soc/intel/broadwell/elog.c +++ b/src/soc/intel/broadwell/elog.c @@ -133,6 +133,4 @@ static void pch_log_state(void *unused) pch_log_wake_source(ps); }
-BOOT_STATE_INIT_ENTRIES(pch_log) = { - BOOT_STATE_INIT_ENTRY(BS_DEV_INIT, BS_ON_ENTRY, pch_log_state, NULL) -}; +BOOT_STATE_INIT_ENTRY(BS_DEV_INIT, BS_ON_ENTRY, pch_log_state, NULL); diff --git a/src/soc/intel/broadwell/finalize.c b/src/soc/intel/broadwell/finalize.c index 67cba66..4f7a518 100644 --- a/src/soc/intel/broadwell/finalize.c +++ b/src/soc/intel/broadwell/finalize.c @@ -119,9 +119,5 @@ static void broadwell_finalize(void *unused) post_code(POST_OS_BOOT); }
-BOOT_STATE_INIT_ENTRIES(finalize) = { - BOOT_STATE_INIT_ENTRY(BS_OS_RESUME, BS_ON_ENTRY, - broadwell_finalize, NULL), - BOOT_STATE_INIT_ENTRY(BS_PAYLOAD_LOAD, BS_ON_EXIT, - broadwell_finalize, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_OS_RESUME, BS_ON_ENTRY, broadwell_finalize, NULL); +BOOT_STATE_INIT_ENTRY(BS_PAYLOAD_LOAD, BS_ON_EXIT, broadwell_finalize, NULL); diff --git a/src/soc/intel/broadwell/spi.c b/src/soc/intel/broadwell/spi.c index 4710271..0069d10 100644 --- a/src/soc/intel/broadwell/spi.c +++ b/src/soc/intel/broadwell/spi.c @@ -315,9 +315,7 @@ static void spi_init_cb(void *unused) spi_init(); }
int spi_claim_bus(struct spi_slave *slave) { diff --git a/src/soc/intel/common/mrc_cache.c b/src/soc/intel/common/mrc_cache.c index 8f0d18f..5860201 100644 --- a/src/soc/intel/common/mrc_cache.c +++ b/src/soc/intel/common/mrc_cache.c @@ -303,9 +303,6 @@ static void update_mrc_cache(void *unused) } }
#endif /* defined(__PRE_RAM__) */ diff --git a/src/southbridge/amd/agesa/hudson/pci.c b/src/southbridge/amd/agesa/hudson/pci.c index 49e2ba6..5858cd2 100644 --- a/src/southbridge/amd/agesa/hudson/pci.c +++ b/src/southbridge/amd/agesa/hudson/pci.c @@ -45,10 +45,7 @@ static void set_pci_irqs(void *unused) * Hook this function into the PCI state machine * on entry into BS_DEV_ENABLE. */ -BOOT_STATE_INIT_ENTRIES(pci_irq_update) = { - BOOT_STATE_INIT_ENTRY(BS_DEV_ENABLE, BS_ON_ENTRY, - set_pci_irqs, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_DEV_ENABLE, BS_ON_ENTRY, set_pci_irqs, NULL);
static struct pci_operations lops_pci = { .set_subsystem = 0, diff --git a/src/southbridge/amd/cimx/sb800/late.c b/src/southbridge/amd/cimx/sb800/late.c index 2125027..f4a7aa3 100644 --- a/src/southbridge/amd/cimx/sb800/late.c +++ b/src/southbridge/amd/cimx/sb800/late.c @@ -326,10 +326,7 @@ static void set_pci_irqs(void *unused) * Hook this function into the PCI state machine * on entry into BS_DEV_ENABLE. */ -BOOT_STATE_INIT_ENTRIES(pci_irq_update) = { - BOOT_STATE_INIT_ENTRY(BS_DEV_ENABLE, BS_ON_ENTRY, - set_pci_irqs, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_DEV_ENABLE, BS_ON_ENTRY, set_pci_irqs, NULL);
/** * @brief SB Cimx entry point sbBeforePciInit wrapper diff --git a/src/southbridge/amd/pi/hudson/pci.c b/src/southbridge/amd/pi/hudson/pci.c index e8836e4..70e2c18 100644 --- a/src/southbridge/amd/pi/hudson/pci.c +++ b/src/southbridge/amd/pi/hudson/pci.c @@ -48,10 +48,7 @@ static void set_pci_irqs(void *unused) * Hook this function into the PCI state machine * on entry into BS_DEV_ENABLE. */ -BOOT_STATE_INIT_ENTRIES(pci_irq_update) = { - BOOT_STATE_INIT_ENTRY(BS_DEV_ENABLE, BS_ON_ENTRY, - set_pci_irqs, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_DEV_ENABLE, BS_ON_ENTRY, set_pci_irqs, NULL);
static struct pci_operations lops_pci = { .set_subsystem = 0, diff --git a/src/southbridge/intel/common/spi.c b/src/southbridge/intel/common/spi.c index 1780fc0..416a30f 100644 --- a/src/southbridge/intel/common/spi.c +++ b/src/southbridge/intel/common/spi.c @@ -366,9 +366,7 @@ static void spi_init_cb(void *unused) spi_init(); }
int spi_claim_bus(struct spi_slave *slave) diff --git a/src/southbridge/intel/lynxpoint/smi.c b/src/southbridge/intel/lynxpoint/smi.c index 94abf5f..18a55f6 100644 --- a/src/southbridge/intel/lynxpoint/smi.c +++ b/src/southbridge/intel/lynxpoint/smi.c @@ -135,9 +135,6 @@ static void finalize_boot(void *unused) outb(0xcb, 0xb2); }
-BOOT_STATE_INIT_ENTRIES(finalize) = { - BOOT_STATE_INIT_ENTRY(BS_PAYLOAD_BOOT, BS_ON_ENTRY, - finalize_boot, NULL), -}; +BOOT_STATE_INIT_ENTRY(BS_PAYLOAD_BOOT, BS_ON_ENTRY, finalize_boot, NULL);
#endif
